Results 1 to 3 of 3
Thread: Auto Scan posted. Need info pleas
    Mar 2014
    I have aftermarket headlight and HID kit. I removed fog lights as well. Flat bottom R8 (not functions are working including horn) with B7 slip ring & control module. And pretty much all fault lights on dash are on. Please check out my scan info and avise me. Thanks Ross-Tech, techs.
    VCDS Version: Release 12.12.2
    Data version: 20140212
    Tuesday,04,March,2014,12:47:24:34624
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
              63 65 67 73 75 76 77
    VIN: WUARL48H46K900514   Mileage: 132170km/82126miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8H2 910 560     HW: 008 H29 075 60
       Component: 4.2L V8/5V      G   0010
       Revision: --H01---    Serial number: AUX6Z0E0090568
       Coding: 0007714
       Shop #: WSC 00672 785 00200
       VCID: E7DD31ABD5EA1426BAD-5122
    16522 - Oxygen (Lambda) Sensor B1 S2
                P0138 - 001 - Signal too High - Intermittent
                        Fault Status: 00100001
                        Mileage: 132165 km
                        RPM: 735 /min
                        Load: 23.9 %
                        Temperature: 99.0°C
                        Temperature: 66.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 13.716 V
    16523 - Oxygen (Lambda) Sensor B1 S2
                P0139 - 004 - Response too Slow
                        Mileage: 132169 km
                        RPM: 1436 /min
                        Load: 13.3 %
                        Speed: 38.0 km/h
                        Temperature: 89.0°C
                        Temperature: 34.0°C
                        Voltage: 13.716 V
    16420 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                P0036 - 004 - Malfunction / Open Circuit - Intermittent
                        Fault Frequency: 29
                        Mileage: 132169 km
                        RPM: 1045 /min
                        Load: 29.0 %
                        Temperature: 7.0°C
                        Temperature: 9.0°C
                        Voltage: 13.716 V
    Readiness: 0100 0101
       Part No: 8E0 614 517 Q
       Component: ABS/ESP allrad      4533
       Coding: 04597
       Shop #: WSC 57389
       VCID: 36632CEF12C03DAE71B-5106
                35-00 - -
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2832
       Coding: 00100
       Shop #: WSC 00672
       VCID: 6DD1C3832716BE76401-5122
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 00672
       VCID: 35612BE30FC636B6781-4AE8
                57-00 - Electric Circuit Failure
       Part No SW: 8E0 035 593 D    HW:
       Component: SDAR SIRIUS
       Revision:             Serial number: AUZ4Z7E2015721
       VCID: 2A5B089F8678694EE53-515E
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 D
       Component: Airbag 8.4EC        0015
       Coding: 0010105
       VCID: 3B753DDB79E2E0C68E5-5140
                001 - Upper Limit Exceeded - Intermittent - MIL ON
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0801
       Coding: 00042
       VCID: 41894F334B0E8A16D49-4AE8
       Part No SW: 8H0 920 980 S    HW: 8H0 920 980 S
       Component: KOMBI+WFS 3     H12 0030
       Revision: 0030        Serial number: AUX6Z0E0090568
       Coding: 0017231
       Shop #: WSC 01115 444 68394
       VCID: 3F8D49CB6DFAFCE6A2D-5122
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8E2.lbl
       Coding: 0017231
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255 B
       Component:  VSG  B6 CABRIO     6593
       VCID: 35612BE35FC636B6781-5140
       Part No: 8H0 959 760
       Component: Sitzmemory EE H06   0010
       Coding: 00002
       Shop #: WSC 00065
       VCID: F4E756E7C43CEFBE0FF-4B00
    01447 - Sensor for Driver Seat; Height Adjust (G231)
                36-00 - Open Circuit
    Address 37: Navigation        Labels: None
       Part No SW: 8H0 035 192 D    HW: 8H0 035 192 D
       Component: RNS-E US        H70 0040
       Revision:      01S    Serial number: AUZBZ7E2101024
       Coding: 0419637
       VCID: 285FF29798745B5EF37-517C
                        Reset counter: 188
                        Date: 2004.09.09
                        Time: 16:29:46
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8H0 959 433 E
       Component: Komfortgerát T7B    3320
       Coding: 11788
       Shop #: WSC 00672
       VCID: 36632CEF12C03DAE71B-4AE8
       Subsystem 1 - Part No: 8H1959801B
       Component: Tőrsteuer.FS BRM 3020
       Subsystem 2 - Part No: 8H1959802B
       Component: Tőrsteuer.BF BRM 3020
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
    00955 - Key 1
                35-10 - - - Intermittent
    Address 55: Xenon Range        Labels: 4Z7-907-357.lbl
       Part No: 4Z7 907 357
       Coding: 00070
       Shop #: WSC 00672
       VCID: 04078627149C5F3EBFF-4B1A
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
                30-00 - Open or Short to Plus
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
    Address 56: Radio        Labels: None
       Coding: 0419637
       VCID: 285FF29798745B5EF37-5140
                        Reset counter: 188
                        Date: 2004.09.09
                        Time: 16:29:46
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H13   0010
       Coding: 00006
       Shop #: WSC 00065
       VCID: 35612BE30FC636B6781-4B00
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273     HW: 8E0 907 273
       Component: Reifendruck 3   H03 0110
       Coding: 0062825
       VCID: E9D93793C3FE2256AC9-5140
                        Fault Status: 11100100
                        Reset counter: 40
                        (no units): 19.0
                        Voltage: 13.70 V
                        (no units): 61.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    02214 - Tire Pressure Warning
                        Fault Frequency: 19
                        Reset counter: 40
                        (no units): 0.0
                        Temperature: 40.0°C
                        Error Code: 1
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H13   0010
       Coding: 00005
       Shop #: WSC 00065
       VCID: 35612BE30FC636B6781-4B1A
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283 A
       Component: Parkingsyst. A4 USA D09
       Coding: 00125
       Shop #: WSC 00672
       VCID: 4385453B51129806C65-5122
                37-00 - Faulty
    01548 - Sensor for Parking Aid; Rear Right (G206)
                37-00 - Faulty
       Part No SW: 8P0 862 335 B    HW: 8P0 862 335 B
       Component: FSE_255x BT     H18 0160
       Revision: 00000001    Serial number: 00000000302542
       Coding: 0000807
                        Fault Frequency: 12
                        Reset counter: 93
                        Time Indication: 15
    Last edited by Uwe; 03-04-2014 at 03:19 PM. Reason: Wrapped CODE tags around Auto-Scan
    There's no obvious way to code out fog lights in that module. I suspect Audi used a different module depending on whether the car did or didn't have fog lights. My guess is the only way to pacify that module is to give it dummy loads, or to replace it with a module from a car that didn't have fog lights. If anyone knows different, please chime in.
    United States
    My only idea would involve checking to see if the Adaptation values (for the 8EC not the installed 8E2 controller) apply:
    http://wiki.ross-tech.com/wiki/index..._%288EC/8ED%29
    "DTM Edition" should be a fog-less bumper cover but that may limited to B7 Audi A4 controllers?
