Results 1 to 10 of 18
Thread: 2011 Touareg EPG module 53 Basic settings help required
    Verified VCDS User Loz's Avatar
    Jul 2014
    Berkeley, Gloucestershire, UK
    2011 Touareg EPB module 53 Basic settings help required
    Hello all
    I have just replaced Rear Pads and Rotors on the Touareg, following the VW manual precisely I disconnected the parking brake actuator (Latest model has shoes in rotor drum) this caused the module to throw up a parking brake fault.
    I have used the VCDS to correctly set the airgap and reset/recode the module but now it requires the Basic settings to be done to recalibrate.
    The problem is the current version of VCDS does not suggest any 3 digit codes?
    I can select Air Gap calibration from the pulldown, but a "1 to 3 digit code is required" does anyone know what these are?
    I tried some of the previous version codes 010 but the module just says "Not Running"
    Here is the current module coding.
    Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
       Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
       Component: EPB           H51 1000
       Revision: 00000000    Serial number: A111110063A
       Coding: 01040000
       Shop #: WSC 31414 790 00001
       ROD: EV_ParkbA7.rod
       VCID: 3462885A9F1F19BE4FF-8061
       Slave 1:
       Slave 3:
    0025 - No Calibration
              B2010 F0 [008] - Deviation From Expected Range
                        Fault Frequency: 164
                        Reset counter: 1
                        Mileage: 540928 km
                        Date: 2118.03.14
                        Time: 27:13:01
    0024 - No Basic Setting
              B2010 00 [009] - -
                        Reset counter: 1
                        Mileage: 540928 km
                        Date: 2118.03.14
                        Time: 25:32:61
    I was able to bring up the measuring blocks and read the airgap and have this set within the tolerances but despite calls to Ross-Tech support (this is not a criticism, just reporting the fact that I did contact support) and an extensive search all I can find are basic settings for the older module that has the actuator built into the floating caliper.
    Any help to prevent me having a trip to the main dealer would be appreciated.
    Regards Loz
    (moderator at mytreg dot com)
    full scan for reference
    Saturday,12,July,2014,14:16:07:09334
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WVGZZZ7PZBD041758   License Plate: W44MUD
    Mileage: 44579   Repair Order:
    Chassis Type: 7P (7P6)
    Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 22 32 34 36 3C 42
              46 52 53 55 56 5F 62 65 6C 6D 72 85 8B 8E 8F 90
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CASA)       Labels: 059-907-401-CAS2.clb
       Part No SW: 7P0 907 401     HW: 7P0 907 401
       Component: 3.0TDI EDC17  H17 0007
       Revision: 51H17---
       Coding: 296A401A236E01020000
       ASAM Dataset: EV_ECM30TDI0117P0907401 002009
       ROD: EV_ECM30TDI0117P0907311.rod
       VCID: ECD2D03A07AF017ED7F-80B9
    Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
       Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
       Component: AL1000 AISIN  001 1885
       Coding: 001568
       Shop #: WSC 13678 000 1048576
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: EV_TCMAL991031.rod
       VCID: 316C814E600D2C96249-8064
    Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
       Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
       Component: MK25A         H36 0418
       Revision: --------    Serial number: 408410010EC010
       Coding: 4B6B13C30B282F54D2FBC898D0DAF4507700
       ASAM Dataset: EV_MK25AXT 007001
       ROD: EV_ESPMK25A00800.rod
       VCID: 4584C59EC4859036E81-8010
       Part No SW: 4H0 907 064 AH    HW: 4H0 907 064 AH
       Component: BCM2 2.0      H24 0217
       Coding: 05B60000000000000000
       VCID: 6FE84736BEB97A6672D-803A
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Revision: AA000000    Serial number: 00001002369378
       Coding: 0038330000004201000001010101202020202121202020
       VCID: 3462885A971F19BE4FF-8061
    Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
       Part No SW: 7P6 907 040 AJ    HW: 7P6 907 040 AJ
       Component: Klima 2 Zonen H18 0613
       Coding: 36F6000E10
       VCID: 7CF2607AF7CF11FEC7F-8029
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
       Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0092
       Revision: 15012002    Serial number: 00000000992707
       Coding: 26001091D1345F010021000380005D0C431D470807010241800000020000
       VCID: 316C814E680D2C96249-8064
       Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
       Component: WWS    110312  31  0020
       Coding: 004DBD
       Component: RLFS  H09 0011
       Coding: 035223
       Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
       Component: E1 - LDS  H04 0031
       Subsystem 4 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Coding: 010300
    Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
       Part No SW: 7P6 919 475     HW: 7P6 919 475
       Component: PARKHILFE 8K  H03 0016
       Revision: --------    Serial number: 55901105402492
       Coding: 508D01
       ASAM Dataset: EV_VW526ParkiAssis2 001008
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 55A415DE342520B6981-8000
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 7P6 907 561 A    HW: 7P6 907 561
       Component: ACC3          H13 0230
       Coding: 3E04010101
       ASAM Dataset: EV_AdaptCruisContrVW526 001004
       ROD: EV_AdaptCruisContrVW526.rod
       VCID: 3A7EA662BD7BEFCE953-806F
    106240 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 204
                        Mileage: 71744 km
                        Date: 2014.07.12
                        Time: 12:42:51
       Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
       Component: VW10Airbag00M H05 0023
       Revision: --------    Serial number: 003JX00215EY
       Coding: 00000000000000000000000000000000304D
       ROD: EV_AirbaVW10BPAVW526_VW52.rod
       VCID: 408AD48ADBA7B51EDB7-8015
       Serial number: 3575LRB40570EACC90K0
       Serial number: 3585LRB405V0BI7S9HE9
       Serial number: 3515RRB404V0HBR0COKE
       Serial number: 3525RRB404T0HBR0E18N
       Serial number: 3555NRB405N09GGS5OGA
       Crash sensor for front airbag; passenger side:
       Serial number: 3565NRB405N09GGSCH72
       Part No SW: 4H0 953 568 B    HW: 7P6 953 507 G
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KCG0000F
       Coding: 000C9D
       VCID: 326E8E426D0B178E5D3-8067
    Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
       Part No SW: 7P6 920 981 C    HW: 7P6 920 981 C
       Component: Kombi         H13 0239
       Revision: 11240062    Serial number: 658020311593025
       Coding: 331F3300FF082600010004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 3D74AD7EAC55D8F6B01-8068
    Address 18: Aux. Heat (J364)       Labels: None
       Part No SW: 7P0 963 272 B    HW: 7P0 963 272 B
       Component: Standheizung  H23 0240
       Revision: 56005006    Serial number: 20110309174552
       Coding: 594200
       VCID: 3666B25281630BAE71B-8063
       Part No SW: 7P6 907 530 D    HW: 7P6 907 530
       Component: GW-CAN-L-FR-M H08 5202
       Revision: --------    Serial number: 00000000112570
       Coding: 000D077500
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 397CB96EB87DE4D69C9-806C
       Serial number: 00000000005650815975
       Voltage stabilizer:
       Part No SW: 0BV 927 755 A    HW: 0BV 927 755 A
       Component: TRANSFERCASE        0217
       VCID: 4C92F0BA2FEF617E37F-8019
    Address 32: Differential Locks        Labels: None
       Part No SW: 0BN 927 771     HW: 0BN 927 771
       Component: Quersperre          5220
       Revision: H04         Serial number: 108512251004
       VCID: 010C118E582D7C16949-8054
    Address 34: Level Control (J197)       Labels: 7P0-907-553.clb
       Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
       Component: PASM          H01 1110
       Revision: 00000000    Serial number: 00000110710564
       Coding: 14210001
       ASAM Dataset: EV_PASMConti 001004
       ROD: EV_PASMConti.rod
       VCID: 3F88D776A659CAE6A2D-806A
       Revision: AA000000    Serial number: 00001002369322
       Coding: 00383B0000004201000001010101202020202121202020
       Part No SW: 7P6 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH03 0110
       Revision: 00H03000    Serial number: 6PZ 010 316-01
       Coding: 0001151
       VCID: FEF6EA72A9D383EE69B-80AB
       Subsystem 1 - Part No: 7P6 907 568
       Component: J770  SWA Slave H01 0110
       Subsystem 2 - Serial number: 6PZ 010 316-21
       Subsystem 3 - Serial number: 5F05.03.1100H010003C520363ˇ
       Subsystem 4 - Serial number: 520363ˇ
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000107831908
       Coding: 011D1620DE01459205080003
       VCID: 3B70A366BA41D6C68E5-806E
    02123 - Door Warning Light / Entry Light
                        Fault Status: 00101100
                        Reset counter: 204
                        Mileage: 71744 km
                        Date: 2014.07.12
                        Time: 10:30:52
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0143761494
       Coding: 011B1E2228B910958B2004240F0000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 171
       Component: DWA-Sensor  002 0204
       Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
       Component: J245 PS30.050  H07 0006
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
       Component: J394 PS30.050  H07 0006
       Coding: 191100
    01234 - Heated Windshield Control Module (J505)
                        Reset counter: 164
                        Mileage: 71744 km
                        Date: 2014.07.12
                        Time: 10:02:21
                        Reset counter: 204
                        Mileage: 71744 km
                        Date: 2014.07.12
                        Time: 11:08:03
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0162
       Revision: --------    Serial number: 0000114182932
       Coding: 011D1620DE01459205080000
                        Reset counter: 204
                        Mileage: 71745 km
                        Date: 2014.07.12
                        Time: 13:43:09
       Coding: 01040000
       ROD: EV_ParkbA7.rod
       Slave 1:
       Slave 3:
                        Reset counter: 1
                        Mileage: 540928 km
                        Date: 2118.03.14
                        Time: 27:13:01
              B2010 00 [009] - -
                        Reset counter: 1
                        Mileage: 540928 km
                        Date: 2118.03.14
                        Time: 25:32:61
    Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 01AE00000F000A00
       ROD: EV_HeadlRegulVWAFSPt.rod
       VCID: FCF2E07A77CF91FE47F-80A9
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo links  H01 0001
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo rechts  H01 0001
       Coding: 130000
       Part No SW: 4G0 035 061 G    HW: 4G0 035 061
       Component: Radio U DAB   H52 0097
       Revision: AB001007    Serial number: 109C.0B7513786
       Coding: 010105020100000001
       VCID: 214C710E38ED9C16B49-8074
       Part No SW: 7P6 035 670 B    HW: 7P6 035 670 B
       Component: H-BNT-EU      H44 0203
       Revision: --------    Serial number: 478CA0B7538778
       Coding: 010101060340FBEF7B105F0E00000003F0040100
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: DU8 SV Touch  H24 0045
       Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: CD-Database  1886
                        Reset counter: 164
                        Mileage: 71744 km
                        Date: 2014.07.12
                        Time: 10:02:22
                        Bin. Bits: 00000000 01000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0162
       Revision: --------    Serial number: 0000114447439
       Coding: 011C16200001259005080000
       VCID: 3A7EA662B57BEFCE953-806F
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000025962
       ROD: EV_RDKBERU25_VW52.rod
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D_
       Component: TopView       H05 0097
       Revision: 11001001    Serial number: 82331010124705
       Coding: 0100000001000000000102000000
       ASAM Dataset: EV_CamerSysteTopViewVW 001014
       ROD: EV_CamerSysteTopViewVW.rod
    Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
       Part No SW: 7P6 959 107     HW: 7P6 959 107
       Component: HDSG-Modul    H10 0611
       Revision: 22010001    Serial number: 077100325
       Coding: 0533314002
       ASAM Dataset: EV_HeckkTouar 202135
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H09 TSG HR        H09 01620162
    No Faults Found
    Address 85: On Board Cam. (J852)       Labels: None
       Part No SW: 7P6 907 217 A    HW: 7P6 907 217
       Component: DPC-SG        H23 0033
       Coding: E9070000
       ASAM Dataset: EV_OnBoardCamerDTR 001001
       ROD: EV_OnBoardCamerDTR.rod
       VCID: 387ABC6A8377FDDE637-806D
       Subsystem 1 - Part No: 7P6 .90 7.6 58
       Component: NICKRATENSENS  H02 0001
       Serial number: 000000003022365_2022
    Address 8B: Adaptive Cruise 2 (J428)       Labels: None
       Part No SW: 7P6 907 541 A    HW: 7P6 907 541
       Coding: 3E04010101
       ASAM Dataset: EV_AdaptCruisContr2VW526 001004
       ROD: EV_AdaptCruisContr2VW526.rod
              U1113 00 [008] - -
                        Reset counter: 204
                        Mileage: 71744 km
                        Date: 2014.07.12
                        Time: 12:42:51
    Address 8E: Image Processing (J851)       Labels: None
       Part No SW: 7P6 907 107 A    HW: 7P6 907 107
       Component: BV-SG         H28 0031
       Serial number: 000040192802117
       Coding: 01A2BE000000
       ASAM Dataset: EV_BTR 002001
       ROD: EV_BTR.rod
       VCID: 3666B25289630BAE71B-8063
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00660600031F037F00033810594097000000
       Shop #: WSC 00001 790 00001
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: EFE8C73636B9FA66F2D-80BA
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       Coding: 006606000317037F00033810594097000000
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: F0EAC44A2B87E59EEB7-80A5
    Last edited by Loz; 07-18-2014 at 06:47 AM. Reason: Added some further clarification
    United States
    We replied to Loz via email but I would like to explain why we do not have a procedure to offer after mechanical repairs to this VW Touareg (7P) Parking Brake EPB system at this time.
    7P0 #53 control modules lose their coding after mechanical repairs to the brake pads and/or rotors (not the actual Electro-Mechanical Parking Brake (EPB) components) and they are extremely sensitive to Air Gap Calibration tolerances. Furthermore, the basic settings parameters are extremely complex in this system so R-T needs to get one of these vehicles onsite for live testing.
    On that note, if an existing Ross-Tech customer with a 7P/BP T'reg happens live in the Lansdale area ... please contact us.
  3. Likes Uwe, jyoung8607, Loz liked this post
    Jul 2014
    Thanks Dana
    Yes, Paul Shu. was very helpful on the phone and in his reply.
    As you say the unit remembers the air gap at each calibration and that changes if you adjust up the brake shoes as you do.
    It is going in to VW in the morning but I am not hopeful of being allowed to observe what they do.
    I'll report back after the visit.
    Regards Loz
    (moderator @ mytreg dot com)
    2011 T3 Escape [4XMotion, Night Blue, CSB Leather, RNS850, Everest Alloys, Keyless Go, air suspension, Bi-Xenons, Adaptive cruise(DAP), Panoramic roof, Electric tailgate, Area View, aux heater, mem seats, low box and locking diffs, Tyre pressure monitor]
  5. Likes Dana liked this post
  6. #4
    Jul 2014
    All sorted now, I went into VW in Bristol and they adjusted the air gap and carried out the Basic Settings, which involved 2 techs going out in the car with a portable VAS unit.
    I wasn't able to glean any info apart from the procedure includes driving the vehicle...
    Regards Loz
  7. Likes Dana, Uwe liked this post
  8. #5
    Aug 2015
    Hi there Just wondering if there has been any updates on this problem. We have one with same problem, same DTC 's after vehicle came in with non operating EPB. Again this is the version with brake shoes inside the disc & we had to recode the module which was straight forward enough. Is this still a trip to the main dealer unfortunately. cheers.
  9. #6
  10. Likes Eric, Santos, Uwe, Dana, RyMar, Ashraf6119 liked this post
  11. #7
    Apr 2015
    South Africa
    I had similar problems after replacing rear brake pads & discs. This Touareq does not have the shoes inside the drum. Had to recode at VW. Adjusted the air gap according to this video. It worked 100%.
    Now I am left with the basic setting!
  12. #8
    Mar 2017
    Quote Originally Posted by Iain Murray View Post
    Hi There,
    How did you recode EPB?
    Any help is very much appreciated,
  13. #9
    Jul 2014
    Quote Originally Posted by Milan View Post
    Hi There,
    I didn't recode as such, just needed to perform a basic settings procedure.
    After adjusting the air gap, you need to follow a procedure to "grind in" the shoes. There is a YouTube vid showing how to do this that involves driving and pulling on the EPG at the same time, I'll try and find a link to it. (Someone might be able to post a link before me but I'll have a look when I get to my desk)
    Regards Loz
  14. #10
    Jul 2014
    I have got an information that someone went into basic settings and gap adjustment and as soon as they clicked on it (gap adjustment )there have been those three faults since and EPB is inoperative,
    Apparently the shoes haven't been changed
    Many thanks
    Yes, correct, just follow the video back in post #6 of this thread after doing any adjustments even if you didn't change the shoes.
    Regards Loz
  15. Likes Uwe liked this post
