Results 1 to 4 of 4
Thread: 2013 S5 abs/esp faults
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    I'm just getting into this car, but I haven't seen these faults before so I'm asking for a little help so I don't waste my day.
    Customer is complaining about the park brake light, ABS light, and lane assist light being on. He did do the auto hill hold modification two years ago.
    I found the location of the G419 under the drivers floor, so I'm going to check for moisture and clogged sunroof drains.
    Any thoughts or point me in some direction? I don't see many of these since they are usually in warranty.
    Friday,13,January,2017,09:46:47:05734
    VCDS Version: 16.8.4.2 (x64)  HEX-NET CB: 0.4321.4
    VIN: WAU3GAFR0DA021884   License Plate:
    Mileage: 99250km-61671mi   Repair Order:
    Chassis Type: FR (8R0)
    Scan: 01 03 05 06 08 09 13 14 15 16 17 19 1B 22 36 3C 42 44 46 47
              52 53 56 5F 6C A9
    VIN: WAU3GAFR0DA021884   Mileage: 99250km-61671miles
    Address 01: Engine (J623-CGXC)       Labels: 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0002
       Revision: --H07---
       Coding: 1A190034054600060000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
       ROD: EV_ECM30TFS0218K5907551E.rod
       VCID: B83C687E03456D82B1-80EC
    6628 - Function Restriction due to Faults in Other Modules
              U1113 00 [045] - -
                        Fault Frequency: 34
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:29
                        Engine speed: 2681.00 /min
                        Normed load value: 47.1 %
                        Vehicle speed: 113 km/h
                        Coolant temperature: 92 C
                        Intake air temperature: -18 C
                        Ambient air pressure: 800 mbar
                        Voltage terminal 30: 14.319 V
                        Engine speed: actual: 0 /min
                        MAF_ENVD: 0.00000 mg/stroke
                        Coolant temperature (unfiltered): 7.50 C
                        Engine: operating status: ES
                        Engine load: 0.000000 %
                        Vehicle speed: actual: 0 km/h
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Component: ESP8 quattro  H09 0100
       Coding: 282D1A
       Shop #: WSC 28826 001 104857
       VCID: 8444CC8E070DF9626D-80D0
                        Fault Frequency: 8
                        Reset counter: 100
                        Mileage: 98359 km
                        Date: 2017.01.07
                        Time: 07:30:50
                        Hex Value: 0x5E00
                        Hex Value: 0x4006
                        Hex Value: 0x1206
                        Hex Value: 0xB5B4
                        Hex Value: 0x0000
    03033 - ESP Sensor Unit 2 (G536)
                        Fault Frequency: 8
                        Reset counter: 100
                        Mileage: 98359 km
                        Date: 2017.01.07
                        Time: 07:30:50
                        Hex Value: 0x5E00
                        Hex Value: 0x4006
                        Hex Value: 0x122A
                        Hex Value: 0xBCB4
                        Hex Value: 0x0000
    01324 - Control Module for All Wheel Drive (J492)
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 9
                        Reset counter: 100
                        Mileage: 98359 km
                        Date: 2017.01.07
                        Time: 07:30:50
                        Hex Value: 0x5E00
                        Hex Value: 0x4006
                        Hex Value: 0x120E
                        Hex Value: 0x50B4
                        Hex Value: 0x0000
                        Fault Frequency: 6
                        Reset counter: 100
                        Mileage: 98359 km
                        Date: 2017.01.07
                        Time: 07:30:50
                        Hex Value: 0x5E00
                        Hex Value: 0x4206
                        Hex Value: 0x121A
                        Hex Value: 0x02B4
                        Hex Value: 0x0000
    02214 - Tire Pressure Warning
                000 -  -  - Intermittent
                        Reset counter: 135
                        Mileage: 98612 km
                        Date: 2017.01.09
                        Time: 13:16:50
                        Hex Value: 0x6A00
                        Hex Value: 0x4006
                        Hex Value: 0x1221
                        Hex Value: 0x18B8
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H11 0621
       Coding: 0F804000000000000000
       Shop #: WSC 06325 000 00000
       Subsystem 1 - Part No SW: 8K0 959 754 AB    HW: 8K0 959 754 AB
       Serial number: 0512000049350016
       Serial number: 2312000157070009
    Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000035621134
       Coding: 00037025002C00000000
       VCID: C5C2118A4CB7006A3A-8090
       Revision: C1000000    Serial number: 01050820120420
       Coding: 6602228000
       Shop #: WSC 28826 001 1048576
       VCID: B93A6D7A304F748A4E-80EC
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000457896401
       Coding: 26000091863CAFF23C0048C300003D0D0F9C9388A2090221000008000000070200020030000000
       VCID: FAB8B27675C9BF9207-80AE
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 310712  H15 0080
       Serial number: SWF12070315476
       Coding: 00FD11
       Serial number: 20473751
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001907121791
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R2EL902
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: A908C046000000000001
       Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
       Component: ACC3          H09 0100
       Coding: 00333E
       VCID: B12A555AE83FBCCAF6-80E4
                        Fault Frequency: 23
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
                        Temperature: 240.0C
                        Voltage: 14.34 V
                        Hex Value: 0x00C5
                        Speed: 111.6 km/h
                        Lateral Accel.: -0.06 m/s^2
                        Fault Frequency: 34
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
                        Temperature: 240.0C
                        Voltage: 14.34 V
                        Hex Value: 0x00BE
                        Speed: 111.6 km/h
    01316 - ABS Control Module
                        Fault Frequency: 30
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
                        Temperature: 240.0C
                        Voltage: 14.34 V
                        Hex Value: 0x00C0
                        Speed: 111.6 km/h
                        Lateral Accel.: -0.04 m/s^2
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8R0 907 364 C    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H09 0054
       Revision: 00000000    Serial number: 24071202800001
       Coding: 070181
       VCID: BA38727635497F9247-80EE
                        Fault Frequency: 23
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:29
                        Bin. Bits: 00000000 00000110
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Serial number: 003KJD90HSR7
       Coding: 303343334830303030304A55304C38543053
       VCID: CAD822B66DA9EF12D7-809E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R120000A4DT
       Serial number: 6334MSME6E305632C
       Serial number: 6344MSME6F624E1DZ
       Serial number: 6352QSME5B172540C
       Serial number: 6362QSME072051722
       Serial number: 63732SME1C203C56/
       Serial number: 63832SME1C203A5A0
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20120806000797
       Coding: 00001E
       VCID: D1EA35DA88FFDCCA96-8084
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 984     HW: 8T0 920 984
       Component: KOMBIINSTR.   H35 0553
       Revision: 00100000    Serial number: RB252CW6D
       Coding: 8BBD0100BF01D705020000
       VCID: FCB4B46E7FFD81A215-80A8
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
       Component: GW-BEM 5CAN-M H11 0051
       Revision: 1Z090025    Serial number: 2541Z12717001C
       Coding: 80C303FF00
       VCID: C6C0168671B10B7233-8092
       Serial number: 6675467901
       Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
       Component: DYNAMIKLENK.  H06 0690
       Coding: 040000
       VCID: B620664601519BF2A3-80E2
       Component: 4 Wheel Drive H13 0100
       Serial number: 001107120001028
       VCID: AF2E5322F60BAA3AE0-80FA
    10 Faults Found:
    0197 - Sensor Units for ESP
              C1024 29 [008] - Signal Implausible
                        Reset counter: 127
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
                        Rotation rate sensor 1: -79.99500 /s
                        Lateral acceleration sensor 1: -2.26755 g
                        Rotation rate sensor 2: -23.67500 /s
                        Lateral acceleration sensor 2: -1.97437 g
                        Front left wheel speed: -3482.7 km/h
                        Front right wheel speed: -3405.9 km/h
                        Left rear wheel speed: -3457.1 km/h
                        Right rear wheel speed: -3329.1 km/h
                        Vehicle speed: 107.96 km/h
                        Steering wheel angle: -4764.7
    0171 - Sensor Units for ESP
                        Reset counter: 127
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
    0062 - No Communications with ESP Multi-Axis Sensor Module
              U0125 00 [137] - -
                        Fault Frequency: 25
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
                        Voltage terminal 15: 14.53 V
                        Voltage terminal 30: 14.69 V
                        VPS Voltage: 14.69 V
                        Pump for all-wheel drive: voltage: 0.00 V
                        motor pump voltage terminal B: 0.00 V
                        Pump for all-wheel drive: current: 0.00 A
                        Torque distribution: 0 Nm
                        Torque distribution: specified value: 0 Nm
                        State KomonentenRegler: Permanent Error
                        Control Module temperature: 2 C
                        Temperature output stage-Data: -4 C
                        Temperature QCU-Data: 2 C
                        Thermal load ECU-Data: 0 bar
                        Thermal load of all-wheel drive pump: 0.0 %
                        Oil pressure and oil temperature sensor temperature: 3 C
    0129 - ESP Sensor Module 2
              U10B0 00 [137] - No Communications
                        Fault Frequency: 25
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
                        Fault Frequency: 35
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:29
                        Voltage terminal 30: 14.53 V
                        VPS Voltage: 14.53 V
                        Temperature QCU-Data: 3 C
    0252 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Fault Frequency: 37
                        Reset counter: 140
                        Mileage: 96336 km
                        Date: 2016.12.18
                        Time: 08:12:47
                        Voltage terminal 15: 11.56 V
                        Voltage terminal 30: 11.72 V
                        VPS Voltage: 11.72 V
                        Pump for all-wheel drive: voltage: 2.97 V
                        motor pump voltage terminal B: 2.97 V
                        State KomonentenRegler: Initalize
                        Control Module temperature: -1 C
                        Temperature output stage-Data: -3 C
                        Temperature QCU-Data: 8 C
                        Thermal load ECU-Data: 19 bar
                        Oil pressure and oil temperature sensor temperature: 8 C
    0066 - Implausible Data Received from ESP Multi-Axis Sensor Module
              U0432 00 [008] - -
                        Fault Frequency: 22
                        Reset counter: 139
                        Mileage: 96353 km
                        Date: 2016.12.18
                        Time: 08:23:13
                        Control Module temperature: 5 C
                        Temperature output stage-Data: -1 C
                        Temperature QCU-Data: 17 C
                        Oil pressure and oil temperature sensor temperature: 16 C
    0067 - Implausible Data Received from ESP Multi-Axis Sensor Module
              U0432 00 [008] - -
                        Fault Frequency: 22
                        Reset counter: 139
                        Mileage: 96353 km
                        Date: 2016.12.18
                        Time: 08:23:13
    0071 - ESP Sensor Module 2
              U10B1 00 [008] - Implausible Signal
                        Fault Frequency: 22
                        Reset counter: 139
                        Mileage: 96353 km
                        Date: 2016.12.18
                        Time: 08:23:13
    0072 - ESP Sensor Module 2
                        Fault Frequency: 22
                        Reset counter: 139
                        Mileage: 96353 km
                        Date: 2016.12.18
                        Time: 08:23:13
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000035625251
       Coding: 001B7B25002C00000000
    Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
       Part No SW: 8T0 907 566 A    HW: 8T0 907 566
       Component: SWA Master    H17 0040
       Serial number: 0181484581
       Coding: 010211
       Shop #: WSC 06324 000 00000
       VCID: BE307E66216153B27B-80EA
       Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
       Component: SWA Slave  H17 0040
       Serial number: 0181474227
       Coding: 010211
    337166 - Databus
                        Fault Frequency: 34
                        Reset counter: 100
                        Mileage: 96333 km
                        Date: 2016.12.18
                        Time: 08:10:28
    733440 - Control Module for Lane-Change Assist
              C1114 F3 [008] - Limited Visibility
                        Mileage: 95535 km
                        Date: 2016.12.09
                        Time: 07:21:21
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Component: TSG FA        H09 0304
       Coding: 011C13224E00120102
       VCID: D6E0C6C6A111BBF243-8082
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Revision: 00001000    Serial number: 0017730591
       Coding: 010000010001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: B4245C4E1F2D89E29D-80E0
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0180853372
       Coding: 0106069A00FA414580B0003200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000550685
       Component: J245EE20SKB13  H03 0220
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Revision: 00005001    Serial number: 94813005002702
       VCID: AD12492AF407D82AD2-80F8
                        Fault Status: 01101011
                        Reset counter: 85
                        Voltage: 11.90 V
                        Temperature: -35.0C
                        Temperature: -35.0C
                        Bin. Bits: 00000100
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Component: TSG BF        H09 0304
       VCID: D5E2C1CABC17B0EA4A-8080
       Revision: --------    Serial number: 00000001156924
       ROD: EV_ParkiBrake_VW51.rod
    459264 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                        Fault Frequency: 8
                        Reset counter: 100
                        Mileage: 98359 km
                        Date: 2017.01.07
                        Time: 07:30:50
                        Voltage terminal 30: 14.5 V
                        Internal Fault ID: 138
                        Vehicle speed: 94 km/h
                        Network management state: normal
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: Dynamic
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Open
                        Status ParkingBrake right: Open
    463616 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                        Fault Frequency: 7
                        Reset counter: 100
                        Mileage: 98359 km
                        Date: 2017.01.07
                        Time: 07:30:50
                        Internal Fault ID: 185
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Revision: AB001007    Serial number: 156H 0C7620348
       Coding: 020007010000000001
       VCID: A404AC0EA7CD19620D-80F0
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 8R1 035 746 G    HW: 8R1 035 746 B
       Component: H-BNT-NA      H43 0901
       Revision: --------    Serial number: 204HY0C7515446
       Coding: 140200020206A9EF75028B4E00000403140000000000000000
       VCID: BB3677723A73469A5C-80EE
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
       Component: DU7 High  H41 0104
       Serial number: A130GK0C2512461
       Serial number: 00000001237192
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
       Revision: --H07---    Serial number: 525PA8-J2691PX
       Coding: 1001008
       Shop #: WSC 09012 002 1048576
       VCID: B83C687ECB456D82B1-80EC
       Component: SAS-GEN 2     H06 0005
       Serial number: 120717200056
       VCID: F2A89A5625B9C7D24F-80A6
    End----------(Elapsed Time: 03:05, VBatt start/end: 11.4V/11.4V)-----------
    Mar 2014
    Utah
    Found out that the soft coding in ABS didn't have the auto hill hold function checked. Did that, all fault codes went away! Test drove and no issues. The AHH still doesn't work, but I have to find out if it ever did...
  3. Likes Dana, Uwe liked this post
    United States
    After some digging I think 282D1A was the correct ABS coding. I don't see anything obviously wrong with the other PT modules (i.e. Engine, trans, ACC, etc) so I suspect the car has (or had) an ESP sensor problem that cause a lot of faults.
    Some B8 models used 2 sensors and others only had one but I would locate and inspect G419 and/or G536. I think those are under the carpet, driver's side but double check your repair sources or bump this back up if that car gives you trouble.
  5. Likes Uwe, hans j liked this post
    Mar 2014
    Utah
    It turns out there is much more to the story my service writer only found out after spending time on it. He still hasn't told me what, but apparently the vehicle owner unclicked the check box for AHH. I really don't know the whole story, but all the lights turned off when I checked that box! Thanks for checking against your scans, this appears to be the first one I have had in.
  7. Likes Dana liked this post
