Results 1 to 7 of 7
Thread: Hello from Iowa! First Scan - Fault Code P0113 - Assistance Please
    Jan 2017
    Iowa, USA
    Hello, It was really cold here a couple of weeks ago and the car threw CEL with a flashing glow plug light. It's now a permanent fixture on the dash and the car has no power. Anyone that could help, guide me to the location of the suspect part or troubleshooting of the issue? THanks in advance.
    2013 Passat TDI NMS
    Chris
    Wednesday,11,January,2017,20:29:26:09958
    VCDS Version: 17.1.0.0  HEX-V2 CB: 0.4334.4
    Data version: 20170106 DS267.0
    VIN: 1VWBN7A37DC147817   License Plate:
    Mileage: 132780km-82505mi   Repair Order:
    Chassis Type: A3 (7N0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
    VIN: 1VWBN7A37DC147817   Mileage: 132780km-82505miles
    Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
       Part No SW: 03L 906 012 DD    HW: 03L 907 309 S
       Component: R4 2,0L EDC   H24 8400
       Revision: 71H24---    Serial number:
       Coding: 00190012042400000000
       Shop #: WSC 02394 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906012DD 004008
       ROD: EV_ECM20TDI01103L906012DD.rod
       VCID: 698CB72F49FB8C2F981-803C
    5282 - Intake Air Temp. Sensor (G42)
              P0113 00 [175] - Signal too High
                        Mileage: 132779 km
                        Date: 2017.01.06
                        Time: 16:51:18
                        Engine speed: 832.00 /min
                        Normed load value: 49.4 %
                        Coolant temperature: 44 C
                        Intake air temperature: -40 C
                        Voltage terminal 30: 14.680 V
                        Exhaust gas temperature sensor 4: 91.8 C
                        Specified value of low pressure exhaust flap: 100.00 %
                        Actual value of low pressure exhaust flap: 99.99 %
                        Low-pressure exhaust flap: offset closed: 0.78 %
                        Low-pressure exhaust flap: status-Bit 0: 0
                        Low-pressure exhaust flap: status-Bit 16: 8
                        Low-pressure exhaust flap: status-Bit 24: 55
                        Low-pressure exhaust flap: status-Bit 8: 66
                        Exhaust flap: actual value: 4299.8 mV
    Readiness: 1 1 0 1 1
       Revision: 00H31001
       Coding: C54BC0F549260001A31303E592200042A71000
       Shop #: WSC 09003 957 00200
       VCID: 7DA4F37F2DF3008F449-8028
    Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
       Part No SW: 561 907 426 C    HW: 561 907 426 C
       Component: AC Manuell    H02 0202
       Revision: 00001K01
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1B60DDE7D327AEBFDAD-804E
       Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
       Component: BCM PQ35 B+   021 0068
       Revision: BH021001
       Coding: 6F200E18902B08D408880001160004480071008650801560648060000C70
       VCID: 43D045870B97B67F72D-8016
                        Reset counter: 43
                        Mileage: 132780 km
                        Date: 2017.01.06
                        Time: 17:05:00
                            Term 15 On
                        Voltage: 14.20 V
    03189 - Bulb for Side Marker Light; Front Right
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 3
                        Mileage: 91225 km
                        Date: 2015.12.16
                        Time: 11:23:38
                            Term 15 On
                        Voltage: 14.20 V
       Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
       Component: AirbagVW10G   014 0851
       Serial number: 003MWM01ULFH
       Coding: 00005033
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 75B4EB5F154358CF0C9-8020
       Serial number: 6940000Y130000U5SU0L
       Coding: 303044
       Serial number: 3572MSME0C161474ZZZS
       Serial number: 3582MSME4B43037BZZZ.
       Serial number: 3516KSME0F695E23ZZZ0
       Serial number: 3526KSME46352B23ZZZQ
       Serial number: 3556LSME090A6B21ZZZX
       Serial number: 3566LSME13087321ZZZK
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010041    Serial number: 20130411300345
       Coding: 008A140000
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 76B6EC53084553D7053-8022
       Component: E221__MFL-YVJ  H07 0022
       Coding: E20000
       Part No SW: 561 920 970 E    HW: 561 920 970 E
       Component: KOMBI         H07 0705
       Coding: 231E01
       VCID: 1C62DEFBD629A987D37-8048
       Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
       Component: J533  Gateway H50 1634
       Revision:   H50       Serial number: 17051303290876
       Coding: 461000
       VCID: 76B6EC5308C553D7053-8022
       Part No SW: 561 919 965     HW: 561 919 965
       Component: Kompass         002 0001
       Revision: 00002000    Serial number: 1829227R4FM006
       VCID: 6390A507A757D67F52D-8036
       Component: IMMO          H07 0705
       VCID: 6A8EC8234CFD873791B-803E
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0006668691
       Coding: 0404F5
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BE09DE793A7EEBF1AD-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630130520151514
       Coding: 800000
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 290    3305
       Revision: 00H22000
       VCID: 37282157434FEADFDE5-8062
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
       Component: EZE_2         H50 1634
       Coding: 00000008
       VCID: 6FB8D937779F621FC65-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0006672956
       Coding: 0404F4
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CE29EFB96A9E987137-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631130513083014
       Coding: 800000
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 17
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
       Component: Radio Prem-8  H05 0008
       Revision: -----09S    Serial number: VWZ4Z7N3464462
       Coding: 0500040004000B
       VCID: 6492A61BAE59D147AB7-8030
                000 -  -
                        Reset counter: 61
                        Mileage: 58070 km
                        Date: 2015.03.16
                        Time: 07:09:44
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007664540338
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A2E38637CDDF7B721B-806E
    End----------(Elapsed Time: 00:54, VBatt start/end: 11.6V/11.9V)-----------
                        Mileage: 132779 km
                        Date: 2017.01.06
                        Time: 16:51:18
       Revision: 00H31001
       Revision: 00001K01
       Coding: 0010001002
       Revision: BH021001
                        Reset counter: 43
                        Mileage: 132780 km
                        Date: 2017.01.06
                        Time: 17:05:00
                            Term 15 On
                        Voltage: 14.20 V
                        Reset counter: 3
                        Mileage: 91225 km
                        Date: 2015.12.16
                        Time: 11:23:38
                            Term 15 On
                        Voltage: 14.20 V
       Coding: 00005033
       Coding: 303044
       Coding: 008A140000
       Coding: E20000
       Coding: 231E01
       Coding: 461000
       Coding: 0404F5
       Slave Driver:
       Coding: 800000
       Revision: 00H22000
       Coding: 00000008
       Coding: 0404F4
       Slave Passenger:
       Coding: 800000
                        Reset counter: 17
                000 -  -
                        Reset counter: 61
                        Mileage: 58070 km
                        Date: 2015.03.16
                        Time: 07:09:44
    End----------(Elapsed Time: 00:53, VBatt start/end: 14.5V/14.6V)-----------
                        Mileage: 132779 km
                        Date: 2017.01.06
                        Time: 16:51:18
       Revision: 00H31001
       Revision: 00001K01
       Coding: 0010001002
       Revision: BH021001
                        Reset counter: 43
                        Mileage: 132780 km
                        Date: 2017.01.06
                        Time: 17:05:00
                            Term 15 On
                        Voltage: 14.20 V
                        Reset counter: 3
                        Mileage: 91225 km
                        Date: 2015.12.16
                        Time: 11:23:38
                            Term 15 On
                        Voltage: 14.20 V
       Coding: 00005033
       Coding: 303044
       Coding: 008A140000
       Coding: E20000
       Coding: 231E01
       Coding: 461000
       Coding: 0404F5
       Slave Driver:
       Coding: 800000
       Revision: 00H22000
       Coding: 00000008
       Coding: 0404F4
       Slave Passenger:
       Coding: 800000
                        Reset counter: 17
                000 -  -
                        Reset counter: 61
                        Mileage: 58070 km
                        Date: 2015.03.16
                        Time: 07:09:44
    End----------(Elapsed Time: 00:52, VBatt start/end: 14.6V/14.6V)-----------
    VCDS Release 17.1.0:  SRI Reset
    Control Module Part Number: 561 920 970 E       Labels:  5K0-920-xxx-17.clb
    Component:KOMBI         H07 0705, Coding:231E01
    Channel        Description                                                     Current val.                                                    New val.
    IDE00342-ESI: Resetting ESI        ESI: Status                                                     Reset                                                           ---
    IDE00510-ESI: distance driven from inspection                                                           ESI: distance driven from inspection                            3900 km                                                         ---
    IDE00511-ESI: time from inspection        ESI: time from inspection                                       56 d                                                            ---
    IDE00515-ESI: oil quality        ESI: oil quality                                                poor oil quality                                                ---
    IDE00517-ESI: soot entry        ESI: soot entry                                                 0 km                                                            ---
    IDE00518-ESI: thermal load        ESI: thermal load                                               0 km                                                            ---
    IDE01153-SIA: maximum value of distance to service                                                      SIA: maximum value of distance to service                       16100 km                                                        ---
    IDE01154-SIA: maximum value of time to service                                                          SIA: maximum value of time to service                           372 d                                                           ---
        FIX: Max. distance until next mileage-related inspection        ---                                                             ---
        FIX: Maximum time until next time-dependent inspection          ---                                                             ---
        FIX: Distance covered since last mileage-dependent inspection    ---                                                             ---
        FIX: Time since last time-dependent inspection                  ---                                                             ---
              P0113 00 [167] - Signal too High
                        Mileage: 132782 km
                        Date: 2017.01.11
                        Time: 20:38:30
                        Engine speed: 845.00 /min
                        Normed load value: 47.5 %
                        Coolant temperature: 36 C
                        Exhaust gas temperature sensor 4: 85.7 C
                        Low-pressure exhaust flap: offset closed: 0.85 %
    Readiness: 0 0 0 1 1
       Revision: 00H31001
       Revision: 00001K01
       Coding: 0010001002
       Revision: BH021001
                        Reset counter: 3
                        Mileage: 132782 km
                        Date: 2017.01.11
                        Time: 20:38:52
                            Term 15 On
                        Voltage: 12.95 V
       Coding: 00005033
       Coding: 303044
       Coding: 008A140000
       Coding: E20000
       Coding: 231E01
       Coding: 461000
       Coding: 0404F5
       Slave Driver:
       Coding: 800000
       Revision: 00H22000
       Coding: 00000008
       Coding: 0404F4
       Slave Passenger:
       Coding: 800000
                000 -  -
                        Reset counter: 3
                        Mileage: 132782 km
                        Date: 2017.01.11
                        Time: 20:38:51
    End----------(Elapsed Time: 00:53, VBatt start/end: 12.9V/12.4V)-----------
    From the Freeze-Frame data... " Intake air temperature: -40 C".. That's usually indicative of an open circuit to that sensor. Check wiring, check resistance of sensor.
    Jan 2017
    Iowa, USA
    Thanks Uwe. I had wondered about that -40C reading also. Might you know where the G42 sensor is located? Or anyone else might know? Thanks again. Chris
    United States
    Hi Chris,
    A 1 day subscription to NAR erWin might be worthwhile if you have wiring issues. Those links are available here: http://wiki.ross-tech.com/wiki/index...ir_Information
    Side note, that IAT -40 C reading looks like an open or short rather than a faulty sensor. I'm guessing open ckt is -40 and shorted is +140 (or +50).
    According to diagram # 5/10 (diagram 5, page 10) GX9 - Intake manifold sensor includes both G31 - Charge air pressure sensor -and- G42 - Intake air temperature sensor so you are looking for a 4 wire component. It should be in the air duct/pipe south of the throttle body, very close to cooling fans and the rad support in the front of the car.
    If all looks well there the diagram shows a T10g (10-pin connector) in between the yellow G42 signal wire and the EDC. I think that's a black D shaped on the driver's frame rail, behind the driver side headlight.
    Vehicle Identification No. 1VWBN7A37DC147817
    Model new passat
    PA
    Date of production 12.06.2013
    Year 2013
    Sales type A32372
    Engine Code CKRA
    Transmission Code NGB
  5. Likes Uwe, tncrom liked this post
    Jan 2017
    Iowa, USA
    Thanks so much Dana. I'll give an update once I have one.
  7. Likes Dana liked this post
    Jan 2017
    Iowa, USA
    Hi,...
    Took the G42 and G31 Combo sensor out of the car today, and ohm'd out the pins. Pin #2 was open line to the other three pins. I'm thinking this may indicate the o/l causing the -40C reading. I have a part on the way, and will provide another update once it's installed. Thanks again -- I'm encouraged this may be the culprit.
    Chris
  9. Likes Uwe, Dana liked this post
  10. #7
    Jan 2017
    Iowa, USA
    Mein Auto lebt noch!
    I replaced the sensor and have no codes. Took a quick test drive and drove beautifully again. Thanks Dana and Uwe!
    Chris
  11. Likes Uwe liked this post
