Page 10 of 10 FirstFirst ... 8910
Results 91 to 95 of 95
Thread: VW Passat B8 2017 Tweaks
  1. #91
    Dec 2016
    DE
    Afaik you can simply switch them. Recoding is necessary but that's it. Part number is "5Q0 955 547" without an index.
  2. #92
    Verified VCDS User @DRI@N's Avatar
    Nov 2017
    Romania
    @TBAx ,
    Hy,
    I found HUMIDITY SENSOR but with code 5K7955547 .
    Is good this code for PASSAT B8 ?
    Thanks .
  3. #93
    Dec 2016
    DE
    The 5K7 module comes from an Up. Since the platform is somewhat different from the MQB, which the Passat is based on, I somewhat doubt this one will work correctly.
  4. #94
    Jan 2020
    BR
    gabriel:I hope that I'm not stealing my knowledeable colleague's thunder! I think that my contribution to your question is consistent with both Uwe's and hazdez16's replies, but it consolidates the adaptation channels into a single list.
    After you select the desired settings for these channels, you will need to complete an in-car procedure HERE
    I tried all the procedures but only the beep happens! No horn!
    Even try to select only one of the following at a time and both
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn
    Still no horn!
    Any suggestions?
  5. #95
    ^^^^ I developed the tweak for those vehicles that weren't fitted with a siren. It sounds like your car is fitted with an anti-theft system. AFAIK, the tweak can't be used for changing the acknowledgement from a siren to the car horn (or vice-a-versa)
