Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
Thread: VW Passat B8 2017 Tweaks
  1. #51
    Oct 2017
    Brazil
    Quote Originally Posted by fschaeffer View Post
    Hi Mauricio
    I'm also from Brazil and managed to unlock Video in Motion on my 2018 Passat. But I used another device - OBD11.
    If you are in Sao Paulo, I can help you or you can just buy the device abroad.
    Cheers
    I´m at Floripa and the tip helps a lot. Tks
  2. #52
    Oct 2017
    Brazil
    Quote Originally Posted by mauriciospilere View Post
    Hey Guys,
    Just started making changes in my Passat b8 2018. Comes with ACC from factory, but not with lane assist, traffic jam and signal recognition.
    Following some tutorials I got succeed activating the lane assist.
    Does anybody tryed activating the Traffic Jam? There is any tutorial for Passat?
    Another question. I activated the traffic signal recognition, but here, in Brazil, the system doesnt works properly. Sometimes it reads a signal, but less than 5% of them. There´s any configuration or region choice do gets it better?
    I´m still interested activating Vídeo in Motion and Digital TV. Anyone got it? know if the discorevy pro 3gp (9´one) has digital tv inside or need another hardware?
    That´s my scan:
    Saturday,27,January,2018,21:44:47:01775
    VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVWMV83C9JE047295   License Plate:
    Chassis Type: 3C-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 42 44 4B 52 5F
              6C 6D A5 BB BC CA D6 D7
    VIN: WVWMV83C9JE047295   Mileage: 4246km-2638miles
    4B-Multifunc. Module -- Status: Malfunction 0010
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 3G0 906 259     HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091D00122464050B3000
       Shop #: WSC 05311 115 00319
       ASAM Dataset: EV_ECM20TFS0203G0906259 001007
       ROD: EV_ECM20TFS_VW48.rod
       VCID: 698CB5F1A9F98CBFDFB-803C
    17176 - Databus
       Part No SW: 0D9 300 043 F    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5202
       Revision: 06454104    Serial number: TFK01706282200
       Shop #: WSC 05311 115 00080
       ROD: EV_TCMDQ250021.rod
       VCID: 1D64D1212D31A01F633-8048
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 62097000001273
       Coding: 0EEC6A8F342423734779060940C84970562CC4E2600292753842F0B8C209420000000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       ROD: EV_Brake1UDSContiMK100IPB_036.rod
       VCID: 79ACE5B1D9593C3F2FB-802C
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0448512768
       Coding: 1F20000723
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 3E2636AD80F7DB075A9-806A
       Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
       Component: GEB.F.Heckoef  H17 0812
       Serial number: ;8082872
       Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
       Component: Climatronic   H04 2001
       Revision: 00001K10
       Coding: 1102001420010001111550000010182A
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       ROD: EV_ACClimaBHBVW37X_006_VW27.rod
       VCID: 78AAE0B5E2532537505-802C
       Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 034 0242
       Revision: --------    Serial number: 8658190717000C
       ROD: EV_BCMBOSCH_018.rod
       VCID: 06569E4D98A743C7529-8052
       Component: WWS    170630  042 0607
       Serial number:         170720040817
       Component: RLHS  042 0105
       Serial number: S9Y17M08D12H01M15S05
       Coding: 00A8DD
       Light switch:
       Serial number: 20 04 2017  10000842
       Serial number: 000000000ZY1717013WM
       Serial number: 00000000000038729518
    263442 - Siren / Alarm Horn for Anti-Theft Alarm System
              U90D757 F7 [008] - No Release by Immobilizer
    527872 - Transport Mode Active
              U1105 00 [008] - -
       Serial number: 000308418617214
       Coding: 0471151811
       ROD: EV_EPHVA18AU3700000_009_VW48.rod
       VCID: 4BC06F79C3457EAFCD7-801E
       Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
       Component: ACC BOSCH MQB H04 0195
       Coding: 320067C259FFC428949C8045
       Shop #: WSC 05311 115 00414
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 35342981B5C1185F8B3-8060
       Serial number: 13071741350394
       ROD: EV_DRCONTITEMIC_VW27.rod
       VCID: 382A20B5A2D3E537905-806C
       Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003W6PF0Q87-
       Coding: 88CCC000000000005C5400CF000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 084A907592B355B7205-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G1857705G0193R01259
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G1857706G0193R01068
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 002 707 17
       Serial number: 35700000000A502CA72K
       Subsystem 4 - Part No SW: -----------    HW: 454 002 707 17
       Serial number: 358000000003703CA72H
       Subsystem 5 - Part No SW: -----------    HW: 454 802 607 17
       Serial number: 3510047ECDC10000000T
       Subsystem 6 - Part No SW: -----------    HW: 454 802 507 17
       Serial number: 35200B315D4100000005
       Subsystem 7 - Part No SW: -----------    HW: 454 802 707 17
       Serial number: 35500BDEC9010000000U
       Part No SW: 5Q0 953 521 AF    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20170801100898
       Coding: 0010
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 76B6EE8DE8475347429-8022
       Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
       Component: KOMBI         406 3193
       Coding: 07A401187F8C000801886B0B1001000080000000
       VCID: 290CF5F169794CBF1FB-807C
    16777008 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_SWA_0x1A keine Kommunikation]
                        Reset counter: 132
                        Mileage: 3803 km
                        Date: 2018.01.21
                        Time: 16:09:17
    16777010 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_LDW_0x19 keine Kommunikation]
                        Reset counter: 171
                        Mileage: 3795 km
                        Date: 2018.01.20
                        Time: 20:25:23
    16776969 - Databus
              [LDW_02 keine Kommunikation]
                        Reset counter: 171
                        Mileage: 3795 km
                        Date: 2018.01.20
                        Time: 20:22:51
    16776982 - Databus
              [SWA_01 keine Kommunikation]
                        Reset counter: 132
                        Mileage: 3803 km
                        Date: 2018.01.21
                        Time: 16:10:52
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 23071710803027
       Coding: 030300047F085900FB00025E9C0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW48.rod
       VCID: 33301799BBB5066FA57-8066
       Serial number: 39170002047840047297
       Coding: 2DFFFF
       Serial number: 7588600000170728031B
       Analog clock:
       Component: Analoguhr  209 2002
       Serial number: 17000198431011
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BCDD918129747F97B-8024
       Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
       Component: Sitzmemory    H05 0022
       Serial number: Y0006QGK25787
       Coding: 001000020000050081C280808080000000008181000000F400
       ROD: EV_SeatMemorDriveSide_002_VW48.rod
       VCID: 3A2E3ABD9CDFF727661-806E
       Serial number: 040717EG40809A
       Coding: 003F1A20D200028000000000
       VCID: 43D04759EB15B6EF357-8016
       Revision: 00000000    Serial number: 0001892199
       Coding: 01000011004001
       Shop #: WSC 00015 115 00319
       ROD: EV_SteerAssisVWBSMQBA_009_VW48.rod
       VCID: 40DA4855FA03ADF7285-8014
    3158336 - Databus
              [Ausfall der CAN-Botschaft "HCA_01" des Frontsensorik-SG (über GW)]
                        Reset counter: 171
                        Mileage: 3795 km
                        Date: 2018.01.20
                        Time: 21:25:39
                        valid
       Serial number: 02081710522509
       Coding: 000000060100034A06004F01020000000000000000000000000000000000
       Shop #: WSC 05311 000 08193
       VCID: 72BED29D842F4F676E1-8026
       Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo links  H02 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo rechts  H02 0003
       Coding: E02400
    0033 - Left/Right Driving Switch-Over Active
              C1080 00 [009] -  -
                        Reset counter: 12
                        Mileage: 345 km
                        Date: 2017.11.11
                        Time: 12:02:44
       Serial number: 070717EG528109
       Coding: 003F1020DE00028200000000
       VCID: 42DE425DF40FBFE73E1-8016
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 045 A    HW: 5NA 035 045
       Component: MU-H-N-RW     H54 1121
       Serial number: A849G0HS006223
       Coding: 02840103FF00000051220001001828001F0100E4012004009F
       ROD: EV_MUHig4CGen2HBAS_VW48.rod
       VCID: 36362E8DA8C71347829-8062
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H50 9130
       Serial number: VWZ6ZJT1945457
       Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
       Component: ROW 2017  --- 0062
       Component: Gracenote2  --- 4012
    7193 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 171
                        Mileage: 3795 km
                        Date: 2018.01.20
                        Time: 21:04:02
                        Voltage terminal 30: 12.1 V
                        BAP-BAP_Function_ID: 02
    7201 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 188
                        Mileage: 4204 km
                        Date: 2018.01.27
                        Time: 13:29:15
                        Voltage terminal 30: 12.5 V
       Coding: 0184010162002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       VCID: 392C25B199D9FC3F6FB-806C
       Part No SW: 5Q0 959 107 K    HW: 5Q0 959 107 H
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: 31384133100000
       Coding: 0108
       ROD: EV_DeckLidCONTIAU736_VW27.rod
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H08 0272
       Serial number: 27071711P10448
       Coding: 0004080100000101002223448156A90090000E300140
       ROD: EV_MFKBoschMQBB_VW27.rod
       VCID: 3C223CA596EBC91774D-8068
    0659 - Steering
              U4E6652 F2 [008] - Lane-Holding Assistance Not Coded
              [HC_interface_at_the_steering_not_activated]
                        Reset counter: 169
                        Mileage: 3795 km
                        Date: 2018.01.20
                        Time: 20:26:25
                        Control Module temperature: 46 °C
                        Outside air temperature: 24.5 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 2448.2 s
                        Voltage terminal 15: 11.9 V
                        mid: 02 A6
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Serial number: 190617EFJ18296
       Coding: 000E10200100028000000000
       VCID: 45D45941E52188DF1B3-8010
       Serial number: 190617EFJ1613A
       Part No SW: 4M0 907 594 K    HW: 4M0 907 594
       Coding: 608000748101
       ROD: EV_SunRoofCONTIAU736.rod
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
       VCID: 1676CE0DC807F347A29-8042
    End----------(Elapsed Time: 02:34, VBatt start/end: 12.3V/12.3V)-----------
    By the way, when activing the active lane assist i turned on the option of side assist at active display. Anyone can help me on where i can take out this option of the dashboard, cause my car dont have the side assist hardware.
  3. #53
    Apr 2018
    Hungary
    Hey Everyone
    I just tried to activate DLA on my 2016 oct Passat B8 (Lane and front assist are OEM installed, also has LED II headlight with dynamic corner light) but according the following description (https://www.ascoding.ch/en/activate-...t-dla-mj-2017/) but I faced some problems:
    In modul 09 central electric I'm not allowed to change Byte 02 to hex 0E (no labeling) as it says it is out of range. I do it in long coding simply changing Byte 02 to 0E. How it should be done normally?
    I could change the Fernlich Assistent (Menusteuerung Fernlichtassistent and Menusteuerung Fernlichtassistent Werkeinstellung) to present but the DLA menu did not pop up in CAR menu/Lighting.
    I can manage to do all other changes except Modul 55 byte 04 bit 6 (Maskiertes Dauerfahrlicht MDF aktiv). There is no bit 6 avaible, only 5 bits I can see.
    Do you may have any idea what do I do wrong?
    THanks in advance guys!
  4. #54
    Dec 2016
    DE
    Quote Originally Posted by PT_operator View Post
    I always die a little inside, when someone says a bit is "not there". Just because VCDS does not have a label for this, it doesn't mean it is missing. You just have to set it manually using the binary field in LCode.
    However, when the coding in 0x09 is all zeroes, just modify the adaption values using the default login:
    > Fernlicht_Assistent-Erweiterte Fernlichtsteuerung > AFS: FLA: Fernlicht (GLW:MDF)
    > Fernlicht_assistent-Assistenzfahrlicht: Empfindlichkeit per BAP einstellbar > present
    > Fernlicht_Assistent-Menüsteuerung Fernlichtassistent > present
    > Fernlicht_Assistent-Menüsteuerung Fernlichtassistent Werkseinstellung > present
  5. Likes Uwe liked this post
  6. #55
    Apr 2018
    Hungary
    Thanks a lot for the quick respone. You're right, I'll try that way.
    'However, when the coding in 0x09 is all zeroes, just modify the adaption values using the default login:'
    What do you mean under '0x09 is all zeroes' - does this mean simply skip no labeling=changing byte 02 to hex0E?
  7. #56
    Jun 2017
    Right. Model year 17 upwards does not have any coding in Unit 09 anymore.
    Everthing went to adaptation channels.
    The instructions you linked also states "up to MY 17"! This does not include MY17.
    For absolute correct statements, please post a full Auto-Scan.
  8. Likes Uwe liked this post
  9. #57
    Apr 2018
    Hungary
    I will post full Auto-Scan however I have doubts my car would be MY17 as I have Modul 55 and cannot find modul 4B (however I have HEX-CAN cable not HEX-V2 type and I'm not sure if it can handle modul 4B) - furthermore first registration of my car is october 2016.
  10. #58
    Apr 2018
    Hungary
    Finally I succeed to activate DLA: you were right simply just switching on bit manually finally made the system work - thanks for your hint.
    By the way: as a next challange I'd like to activate traffic jam assist but I could not find anything about it on forums. Did anyone try it?
  11. #59
    Jun 2017
    Yes but it's not possible with VCDS.
  12. #60
    Apr 2018
    Hungary
    Does it requires OBDeleven?
