5F-Information Electr.
blockmap-5F-3Q0-035-876-A.CSV
adpmap-5F-3Q0-035-876-A.CSV
;SW:3Q0-035-876-A HW:3Q0-035-876-A --- Information Electr.
;Component:MU-S-NS-US 840 0751 Coding:027302020000000051220002001808009F0108F401200105C6
;EV_MUStd4CDELP 1001 EV_MUStd4CDELP_VW26.rod
;Wednesday 11 January 2017 20:17:18:08929
;VCDS Version: Release 17.1.1 (x64) Data version: 20170106 DS267.0
;VCID: B227196DE50D00D193-80E6
Group Description Actual
IDE00019 Voltage terminal 30 12.9 V
IDE00020 Terminal 15 status On
IDE00021 Engine speed 0 /min
IDE00075 Vehicle speed 0 km/h
IDE00323 Security Access: Number of invalid keys 0
IDE00668-MAS03231 Microphone current consumption-Microphone 1 5.9 mA
IDE00668-MAS03232 Microphone current consumption-Microphone 2 25.5 mA
IDE00767 No. of unscheduled ECU resets 0 counts
IDE00916-IDE02127 Speaker status-Left front speaker Measured value not available
IDE00916-IDE02128 Speaker status-Right front speaker Measured value not available
IDE00916-IDE02129 Speaker status-Left rear speaker Measured value not available
IDE00916-IDE02130 Speaker status-Right rear speaker Measured value not available
IDE00916-ENG117413 Speaker status-loudspeaker_channel_10 Measured value not available
IDE00916-ENG117414 Speaker status-loudspeaker_channel_11 Measured value not available
IDE00916-ENG117415 Speaker status-loudspeaker_channel_12 Measured value not available
IDE00916-ENG117416 Speaker status-loudspeaker_channel_13 Measured value not available
IDE00916-ENG117417 Speaker status-loudspeaker_channel_14 Measured value not available
IDE00916-ENG117418 Speaker status-loudspeaker_channel_15 Measured value not available
IDE00916-ENG117419 Speaker status-loudspeaker_channel_16 Measured value not available
IDE00916-ENG117408 Speaker status-loudspeaker_channel_5 Measured value not available
IDE00916-ENG117409 Speaker status-loudspeaker_channel_6 Measured value not available
IDE00916-ENG117410 Speaker status-loudspeaker_channel_7 Measured value not available
IDE00916-ENG117411 Speaker status-loudspeaker_channel_8 Measured value not available
IDE00916-ENG117412 Speaker status-loudspeaker_channel_9 Measured value not available
IDE01285-ENG101364 Counter of component protection malfunctions-Theft Protection Error Counter 00 00
IDE01351 Terminal 75 status OFF
IDE01442-MAS06123 Pressing a button-Eject button not activated
IDE01698-MAS07206 Status audio signal outputs-Audio signal output channel 1 Measured value not available
IDE01698-MAS07207 Status audio signal outputs-Audio signal output channel 2 Measured value not available
IDE01698-MAS07208 Status audio signal outputs-Audio signal output channel 3 Measured value not available
IDE01698-MAS07209 Status audio signal outputs-Audio signal output channel 4 Measured value not available
IDE01712-MAS01779 GPS Position-Length 079°37'22.91"W
IDE01712-MAS01780 GPS Position-Width 040°31'58.95"N
IDE01713-MAS01632 Status GPS reception-Status GPS data is being received: position completely determined
IDE01713-MAS01785 Status GPS reception-Number of visible satellites 14
IDE01713-MAS01786 Status GPS reception-Number of tracked satellites 10
IDE01715 Status terminal S On
IDE01716 Terminal 50 status OFF
IDE01767-MAS00940 Status of telephone-Antenna diagnostic Not available
IDE01767-MAS00941 Status of telephone-Telephone baseplate diagnostic not connected
IDE01767-MAS00955 Status of telephone-Handset in handset holder (cradle) not selected
IDE01767-MAS01806 Status of telephone-Handset holder (cradle) not connected
IDE01768-MAS01808 Status of antenna 1 for radio-Antenna current 61 mA
IDE01768-MAS03938 Status of antenna 1 for radio-Connection between radio and antenna amplifier Electrical OK
IDE01768-MAS03939 Status of antenna 1 for radio-Connection between antenna amplifier and antenna Electrical OK
IDE01768-MAS03991 Status of antenna 1 for radio-Reception level antenna 1 9 dBµV
IDE01769-MAS01808 Status of antenna 2 for radio-Antenna current 51 mA
IDE01769-MAS03938 Status of antenna 2 for radio-Connection between radio and antenna amplifier Electrical OK
IDE01769-MAS03939 Status of antenna 2 for radio-Connection between antenna amplifier and antenna Electrical OK
IDE01769-MAS04344 Status of antenna 2 for radio-Reception level antenna 2 14 dBµV
IDE01770-MAS01632 Status of GPS antenna-Status Electrical OK
IDE01770-MAS01808 Status of GPS antenna-Antenna current 24 mA
IDE01868-MAS00839 Ring break diagnostic result-TV Tuner Not available
IDE01868-MAS00840 Ring break diagnostic result-Media Player: Position 1 Not available
IDE01868-MAS00844 Ring break diagnostic result-Radio Not available
IDE01868-MAS00847 Ring break diagnostic result-Digital Sound System Control Module Not available
IDE01868-MAS00849 Ring break diagnostic result-Information electronics control module 1 System OK
IDE01868-MAS00850 Ring break diagnostic result-Information electronics control module 2 Not available
IDE01868-MAS02840 Ring break diagnostic result-Instrument cluster display Not available
IDE01868-ENG117473 Ring break diagnostic result-MOST_Component_10 Not available
IDE01868-ENG117474 Ring break diagnostic result-MOST_Component_11 Not available
IDE01868-ENG117475 Ring break diagnostic result-MOST_Component_12 Not available
IDE01868-ENG117476 Ring break diagnostic result-MOST_Component_13 Not available
IDE01868-ENG117477 Ring break diagnostic result-MOST_Component_14 Not available
IDE01868-ENG117478 Ring break diagnostic result-MOST_Component_15 Not available
IDE01868-ENG117479 Ring break diagnostic result-MOST_Component_16 Not available
IDE01868-ENG117480 Ring break diagnostic result-MOST_Component_17 Not available
IDE01868-ENG117481 Ring break diagnostic result-MOST_Component_18 Not available
IDE01868-ENG117482 Ring break diagnostic result-MOST_Component_19 Not available
IDE01868-ENG117483 Ring break diagnostic result-MOST_Component_20 Not available
IDE01868-ENG117471 Ring break diagnostic result-MOST_Component_8 Not available
IDE01868-ENG117472 Ring break diagnostic result-MOST_Component_9 Not available
IDE01992-ENG117819 Installation list: current installations-ECUs present_1 installed
IDE01992-ENG117820 Installation list: current installations-ECUs present_2 not installed
IDE01992-ENG117821 Installation list: current installations-ECUs present_3 not installed
IDE01995-ENG103538 Control module protocol information-ECUs DiagProt Yes
IDE02070-IDE02060 Wake-up cause-Eject optical medium\ (CD/DVD Eject) No
IDE02070-IDE04544 Wake-up cause-Media type in optical drive No
IDE02070-MAS03177 Wake-up cause-Databus Infotainment Yes
IDE02070-MAS03180 Wake-up cause-Local data bus No
IDE02070-MAS03690 Wake-up cause-Telephone No
IDE02070-MAS03782 Wake-up cause-WLAN No
IDE02070-MAS03833 Wake-up cause-Optical data bus No
IDE02326-ENG117459 GPS signal strength-ID_GPS_satellite_no_1 9
IDE02326-ENG117461 GPS signal strength-ID_GPS_satellite_no_2 23
IDE02326-ENG117463 GPS signal strength-ID_GPS_satellite_no_3 27
IDE02326-ENG117465 GPS signal strength-ID_GPS_satellite_no_4 16
IDE02326-ENG117460 GPS signal strength-S/N_GPS_satellite_no_1 50 dBµV
IDE02326-ENG117462 GPS signal strength-S/N_GPS_satellite_no_2 50 dBµV
IDE02326-ENG117464 GPS signal strength-S/N_GPS_satellite_no_3 49 dBµV
IDE02326-ENG117466 GPS signal strength-S/N_GPS_satellite_no_4 48 dBµV
IDE02384-ENG117816 Status of event memory-ECU Dtcs_1 OK
IDE02384-ENG117817 Status of event memory-ECU Dtcs_2 OK
IDE02384-ENG117818 Status of event memory-ECU Dtcs_3 OK
IDE02486 Data logger triggering not active
IDE02508-MAS00951 Bluetooth: Visibility-Bluetooth On
IDE02508-MAS03001 Bluetooth: Visibility-Mode Bluetooth available
IDE02766 Malfunction status FF FB
IDE03150-ENG117823 Readiness for bus sleep mode-Sleep_1 End busstat
IDE03150-ENG117824 Readiness for bus sleep mode-Sleep_2 Unknown
IDE03150-ENG117825 Readiness for bus sleep mode-Sleep_3 Unknown
IDE03151-ENG117815 TP CAN identifier-ECUs TP-CAN-Identifier 1907
IDE03477-MAS01632 GPS time-Status valid
IDE03477-ENG117467 GPS time-gps_date_time 2017
IDE03610-MAS02573 Voice operation: last detected command-Reception quality 255 %
IDE03610-MAS03874 Voice operation: last detected command-last detected command 16776960
IDE03610-MAS03875 Voice operation: last detected command-Reliability 255 %
IDE03880-MAS03119 MOST address-Functional block: diagnostic instance 5F
IDE03880-MAS03425 MOST address-Physical address 04 00
IDE04312-MAS00109 System run time-Hours 0 H
IDE04312-MAS00110 System run time-Minutes 36 min
IDE04317-MAS00108 Total system run time-Day 0 d
IDE04317-MAS00109 Total system run time-Hours 15 H
IDE04317-MAS00110 Total system run time-Minutes 53 min
IDE04329 Status of all SWaP functions 00 03 00 00
IDE04329 Status of all SWaP functions Available
IDE04329 Status of all SWaP functions No
IDE04329 Status of all SWaP functions valid
IDE04329 Status of all SWaP functions Condition met
IDE04329 Status of all SWaP functions OK
IDE04332 Release code for a SWaP function Not available
IDE04334-MAS02643 Public key for SWaP function-Key C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
IDE04343-ENG117822 Bus identification-BusIdentifier Busmaster
IDE04344-ENG103664 Control module assignment-ECU IDs Information Control Unit 1
IDE04541-MAS03621 Status of active media source at output 1-Video codec --------------------
IDE04541-MAS03622 Status of active media source at output 1-Horizontal video resolution 65535
IDE04541-MAS03623 Status of active media source at output 1-Vertical video resolution 65535
IDE04541-MAS03778 Status of active media source at output 1-Active media source Not available
IDE04541-MAS03783 Status of active media source at output 1-Video Bitrate 65535 kbps
IDE04541-MAS03784 Status of active media source at output 1-Audio Bitrate Not available
IDE04541-MAS03785 Status of active media source at output 1-Digital rights management (DRM) Not available
IDE04541-MAS03786 Status of active media source at output 1-Audio Codec --------------------
IDE04541-MAS03787 Status of active media source at output 1-Image format --------------------
IDE04541-MAS03788 Status of active media source at output 1-Horizontal image resolution 65535
IDE04541-MAS03789 Status of active media source at output 1-Vertical image resolution 65535
IDE04541-MAS03793 Status of active media source at output 1-Color depth 65535 bit
IDE04544 Media type in optical drive Not available
IDE04545-IDE01588 Vehicle state-Driving direction Measured value not available
IDE04545-IDE01714 Vehicle state-Status reverse gear not selected
IDE04545-IDE01766 Vehicle state-Distance impulses 0
IDE04545-IDE03684 Vehicle state-Vehicle stopped Yes
IDE04546-IDE00301 Navigation calibration-Distance 0.46 mm
IDE04546-MAS03647 Navigation calibration-Calibration condition Position finding possible even without GPS
IDE04547 Traffic information OFF
IDE04605-MAS01779 Navigation: Corrected position-Length 079°37'22.42"W
IDE04605-MAS01780 Navigation: Corrected position-Width 040°31'58.15"N
IDE04607-IDE03661 Angle of turn sensor for navigation-Rotation rate 3.6 °/s
IDE04607-ENG117452 Angle of turn sensor for navigation-gyro_sensor_x_acceleration 20.08 m/s²
IDE04607-ENG117453 Angle of turn sensor for navigation-gyro_sensor_y_acceleration 20.08 m/s²
IDE04607-ENG117454 Angle of turn sensor for navigation-gyro_sensor_z_acceleration 20.08 m/s²
IDE04639-IDE02060 Last wake-up cause-Eject optical medium\ (CD/DVD Eject) No
IDE04639-IDE04544 Last wake-up cause-Media type in optical drive No
IDE04639-MAS03177 Last wake-up cause-Databus Infotainment Yes
IDE04639-MAS03180 Last wake-up cause-Local data bus No
IDE04639-MAS03690 Last wake-up cause-Telephone No
IDE04639-MAS03782 Last wake-up cause-WLAN No
IDE04639-MAS03833 Last wake-up cause-Optical data bus No
IDE04640 Over-temperature protection for amplifier no restriction
IDE04641 Speed-dependent volume adjustment 0 dB
IDE04649-MAS01968 Activation for housing fan-Fan Stage 3
IDE04649-MAS06857 Activation for housing fan-Speed 6000 /min
IDE04748 Microphone override meter 0
IDE04749-ENG117444 Mute-am_fm_tuner No
IDE04749-ENG117443 Mute-audiomanager No
IDE04749-ENG117447 Mute-component_protection No
IDE04749-ENG117445 Mute-dab_sdars_tuner No
IDE04749-ENG117446 Mute-drm_hd_tuner No
IDE04749-ENG113342 Mute-Hardware No
IDE04767-MAS01240 Update software via medium-Programming status not active
IDE04767-MAS02111 Update software via medium-Data consistency valid
IDE04767-MAS02112 Update software via medium-Programmability no request
IDE04768 Bluetooth device address 28 A1 83 DD 3E B9
IDE05040-MAS01632 Video input status-Status Not available
IDE05040-MAS04390 Video input status-Active source Not available
IDE05536-MAS01632 GPS almanac-Status valid
IDE05595-MAS00106 Last time GPS without satellite reception-Year 2017
IDE05595-MAS00107 Last time GPS without satellite reception-Month 1
IDE05595-MAS00108 Last time GPS without satellite reception-Day 11
IDE05595-MAS00109 Last time GPS without satellite reception-Hours 23
IDE05595-MAS00110 Last time GPS without satellite reception-Minutes 53
IDE05595-MAS00111 Last time GPS without satellite reception-Seconds 44
IDE05596-MAS00106 Last time GPS position outside map-Year 2000
IDE05596-MAS00107 Last time GPS position outside map-Month 0
IDE05596-MAS00108 Last time GPS position outside map-Day 0
IDE05596-MAS00109 Last time GPS position outside map-Hours 0
IDE05596-MAS00110 Last time GPS position outside map-Minutes 0
IDE05596-MAS00111 Last time GPS position outside map-Seconds 0
IDE05597-IDE03615 Bluetooth: Paired device 1-Version a
IDE05597-IDE04768 Bluetooth: Paired device 1-Bluetooth device address 90 E7 C4 46 C4 6A
IDE05597-MAS01483 Bluetooth: Paired device 1-Software version z
IDE05597-MAS02159 Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP) 48 54
IDE05597-MAS02160 Bluetooth: Paired device 1-Hands free profile (HFP) 65 03
IDE05597-MAS03159 Bluetooth: Paired device 1-Manufacturer R
IDE05597-MAS04326 Bluetooth: Paired device 1-Device name
IDE05597-ENG117431 Bluetooth: Paired device 1-A2DP 43 0A
IDE05597-ENG117440 Bluetooth: Paired device 1-ACTIVESYNCML FF 01
IDE05597-ENG105233 Bluetooth: Paired device 1-AT 02 01
IDE05597-ENG117432 Bluetooth: Paired device 1-AVRCP 48 54
IDE05597-ENG117434 Bluetooth: Paired device 1-DUN 4F 6E
IDE05597-ENG106692 Bluetooth: Paired device 1-FTP FF 01
IDE05597-ENG117435 Bluetooth: Paired device 1-HIDP 65 20
IDE05597-ENG117429 Bluetooth: Paired device 1-HSP 61 64
IDE05597-ENG117437 Bluetooth: Paired device 1-IRMC 2D FF
IDE05597-ENG101499 Bluetooth: Paired device 1-map 4D 39
IDE05597-ENG117436 Bluetooth: Paired device 1-OBEX 02 2D
IDE05597-ENG117439 Bluetooth: Paired device 1-OPP FF FF
IDE05597-ENG117433 Bluetooth: Paired device 1-PAN 43 20
IDE05597-ENG108174 Bluetooth: Paired device 1-PBAP 06 FF
IDE05597-ENG117427 Bluetooth: Paired device 1-SDAP 6F 72
IDE05597-ENG117428 Bluetooth: Paired device 1-SPP 62 6C
IDE05597-ENG117438 Bluetooth: Paired device 1-SYNCML FF FF
IDE05598-IDE03615 Bluetooth: Paired device 2-Version -
IDE05598-IDE04768 Bluetooth: Paired device 2-Bluetooth device address 00 00 00 00 00 00
IDE05598-MAS01483 Bluetooth: Paired device 2-Software version
IDE05598-MAS02159 Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP) FF FF
IDE05598-MAS02160 Bluetooth: Paired device 2-Hands free profile (HFP) 2D 2D
IDE05598-MAS03159 Bluetooth: Paired device 2-Manufacturer -
IDE05598-MAS04326 Bluetooth: Paired device 2-Device name
IDE05598-ENG117431 Bluetooth: Paired device 2-A2DP FF FF
IDE05598-ENG117440 Bluetooth: Paired device 2-ACTIVESYNCML FF FF
IDE05598-ENG105233 Bluetooth: Paired device 2-AT FF FF
IDE05598-ENG117432 Bluetooth: Paired device 2-AVRCP FF FF
IDE05598-ENG117434 Bluetooth: Paired device 2-DUN FF FF
IDE05598-ENG106692 Bluetooth: Paired device 2-FTP FF FF
IDE05598-ENG117435 Bluetooth: Paired device 2-HIDP FF FF
IDE05598-ENG117429 Bluetooth: Paired device 2-HSP 2D 02
IDE05598-ENG117437 Bluetooth: Paired device 2-IRMC FF FF
IDE05598-ENG101499 Bluetooth: Paired device 2-map FF FF
IDE05598-ENG117436 Bluetooth: Paired device 2-OBEX FF FF
IDE05598-ENG117439 Bluetooth: Paired device 2-OPP FF FF
IDE05598-ENG117433 Bluetooth: Paired device 2-PAN FF FF
IDE05598-ENG108174 Bluetooth: Paired device 2-PBAP FF FF
IDE05598-ENG117427 Bluetooth: Paired device 2-SDAP 2D 2D
IDE05598-ENG117428 Bluetooth: Paired device 2-SPP 02 2D
IDE05598-ENG117438 Bluetooth: Paired device 2-SYNCML FF FF
IDE05599-IDE03615 Bluetooth: Paired device 3-Version -
IDE05599-IDE04768 Bluetooth: Paired device 3-Bluetooth device address 00 00 00 00 00 00
IDE05599-MAS01483 Bluetooth: Paired device 3-Software version
IDE05599-MAS02159 Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP) FF FF
IDE05599-MAS02160 Bluetooth: Paired device 3-Hands free profile (HFP) 2D 2D
IDE05599-MAS03159 Bluetooth: Paired device 3-Manufacturer -
IDE05599-MAS04326 Bluetooth: Paired device 3-Device name
IDE05599-ENG117431 Bluetooth: Paired device 3-A2DP FF FF
IDE05599-ENG117440 Bluetooth: Paired device 3-ACTIVESYNCML FF FF
IDE05599-ENG105233 Bluetooth: Paired device 3-AT FF FF
IDE05599-ENG117432 Bluetooth: Paired device 3-AVRCP FF FF
IDE05599-ENG117434 Bluetooth: Paired device 3-DUN FF FF
IDE05599-ENG106692 Bluetooth: Paired device 3-FTP FF FF
IDE05599-ENG117435 Bluetooth: Paired device 3-HIDP FF FF
IDE05599-ENG117429 Bluetooth: Paired device 3-HSP 2D 02
IDE05599-ENG117437 Bluetooth: Paired device 3-IRMC FF FF
IDE05599-ENG101499 Bluetooth: Paired device 3-map FF FF
IDE05599-ENG117436 Bluetooth: Paired device 3-OBEX FF FF
IDE05599-ENG117439 Bluetooth: Paired device 3-OPP FF FF
IDE05599-ENG117433 Bluetooth: Paired device 3-PAN FF FF
IDE05599-ENG108174 Bluetooth: Paired device 3-PBAP FF FF
IDE05599-ENG117427 Bluetooth: Paired device 3-SDAP 2D 2D
IDE05599-ENG117428 Bluetooth: Paired device 3-SPP 02 2D
IDE05599-ENG117438 Bluetooth: Paired device 3-SYNCML FF FF
IDE05600-IDE03615 Bluetooth: Paired device 4-Version -
IDE05600-IDE04768 Bluetooth: Paired device 4-Bluetooth device address 00 00 00 00 00 00
IDE05600-MAS01483 Bluetooth: Paired device 4-Software version
IDE05600-MAS02159 Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP) FF FF
IDE05600-MAS02160 Bluetooth: Paired device 4-Hands free profile (HFP) 2D 2D
IDE05600-MAS03159 Bluetooth: Paired device 4-Manufacturer -
IDE05600-MAS04326 Bluetooth: Paired device 4-Device name
IDE05600-ENG117431 Bluetooth: Paired device 4-A2DP FF FF
IDE05600-ENG117440 Bluetooth: Paired device 4-ACTIVESYNCML FF FF
IDE05600-ENG105233 Bluetooth: Paired device 4-AT FF FF
IDE05600-ENG117432 Bluetooth: Paired device 4-AVRCP FF FF
IDE05600-ENG117434 Bluetooth: Paired device 4-DUN FF FF
IDE05600-ENG106692 Bluetooth: Paired device 4-FTP FF FF
IDE05600-ENG117435 Bluetooth: Paired device 4-HIDP FF FF
IDE05600-ENG117429 Bluetooth: Paired device 4-HSP 2D 02
IDE05600-ENG117437 Bluetooth: Paired device 4-IRMC FF FF
IDE05600-ENG101499 Bluetooth: Paired device 4-map FF FF
IDE05600-ENG117436 Bluetooth: Paired device 4-OBEX FF FF
IDE05600-ENG117439 Bluetooth: Paired device 4-OPP FF FF
IDE05600-ENG117433 Bluetooth: Paired device 4-PAN FF FF
IDE05600-ENG108174 Bluetooth: Paired device 4-PBAP FF FF
IDE05600-ENG117427 Bluetooth: Paired device 4-SDAP 2D 2D
IDE05600-ENG117428 Bluetooth: Paired device 4-SPP 02 2D
IDE05600-ENG117438 Bluetooth: Paired device 4-SYNCML FF FF
IDE05601-IDE03615 Bluetooth: Paired device 5-Version -
IDE05601-IDE04768 Bluetooth: Paired device 5-Bluetooth device address 00 00 00 00 00 00
IDE05601-MAS01483 Bluetooth: Paired device 5-Software version
IDE05601-MAS02159 Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP) FF FF
IDE05601-MAS02160 Bluetooth: Paired device 5-Hands free profile (HFP) 2D 2D
IDE05601-MAS03159 Bluetooth: Paired device 5-Manufacturer -
IDE05601-MAS04326 Bluetooth: Paired device 5-Device name
IDE05601-ENG117431 Bluetooth: Paired device 5-A2DP FF FF
IDE05601-ENG117440 Bluetooth: Paired device 5-ACTIVESYNCML FF FF
IDE05601-ENG105233 Bluetooth: Paired device 5-AT FF FF
IDE05601-ENG117432 Bluetooth: Paired device 5-AVRCP FF FF
IDE05601-ENG117434 Bluetooth: Paired device 5-DUN FF FF
IDE05601-ENG106692 Bluetooth: Paired device 5-FTP FF FF
IDE05601-ENG117435 Bluetooth: Paired device 5-HIDP FF FF
IDE05601-ENG117429 Bluetooth: Paired device 5-HSP 2D 02
IDE05601-ENG117437 Bluetooth: Paired device 5-IRMC FF FF
IDE05601-ENG101499 Bluetooth: Paired device 5-map FF FF
IDE05601-ENG117436 Bluetooth: Paired device 5-OBEX FF FF
IDE05601-ENG117439 Bluetooth: Paired device 5-OPP FF FF
IDE05601-ENG117433 Bluetooth: Paired device 5-PAN FF FF
IDE05601-ENG108174 Bluetooth: Paired device 5-PBAP FF FF
IDE05601-ENG117427 Bluetooth: Paired device 5-SDAP 2D 2D
IDE05601-ENG117428 Bluetooth: Paired device 5-SPP 02 2D
IDE05601-ENG117438 Bluetooth: Paired device 5-SYNCML FF FF
IDE05602-MAS01763 Bluetooth: connected device 1-Signal Strength Not available
IDE05602-MAS04326 Bluetooth: connected device 1-Device name 65280
IDE05603-MAS01763 Bluetooth: connected device 2-Signal Strength Not available
IDE05603-MAS04326 Bluetooth: connected device 2-Device name 65280
IDE05604-MAS01763 Bluetooth: connected device 3-Signal Strength Not available
IDE05604-MAS04326 Bluetooth: connected device 3-Device name 65280
IDE05605-MAS01763 Bluetooth: connected device 4-Signal Strength Not available
IDE05605-MAS04326 Bluetooth: connected device 4-Device name 65280
IDE05606-MAS01763 Bluetooth: connected device 5-Signal Strength Not available
IDE05606-MAS04326 Bluetooth: connected device 5-Device name 65280
IDE05700-MAS01456 USB connection-Speed Not available
IDE05700-MAS01632 USB connection-Status OK
IDE05700-MAS03159 USB connection-Manufacturer FF FF
IDE05700-MAS04393 USB connection-USB device class FF
IDE05700-MAS04394 USB connection-Connection status not connected
IDE05700-MAS04436 USB connection-USB device sub-class FF
IDE05700-ENG111957 USB connection-usb_product_id FF FF
IDE05700-ENG111955 USB connection-usb_protocol FF
IDE05713-MAS01632 Network diagnosis-Status Enabled
IDE05725 Terminal 58xs dimmer 0 %
IDE05726 Terminal 58xd dimmer 39.5 %
IDE05814 Individualization characteristic CA 33 28 6A 07
IDE06028-MAS02317 Control head button operation-Button code 1 FF
IDE06028-MAS02318 Control head button operation-Button code 2 FF
IDE06028-MAS04151 Control head button operation-Joystick 0
IDE06028-MAS04413 Control head button operation-Push-and rotary knob for selection 0
IDE06028-MAS04414 Control head button operation-Volume control 0
IDE06425 Roller test bench mode: functional not activated
IDE07589-IDE07590 Update programming: status-Currently processed module 0
IDE07589-IDE07591 Update programming: status-Number of modules to be programmed 0
IDE07589-MAS01632 Update programming: status-Status not active
IDE07589-MAS10948 Update programming: status-control Diagnosis
IDE07938 Cause of system start Data bus
IDE07939 Last cause of system start Data bus
IDE09563-MAS09154 Proximity detection for touchscreen 1-Proximity sensor 1 No object in sector
IDE10478-MAS01632 Interface for external media: status-Status OK
IDE10479-MAS01482 Interface for external media: identification-Hardware version ---
IDE10479-MAS01483 Interface for external media: identification-Software version ----
IDE10479-MAS04970 Interface for external media: identification-Part Number -----------
MAS00464 Standard - ambient data 1 5
MAS00464 Standard - ambient data 1 2
MAS00464 Standard - ambient data 1 9
MAS00481-ENG117777 BAP-BAP_Function_ID FF
MAS00778-IDE03619 Multimedia display unit 1-System status On
MAS00778-IDE05228 Multimedia display unit 1-Operating hour counter 10 H
MAS00778-MAS00362 Multimedia display unit 1-Battery voltage 12.9 V
MAS00778-MAS02200 Multimedia display unit 1-Highest measured temperature 47 °C
MAS00778-MAS02201 Multimedia display unit 1-Temperature 29 °C
MAS00778-MAS03691 Multimedia display unit 1-Dimming 8 %
MAS00951-IDE04058 Bluetooth-Bluetooth: devices found 0
MAS00951-MAS04324 Bluetooth-Bluetooth: connected devices 0
MAS00951-MAS04325 Bluetooth-Bluetooth: Paired devices 1
MAS01760-MAS01765 Radio Tuner 1-Audio Signal Mute
MAS01760-MAS02949 Radio Tuner 1-Frequency 88.7 MHz
MAS01760-MAS03991 Radio Tuner 1-Reception level antenna 1 10 dBµV
MAS01760-MAS04344 Radio Tuner 1-Reception level antenna 2 15 dBµV
MAS01760-MAS04345 Radio Tuner 1-Frequency (AM) 65535 kHz
MAS01760-ENG117356 Radio Tuner 1-iboc_audio_signal Not available
MAS01760-ENG117358 Radio Tuner 1-iboc_count 0
MAS01760-ENG117355 Radio Tuner 1-iboc_error_rate 255
MAS01760-ENG117357 Radio Tuner 1-iboc_service 1
MAS01761-MAS01763 Radio Tuner 2-Signal Strength 14 dBµV
MAS01991-IDE00010 Card reader-Serial number 10 7C 3B BB
MAS01991-IDE01001 Card reader-Application AP
MAS01991-MAS01632 Card reader-Status connected
MAS01991-MAS03159 Card reader-Manufacturer 9
MAS01991-MAS03375 Card reader-Major version 2
MAS01991-MAS03376 Card reader-Minor version 0
MAS01991-MAS03959 Card reader-Write-protection activated
MAS01991-MAS04388 Card reader-Card type MIBST
MAS01991-MAS13476 Card reader-Herstellungsdatum: Monat 6 mon
MAS01991-MAS13477 Card reader-Herstellungsdatum: Jahr 2016 yr
MAS03121 Ring break diagnostic line status Supply voltage
MAS03780-IDE00010 Card reader 2-Serial number FF FF FF FF
MAS03780-IDE01001 Card reader 2-Application --
MAS03780-MAS01632 Card reader 2-Status not connected
MAS03780-MAS03159 Card reader 2-Manufacturer FF
MAS03780-MAS03375 Card reader 2-Major version 15
MAS03780-MAS03376 Card reader 2-Minor version 15
MAS03780-MAS03959 Card reader 2-Write-protection Not available
MAS03780-MAS04388 Card reader 2-Card type -----
MAS03780-MAS13476 Card reader 2-Herstellungsdatum: Monat 15 mon
MAS03780-MAS13477 Card reader 2-Herstellungsdatum: Jahr 2255 yr
MAS04324 Bluetooth: connected devices SDAP
MAS04324 Bluetooth: connected devices 0
MAS04325 Bluetooth: Paired devices Remote SIM Access Profile (rSAP)
MAS04325 Bluetooth: Paired devices 1.12955E+15
ENG117872-ENG117778 Byte_Coding_Condition-byte_0_condition OK
ENG117872-ENG117779 Byte_Coding_Condition-byte_1_condition OK
ENG117872-ENG117788 Byte_Coding_Condition-byte_10_condition OK
ENG117872-ENG117789 Byte_Coding_Condition-byte_11_condition OK
ENG117872-ENG117790 Byte_Coding_Condition-byte_12_condition OK
ENG117872-ENG117791 Byte_Coding_Condition-byte_13_condition OK
ENG117872-ENG117792 Byte_Coding_Condition-byte_14_condition OK
ENG117872-ENG117793 Byte_Coding_Condition-byte_15_condition OK
ENG117872-ENG117794 Byte_Coding_Condition-byte_16_condition OK
ENG117872-ENG117795 Byte_Coding_Condition-byte_17_condition OK
ENG117872-ENG117796 Byte_Coding_Condition-byte_18_condition OK
ENG117872-ENG117797 Byte_Coding_Condition-byte_19_condition OK
ENG117872-ENG117780 Byte_Coding_Condition-byte_2_condition OK
ENG117872-ENG117798 Byte_Coding_Condition-byte_20_condition OK
ENG117872-ENG117799 Byte_Coding_Condition-byte_21_condition OK
ENG117872-ENG117800 Byte_Coding_Condition-byte_22_condition OK
ENG117872-ENG117801 Byte_Coding_Condition-byte_23_condition OK
ENG117872-ENG117802 Byte_Coding_Condition-byte_24_condition OK
ENG117872-ENG117803 Byte_Coding_Condition-byte_25_condition dont care
ENG117872-ENG117804 Byte_Coding_Condition-byte_26_condition dont care
ENG117872-ENG117805 Byte_Coding_Condition-byte_27_condition dont care
ENG117872-ENG117781 Byte_Coding_Condition-byte_3_condition OK
ENG117872-ENG117782 Byte_Coding_Condition-byte_4_condition OK
ENG117872-ENG117783 Byte_Coding_Condition-byte_5_condition OK
ENG117872-ENG117784 Byte_Coding_Condition-byte_6_condition OK
ENG117872-ENG117785 Byte_Coding_Condition-byte_7_condition OK
ENG117872-ENG117786 Byte_Coding_Condition-byte_8_condition OK
ENG117872-ENG117787 Byte_Coding_Condition-byte_9_condition OK
ENG117867-ENG117773 GPS_Count_Satellite_Phase_Lock_Counter-satellites 10
ENG117868-ENG117773 GPS_Satellite_Code_Lock_Counter-satellites 10
ENG117857-MAS00109 Last_System_Operating_Time-Hours 0 H
ENG117857-MAS00110 Last_System_Operating_Time-Minutes 14 min
ENG117856-MAS00106 Last_System_Operating_Time/Mins.-Year 0 yr
ENG117856-MAS00107 Last_System_Operating_Time/Mins.-Month 0 mon
ENG117856-MAS00108 Last_System_Operating_Time/Mins.-Day 0 d
ENG117856-MAS00109 Last_System_Operating_Time/Mins.-Hours 0 H
ENG117856-MAS00110 Last_System_Operating_Time/Mins.-Minutes 0 min
ENG117856-MAS00111 Last_System_Operating_Time/Mins.-Seconds 0 s
ENG117869-ENG117441 Nav._Calculated_Direction-driving direction corrected 248 °
ENG117869-ENG98933 Nav._Calculated_Direction-Status OK
ENG122217-ENG122284 SDARS_service-audio_service subscribed
ENG122217-ENG122285 SDARS_service-traffic_service subscribed
ENG122217-ENG122286 SDARS_service-travel_link_service subscribed
ENG122216-ENG122281 SDARS_subscription_status-SDARS_expiration_date 2000
ENG122216-ENG122279 SDARS_subscription_status-SDARS_subscription subscribed
ENG122216-ENG125804 SDARS_subscription_status-SDARS_suspend_alert 0
ENG122216-ENG122280 SDARS_subscription_status-SDARS_suspension not_suspended
ENG127487-IDE02451 SDARS_tuner_status_2-Satellite radio antenna status Electrical OK
ENG127487-IDE02453 SDARS_tuner_status_2-Channel selection for satellite radio 34
ENG127487-MAS01765 SDARS_tuner_status_2-Audio Signal Available
ENG127487-MAS01808 SDARS_tuner_status_2-Antenna current 146 mA
ENG127487-MAS02573 SDARS_tuner_status_2-Reception quality optimum_signal
ENG127487-MAS13343 SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung 7
ENG127487-MAS13344 SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung 7
ENG117864-MAS01632 Status_Position_Touchscreen_1-Status Not available
ENG117864-ENG117402 Status_Position_Touchscreen_1-calibrate_delta_x 65535
ENG117864-ENG117403 Status_Position_Touchscreen_1-calibrate_delta_y 65535
ENG117864-ENG117396 Status_Position_Touchscreen_1-position_x1 65535
ENG117864-ENG117397 Status_Position_Touchscreen_1-position_x2 65535
ENG117864-ENG117398 Status_Position_Touchscreen_1-position_x3 65535
ENG117864-ENG117399 Status_Position_Touchscreen_1-position_y1 65535
ENG117864-ENG117400 Status_Position_Touchscreen_1-position_y2 65535
ENG117864-ENG117401 Status_Position_Touchscreen_1-position_y3 65535
ENG117858-MAS01424 System_Temperature_Sensor_2-Maximum value 55 °C
ENG117858-MAS01425 System_Temperature_Sensor_2-Minimum value -7 °C
ENG117858-MAS02238 System_Temperature_Sensor_2-Current 48 °C
ENG117860-MAS01424 System_Temperature_Sensor_4-Maximum value 47 °C
ENG117860-MAS01425 System_Temperature_Sensor_4-Minimum value -11 °C
ENG117860-MAS02238 System_Temperature_Sensor_4-Current 40 °C
ENG117862-MAS01424 System_Temperature_Sensor_6-Maximum value 52 °C
ENG117862-MAS01425 System_Temperature_Sensor_6-Minimum value -7 °C
ENG117862-MAS02238 System_Temperature_Sensor_6-Current 46 °C
Elapsed Time: 00:40
;Wednesday 11 January 2017 20:17:59:08929
IDE00001-Production mode 00 00 00
IDE00346-Summertime-automatic manual
IDE00758-Base volume of telephone 50%
IDE00759-Base volume of speech output 50%
IDE00760-Microphone sensitivity 0 dB
IDE00769-Number 1 for Info call FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00770-Number 1 for roadside assistance FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages OFF
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages OFF
IDE00845-Wheel circ. 0 mm
IDE01996-ENG99724-Installation list: specified installations-ECU coded Yes
IDE01996-ENG99724-Installation list: specified installations-ECU coded No
IDE01996-ENG06573-Installation list: specified installations-ECU coded 2 No
IDE02121-CD eject button Enabled
IDE02122-Developer mode not activated
IDE02330-Number 2 for Info call FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02331-Number 2 for roadside assistance FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02332-Deactivate production mode 0
IDE02476-MAS03001-Electrical test of loudspeakers-Mode automatic
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency 19000 Hz
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume 27
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume 27
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume 27
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume 27
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume 27
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume 27
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume 27
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume 27
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency 19000 Hz
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume 27
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency 19000 Hz
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume 27
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency 19000 Hz
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume 27
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency 19000 Hz
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume 27
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency 19000 Hz
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume 27
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency 19000 Hz
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume 27
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency 19000 Hz
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume 27
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency 19000 Hz
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume 27
IDE02502-Confirmation of installation change A4 5A
IDE02607-Wheel pulse 0
IDE02699-Number 1 for roadside assistance FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02701-Number 1 (roaming) for roadside assistance FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE03471-ENG117847-Vehicle configuration-advanced_range_display OFF
IDE03471-ENG130249-Vehicle configuration-Apple_DIO On
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call On
IDE03471-ENG130248-Vehicle configuration-Google_GAL On
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts OFF
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other OFF
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts OFF
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other OFF
IDE03471-ENG125049-Vehicle configuration-Joker_button_1 Not Present
IDE03471-ENG125050-Vehicle configuration-Joker_button_2 Not Present
IDE03471-ENG127492-Vehicle configuration-LGI OFF
IDE03471-ENG130246-Vehicle configuration-LTE_modul activated
IDE03471-ENG07590-Vehicle configuration-Mirror_link function_on_hmi_on
IDE03471-ENG117843-Vehicle configuration-my_audi OFF
IDE03471-ENG117845-Vehicle configuration-online_dictation OFF
IDE03471-ENG127495-Vehicle configuration-online_media OFF
IDE03471-ENG117840-Vehicle configuration-online_navigation OFF
IDE03471-ENG117837-Vehicle configuration-online_POI OFF
IDE03471-ENG117838-Vehicle configuration-online_POI_voice OFF
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services OFF
IDE03471-ENG117841-Vehicle configuration-online_street_view OFF
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit OFF
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode Data & language service active
IDE03471-ENG117844-Vehicle configuration-picture_navi On
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi OFF
IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo OFF
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version PSD_1.5
IDE03471-ENG117846-Vehicle configuration-remote_HMI OFF
IDE03471-ENG07589-Vehicle configuration-RSE_software_component activated
IDE03471-ENG126143-Vehicle configuration-RVC_video_input FBAS
IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation no restriction
IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag no_region
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch Not Present
IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi activated
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode 0
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold OFF
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling On
IDE03471-ENG130247-Vehicle configuration-Support_second_phone On
IDE03471-ENG126994-Vehicle configuration-TPEG_availability OFF
IDE03471-ENG06575-Vehicle configuration-UOTA OFF
IDE03471-ENG117852-Vehicle configuration-UPnP OFF
IDE03471-ENG117836-Vehicle configuration-VZAPro OFF
IDE03471-ENG127494-Vehicle configuration-VZO OFF
IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI OFF
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot OFF
IDE03902-Automatic ring break diagnostic No automatic start
IDE04295-Bluetooth: Preferred connection profile for phone book data PBAP
IDE04331-Selection of release codes for a SWaP function FF FF FF FF
IDE04521-Sporadic ring break detection Visual
IDE04522-Awakening ability on optical databus OFF
IDE04550-Bluetooth: Sniff mode OFF
IDE05111-Fee-based traffic information (TMC) 1537
IDE05113-Infotainment Recorder activated
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass OFF
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default On
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS OFF
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo OFF
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass OFF
IDE08814-ENG10975-Navigation receiver GNSS configuration-external_gps_1 OFF
IDE08814-ENG10976-Navigation receiver GNSS configuration-external_gps_2 OFF
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner -128
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio 5
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM) -128
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM) -128
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB) -128
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB -128
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP -128
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay -128
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter -128
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN -128
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray -128
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice -128
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA -128
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud -128
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD -128
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI -128
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP -128
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP -128
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink -128
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP -128
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB -3
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice -128
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM -128
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep -128
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging -128
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen 6
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning -128
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav -128
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS -128
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online -128
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal -128
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI -128
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN -128
IDE10480-MAS10741-Interface for external media: activation-Connection 1 activated
IDE10480-MAS10742-Interface for external media: activation-Connection 2 not activated
IDE10480-MAS10743-Interface for external media: activation-Connection 3 not activated
IDE10480-MAS10744-Interface for external media: activation-Connection 4 not activated
IDE10604-Menu entries for mobile online services not activated
IDE11122-Country identification: country of sale HMI US
IDE11502-ENG127601-Locked menu contents-FB_CAR_0 blocked
IDE11502-ENG127602-Locked menu contents-FB_CAR_1 non_blocked
IDE11502-ENG127611-Locked menu contents-FB_CAR_10 non_blocked
IDE11502-ENG127612-Locked menu contents-FB_CAR_11 blocked
IDE11502-ENG127613-Locked menu contents-FB_CAR_12 blocked
IDE11502-ENG127614-Locked menu contents-FB_CAR_13 non_blocked
IDE11502-ENG127615-Locked menu contents-FB_CAR_14 non_blocked
IDE11502-ENG127616-Locked menu contents-FB_CAR_15 non_blocked
IDE11502-ENG127617-Locked menu contents-FB_CAR_16 non_blocked
IDE11502-ENG127618-Locked menu contents-FB_CAR_17 non_blocked
IDE11502-ENG127619-Locked menu contents-FB_CAR_18 non_blocked
IDE11502-ENG127620-Locked menu contents-FB_CAR_19 non_blocked
IDE11502-ENG127603-Locked menu contents-FB_CAR_2 blocked
IDE11502-ENG127621-Locked menu contents-FB_CAR_20 non_blocked
IDE11502-ENG127622-Locked menu contents-FB_CAR_21 non_blocked
IDE11502-ENG127623-Locked menu contents-FB_CAR_22 non_blocked
IDE11502-ENG127624-Locked menu contents-FB_CAR_23 non_blocked
IDE11502-ENG127604-Locked menu contents-FB_CAR_3 blocked
IDE11502-ENG127605-Locked menu contents-FB_CAR_4 non_blocked
IDE11502-ENG127606-Locked menu contents-FB_CAR_5 non_blocked
IDE11502-ENG127607-Locked menu contents-FB_CAR_6 non_blocked
IDE11502-ENG127608-Locked menu contents-FB_CAR_7 blocked
IDE11502-ENG127609-Locked menu contents-FB_CAR_8 non_blocked
IDE11502-ENG127610-Locked menu contents-FB_CAR_9 non_blocked
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0 non_blocked
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1 blocked
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10 blocked
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11 blocked
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12 blocked
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13 blocked
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14 non_blocked
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15 blocked
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16 non_blocked
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17 non_blocked
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18 non_blocked
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19 non_blocked
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2 non_blocked
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20 non_blocked
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21 non_blocked
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22 non_blocked
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23 non_blocked
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3 blocked
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4 blocked
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5 blocked
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6 non_blocked
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7 non_blocked
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8 blocked
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9 blocked
IDE11502-ENG127625-Locked menu contents-FB_MISC_0 blocked
IDE11502-ENG127626-Locked menu contents-FB_MISC_1 non_blocked
IDE11502-ENG127635-Locked menu contents-FB_MISC_10 blocked
IDE11502-ENG127636-Locked menu contents-FB_MISC_11 blocked
IDE11502-ENG127637-Locked menu contents-FB_MISC_12 blocked
IDE11502-ENG127638-Locked menu contents-FB_MISC_13 blocked
IDE11502-ENG127639-Locked menu contents-FB_MISC_14 blocked
IDE11502-ENG127640-Locked menu contents-FB_MISC_15 non_blocked
IDE11502-ENG127641-Locked menu contents-FB_MISC_16 non_blocked
IDE11502-ENG127642-Locked menu contents-FB_MISC_17 non_blocked
IDE11502-ENG127643-Locked menu contents-FB_MISC_18 blocked
IDE11502-ENG127644-Locked menu contents-FB_MISC_19 blocked
IDE11502-ENG127627-Locked menu contents-FB_MISC_2 blocked
IDE11502-ENG127645-Locked menu contents-FB_MISC_20 blocked
IDE11502-ENG127646-Locked menu contents-FB_MISC_21 non_blocked
IDE11502-ENG127647-Locked menu contents-FB_MISC_22 non_blocked
IDE11502-ENG127648-Locked menu contents-FB_MISC_23 non_blocked
IDE11502-ENG127649-Locked menu contents-FB_MISC_24 non_blocked
IDE11502-ENG127650-Locked menu contents-FB_MISC_25 non_blocked
IDE11502-ENG127651-Locked menu contents-FB_MISC_26 non_blocked
IDE11502-ENG127652-Locked menu contents-FB_MISC_27 non_blocked
IDE11502-ENG127653-Locked menu contents-FB_MISC_28 non_blocked
IDE11502-ENG127654-Locked menu contents-FB_MISC_29 non_blocked
IDE11502-ENG127628-Locked menu contents-FB_MISC_3 non_blocked
IDE11502-ENG127655-Locked menu contents-FB_MISC_30 non_blocked
IDE11502-ENG127656-Locked menu contents-FB_MISC_31 non_blocked
IDE11502-ENG127657-Locked menu contents-FB_MISC_32 non_blocked
IDE11502-ENG127658-Locked menu contents-FB_MISC_33 non_blocked
IDE11502-ENG127659-Locked menu contents-FB_MISC_34 non_blocked
IDE11502-ENG127660-Locked menu contents-FB_MISC_35 non_blocked
IDE11502-ENG127661-Locked menu contents-FB_MISC_36 non_blocked
IDE11502-ENG127662-Locked menu contents-FB_MISC_37 non_blocked
IDE11502-ENG127663-Locked menu contents-FB_MISC_38 non_blocked
IDE11502-ENG127664-Locked menu contents-FB_MISC_39 non_blocked
IDE11502-ENG127629-Locked menu contents-FB_MISC_4 non_blocked
IDE11502-ENG127665-Locked menu contents-FB_MISC_40 non_blocked
IDE11502-ENG127666-Locked menu contents-FB_MISC_41 non_blocked
IDE11502-ENG127667-Locked menu contents-FB_MISC_42 non_blocked
IDE11502-ENG127668-Locked menu contents-FB_MISC_43 non_blocked
IDE11502-ENG127669-Locked menu contents-FB_MISC_44 blocked
IDE11502-ENG127670-Locked menu contents-FB_MISC_45 blocked
IDE11502-ENG127671-Locked menu contents-FB_MISC_46 blocked
IDE11502-ENG127672-Locked menu contents-FB_MISC_47 blocked
IDE11502-ENG127630-Locked menu contents-FB_MISC_5 blocked
IDE11502-ENG127631-Locked menu contents-FB_MISC_6 non_blocked
IDE11502-ENG127632-Locked menu contents-FB_MISC_7 non_blocked
IDE11502-ENG127633-Locked menu contents-FB_MISC_8 non_blocked
IDE11502-ENG127634-Locked menu contents-FB_MISC_9 blocked
IDE11502-ENG127561-Locked menu contents-FB_NAV_0 blocked
IDE11502-ENG127562-Locked menu contents-FB_NAV_1 non_blocked
IDE11502-ENG127571-Locked menu contents-FB_NAV_10 non_blocked
IDE11502-ENG127572-Locked menu contents-FB_NAV_11 non_blocked
IDE11502-ENG127573-Locked menu contents-FB_NAV_12 non_blocked
IDE11502-ENG127574-Locked menu contents-FB_NAV_13 non_blocked
IDE11502-ENG127575-Locked menu contents-FB_NAV_14 non_blocked
IDE11502-ENG127576-Locked menu contents-FB_NAV_15 non_blocked
IDE11502-ENG127577-Locked menu contents-FB_NAV_16 non_blocked
IDE11502-ENG127578-Locked menu contents-FB_NAV_17 non_blocked
IDE11502-ENG127579-Locked menu contents-FB_NAV_18 non_blocked
IDE11502-ENG127580-Locked menu contents-FB_NAV_19 non_blocked
IDE11502-ENG127563-Locked menu contents-FB_NAV_2 non_blocked
IDE11502-ENG127581-Locked menu contents-FB_NAV_20 non_blocked
IDE11502-ENG127582-Locked menu contents-FB_NAV_21 blocked
IDE11502-ENG127583-Locked menu contents-FB_NAV_22 non_blocked
IDE11502-ENG127584-Locked menu contents-FB_NAV_23 non_blocked
IDE11502-ENG127585-Locked menu contents-FB_NAV_24 non_blocked
IDE11502-ENG127586-Locked menu contents-FB_NAV_25 non_blocked
IDE11502-ENG127587-Locked menu contents-FB_NAV_26 non_blocked
IDE11502-ENG127588-Locked menu contents-FB_NAV_27 non_blocked
IDE11502-ENG127589-Locked menu contents-FB_NAV_28 non_blocked
IDE11502-ENG127590-Locked menu contents-FB_NAV_29 non_blocked
IDE11502-ENG127564-Locked menu contents-FB_NAV_3 non_blocked
IDE11502-ENG127591-Locked menu contents-FB_NAV_30 non_blocked
IDE11502-ENG127592-Locked menu contents-FB_NAV_31 non_blocked
IDE11502-ENG127593-Locked menu contents-FB_NAV_32 non_blocked
IDE11502-ENG127594-Locked menu contents-FB_NAV_33 non_blocked
IDE11502-ENG127595-Locked menu contents-FB_NAV_34 non_blocked
IDE11502-ENG127596-Locked menu contents-FB_NAV_35 non_blocked
IDE11502-ENG127597-Locked menu contents-FB_NAV_36 non_blocked
IDE11502-ENG127598-Locked menu contents-FB_NAV_37 non_blocked
IDE11502-ENG127599-Locked menu contents-FB_NAV_38 non_blocked
IDE11502-ENG127600-Locked menu contents-FB_NAV_39 non_blocked
IDE11502-ENG127565-Locked menu contents-FB_NAV_4 blocked
IDE11502-ENG127566-Locked menu contents-FB_NAV_5 non_blocked
IDE11502-ENG127567-Locked menu contents-FB_NAV_6 blocked
IDE11502-ENG127568-Locked menu contents-FB_NAV_7 non_blocked
IDE11502-ENG127569-Locked menu contents-FB_NAV_8 non_blocked
IDE11502-ENG127570-Locked menu contents-FB_NAV_9 blocked
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0 blocked
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1 non_blocked
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10 non_blocked
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11 non_blocked
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12 non_blocked
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13 non_blocked
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14 non_blocked
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15 non_blocked
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2 non_blocked
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3 non_blocked
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4 blocked
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5 blocked
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6 blocked
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7 blocked
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8 non_blocked
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9 non_blocked
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0 non_blocked
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1 non_blocked
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10 non_blocked
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11 non_blocked
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12 non_blocked
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13 non_blocked
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14 non_blocked
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15 non_blocked
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2 non_blocked
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3 blocked
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4 blocked
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5 blocked
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6 blocked
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7 blocked
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8 non_blocked
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9 non_blocked
IDE11503-Tuner for satellite radio: preparation 7
MAS00951-Bluetooth On
MAS01968-Fan normal
MAS02809-MAS02870-Check tone frequency-High note frequency range 4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range 1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range 100 Hz
MAS03782-WLAN On
ENG117917-BAP_Debug_Mode_Release not_released
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization not activated
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer not activated
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off not activated
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high not activated
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill not activated
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC activated
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer not activated
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off not activated
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high activated
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill not activated
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key not activated
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer not activated
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off not activated
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high not activated
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill not activated
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue not activated
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer not activated
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off not activated
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high not activated
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill not activated
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper not activated
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer not activated
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off not activated
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high not activated
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill not activated
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination activated
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer not activated
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off not activated
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high activated
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill not activated
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope not activated
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer not activated
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off not activated
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high not activated
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill not activated
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification not activated
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer not activated
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off not activated
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high not activated
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill not activated
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating not activated
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer not activated
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off not activated
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high not activated
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill not activated
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv activated
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer not activated
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off not activated
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high activated
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill not activated
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management not activated
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer not activated
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off not activated
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high not activated
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill not activated
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE activated
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer not activated
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off not activated
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high activated
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill not activated
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer activated
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer not activated
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off not activated
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high activated
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill not activated
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function activated
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer not activated
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off not activated
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high activated
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill not activated
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror activated
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer not activated
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off not activated
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high activated
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill not activated
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking activated
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer not activated
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off not activated
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high activated
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill not activated
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master activated
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer not activated
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off not activated
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high activated
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill not activated
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma activated
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer not activated
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off not activated
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high activated
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill not activated
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration activated
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer not activated
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off not activated
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high activated
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill not activated
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock activated
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer not activated
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off not activated
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high activated
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill not activated
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass activated
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer not activated
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off not activated
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high activated
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill not activated
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist not activated
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer not activated
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off not activated
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high not activated
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill not activated
ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration not activated
ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer not activated
ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off not activated
ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high not activated
ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill not activated
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school not activated
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer not activated
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off not activated
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high not activated
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill not activated
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall activated
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer not activated
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off not activated
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high activated
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill not activated
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist not activated
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer not activated
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off not activated
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high not activated
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill not activated
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI activated
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer not activated
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off not activated
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high activated
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill not activated
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination activated
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer not activated
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off not activated
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high activated
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill not activated
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display not activated
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer not activated
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off not activated
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high not activated
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill not activated
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid not activated
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer not activated
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off not activated
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high not activated
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill not activated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant not activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high not activated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off not activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill not activated
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker not activated
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer not activated
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off not activated
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high not activated
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill not activated
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision not activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high not activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill not activated
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level not activated
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer not activated
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off not activated
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high not activated
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill not activated
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill not activated
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist not activated
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer not activated
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off not activated
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high not activated
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill not activated
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk activated
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer not activated
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off not activated
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high activated
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill not activated
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment not activated
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer not activated
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off not activated
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high not activated
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill not activated
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load not activated
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer not activated
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off not activated
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high not activated
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill not activated
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification not activated
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer not activated
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off not activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high not activated
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill not activated
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration not activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer not activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high not activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill not activated
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic not activated
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer not activated
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off not activated
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high not activated
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill not activated
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia activated
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer not activated
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off not activated
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high activated
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill not activated
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view not activated
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer not activated
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off not activated
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high not activated
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill not activated
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions not activated
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer not activated
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off not activated
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high not activated
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill not activated
ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler not activated
ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer not activated
ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off not activated
ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high not activated
ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill not activated
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI not activated
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer not activated
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off not activated
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high not activated
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill not activated
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons not activated
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer not activated
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off not activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high not activated
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill not activated
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant not activated
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer not activated
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off not activated
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high not activated
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill not activated
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner not activated
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer not activated
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off not activated
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high not activated
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill not activated
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo not activated
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer not activated
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off not activated
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high not activated
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill not activated
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating activated
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer not activated
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off not activated
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high activated
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill not activated
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin activated
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer not activated
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off not activated
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high activated
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill not activated
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition not activated
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer not activated
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off not activated
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high not activated
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill not activated
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows activated
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer not activated
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off not activated
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high activated
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill not activated
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper activated
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer not activated
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off not activated
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high activated
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill not activated
ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol not activated
ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer not activated
ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off not activated
ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high not activated
ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill not activated
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05 activated
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus Databus extended
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06 not activated
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus Suspension data bus
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D not activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus Databus Infotainment
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24 not activated
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus not activated
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03 not activated
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus Comfort data bus
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B activated
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus Terminal 15
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25 not activated
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus Databus drivetrain
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23 activated
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus Databus Infotainment
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26 activated
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus Suspension data bus
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D activated
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus Comfort data bus
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17 activated
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus Databus Infotainment
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16 not activated
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus Comfort data bus
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01 activated
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus Comfort data bus
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02 not activated
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus Comfort data bus
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11 activated
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus Comfort data bus
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15 not activated
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus not activated
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10 not activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus Comfort data bus
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33 activated
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus Comfort data bus
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C Comfort data bus
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C not activated
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37 activated
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus Comfort data bus
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09 activated
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus Comfort data bus
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04 not activated
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus Comfort data bus
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D not activated
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus Databus drivetrain
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08 activated
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus Comfort data bus
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19 activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus Databus extended
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F activated
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus Comfort data bus
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34 not activated
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34 Databus Infotainment
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E activated
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus Comfort data bus
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18 not activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus not activated
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus Terminal 15
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20 not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus Comfort data bus
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A not activated
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A Databus extended
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39 not activated
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39 Databus Infotainment
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E not activated
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus Comfort data bus
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F not activated
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus Databus drivetrain
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B not activated
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B Comfort data bus
ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F not activated
ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F Comfort data bus
ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E not activated
ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E Comfort data bus
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12 activated
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus Comfort data bus
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E not activated
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus not activated
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35 not activated
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35 Comfort data bus
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27 not activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus Databus Infotainment
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A not activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus Databus extended
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07 activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus Suspension data bus
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 not activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus Databus extended
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36 not activated
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36 Comfort data bus
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C not activated
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus Comfort data bus
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14 not activated
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus Terminal 15
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13 activated
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus Comfort data bus
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B not activated
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus Databus Infotainment
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22 not activated
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus Databus Infotainment
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C activated
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus Comfort data bus
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key Not available
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus Comfort data bus
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school Not available
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus Databus Infotainment
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL Available
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus Databus Infotainment
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level Not available
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus Databus drivetrain
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering Available
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus Suspension data bus
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN Available
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus Comfort data bus
ENG122230-ENG11025-Dashboard_Display_Configuration-ability_switch_nav_maps OFF
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture OFF
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart OFF
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode RLE
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution resolution_1
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode OFF
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most OFF
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode RLE
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution resolution_1
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode OFF
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart OFF
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1 0
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2 50
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3 100
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1 0
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2 50
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3 100
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1 0
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2 50
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3 100
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1 0
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2 50
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3 100
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1 0
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2 10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3 100
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4 150
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5 220
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6 253
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1 1%
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2 1%
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3 8%
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4 20%
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5 60%
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6 100%
ENG10564-ENG10977-Key_code_monitoring-monitoring_keycode_0x00_0x07 0
ENG10564-ENG10978-Key_code_monitoring-monitoring_keycode_0x08_0x0F 0
ENG10564-ENG10979-Key_code_monitoring-monitoring_keycode_0x10_0x17 0
ENG10564-ENG10980-Key_code_monitoring-monitoring_keycode_0x18_0x1F 0
ENG10564-ENG10981-Key_code_monitoring-monitoring_keycode_0x20_0x27 0
ENG10564-ENG10982-Key_code_monitoring-monitoring_keycode_0x28_0x2F 0
ENG10564-ENG10983-Key_code_monitoring-monitoring_keycode_0x30_0x37 0
ENG10564-ENG10984-Key_code_monitoring-monitoring_keycode_0x38_0x3F 0
ENG10564-ENG10985-Key_code_monitoring-monitoring_keycode_0x40_0x47 0
ENG10564-ENG10986-Key_code_monitoring-monitoring_keycode_0x48_0x4F 0
ENG10564-ENG10987-Key_code_monitoring-monitoring_keycode_0x50_0x57 0
ENG10564-ENG10988-Key_code_monitoring-monitoring_keycode_0x58_0x5F 0
ENG10564-ENG10989-Key_code_monitoring-monitoring_keycode_0x60_0x67 0
ENG10564-ENG10990-Key_code_monitoring-monitoring_keycode_0x68_0x6F 0
ENG10564-ENG10991-Key_code_monitoring-monitoring_keycode_0x70_0x77 0
ENG10564-ENG10992-Key_code_monitoring-monitoring_keycode_0x78_0x7F 0
ENG10564-ENG10993-Key_code_monitoring-monitoring_keycode_0x80_0x87 0
ENG10564-ENG10994-Key_code_monitoring-monitoring_keycode_0x88_0x8F 0
ENG10564-ENG10995-Key_code_monitoring-monitoring_keycode_0x90_0x97 0
ENG10564-ENG10996-Key_code_monitoring-monitoring_keycode_0x98_0x9F 0
ENG10564-ENG10997-Key_code_monitoring-monitoring_keycode_0xA0_0xA7 0
ENG10564-ENG10998-Key_code_monitoring-monitoring_keycode_0xA8_0xAF 0
ENG10564-ENG10999-Key_code_monitoring-monitoring_keycode_0xB0_0xB7 0
ENG10564-ENG11000-Key_code_monitoring-monitoring_keycode_0xB8_0xBF 0
ENG10564-ENG11001-Key_code_monitoring-monitoring_keycode_0xC0_0xC7 0
ENG10564-ENG11002-Key_code_monitoring-monitoring_keycode_0xC8_0xCF 0
ENG10564-ENG11003-Key_code_monitoring-monitoring_keycode_0xD0_0xD7 0
ENG10564-ENG11004-Key_code_monitoring-monitoring_keycode_0xD8_0xDF 0
ENG10564-ENG11005-Key_code_monitoring-monitoring_keycode_0xE0_0xE7 0
ENG10564-ENG11006-Key_code_monitoring-monitoring_keycode_0xE8_0xEF 0
ENG10564-ENG11007-Key_code_monitoring-monitoring_keycode_0xF0_0xF7 0
ENG10564-ENG11008-Key_code_monitoring-monitoring_keycode_0xF8_0xFF 0
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation 04 01 52 04 52 10 52 40 52 32 00 64 00 3C 00 7C 01 1D 01 50 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 02 00 A8
ENG117809-p_damping_Display 5 ms
ENG117808-p_HMI_Display 13%
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset 0
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset 0
ENG117919-Startup_Screen_Sticker_HMI 00 01
Elapsed Time: 00:29
