VW PASSAT 2.0 TDI 3C 2009 model help how to code EPB module
Bagoshite
C?ID=45889
Hi Guys, I have just joined and its my first post. Unfortunately it is a request for help rather than offering help.
I am having a real issue trying to code a parking brake module on a 2009 passat 3C.
I correctly diagnosed a faulty EPB module due to code "02845 function display in instrument cluster short to ground".
I have replaced the module with a new unit.
I have followed the ross-tech wikki instructions step by step word by word which instructs me to code the ABS module carry out basic settings within the ABS module, then code the EPB module then carry out basic setting within the EPB module. The instructions are a little confusing on the wikki as to whether or not to firstly carry out the EPB coding or to firstly carry out the EPB basic settings, either way i have tried it both ways but all i get when entering the coding is
coding rejected Error 31 request out of range.
Between each coding attemp i have also tried locking up the car for 20 minutes to allow CAN network to sleep.
I have also tried a battery disconection for 1 hour and shorting the positive and negative leads together for half hour.
I have also locked the car up over night to allow the CAN network to go to sleep and then followed the wikki instruction again but it still fails to code the EPB.
Before i replaced the module i did save a LOG file, i have also saved a LOG file with the new module fitted which i will post both here below my text.
Ross-Tech wikki does say that when replacing the EPB module it will erase the coding in the ABS module so always save a log file before replacing the EPB module.
However im my instance this did NOT happen the coding in the ABS module was never affected.
My old module part number is 3C8907801A
My new module part number is 3AA907801H
I have checked with my local VW parts supplier TPS who supplied the parts and they assure me it is the correct new part for my VIN.
This vehicle has a Auto hold button at the left side of the gear selector.
The coding i am entering is 0000057.
Hope i have given enough information, any help with this issue will be much appreciated.
Many thanks
Dave
Log file with old EPB module
Wednesday,09,July,2014,13:37:07:00293
VCDS Version: 14.7.0.0
Data version: 20140601
VIN: WVWZZZ3CZ9P019584   License Plate: YE58 FXJ
Mileage:    Repair Order: 3C PASSAT 2008
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9P019584   Mileage: 124150km-77143miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  2650
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 17026 210 91072
   VCID: 70E47F1A63A236BA9F-8025
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785880375
   Coding: 0001298
   Shop #: WSC 00028 028 00001
   VCID: 2B5EA8768A041562EA-807E
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 77F6440606CC61825E-8022
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000005892758
   Coding: E1808F0700041A00470A00000F00000000085D435C000120000000000000
   VCID: 336EB01652344DA2A2-8066
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 020608 022  0601
   Coding: 00046997
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     040708 046  0204
   Coding: 00208933
   Shop #: WSC 00028
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475     HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0007
   Revision: --------    Serial number: 97530818200547
   Coding: 100002
   VCID: 71E27A1EA8A83FB290-8024
   Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPCV4L8/
   Coding: 0012342
   VCID: 3B7E98367A6485E27A-806E
   Subsystem 1 - Serial number: 6333FTS649091708
   Subsystem 2 - Serial number: 6343FTS642291558
   Subsystem 3 - Serial number: 6353ETS6OCF0UVNP
   Subsystem 4 - Serial number: 6363ETS629E2UVNH
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AT
   Coding: 0000111
   VCID: 6FE67C667E9C294286-803A
   Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   VCID: 2756544696EC31020E-8072
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P086200E67
   Coding: F9A07F060002021003
   VCID: 2648594291E6280A35-8073
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 3972823E7058B7F268-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1518
   Revision: 72009005    Serial number: 00000790788625
   Coding: 0000693
                    Fault Status: 01100101
                    Reset counter: 254
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 195    2301
   Revision: 00H15000
   VCID: 2A50AD7285FE0C6A11-807F
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E763004941570085FCE107C01
   Component: J387  TUER-SG BT    1518
   Revision: 72009005    Serial number: 00000342588622
   Coding: 0000692
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000065085
   Coding: 0000057
   VCID: 2854577A9BF23E7A07-807D
02845 - Function Display in Instrument Cluster (!)
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Reset counter: 254
                    Mileage: 124145 km
                    Date: 2014.07.08
                    Time: 17:15:53
                    Voltage: 13.70 V
                    Count: 78
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5343418
   Coding: 0500040004
   VCID: 65CA1E4E6C60E312FC-8030
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000490770
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000495101
   Coding: 0000144
   VCID: 71E27A1E68A83FB290-8024
LOG file with new module fitted
Friday,11,July,2014,16:07:27:00293
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Mileage: 124160km-77149mi   Repair Order: LOG No 2 with new EPB module
VIN: WVWZZZ3CZ9P019584   Mileage: 124160km/77149miles
   Coding: 0000072
   VCID: 70E47F1A63A2369E6B7-8025
   Coding: 0001298
   VCID: 2B5EA8768A0415461E5-807E
   VCID: 77F6440606CC61A6AAD-8022
   VCID: 336EB01652344D86565-8066
   Coding: 00046997
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
   Coding: 100002
   VCID: F1E2FA1E28A8BF96E49-80A4
   Coding: 0012342
   VCID: 3B7E98367A6485C68E5-806E
   Coding: 0000111
   VCID: 6FE67C667E9C296672D-803A
   Coding: 0007405
   VCID: 2756544696EC3126FAD-8072
   VCID: 2648594291E6282EC1B-8073
   VCID: 3972823E7058B7D69C9-806C
   Coding: 0000693
   Revision: 00H15000
   VCID: 2A50AD7285FE0C4EE53-807F
   Coding: 0000692
   Revision:   H19       Serial number: 00000001653983
   Coding: 0010000
   VCID: 36688902414658AE71B-8063
                    Fault Status: 01110000
                    Reset counter: 1
                    Voltage: 13.90 V
                    Count: 98
                    Hex Value: 0x0140
                    Hex Value: 0x0082
                    Hex Value: 0x4040
   Coding: 0500040004
   VCID: 65CA1E4E6C60E336081-8030
   Coding: 0000144
   Coding: 0000144
   VCID: 71E27A1E68A83F96649-8024
Are you giving it non-zero values for WSC, Importer, and Equipment Number?
Bagoshite
C?ID=45889
Hi Uwe,
i am leaving the other fields as they are
workshop code 00000
importer 000
equipment 00000
thanks
dave
Please try some non-zero values in those fields.
Bagoshite
C?ID=45889
Fixed
Apologies guys, This really was a matter of not seeing the wood for the trees.
If you take a look at the original LOG file that i saved from the old EPB the coding in the original EPB was 0000057
so the mistake i made was to write this coding down on the back of my hand, and with the laptop in the car i was always trying to write this same code
into the new EPB.
Also the second mistake i made when i looked on Ross-Tech wikki for the instructions, i selected EPB module generation 3 2008-2010 (which is my old module)
Not realising that my new replacement module is a generation 4 2011> the instruction here tells you that a pop up balloon will advise you with the coding.
Which it did but like a dummy i completely ignored it because i had wrote the old coding on my hand ;-(
The coding for the new module is actually 0021057
Many thanks for the help, great forum
Regards
Dave
Dana
Western PA, USA
Thanks for the update Dave. VW superseded all Gen 3 (2008-2010) replacement EPB modules to the latest 3AA series part numbers which happen to be Gen4 and they use an entirely different coding scheme as you pointed out.
Copy/pasting the old coding would work with a used replacement module (which is not the best way to go when the old controllers have plenty of known bugs).
-Dana
