Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 95
Thread: VW Passat B8 2017 Tweaks
  1. #21
    Jan 2017
    Belgium
    Further adaptations:
    Coming / Leaving Home automatic
    Select Control unit 09 (Central Electrics)
    Security access
    Access Code 31347
    Adaptation
    ENG10584-ENG116601-Außenlicht_uebergreifend (früher Komfortbeleuchtung)
    Coming Home Verbaustatus change to "automatisch"
  2. #22
    Jan 2017
    Belgium
    Next step in my adaptations: Enabling of Lane Assist
    There were several guides with some variantions, but I found the following to work for my MY17 Passat B8
    Select Control Unit 17
    Codierung
    Byte 4 Bit 6 aktivieren ("Spurhalteassistent/Lane Assist aktivieren")
    Byte 11 Bit 1 aktivieren ("Spurhalteassistent/Lane Assist Information BAP verbaut aktivieren")
    Select Control Unit A5
    Codierung
    Byte 16 Bit 7 aktivieren
    Security access
    Access Code 20103
    Adaptation
    - IDE10872- Warning intensity; lane depart. warning, Medium) Auf "Menu" setzen - My standard setting was MEDIUM
    - IDE10873 - BAP personalization set to activated - My standard setting was ACTIVATED
    - IDE07596-Personalisierung Spurhalteassistent bei Kl. 15 ein Auf "letzte Einstellung" setzen - My standard setting was LAST SETTING
    Select Control Unit 44
    Codierung
    Byte 0 Bit 4 (Spurhalteassistent HCA verbaut) aktivieren
    Select Control Unit 5F
    -ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19) von nicht aktiviert auf aktiviert - My standard setting was NOT ACTIVATED
    -ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning) von nicht aktiviert auf aktiviert - My standard setting was NOT ACTIVATED
    -ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high) von nicht aktiviert auf aktiviert - My standard setting was NOT ACTIVATED
    Some remarks and questions:
    This enabled the lane assist and I can enable/disable it in my instrument cluster under assist systems, but I do not see any setting related for Lane Assist in my Discovery Pro under the CAR Menu / assist systems ?
    So there I cannot enable / disable it or configure it???
    >> Solved, seems my IDE10873 - BAP personalization has another config then described in guides, must be activated. (Also adapted above)
    Other question:
    Following settings were in some guides, but I did not find them:
    Control Unit A5
    - HCA_On_State auswählen -- Wert auf Menü setzen
    - Kanal - Eingriffszeitpunkt auswählen -- Wert auf spät - Einstellung über Menü setzen
    Are these related to my problem above? Any idea?
  3. #23
    Dec 2016
    DE
    The adaption channels in the A5 module are only present in the MQB_MFK, but not in the MQB_B_MFK. So it's correct, you can't find them.
  4. Likes Uwe liked this post
  5. #24
    Jan 2017
    Belgium
    Thanks, that confirms I indeed cannot find it.
    Also solved my problem with not seeing the setting in my Discovery Pro, my IDE10873 - BAP personalization has another config then described in guides, must be activated. (Also adapted in above post)
  6. Likes XaGiCo liked this post
  7. #25
    Jan 2017
    Belgium
    further question on the Lane Assist...
    Did some testing and it seems to work very well from ~60km/h and up, below 60km/h it seems to automatically deactivate, a pity, but no problem for me...
    Now my question, there also is a feature called 'Traffic Jam Assist' that helps steering in stop&go traffic while the ACC is active.
    (I have the DSG automatic, so full stop and resume is possible and I enjoy using it)
    I have not yet been in stop&go traffic since the recoding, but did the 'Lane Assist' activation automatically also give me the 'Traffic Jam Assist', or is there some more adaptation required???
  8. #26
    Verified VCDS User murmeltier's Avatar
    Dec 2015
    Switzerland
    Hey
    I'm trying to activate the Dynamic Light Assist - Function (DLA) for my Passat B8, (MY 2017). I have the Front Sensor
    (Camera A5) and the LED Headlights (high). I have already activate the high beam Assist (Light Assist) and it works.
    Does somebody knows what i have to do for the DLA? I'm really lost...
    Thanks and greetings from Switzerland,
    adrian
  9. #27
    May 2014
    Quote Originally Posted by murmeltier View Post
    Hey
    adrian
    Adrian - not familiar with the particular headlight assemblies in Switzerland for the B8, but are you sure that the LED fittings have swivel motors for DLA?
    If so, perhaps a place to start your initial investigation is Byte 2 in the BCM. If you have loaded the latest Ross-Tech software, you should be able to access the all new, all singing, all dancing "yellow" long coding helper screens. Here's a screen shot from my MQB platform vehicle showing the light Assist opions:
    Of course, if the BCM on your B8 is of the type that reports a zero-series code-string, then the long coding helper screens will be as useless as "tits-on-a-turkey". In this case, you will need to go to ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung adaptation channel in the hex09 module where you should find the same options as in my picture above
    PS: It's usually beneficial when asking for assistance to post-up a copy of the autoscan from your car. That way folk get to understand what equipment has been installed
  10. Likes Uwe, murmeltier liked this post
  11. #28
    Dec 2015
    Switzerland
    Hey Don
    Thanks for your answer and sorry about the AutoScan! Yes, my LED Headlights have motors for the DLA. I compared the PartNr. of my LED Headlights with other headlights which have the DLA-Function and it's the same. And yes, I have a 09er with only adaptions-channels.
    I already tried it with ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung (AFS:BCM:Fernlicht) but it didn't work. So I changed it to "FLA:Fernlicht (GLW:MDF)" and it shows the "Dynamic Light Assist" in the Car Menu. I also set the Byte 19 & 21 in the A5 as shown in the pictures:
    But I still get the "error message": Störung: Light Assist. Does somebody have an idea what's the problem? I guess it's just a small problem which causes this error message.
    Oh, and my Passat has no STG 55 (headlight range adjustment / Leuchtweitenregulierung), could this be the problem?
    Sorry for my englisch and greetings from Switzerland ;-)
    adrian
    Sonntag,06,August,2017,15:01:40:60163
    VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x86
    VCDS Version: PCI 17.1.3.0  HEX-V2 CB: 0.4401.4
    Datenstand: 20170508 DS267.9
    www.VCDSpro.de
    Betriebsnummer: 123 12345 012345
    Fahrzeug-Ident.-Nr.: WVWZZZ3CZHP030366   KFZ-Kennzeichen:
    Kilometerstand: 9212km   Reparaturauftrag:
    Fahrzeugtyp: 3C (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 55 5F 69
              6C 6D A5 BB BC CF D6 D7
    Fahrzeug-Ident.-Nr.: WVWZZZ3CZHP030366   Kilometerstand: 9212km
    03-Bremsenelektronik -- Status: Fehler 0010
    05-Zugangs-/Startber. -- Status: i.O. 0000
    09-Zentralelektrik -- Status: Fehler 0010
    13-Distanzregelung -- Status: i.O. 0000
    16-Lenkradelektronik -- Status: i.O. 0000
    19-Diagnoseinterface -- Status: Fehler 0010
    2B-Lenksäulenverrieg. -- Status: i.O. 0000
    3C-Spurwechsel -- Status: i.O. 0000
    42-Türelektr. Fahrer -- Status: i.O. 0000
    44-Lenkhilfe -- Status: i.O. 0000
    52-Türelektr. Beifahr. -- Status: i.O. 0000
    55-Leuchtweitenreg. -- Status: nicht erreichbar 0100
    5F-Informationselek. I -- Status: Fehler 0010
    69-Anhänger -- Status: i.O. 0000
    6C-Rückfahrkamera -- Status: i.O. 0000
    6D-Heckklappe -- Status: i.O. 0000
    A5-Front-/Vorfeldkamera -- Status: i.O. 0000
    BB-Türelektronik hinten links -- Status: i.O. 0000
    BC-Türelektronik hinten rechts -- Status: i.O. 0000
    CF-Spurwechselassistent 2 -- Status: i.O. 0000
    D6-Lichtsteuerung links 2 -- Status: nicht erreichbar 0100
    D7-Lichtsteuerung rechts 2 -- Status: nicht erreichbar 0100
    Adresse 01: Motorelektronik (J623-DFCA)       Labeldatei: DRV\04L-907-309-V1.clb
       Teilenummer SW: 04L 906 026 FN    HW: 04L 907 309 M
       Bauteil: R4 2.0l TDI   H25 2011
       Revision: B4H25---
       Codierung: 011D0032047405083000
       Betriebsnr.: WSC 00028 028 00038
       ASAM Datensatz: EV_ECM20TDI01104L906026FN 004002
       ROD: EV_ECM20TDI01104L906026FN_002.rod
       VCID: 7BA20516E36BD0EF78B-802E
    Adresse 02: Getriebe (J743)       Labeldatei: DRV\0D9-927-770.clb
       Teilenummer SW: 0D9 300 042 N    HW: 02E 927 770 AS
       Bauteil: DQ250-6F MQB  H54 5004
       Revision: 06454104    Seriennummer: TFK01703160056
       Codierung: 0014
       ASAM Datensatz: EV_TCMDQ250021 001001
       ROD: EV_TCMDQ250021.rod
       VCID: 24101E6A3E554F17691-8070
    1 Fehler gefunden:
    10763 - Anlasserfreigabe von der Wählhebelsensorik
              P1734 00 [002] - -
              Sporadisch - unbestätigt - geprüft seit letzter Löschung
    Adresse 03: Bremsenelektronik (J104)       Labeldatei: 5Q0-907-379-IPB-V1.clb
       Teilenummer SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Bauteil: ESC           H62 0743
       Revision: 00000000    Seriennummer: 61177000000165
       Codierung: 0FEC6A8F34230B6C477A060640C949F0562CD0E2600292753862F078C2A9420000000012121212B835351919323200
       ASAM Datensatz: EV_Brake1UDSContiMK100IPB 036010
       ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
       VCID: 79AE1F1EE957E2FF6A7-802C
    1 Fehler gefunden:
    16401 - Reifendruckwarnung
              C102D 00 [008] - -
              Sporadisch - bestätigt - geprüft seit letzter Löschung
                 Umgebungsbedingungen:
                        Fehlerstatus: 00000001
                        Fehlerpriorität: 2
                        Fehlerhäufigkeit: 1
                        Verlernzähler: 151
                        Kilometerstand: 8501 km
                        Datum: 2017.07.28
                        Zeit: 13:11:21
    Adresse 05: Zugangs-/Startber. (J518)       Labeldatei: DRV\5Q0-959-435.clb
       Teilenummer SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Bauteil: VWKESSYMQB    036 0811
       Revision: 00036000    Seriennummer: 0440841347
       Codierung: 0F2020070F
       ASAM Datensatz: EV_KessyHellaMQBAB 004039
       VCID: 3C20C60AA6E517D7311-8068
       Steuergerät für Heckklappenöffnung:
       Subsystem 1 - Teilenummer SW: 3G0 962 243     HW: 3G0 962 243
       Bauteil: GEB.F.Heckoef  H17 0812
       Seriennummer: ;8075262
    Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei: DRV\5G0-907-044.clb
       Teilenummer SW: 5G0 907 044 CJ    HW: 5G0 907 044 CJ
       Bauteil: Climatronic   H04 1801
       Revision: 00001K10
       Codierung: 1202010420241001111550020010182A
       ASAM Datensatz: EV_ACClimaBHBVW37X 006145
       ROD: EV_ACClimaBHBVW37X_004_VW48.rod
       VCID: 71BE273EB127AABFD27-8024
       Steuergerät für Frischluftgebläse (vorn):
       Geber für Kältemitteldruck und Kältemitteltemperatur:
       Sensor für Luftgüte:
       Geber für Luftfeuchtigkeit: außen:
    Adresse 09: Zentralelektrik (J519)       Labeldatei: DRV\5Q0-937-08X-V2.clb
       Teilenummer SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Bauteil: BCM PQ37BOSCH 032 0223
       Revision: --------    Seriennummer: 8658210417022E
       Betriebsnr.: WSC 00028 028 00037
       ASAM Datensatz: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017.rod
       VCID: 015E77FE8187BA3F227-8054
       Steuergerät für Wischermotor:
       Subsystem 1 - Teilenummer SW: 3G1 955 119 A    HW: 3G1 955 119   Labeldatei: DRV\5QX-955-119-V1.CLB
       Bauteil: WWS    170401  042 0607
       Seriennummer:         170419152012
       Codierung: 0E4DDD
       Sensor für Regen- und Lichterkennung:
       Subsystem 2 - Teilenummer SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labeldatei: DRV\5Q0-955-547.CLB
       Bauteil: RLHS  042 0105
       Seriennummer: S9Y17M05D03H00M31S25
       Codierung: 00A8EE
       Lichtschalter:
       Subsystem 3 - Teilenummer SW: 3G0 941 633 H    HW: 3G0 941 633 H
       Bauteil: E1 - LDS MQB  H01 0032
       Seriennummer: 15 03 2017  10000903
       Steuergerät für Dachelektronik:
       Subsystem 4 - Teilenummer SW: 3G0 947 105 C    HW: 3G0 947 105 C
       Bauteil: J528 Dachelek  H08 0008
       Seriennummer: 17050400010188C
       Codierung: F38380
       Geber für Luftfeuchtigkeit: innen:
    1 Fehler gefunden:
    534549 - Datenbus fehlende Botschaft
              U1121 00 [008] - -
                        Fehlerpriorität: 6
                        Fehlerhäufigkeit: 3
                        Verlernzähler: 157
                        Kilometerstand: 8854 km
                        Datum: 2017.08.03
                        Zeit: 18:37:32
    Adresse 10: Einparkhilfe 2 (J791)       Labeldatei: DRV\5Q0-919-298.clb
       Teilenummer SW: 5QA 919 298 B    HW: 5QA 919 298 A
       Bauteil: PLA 3.0 12KH07 0038
       Seriennummer: 000308417617126
       Codierung: 0271167151
       ASAM Datensatz: EV_EPHVA2CAU3700000 009032
       ROD: EV_EPHVA2CAU3700000_009.rod
       VCID: 4FFA81C607539C4FE43-801A
    Adresse 13: Distanzregelung (J428)       Labeldatei: 3Q0-907-572.clb
       Teilenummer SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
       Bauteil: ACC BOSCH MQB H04 0195
       Codierung: 320467DB51FFC428949C8045
       ASAM Datensatz: EV_ACCBOSCHVW48X 001009
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3536D32E85CFC69FCEF-8060
    Adresse 15: Airbag (J234)       Labeldatei: DRV\5Q0-959-655.clb
       Teilenummer SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
       Bauteil: Airbag VW21   004 0306
       Revision: --------    Seriennummer: 003RAP7PBKYX
       Codierung: 88CCC000000000005C5400CF000800000065
       Betriebsnr.: WSC 00028 028 00006
       ASAM Datensatz: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0C4056CAB6C5E757411-8058
       Gurtstraffer links:
       Subsystem 1 - Teilenummer SW: 4M0 980 945 A    HW: 4M0 980 945 A
       Bauteil: BeltPretRevFL  106 1032
       Seriennummer: 3G1857705G0101R01281
       Codierung: 80000D
       Gurtstraffer rechts:
       Subsystem 2 - Teilenummer SW: 4M0 980 946 A    HW: 4M0 980 946 A
       Bauteil: BeltPretRevFR  106 1032
       Seriennummer: 3G1857706G0115R00923
       Codierung: 80000D
       Subsystem 3 - Teilenummer SW: -----------    HW: 454 001 704 17
       Bauteil: SideSensor_Df  008 0887
       Seriennummer: 3570000000030090C321
       Codierung: 2D2D2D
       Subsystem 4 - Teilenummer SW: -----------    HW: 454 002 504 17
       Bauteil: SideSensor_Pf  008 0887
       Seriennummer: 35800000000C5869732P
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Fahrerseite:
       Subsystem 5 - Teilenummer SW: -----------    HW: 454 800 804 17
       Bauteil: SideSensor_Dr  301 0148
       Seriennummer: 3510059E9AE0F000000%
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Beifahrerseite:
       Subsystem 6 - Teilenummer SW: -----------    HW: 454 800 704 17
       Bauteil: SideSensor_Pr  301 0148
       Seriennummer: 35200B147890F000000M
       Codierung: 2D2D2D
       Subsystem 7 - Teilenummer SW: -----------    HW: 454 801 104 17
       Bauteil: FrontSensor_D  304 0149
       Seriennummer: 355006E8E800E000000Y
       Codierung: 2D2D2D
    Adresse 16: Lenkradelektronik (J524)       Labeldatei: DRV\5Q0-953-549.clb
       Teilenummer SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
       Bauteil: Lenks.Modul   075 0235
       Revision: FF033033    Seriennummer: 20170502200554
       Codierung: 0C10
       ASAM Datensatz: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 7EA40C02F079C5C75F5-802A
    Adresse 17: Schalttafeleinsatz (J285)       Labeldatei: DRV\5G0-920-XXX-17.clb
       Teilenummer SW: 3G0 920 751 B    HW: 3G0 920 751 B
       Bauteil: KOMBI         304 8311
       Codierung: 07A509186F8C000801887F0B1001000000000000
       Betriebsnr.: WSC 12345 123 12345
       ASAM Datensatz: EV_DashBoardVDDMQBAB 009051
    Adresse 19: Diagnoseinterface (J533)       Labeldatei: Keine
       Teilenummer SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
       Bauteil: GW MQB High   515 5286
       Seriennummer: 02051710801153
       Codierung: 030300345F087300FB00025E1C0F00010001070000000000000000000000
       ASAM Datensatz: EV_GatewNF 013020
       ROD: EV_GatewConti_013.rod
       VCID: 2F3AE1466793FC4F843-807A
       Generator:
       Steuergerät für Multifunktionslenkrad:
       Subsystem 2 - Teilenummer SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labeldatei: DRV\3C8-959-537.CLB
       Bauteil: E221__MFL-DC1  H17 0040
       Seriennummer: 46170001178840107175
       Codierung: 2DFFFF
       Steuergerät für Batterieüberwachung:
       Subsystem 3 - Teilenummer SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
       Bauteil: J367-BDMHella  H10 9070
       Seriennummer: 4457453804
       Analoguhr:
       Subsystem 4 - Teilenummer SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Bauteil: Analoguhr  209 2002
    3 Fehlercodes gefunden:
    131668 - Steuergerät für Leuchtweitenregelung
              U101E 00 [009] - keine Kommunikation
                        Fehlerpriorität: 2
                        Fehlerhäufigkeit: 2
                        Verlernzähler: 117
                        Kilometerstand: 9212 km
                        Datum: 2017.08.06
                        Zeit: 14:03:41
                        Versorgungsspannung Klemme 30: 12.2 V
                        Klemme 15: ein
    131734 - nicht definiertes Steuergerät
              U1126 00 [009] - keine Kommunikation
                        Fehlerpriorität: 2
                        Fehlerhäufigkeit: 1
                        Verlernzähler: 117
                        Datum: 2017.08.06
                        Zeit: 14:31:49
                        Klemme 15: ein
    131735 - nicht definiertes Steuergerät
                        Fehlerpriorität: 2
                        Fehlerhäufigkeit: 1
                        Verlernzähler: 117
                        Datum: 2017.08.06
                        Zeit: 14:31:49
                        Klemme 15: ein
    Adresse 2B: Lenksäulenverrieg. (J764)       Labeldatei: DRV\5Q0-905-861.clb
       Teilenummer SW: 3Q0 905 861     HW: 3Q0 905 861
       Bauteil: ELV-MQBB      H05 0032
       Seriennummer: 17000104152012
       Codierung: 0800000000000000
       ASAM Datensatz: EV_ELVMarquMQBB 001007
       ROD: EV_ELVMarquMQBB.rod
    Adresse 3C: Spurwechsel (J769)       Labeldatei: Keine
       Teilenummer SW: 3Q0 907 566 C    HW: 3Q0 907 566
       Bauteil: MRR1Rear      H16 0310
       Revision: --------
       Codierung: 14C002
       ASAM Datensatz: EV_RearRadarS1BoschVW48X 001002
       VCID: 3828DA1A92DD3BF7D59-806C
    Adresse 42: Türelektr. Fahrer (J386)       Labeldatei: 5QX-959-X93-42.clb
       Teilenummer SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
       Bauteil: TSG FS        010 0032
       Seriennummer: 0000254916345
       Codierung: 003F1B20D000028000001000
       ASAM Datensatz: EV_DCUDriveSideEWMAXCONT 006001
       VCID: 47CAA9E6EF23440FAC3-8012
    Adresse 44: Lenkhilfe (J500)       Labeldatei: DRV\5Q0-909-143.clb
       Teilenummer SW: 5Q0 909 143 P    HW: 5Q0 909 143 E
       Bauteil: MQB_PP_APA    204 2051
       Revision: 00000000    Seriennummer: 0001628639
       Codierung: 01010011004001
       ASAM Datensatz: EV_SteerAssisVWBSMQBA 009129
       ROD: EV_SteerAssisVWBSMQBA_007.rod
       VCID: 40D8B2FACA0D73376D9-8014
    Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei: 5QX-959-X92-52.clb
       Teilenummer SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
       Bauteil: TSG BFS       010 0032
       Seriennummer: 0000253563962
       Codierung: 003F1120DE00028000001000
       ASAM Datensatz: EV_DCUPasseSideEWMAXCONT 006001
       VCID: 46D4A4E2E8295D07575-8012
    Adresse 55: Leuchtweitenreg.
    nicht erreichbar
    Adresse 5F: Informationselek. I (J794)       Labeldatei: 5G0-035-MIB-HGH2.clb
       Teilenummer SW: 3G0 035 020 E    HW: 3G0 035 020
       Bauteil: MU-H-ND-EU    H51 0814
       Seriennummer: A682D0HS023688
       Codierung: 02840201FF00000051110101008808031F0100C4012001009F
       ASAM Datensatz: EV_MUHig4CGen2HBAS 001001
       VCID: 196E3F9E091702FFCA7-804C
       Anzeige- und Bedienungseinheit 1 für Informationselektronik:
       Subsystem 1 - Teilenummer SW: 5G0 919 606     HW: 5G0 919 606
       Bauteil: ABT_High  H63 0032
       Seriennummer: VWZ8Z9TKL08GE5
       Datenträger:
       Subsystem 2 - Teilenummer SW: V03 959 800 QR    HW: -----------
       Bauteil: ECE 2017/2018  --- 0161
       Seriennummer: --------------------
       Compact Disc Datenbank:
       Subsystem 3 - Teilenummer SW: V03 959 800 EG    HW: -----------
       Bauteil: Gracenote2---  --- 1013
    1 Fehler gefunden:
    5688 - Bedienungseinheit für Multimediasystem
              B13C9 F2 [008] - Ein-/Ausschalter
                        Fehlerpriorität: 6
                        Fehlerhäufigkeit: 1
                        Verlernzähler: 153
                        Kilometerstand: 8266 km
                        Datum: 2017.07.27
                        Zeit: 14:22:28
                        Spannung Klemme 30: 13.5 V
    Adresse 69: Anhänger (J345)       Labeldatei: DRV\5Q0-907-383.clb
       Teilenummer SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Bauteil: Anhaenger     H21 0204
       Revision: 8A001003    Seriennummer: 0438155937
       Codierung: 0100000202000000
       ASAM Datensatz: EV_TrailFunctGener2Hella 001008
       VCID: 3B22C516A3EB10EF38B-806E
    Adresse 6C: Rückfahrkamera (J772)       Labeldatei: DRV\5Q0-980-556.clb
       Teilenummer SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
       Bauteil: RVC Compact   H12 0231
       Codierung: 0184020163002017000040
       ASAM Datensatz: EV_CamSysRVRVCPANAMQBAB 006009
       ROD: EV_CamSysRVRVCPANAMQBAB_004.rod
       VCID: 392EDF1EA9D722FF2A7-806C
    Adresse 6D: Heckklappe (J605)       Labeldatei: DRV\5Q0-959-107.clb
       Teilenummer SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Bauteil: HDSG-Modul    H12 0261
       Revision: --------    Seriennummer: 31301161100000
       Codierung: 02A8
       Betriebsnr.: WSC 00028 028 00207
       ASAM Datensatz: EV_DeckLidCONTIAU736 001014
       VCID: 42DCB8F2C40161277BD-8016
    Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei: DRV\3Q0-980-65X-A5.clb
       Teilenummer SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Bauteil: MQB_B_MFK     H06 0231
       Seriennummer: 26041712K21865
       Codierung: 000408020000040100262347C050A90094000E200020
       ASAM Datensatz: EV_MFKBoschMQBB 001001
       ROD: EV_MFKBoschMQBB.rod
    Adresse BB: Türelektronik hinten links (J388)       Labeldatei: Keine
       Teilenummer SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Bauteil: TSG HFS       011 0032
       Seriennummer: 0000253659589
       Codierung: 000E11200100028000001000
       ASAM Datensatz: EV_DCURearDriveMAXCONT 006001
       VCID: 49CEAFDEF937B27FBA7-801C
    Adresse BC: Türelektronik hinten rechts (J389)       Labeldatei: Keine
       Bauteil: TSG HBFS      011 0032
       Seriennummer: 0000253657334
       ASAM Datensatz: EV_DCURearPasseMAXCONT 006001
    Adresse CF: Spurwechselassistent 2 (J770)       Labeldatei: Keine
       Teilenummer SW: 3Q0 907 590 C    HW: 3Q0 907 590
       Revision: --------
       Codierung: 14C002
       ASAM Datensatz: EV_RearRadarS2BoschVW48X 001002
    Adresse D6: Lichtsteuerung links 2 (A31)       Labeldatei: 7PP-941-572.clb
       Teilenummer SW: 7PP 941 572 AB    HW: 7PP 941 572 A
       Bauteil: LED1L         H09 0003
       ASAM Datensatz: EV_LEDModLeftMELCOAU736 001004
       ROD: n.v.
       VCID: 167434A2F8092D87E75-8042
    Keine ASAM Daten verfügbar: "EV_LEDModLeftMELCOAU736" (VW48)
    1 Fehler gefunden:
    0774 - ROD - Unbekannter Fehlercode
              - 00 [008]
                        Fehlerpriorität: 4
                        Fehlerhäufigkeit: 4
                        Verlernzähler: 124
                        Kilometerstand: 4913 km
                        Datum: 2017.07.10
                        Zeit: 05:48:42
    Adresse D7: Lichtsteuerung rechts 2 (A27)       Labeldatei: 7PP-941-572.clb
       Bauteil: LED1R         H09 0003
       ASAM Datensatz: EV_LEDModRightMELCOAU736 001004
       ROD: n.v.
    Keine ASAM Daten verfügbar: "EV_LEDModRightMELCOAU736" (VW48)
    1 Fehler gefunden:
              - 00 [008]
                        Fehlerpriorität: 4
                        Fehlerhäufigkeit: 4
                        Verlernzähler: 124
                        Datum: 2017.07.10
                        Zeit: 05:48:42
    Ende--------(Dauer: 02:15, Batt.-Spannung Start/Ende: 12.0V/12.0V)---------
  12. #29
    Your English is fine.
    But for posting data in this forum, we would appreciate it if you would use the English version of VCDS. You can download it here, and you can have it installed in parallel with the German version you are currently using.
    Thanks!
  13. Likes murmeltier liked this post
  14. #30
    Dec 2015
    Switzerland
    Of course, sorry! AutoScan with the English version of VCDS:
    Tuesday,08,August,2017,10:55:29:60163
    VCDS Version: 17.8.0.1  HEX-V2 CB: 0.4401.4
    VIN: WVWZZZ3CZHP030366   License Plate: ENGLISCH
    Mileage: 9601km-5965mi   Repair Order:
    Chassis Type: 3C-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 4B 52 5F 69
    VIN: WVWZZZ3CZHP030366   Mileage: 9601km-5965miles
    D6-Light Ctrl Left 2 -- Status: Malfunction 0010
    D7-Light Ctrl Right 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
       Component: R4 2.0l TDI   H25 2011
       Revision: B4H25---
       Coding: 011D0032047405083000
       Shop #: WSC 00028 028 00038
       ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
       ROD: EV_ECM20TDI01104L906026FN_004.rod
       VCID: 7BA20516E36BD0EF0E8-802E
       Part No SW: 0D9 300 042 N    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5004
       Revision: 06454104    Serial number: TFK01703160056
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 24101E6A3E554F171F2-8070
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 61177000000165
       Coding: 0FEC6A8F34230B6C477A060640C949F0562CD0E2600292753862F078C2A9420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 79AE1F1EE957E2FF1C4-802C
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 151
                        Mileage: 8501 km
                        Date: 2017.07.28
                        Time: 13:11:21
                        Extended Freeze Frames:
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0440841347
       Coding: 0F2020070F
       VCID: 3C20C60AA6E517D7472-8068
       Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
       Component: GEB.F.Heckoef  H17 0812
       Serial number: ;8075262
       Part No SW: 5G0 907 044 CJ    HW: 5G0 907 044 CJ
       Revision: 00001K10
       Coding: 1202010420241001111550020010182A
       ROD: EV_ACClimaBHBVW37X_006_VW27.rod
       VCID: 71BE273EB127AABFA44-8024
       Air quality sensor:
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0223
       Revision: --------    Serial number: 8658210417022E
       Shop #: WSC 00028 028 00037
       ROD: EV_BCMBOSCH_017_VW27.rod
       VCID: 015E77FE8187BA3F544-8054
       Component: WWS    170401  042 0607
       Serial number:         170419152012
       Component: RLHS  042 0105
       Serial number: S9Y17M05D03H00M31S25
       Coding: 00A8EE
       Serial number: 15 03 2017  10000903
       Ceiling Light Module:
       Subsystem 4 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
       Component: J528 Dachelek  H08 0008
       Serial number: 17050400010188C
       Coding: F38380
       Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0038
       Serial number: 000308417617126
       Coding: 0271167151
       ASAM Dataset: EV_EPHVA2CAU3700000 009032
       VCID: 4FFA81C607539C4F920-801A
       Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
       Component: ACC BOSCH MQB H04 0195
       Coding: 320467DB51FFC428949C8045
       VCID: 3536D32E85CFC69FB8C-8060
       Part No SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
       Component: Airbag VW21   004 0306
       Revision: --------    Serial number: 003RAP7PBKYX
       Coding: 88CCC000000000005C5400CF000800000065
       Shop #: WSC 00028 028 00006
       ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X_VW27.rod
       VCID: 0C4056CAB6C5E757372-8058
       Belt Pretensioner left:
       Serial number: 3G1857705G0101R01281
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 3G1857706G0115R00923
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 001 704 17
       Serial number: 3570000000030090C321
       Subsystem 4 - Part No SW: -----------    HW: 454 002 504 17
       Serial number: 35800000000C5869732P
       Subsystem 5 - Part No SW: -----------    HW: 454 800 804 17
       Serial number: 3510059E9AE0F000000%
       Subsystem 6 - Part No SW: -----------    HW: 454 800 704 17
       Serial number: 35200B147890F000000M
       Subsystem 7 - Part No SW: -----------    HW: 454 801 104 17
       Serial number: 355006E8E800E000000Y
       Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20170502200554
       Coding: 0C10
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 7EA40C02F079C5C7296-802A
       Part No SW: 3G0 920 751 B    HW: 3G0 920 751 B
       Component: KOMBI         304 8311
       Coding: 07A509186F8C000801887F0B1001000000000000
       Shop #: WSC 12345 123 12345
       Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
       Component: GW MQB High   515 5286
       Serial number: 02051710801153
       Coding: 030300345F087300FB00025E1C0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F3AE1466793FC4FF20-807A
       Serial number: 46170001178840107175
       Coding: 2DFFFF
       Serial number: 4457453804
       Analog clock:
    131668 - Headlight Range Control Module
              U101E 00 [008] - No Communication
                        Reset counter: 157
                        Mileage: 9212 km
                        Date: 2017.08.06
                        Time: 14:03:41
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: On
    131734 - No Communications with Undefined Control Module
              U1126 00 [008] - -
                        Reset counter: 157
                        Mileage: 9212 km
                        Date: 2017.08.06
                        Time: 14:31:49
                        Terminal 15: On
    131735 - No Communications with Undefined Control Module
              U1126 00 [008] - -
                        Reset counter: 157
                        Mileage: 9212 km
                        Date: 2017.08.06
                        Time: 14:31:49
                        Terminal 15: On
       Serial number: 17000104152012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
       Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0310
       Revision: --------
       Coding: 14C002
       VCID: 3828DA1A92DD3BF7A3A-806C
       Component: TSG FS        010 0032
       Serial number: 0000254916345
       Coding: 003F1B20D000028000001000
       VCID: 47CAA9E6EF23440FDA0-8012
       Part No SW: 5Q0 909 143 P    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2051
       Revision: 00000000    Serial number: 0001628639
       Coding: 01010011004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
       VCID: 40D8B2FACA0D73371BA-8014
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338     HW: 3Q0 907 338
       Component: FCM MQB Low   001 0285
       Serial number: 24041710521319
       Coding: 000000060100034A00000F01020000000000000000000000000000000000
       ROD: EV_MultiModulContiVW48X_VW27.rod
       VCID: 72BC2832B42191A75DE-8026
       Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo links  H02 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo rechts  H02 0003
       Coding: E02400
       Component: TSG BFS       010 0032
       Serial number: 0000253563962
       Coding: 003F1120DE00028000001000
       VCID: 46D4A4E2E8295D07216-8012
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 020 E    HW: 3G0 035 020
       Component: MU-H-ND-EU    H51 0814
       Serial number: A682D0HS023688
       Coding: 02840201FF00000051110101008808031F0100C4012001009F
       VCID: 196E3F9E091702FFBC4-804C
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9TKL08GE5
       Subsystem 2 - Part No SW: V03 959 800 QR    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Component: Gracenote2---  --- 1013
    5688 - Control Head for Mulimedia System
              B13C9 F2 [008] - On/Off Switch
                        Reset counter: 153
                        Mileage: 8266 km
                        Date: 2017.07.27
                        Time: 14:22:28
                        Voltage terminal 30: 13.5 V
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0438155937
       Coding: 0100000202000000
       VCID: 3B22C516A3EB10EF4E8-806E
       Coding: 0184020163002017000040
       VCID: 392EDF1EA9D722FF5C4-806C
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 31301161100000
       Coding: 02A8
       Shop #: WSC 00028 028 00207
       VCID: 42DCB8F2C40161270DE-8016
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 26041712K21865
       Coding: 000408020000040100262347C050A90094000E200020
       ROD: EV_MFKBoschMQBB_VW36.rod
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       011 0032
       Serial number: 0000253659589
       Coding: 000E11200100028000001000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 49CEAFDEF937B27FCC4-801C
       Component: TSG HBFS      011 0032
       Serial number: 0000253657334
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
       Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
       Component: LED1L         H09 0003
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
       VCID: 167434A2F8092D87916-8042
    0774 - Light Bulb for Low Beam
              C1198 29 [008] - Signal Implausible
                        Reset counter: 124
                        Mileage: 4913 km
                        Date: 2017.07.10
                        Time: 05:48:42
       Component: LED1R         H09 0003
                        Reset counter: 124
                        Mileage: 4913 km
                        Date: 2017.07.10
                        Time: 05:48:42
    End----------(Elapsed Time: 02:24, VBatt start/end: 12.6V/12.6V)-----------
    Any ideas what I have to do to activate the Dynamic Light Assist, even without STG 55?
    Thanks!
    Btw. is there an option to add admaps to the post?
  15. Likes Uwe liked this post
