Hey Guys,
Just started making changes in my Passat b8 2018. Comes with from factory, but not with lane assist, traffic jam and signal recognition.
Following some tutorials I got succeed activating the lane assist.
Does anybody tryed activating the Traffic Jam? There is any tutorial for Passat?
Another question. I activated the traffic signal recognition, but here, in Brazil, the system doesnt works properly. Sometimes it reads a signal, but less than 5% of them. There´s any configuration or region choice do gets it better?
I´m still interested activating Vídeo in Motion and Digital TV. Anyone got it? know if the discorevy pro 3gp (9´one) has digital tv inside or need another hardware?
That´s my scan:
Saturday,27,January,2018,21:44:47:01775
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWMV83C9JE047295 License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 42 44 4B 52 5F
6C 6D A5 BB BC CA D6 D7
VIN: WVWMV83C9JE047295 Mileage: 4246km-2638miles
4B-Multifunc. Module -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 259 HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 091D00122464050B3000
Shop #: WSC 05311 115 00319
ASAM Dataset: EV_ECM20TFS0203G0906259 001007
ROD: EV_ECM20TFS_VW48.rod
VCID: 698CB5F1A9F98CBFDFB-803C
17176 - Databus
Part No SW: 0D9 300 043 F HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5202
Revision: 06454104 Serial number: TFK01706282200
Shop #: WSC 05311 115 00080
ROD: EV_TCMDQ250021.rod
VCID: 1D64D1212D31A01F633-8048
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 62097000001273
Coding: 0EEC6A8F342423734779060940C84970562CC4E2600292753842F0B8C209420000000012121212B835351919323200
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_036.rod
VCID: 79ACE5B1D9593C3F2FB-802C
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0448512768
Coding: 1F20000723
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E2636AD80F7DB075A9-806A
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8082872
Part No SW: 5G0 907 044 DP HW: 5G0 907 044 DP
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1102001420010001111550000010182A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 78AAE0B5E2532537505-802C
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 8658190717000C
ROD: EV_BCMBOSCH_018.rod
VCID: 06569E4D98A743C7529-8052
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170630 042 0607
Serial number: 170720040817
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S9Y17M08D12H01M15S05
Coding: 00A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 20 04 2017 10000842
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1717013WM
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000038729518
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
U90D757 F7 [008] - No Release by Immobilizer
527872 - Transport Mode Active
U1105 00 [008] - -
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617214
Coding: 0471151811
ROD: EV_EPHVA18AU3700000_009_VW48.rod
VCID: 4BC06F79C3457EAFCD7-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 320067C259FFC428949C8045
Shop #: WSC 05311 115 00414
ROD: EV_ACCBOSCHVW48X.rod
VCID: 35342981B5C1185F8B3-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 13071741350394
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 382A20B5A2D3E537905-806C
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W6PF0Q87-
Coding: 88CCC000000000005C5400CF000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 084A907592B355B7205-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G1857705G0193R01259
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706G0193R01068
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 002 707 17
Serial number: 35700000000A502CA72K
Subsystem 4 - Part No SW: ----------- HW: 454 002 707 17
Serial number: 358000000003703CA72H
Subsystem 5 - Part No SW: ----------- HW: 454 802 607 17
Component: SideSensor_Dr 301 0148
Serial number: 3510047ECDC10000000T
Subsystem 6 - Part No SW: ----------- HW: 454 802 507 17
Component: SideSensor_Pr 301 0148
Serial number: 35200B315D4100000005
Subsystem 7 - Part No SW: ----------- HW: 454 802 707 17
Component: FrontSensor_D 304 0149
Serial number: 35500BDEC9010000000U
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AF HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170801100898
Coding: 0010
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 76B6EE8DE8475347429-8022
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 406 3193
Coding: 07A401187F8C000801886B0B1001000080000000
VCID: 290CF5F169794CBF1FB-807C
16777008 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_SWA_0x1A keine Kommunikation]
Reset counter: 132
Mileage: 3803 km
Date: 2018.01.21
Time: 16:09:17
16777010 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_LDW_0x19 keine Kommunikation]
Reset counter: 171
Mileage: 3795 km
Date: 2018.01.20
Time: 20:25:23
16776969 - Databus
[LDW_02 keine Kommunikation]
Reset counter: 171
Mileage: 3795 km
Date: 2018.01.20
Time: 20:22:51
16776982 - Databus
[SWA_01 keine Kommunikation]
Reset counter: 132
Mileage: 3803 km
Date: 2018.01.21
Time: 16:10:52
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 23071710803027
Coding: 030300047F085900FB00025E9C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW48.rod
VCID: 33301799BBB5066FA57-8066
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 39170002047840047297
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 7588600000170728031B
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000198431011
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BCDD918129747F97B-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H05 0022
Serial number: Y0006QGK25787
Coding: 001000020000050081C280808080000000008181000000F400
ROD: EV_SeatMemorDriveSide_002_VW48.rod
VCID: 3A2E3ABD9CDFF727661-806E
Component: TSG FS 020 0041
Serial number: 040717EG40809A
Coding: 003F1A20D200028000000000
VCID: 43D04759EB15B6EF357-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001892199
Coding: 01000011004001
Shop #: WSC 00015 115 00319
ROD: EV_SteerAssisVWBSMQBA_009_VW48.rod
VCID: 40DA4855FA03ADF7285-8014
3158336 - Databus
[Ausfall der CAN-Botschaft "HCA_01" des Frontsensorik-SG (über GW)]
Reset counter: 171
Mileage: 3795 km
Date: 2018.01.20
Time: 21:25:39
valid
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 02081710522509
Coding: 000000060100034A06004F01020000000000000000000000000000000000
Shop #: WSC 05311 000 08193
VCID: 72BED29D842F4F676E1-8026
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
0033 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Reset counter: 12
Mileage: 345 km
Date: 2017.11.11
Time: 12:02:44
Component: TSG BFS 020 0041
Serial number: 070717EG528109
Coding: 003F1020DE00028200000000
VCID: 42DE425DF40FBFE73E1-8016
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 045 A HW: 5NA 035 045
Component: MU-H-N-RW H54 1121
Serial number: A849G0HS006223
Coding: 02840103FF00000051220001001828001F0100E4012004009F
ROD: EV_MUHig4CGen2HBAS_VW48.rod
VCID: 36362E8DA8C71347829-8062
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT1945457
Subsystem 2 - Part No SW: V03 959 801 EC HW: -----------
Component: ROW 2017 --- 0062
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 4012
7193 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 171
Mileage: 3795 km
Date: 2018.01.20
Time: 21:04:02
Voltage terminal 30: 12.1 V
BAP-BAP_Function_ID: 02
7201 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 188
Mileage: 4204 km
Date: 2018.01.27
Time: 13:29:15
Voltage terminal 30: 12.5 V
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0184010162002017000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 392C25B199D9FC3F6FB-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 K HW: 5Q0 959 107 H
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31384133100000
Coding: 0108
ROD: EV_DeckLidCONTIAU736_VW27.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 27071711P10448
Coding: 0004080100000101002223448156A90090000E300140
ROD: EV_MFKBoschMQBB_VW27.rod
VCID: 3C223CA596EBC91774D-8068
0659 - Steering
U4E6652 F2 [008] - Lane-Holding Assistance Not Coded
[HC_interface_at_the_steering_not_activated]
Reset counter: 169
Mileage: 3795 km
Date: 2018.01.20
Time: 20:26:25
Control Module temperature: 46 °C
Outside air temperature: 24.5 °C
Vehicle speed: 0.00 km/h
System run time: 2448.2 s
Voltage terminal 15: 11.9 V
mid: 02 A6
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 190617EFJ18296
Coding: 000E10200100028000000000
VCID: 45D45941E52188DF1B3-8010
Component: TSG HBFS 020 0041
Serial number: 190617EFJ1613A
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 K HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 608000748101
ROD: EV_SunRoofCONTIAU736.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
VCID: 1676CE0DC807F347A29-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
End----------(Elapsed Time: 02:34, VBatt start/end: 12.3V/12.3V)-----------
