Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 95
Thread: VW Passat B8 2017 Tweaks
  1. #31
    Quote Originally Posted by murmeltier View Post
    Btw. is there an option to add admaps to the post?
    Just post them in-line, like you did the Auto-Scan above.
  2. #32
    Verified VCDS User murmeltier's Avatar
    Dec 2015
    Switzerland
    Of course, sorry! AutoScan with the English version of VCDS:
    Tuesday,08,August,2017,10:55:29:60163
    VCDS Version: 17.8.0.1  HEX-V2 CB: 0.4401.4
    VIN: WVWZZZ3CZHP030366   License Plate: ENGLISCH
    Mileage: 9601km-5965mi   Repair Order:
    Chassis Type: 3C-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 4B 52 5F 69
              6C 6D A5 BB BC CF D6 D7
    VIN: WVWZZZ3CZHP030366   Mileage: 9601km-5965miles
    D6-Light Ctrl Left 2 -- Status: Malfunction 0010
    D7-Light Ctrl Right 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
       Component: R4 2.0l TDI   H25 2011
       Revision: B4H25---
       Coding: 011D0032047405083000
       Shop #: WSC 00028 028 00038
       ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
       ROD: EV_ECM20TDI01104L906026FN_004.rod
       VCID: 7BA20516E36BD0EF0E8-802E
       Part No SW: 0D9 300 042 N    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5004
       Revision: 06454104    Serial number: TFK01703160056
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 24101E6A3E554F171F2-8070
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 61177000000165
       Coding: 0FEC6A8F34230B6C477A060640C949F0562CD0E2600292753862F078C2A9420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 79AE1F1EE957E2FF1C4-802C
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 151
                        Mileage: 8501 km
                        Date: 2017.07.28
                        Time: 13:11:21
                        Extended Freeze Frames:
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0440841347
       Coding: 0F2020070F
       VCID: 3C20C60AA6E517D7472-8068
       Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
       Component: GEB.F.Heckoef  H17 0812
       Serial number: ;8075262
       Part No SW: 5G0 907 044 CJ    HW: 5G0 907 044 CJ
       Revision: 00001K10
       Coding: 1202010420241001111550020010182A
       ROD: EV_ACClimaBHBVW37X_006_VW27.rod
       VCID: 71BE273EB127AABFA44-8024
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0223
       Revision: --------    Serial number: 8658210417022E
       Shop #: WSC 00028 028 00037
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017_VW27.rod
       VCID: 015E77FE8187BA3F544-8054
       Component: WWS    170401  042 0607
       Serial number:         170419152012
       Component: RLHS  042 0105
       Serial number: S9Y17M05D03H00M31S25
       Coding: 00A8EE
       Light switch:
       Serial number: 15 03 2017  10000903
       Ceiling Light Module:
       Subsystem 4 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
       Component: J528 Dachelek  H08 0008
       Serial number: 17050400010188C
       Coding: F38380
       Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0038
       Serial number: 000308417617126
       Coding: 0271167151
       ASAM Dataset: EV_EPHVA2CAU3700000 009032
       ROD: EV_EPHVA2CAU3700000_009_VW37.rod
       VCID: 4FFA81C607539C4F920-801A
       Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
       Component: ACC BOSCH MQB H04 0195
       Coding: 320467DB51FFC428949C8045
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3536D32E85CFC69FB8C-8060
       Part No SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
       Component: Airbag VW21   004 0306
       Revision: --------    Serial number: 003RAP7PBKYX
       Coding: 88CCC000000000005C5400CF000800000065
       Shop #: WSC 00028 028 00006
       ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X_VW27.rod
       VCID: 0C4056CAB6C5E757372-8058
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G1857705G0101R01281
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G1857706G0115R00923
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 001 704 17
       Serial number: 3570000000030090C321
       Subsystem 4 - Part No SW: -----------    HW: 454 002 504 17
       Serial number: 35800000000C5869732P
       Subsystem 5 - Part No SW: -----------    HW: 454 800 804 17
       Serial number: 3510059E9AE0F000000%
       Subsystem 6 - Part No SW: -----------    HW: 454 800 704 17
       Serial number: 35200B147890F000000M
       Subsystem 7 - Part No SW: -----------    HW: 454 801 104 17
       Serial number: 355006E8E800E000000Y
       Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20170502200554
       Coding: 0C10
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 7EA40C02F079C5C7296-802A
       Part No SW: 3G0 920 751 B    HW: 3G0 920 751 B
       Component: KOMBI         304 8311
       Coding: 07A509186F8C000801887F0B1001000000000000
       Component: GW MQB High   515 5286
       Serial number: 02051710801153
       Coding: 030300345F087300FB00025E1C0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F3AE1466793FC4FF20-807A
       Serial number: 46170001178840107175
       Coding: 2DFFFF
       Serial number: 4457453804
       Analog clock:
       Component: Analoguhr  209 2002
    131668 - Headlight Range Control Module
              U101E 00 [008] - No Communication
                        Reset counter: 157
                        Mileage: 9212 km
                        Date: 2017.08.06
                        Time: 14:03:41
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: On
    131734 - No Communications with Undefined Control Module
              U1126 00 [008] - -
                        Reset counter: 157
                        Mileage: 9212 km
                        Date: 2017.08.06
                        Time: 14:31:49
                        Terminal 15: On
    131735 - No Communications with Undefined Control Module
              U1126 00 [008] - -
                        Reset counter: 157
                        Mileage: 9212 km
                        Date: 2017.08.06
                        Time: 14:31:49
                        Terminal 15: On
       Serial number: 17000104152012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0310
       Revision: --------
       Coding: 14C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
       VCID: 3828DA1A92DD3BF7A3A-806C
       Component: TSG FS        010 0032
       Serial number: 0000254916345
       Coding: 003F1B20D000028000001000
       VCID: 47CAA9E6EF23440FDA0-8012
       Revision: 00000000    Serial number: 0001628639
       Coding: 01010011004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
       VCID: 40D8B2FACA0D73371BA-8014
       Component: FCM MQB Low   001 0285
       Serial number: 24041710521319
       Coding: 000000060100034A00000F01020000000000000000000000000000000000
       ROD: EV_MultiModulContiVW48X_VW27.rod
       VCID: 72BC2832B42191A75DE-8026
       Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo links  H02 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo rechts  H02 0003
       Coding: E02400
       Component: TSG BFS       010 0032
       Serial number: 0000253563962
       Coding: 003F1120DE00028000001000
       VCID: 46D4A4E2E8295D07216-8012
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 020 E    HW: 3G0 035 020
       Component: MU-H-ND-EU    H51 0814
       Serial number: A682D0HS023688
       Coding: 02840201FF00000051110101008808031F0100C4012001009F
       VCID: 196E3F9E091702FFBC4-804C
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9TKL08GE5
       Subsystem 2 - Part No SW: V03 959 800 QR    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Component: Gracenote2---  --- 1013
    5688 - Control Head for Mulimedia System
              B13C9 F2 [008] - On/Off Switch
                        Reset counter: 153
                        Mileage: 8266 km
                        Date: 2017.07.27
                        Time: 14:22:28
                        Voltage terminal 30: 13.5 V
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0438155937
       Coding: 0100000202000000
       VCID: 3B22C516A3EB10EF4E8-806E
       Coding: 0184020163002017000040
       VCID: 392EDF1EA9D722FF5C4-806C
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 31301161100000
       Coding: 02A8
       Shop #: WSC 00028 028 00207
       VCID: 42DCB8F2C40161270DE-8016
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 26041712K21865
       Coding: 000408020000040100262347C050A90094000E200020
       ROD: EV_MFKBoschMQBB_VW36.rod
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       011 0032
       Serial number: 0000253659589
       Coding: 000E11200100028000001000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 49CEAFDEF937B27FCC4-801C
       Component: TSG HBFS      011 0032
       Serial number: 0000253657334
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
       VCID: 167434A2F8092D87916-8042
    0774 - Light Bulb for Low Beam
              C1198 29 [008] - Signal Implausible
                        Reset counter: 124
                        Mileage: 4913 km
                        Date: 2017.07.10
                        Time: 05:48:42
                        Reset counter: 124
                        Mileage: 4913 km
                        Date: 2017.07.10
                        Time: 05:48:42
    End----------(Elapsed Time: 02:24, VBatt start/end: 12.6V/12.6V)-----------
    Any ideas what I have to do to activate the Dynamic Light Assist, even without STG 55?
    Thanks!
    ADMAP 09:
    	SW:5Q0-937-086-BH   HW:5Q0-937-086-BH ---  Cent. Elect.
    	Component:BCM PQ37BOSCH 032 0223, Coding:
    	EV_BodyContrModul1UDSBosc,017002,EV_BCMBOSCH_017_VW27.rod
    	Tuesday,08,August,2017,11:04:13:60163
    	VCDS Version: Release 17.8.0  Data version: 20170721 DS276.2
    IDE01550-Service position,153.296551 °,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,30 s,8
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
    IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe,installed ,11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
    IDE05143-MAS02985-Writing parameter-Value,130 ,5
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
    IDE05144-Read parameter address,FE 00 00 ,3
    IDE05145-Light configuration,21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 00 64 08 09 1C 12 00 9C 04 4C 00 4C 14 00 64 07 00 64 08 0A 1C 13 00 9C 01 3A 00 49 14 00 7F 00 00 00 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 00 00 00 08 0A 7F 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,23.00 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,53.00 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,53.00 °C,30
    IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remotestart,not installed ,8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
    IDE07356-Position during interval mode,24.890085 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,4 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,10 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,4 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,80 %,19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,10 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
    IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,installed ,19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,installed ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
    IDE10298-Alternating park position 1,8.296695 °,2
    IDE10299-Alternating park position 2,24.890085 °,2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.40 ,256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000101  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00111100  ,256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000010  ,256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00011100  ,256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00011010  ,256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,127 %,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,127 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,127 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,127 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,127 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,127 %,256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,127 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,127 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,127 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,127 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,2.0 s,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,64 ,30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,200 ,30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,198 ,30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,255 ,30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,255 ,30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,255 ,30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,175 ,30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,32 ,30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
    MAS05055-lower turn position,26.296677 °,2
    MAS05056-upper turn position,171.296533 °,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,I-panel ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,multicolor ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,20 ,60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,21 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60
    ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,active ,13
    ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,not active ,13
    ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,1.00 ,13
    ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,1.00 ,13
    ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,0.94 ,13
    ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,0.17 ,13
    ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,1.00 ,13
    ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,0.86 ,13
    ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,1.00 ,13
    ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,0.86 ,13
    ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,1.00 ,13
    ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,0 ms,22
    ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,200 ms,22
    ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,2000 ms,22
    ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,400 ms,22
    ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,600 ms,22
    ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,800 ms,22
    ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,1000 ms,22
    ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,1200 ms,22
    ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,1400 ms,22
    ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,1600 ms,22
    ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,1800 ms,22
    ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,0.0 %,22
    ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,0.5 %,22
    ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,100.0 %,22
    ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,2.0 %,22
    ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,5.0 %,22
    ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,10.0 %,22
    ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,20.0 %,22
    ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,40.0 %,22
    ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,80.0 %,22
    ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,95.0 %,22
    ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,99.0 %,22
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
    ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
    ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
    ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv,active ,8
    ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung,installed ,8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
    ENG126651-ENG115658-Kennlinie Abdimmen-x0,0 ,22
    ENG126651-ENG101574-Kennlinie Abdimmen-X1,200 ,22
    ENG126651-ENG115664-Kennlinie Abdimmen-x10,2000 ,22
    ENG126651-ENG99557-Kennlinie Abdimmen-X2,400 ,22
    ENG126651-ENG102140-Kennlinie Abdimmen-X3,600 ,22
    ENG126651-ENG102936-Kennlinie Abdimmen-X4,800 ,22
    ENG126651-ENG103548-Kennlinie Abdimmen-X5,1000 ,22
    ENG126651-ENG113992-Kennlinie Abdimmen-X6,1200 ,22
    ENG126651-ENG115661-Kennlinie Abdimmen-x7,1400 ,22
    ENG126651-ENG115662-Kennlinie Abdimmen-x8,1600 ,22
    ENG126651-ENG115663-Kennlinie Abdimmen-x9,1800 ,22
    ENG126651-ENG115659-Kennlinie Abdimmen-y0,100.0 ,22
    ENG126651-ENG99777-Kennlinie Abdimmen-Y1,99.0 ,22
    ENG126651-ENG115668-Kennlinie Abdimmen-y10,0.0 ,22
    ENG126651-ENG100480-Kennlinie Abdimmen-Y2,95.0 ,22
    ENG126651-ENG100773-Kennlinie Abdimmen-Y3,80.0 ,22
    ENG126651-ENG100631-Kennlinie Abdimmen-Y4,40.0 ,22
    ENG126651-ENG102174-Kennlinie Abdimmen-Y5,20.0 ,22
    ENG126651-ENG113993-Kennlinie Abdimmen-Y6,10.0 ,22
    ENG126651-ENG115665-Kennlinie Abdimmen-y7,5.0 ,22
    ENG126651-ENG115666-Kennlinie Abdimmen-y8,2.0 ,22
    ENG126651-ENG115667-Kennlinie Abdimmen-y9,0.5 ,22
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-100.00 %,30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-100.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-100.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-100.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-100.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-100.00 %,30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-100.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,100 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,3A ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,20 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake light ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,100 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,39 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,10 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake light ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,minimize ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Blinken links aktiv (beide Phasen) ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Brake light ,16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Blinken rechts aktiv (beide Phasen) ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Brake light ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,90 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,100 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Brake light ,16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,37 ,16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,09 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,34 - LED Bremsleuchten ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Brake light ,16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,100 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28 ,16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,28 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Nebellicht links ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,100 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28 ,16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,28 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Nebellicht rechts ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 64 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 64 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 64 06 18 80 00 00 00 00 00 00 20 1A 00 2A 08 0A 64 07 18 80 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 DA 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 64 18 00 80 1B 00 64 00 00 00 22 09 00 37 18 00 64 1B 00 80 00 00 00 00 00 00 25 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,25 20 00 3A 08 0A 64 18 00 64 00 00 00 00 00 00 25 10 00 39 08 09 64 18 00 64 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
    ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4,-8.00 mm/%,62
    ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn,-8.00 mm/%,62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Verbundlenkerhinterachse ,62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,0 ,62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
    ENG124714-ENG142044-OCU-DWA_push,not active ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
    ENG124714-OCU-,not installed ,8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 ,8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,20.0 ms,8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin 31 ,5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2550 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
    ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
    ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
    ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
    ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
    ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
    ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
    ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
    ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
    ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
    ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
    ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
    ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
    ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
    ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
    ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
    ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
    ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
    ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM,0.00 s,21
    ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM,0.00 s,21
    ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM,0.00 s,21
    ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM,0.00 s,21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
    ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM,0.00 s,21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
    ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv,active ,9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,installed ,9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,nur wenn freigegeben ,9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active ,9
    ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,active ,9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed ,9
    ENG122979-ENG141954-Vernetzung-A/C electronics,installed ,8
    ENG122979-ENG141968-Vernetzung-Anhaengeranschlussgeraet,installed ,8
    ENG122979-ENG141974-Vernetzung-Bremsen_Steuergeraet,installed ,8
    ENG122979-ENG141953-Vernetzung-Getriebesteuergeraet,installed ,8
    ENG122979-ENG99457-Vernetzung-Head area heater,not installed ,8
    ENG122979-ENG142040-Vernetzung-Kunden_spezifisches_Funktions_SG,not installed ,8
    ENG122979-ENG141969-Vernetzung-UGDO,not installed ,8
    ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,active ,7
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
    ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
    ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
    ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
    ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,Inverted ,5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
    Elapsed Time: 01:40
    Any ideas what I have to activate for the Dynamic Light Assist, even without STG 55?
    Thanks!
  3. Likes DV52 liked this post
  4. #33
    murmeltier: Nice info paste - which I will thieve with your permission (it will go straight into my database)- many thanks!!
    Hmm........... I'm more than happy to be advised otherwise, but isn't the control module in your car @ address hex 4B (J745) the range control unit for the headlights?
  5. #34
    Verified VCDS User murmeltier's Avatar
    Dec 2015
    Switzerland
    You're welcome and thanks for the hint with the 4B :-) With the VCDS 17.3 (German) I don't see the 4B-Multifunc. Module, can somebody explain that?
    But as it looks the 4B has no labels, so I will not find out if there is something to change and when yes what I have to change...
    adrian
  6. #35
    Jun 2017
    Is 4B still compatible with HEX-CAN USB?
  7. #36
    Near Philadelphia, PA, USA
    The HEX+CAN is compatible with the 3C Passat and should have full access to the 4B module.
    Did I miss something?
  8. #37
    Quote Originally Posted by Bruce View Post
    This 2017 3C is MQB-based and address 4B uses 29bit addressing. Only HEX-NET and HEX-v2 with a current codeblock and version of VCDS can see it.
  9. Likes Uwe, hadez16 liked this post
  10. #38
    Quote Originally Posted by murmeltier View Post
    See my reply to Bruce.
    The star indicates that the ROD file will give you coding info. Give it a try!
  11. Likes Uwe, murmeltier liked this post
  12. #39
    Quote Originally Posted by Eric View Post
    Eric: 29 Bit? That's an odd (not in the decimal sense - mean "strange") number for addressing? I'm more familiar with multiples of 8bits (used to be 4bits). Is that a CAN thing?
  13. #40
    It is a CAN thing.
  14. Likes Eric, Uwe liked this post
