Results 1 to 7 of 7
Thread: Can't clear some codes -- 2013 A4
    Hi there,
    I am also having trouble clearing 2 codes. Did brakes per instructions including rears with the program and all went well. Followed all procedures and brakes including EPB work perfectly. I cnnot clear the 2 fault codes associated with that were there before. I can clear them and the message says all dtc's cleared but they show right up again with a followup autoscan. Nothing on the dash except when i do the autoscan a ESC fault shows briefly as it runs through. Car shows no codes during startup or driving. I believe I have latest version of 12. What would you need from me ahead of time so I don't tie you up? Car has had the DSR disabled and all runs perfectly. 2013 A4.
    Thanks in advance
    I split this out from the thread you posted it in as I believe it's unrelated.
    Stoke on Trent, England
    Can you post an AutoScan so we can see which codes can't be cleared?
    New User Keith
    Quote Originally Posted by Keithuk View Post
    Yes, I will post up the scans tomorrow. Hi Uwe I think it may be related as I also deactivated my DSR and previously I was able to delete codes? At any rate I wil post scans and screen shots. There is also a dialog box that pops up mentioning a missing .rod file when i finish my autoscan. I wil image that as well.
    Hopefully I did this right. This is the autoscan before clearing the faults
    Sunday,13,July,2014,10:58:09:21746
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUHFAFL2DA195461   License Plate:
    Mileage: 20910km-12992mi   Repair Order: 7-13-14
    Chassis Type: FL (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62 6C
             72
             72
    VIN: WAUHFAFL2DA195461   Mileage: 20910km/12992miles
    Address 01: Engine (0-----CAEB)       Labels: 06H-907-115-CDN.clb
      Part No SW: 8K5 907 115 C    HW: 8K2 907 115 L
      Component: 2.0l R4/4V TF H09 0005
      Revision: ECH09---
      Coding: 4A190013242600062000
      Shop #: WSC 38543 000 1048576
      ASAM Dataset: EV_ECM20TFS0118K5907115C 001006
      ROD: N/A
      VCID: 326B16B4657B938E5D3-8067
    No ASAM data for: "EV_ECM20TFS0118K5907115C" (AU48)
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
      Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
      Coding: 071D18
      Shop #: WSC 06325 000 00000
      VCID: 8407006C074F6D3E3FF-80D1
                       Reset counter: 196
                       Mileage: 20893 km
                       Date: 2014.07.12
                       Time: 16:42:38
                       Hex Value: 0x0000
                       Hex Value: 0x0782
                       Hex Value: 0x0015
                       Hex Value: 0x109A
                       Hex Value: 0x0000
      Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
      Component: BCM2 2.0      H12 0633
      Coding: 0F814000000000000000
      VCID: 81090978185D7816149-80D4
      Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
      Revision: C1000000    Serial number: 01180120131569
      Coding: 6400208000
      VCID: 39792198B00D60D69C9-806C
      Revision: 08016001    Serial number: 00000539092902
      Coding:
    26000091863CAFC00000480300003D0D0F1C1208A20902210000080000000301000000300000
    00
      VCID: 78FFE49CCB87B9DEA37-802D
      Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels:
    1KX-955-119.CLB
      Component: WWS 210113  H07 0080
      Coding: 00FD11
      Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
      Coding: 02005D
      Component: E1 - LDS  H03 0031
      Component: USHL4.2  H30 0030
      Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
      Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
      Serial number: 003KJD91AGHM
      Coding: 303842354730303030304A55304C384B3053
      ROD: EV_AirbaECUVWAUDI010_AU48.rod
      VCID: 4A9B6E54EDEBFB4E053-801F
      Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
      Serial number: 5810000R120000AZ8Z
      Serial number: 6334MSME76116C44E
      Serial number: 6344MSME761108647
      Serial number: 6352QSME6826365AN
      Serial number: 6362QSME3E2D486C/
      Serial number: 63732SME6D262544+
      Crash sensor for front airbag; passenger side:
      Serial number: 63832SME4527336E1
      Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
      Component: Lenks.Modul   H02 0171
      Revision: 00000000    Serial number: 20130121000643
      Coding: 000016
      VCID: 4FAD7F401E89DE6652D-801A
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
      Part No SW: 8K0 920 982 D    HW: 8K0 920 982 D
      Component: KOMBIINSTR.   H35 0556
      Revision: 00300000    Serial number: UVN79AJ1E
      Coding: 8BB409000301D705020000
      VCID: 35612DA89C1584B6781-8060
      Component: GW-BEM 4CAN-M H11 0055
      Revision: 1Y060027    Serial number: 2741Y131150658
      Coding: 80C303FF00
      VCID: 4A9B6E54E5EBFB4E053-801F
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
      Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
      Component: MEM-FS        H06 0076
      Revision: AA000000    Serial number: 00000048546902
      Coding: 00581B00000000000000
      VCID: 3B753B90BA3152C68E5-806E
      Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
      Component: TSG FA        H09 0304
      Coding: 011C13204E00410001
      VCID: 56A38A242153AFAE91B-8003
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
      Revision: 00001000    Serial number: 0007166157
      Coding: 000000000001
      Shop #: WSC 06324 000 00000
      ROD: EV_RCEPSAU48X.rod
      VCID: 346710AC9F6F9DBE4FF-8061
      Revision: 00002001    Serial number: 0300234317
      Coding: 0106023A00FA404580B0013200000000
      Component: GTO BF  H01 0080
      Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
      Component: J245 PS050  H08 0043
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
      Revision: 00005001    Serial number: 94813009669202
      VCID: 2D5105C87445CC76001-8078
      Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
      Component: TSG BF        H09 0304
      VCID: 55A18D283C55A4B6981-8000
      Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
      Component: EPB-4         H01 0003
      Revision: --------    Serial number: 00000001232281
      ROD: EV_ParkiBrake_AU48.rod
      VCID: 387F249C830779DE637-806D
      Part No SW: 4G0 035 082 E    HW: 4G0 035 082
      Component: Radio U SIRIU H60 0121
      Revision: AB001007    Serial number: 156AV0D7682402
      Coding: 020007010000000001
      VCID: 224BE6F43D9B030EAD3-8077
      Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
      Component: H-BNT-NA      H44 0624
      Revision: --------    Serial number: 204AO0D7555132
      Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
      VCID: 377D27A0861976A66AD-8062
      Subsystem 1 - Part No: 8R0 060 884 BA
      Component: NAR 2013  0703
      Component: DU7 High  H42 0104
      Component: CD-Database  4949
      Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
      Component: TSG HL        H07 0304
      Coding: 010C13204000210001
      VCID: 59B98118504D80D6BC9-800C
      Revision: --H07---    Serial number: 525PA8-J2X935D
      Coding: 1000006
      VCID: 387F249C4B0779DE637-806D
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
      Component: TSG HR        H07 0304
    And here is the scan after I have cleared the codes.
    Sunday,13,July,2014,11:09:51:21746
    VIN: WAUHFAFL2DA195461   License Plate: GFM1511
    Mileage: 20910km-12992mi   Repair Order: 7-13-14/2
             72
             72
      Revision: ECH09---
      ROD: N/A
      Coding: 071D18
                       Reset counter: 196
                       Mileage: 20917 km
                       Date: 2014.07.13
                       Time: 11:04:01
                       Hex Value: 0x0000
                       Hex Value: 0x0782
                       Hex Value: 0x0015
                       Hex Value: 0x109B
                       Hex Value: 0x0000
      Coding: 6400208000
      Coding:
    00
    1KX-955-119.CLB
      Coding: 00FD11
      Coding: 02005D
      Coding: 000016
      Coding: 80C303FF00
      Coding: 1000006
    I only see one fault in the whole car:
      Coding: 071D18
    Didn't we go through this in another thread? If DSR is enabled or disabled, a corresponding change has to be made to the ABS module, and some don't support that change?
    Hi Uwe,
    No that was not me. The only posting I have done was about disabling the DSR and Work Shop Code but nothing about the fault code. My fault code was there even before I did the DSR mod. What I did ask at the time was if it was okay to clear the codes but I never actually got around to it. After I did my full brakes recently including the rears with the software I thought it would be a good time to clear them. Thing is when I do clear it I get confirmation and software says it's cleared but it is still there after another autoscan. Unlike the other thread the default for my car was the DSR on and I used the check box to disable it. My car does not drive well at all with the factory default which was " on". Nothing was ever noted about not being supported in my original thread I don't believe. At any rate my car drives 100% so I am satisfied with the performance. I was able to change the steering to the Original Audi feel and pull my rear brakes and rotors with the Ross Tech software. When I saw a similar post about the same fault it piqued my interest. Does the missing "Rod" file have any signifigance to you? I get it after my autoscan is finished and it says to contact Ross Tech about it.
