Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 96
Thread: VW Passat B8 2017 Tweaks
  1. #71
    Sep 2018
    Quote Originally Posted by zak69 View Post
    Hi, Passat B8 and i want my rear lights on all the time.
    But don't know where to do that, no coding setting for that and adaption i found D16 and D17 which are. i guess, for rear lights but changing those values isn't the right place to do that?
    I haven't tried this on the Passat B8 but I disabled this option on the finance's Polo 6R. I was able to achieve it by changing the long coding on the central electrics unit which was named something along the lines of "Parking Lights ON Terminal 15" in VCDS. Perhaps worth investigating in VCDS?
  2. #72
    Apr 2018
    Quote Originally Posted by PuJuM View Post
    Thanks for the hint, i will check that out. First i checked all the long coding options but can't remember was that there.
  3. #73
    Aug 2016
    Quote Originally Posted by murmeltier View Post
    Hey guys
    In the meantime I managed to activate the Dynamic Light Assist! :-)
    I published a free instruction on the internet:
    https://www.vcdsschweiz.ch/en/activa...ht-assist-dla/
    (this is for MY 2017 and higher, but there is also one for the older MY).
    Thanks everybody who helped me by finding the solution... :-)
    Regards
    Your link doesn’t work. Can you please post how you got this working?
    Thank You.
  4. #74
    Apr 2018
    No such thing found, anybody knows where to apply that function?
  5. #75
    Apr 2018
    Anybody can help with that light settings??
  6. #76
    Jun 2017
    Activate this channel in Unit 09:
    IDE06864-ENG116593-Tagfahrlicht-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
    It is the easiest way. DRL activates rear lights, plate lights and instrument lights...
    If you do not want this but only the rear lights, report back.
  7. Likes Uwe liked this post
  8. #77
    Apr 2018
    Thanks a lot, i will try that!
  9. #78
    Verified VCDS User @DRI@N's Avatar
    Nov 2017
    Romania
    Hy guys,
    I want to ask you if anybody of you know how to set LIGHT SENSOR SENSITIVITY with VCDS to stop starting the DIPPER HEADLIGHT BEAM in the middle of the day .
    Thanks .
  10. #79
    United States
    Quote Originally Posted by @DRI@N View Post
    Hy guys,
    Thanks .
    I'd look at the IDE08786 channels. This one in particular may be what you are looking for:
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal
  11. Likes Uwe liked this post
  12. #80
    United States
    P.S. In ref to the horn confirmation question asked by gabriel.taran (way back on 06-01-2018) .. this may or may not be relevant but I recently corrected an annoying problem on my 2018 Golf Alltrack. As the guys mentioned at the time you need the function enabled in the BCM in the first place in addition to any CAR menus however this channel was preventing a confirmation on the 1st lock in my 2018:
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl
    To be clear I had to lock it 2 times (twice) to get a locking confirmation beep/horn. It was like that from the factory.
    My 2017 Golf Alltrack, with older BCM which supported coding, had a normal confirmation on the 1st lock from the factory. That channel did NOT exist in the 2017 BCM but there were similar ones with "zweitem" (second) in the description.
  13. Likes Uwe liked this post
