Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 2017 NAR Golf Alltrack SEL with Driver assist
    United States
    11/9/2018 Update. I don't own this vehicle anymore. VW decided to buy it back (3 interior water leaks in 6 months) in the last quarter of 2017. That was finalized in Jan, 2018 but I didn't update this thread.
    The replacement vehicle is a low-spec (non sunroof!) 2018 Alltrack S: https://forums.ross-tech.com/showthr...nd-1-8T-(CXBB)
    Since we're missing ASAM data for the 01-Engine and 13-ACC module I can't run/post maps on those controllers. If I forget to report back and someone needs info please bump this up.
    Delivery condition scan:
    Wednesday,11,January,2017,19:50:57:08929
    VCDS Version: 17.1.1.0 (x64)  HEX-NET CB: 0.4334.4
    Data version: 20170106 DS267.0
    VIN: 3VWH17AU6HM508859   License Plate: ALLTRACK DELIVERY SCAN
    Mileage: 490km-304mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 55 5F
              75 A5
    VIN: 3VWH17AU6HM508859   Mileage: 490km-304miles
    Address 01: Engine (J623-CXBB)       Labels: 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 L    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 311D00322466002F1000
       Shop #: WSC 00066 790 00064
       ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
       ROD: N/A
       VCID: C5CD52B14483876926-8090
    No ASAM data for: "EV_ECM18TFS0208V0906264L" (VW37)
    Readiness: 0000 0100
       Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H54 4901
       Revision: 06354004    Serial number: TFK01607131131
       ROD: EV_TCMDQ250021.rod
       VCID: 9975CEC198BBD389B2-80CC
       Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
       Component: ESC           H62 0736
       Revision: 00000000    Serial number: 61866000000710
       Coding: 43FA6AA134200974807F130581CC29C2562C9001C881943C16435052E02903
       Shop #: WSC 01383 790 50316
       VCID: FBB9F44972C7019900-80AE
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 51
                        Mileage: 343 km
                        Date: 2017.01.07
                        Time: 02:58:44
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0406490428
       Coding: 032C0C
       VCID: BB3934493247C19940-80EE
       Part No SW: 5GM 907 044 C    HW: 5GM 907 044 C
       Revision: 00001K03
       Coding: 02020024200100000105000012111402
       ROD: EV_ACClimaBHBVW37X_005_VW37.rod
       VCID: C4CB4FB54FB9BE6131-8090
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 865820071600N2
       Coding: 00511B464041A2E969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00200
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: FAB7F14D7DFD38911B-80AE
       Component: WWS    160829  043 0581
       Serial number:         160905084823
       Component: RLHS  042 0105
       Serial number: S2Y16M07D27H22M38S53
       Coding: 00A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS22.409  H03 0004
       Serial number: 0000FST000ZOW1K00000
       Coding: 191800
       Roof Blind:
       Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS22.409  H03 0004
       Serial number: 0000FST000ZOVTB00000
       Coding: 191800
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0054
       Revision: --------    Serial number: 39431619801141
       Coding: 0031163011
       ASAM Dataset: EV_EPHVA2CAU3700000 003021
       ROD: EV_EPHVA2CAU3700000_003_VW37.rod
       VCID: C7D158B97E8F9579D4-8092
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: 350000C141FFC428949C8045000016
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: N/A
    No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
       Serial number: 003GCR05E0WN
       Occupant Detection:
       Serial number: IBH000000000005PD6GP
       Coding: 303137
       Subsystem 2 - Part No SW: -----------    HW: 480 000 907 16
       Serial number: 35700000000DA661DC1Y
       Subsystem 3 - Part No SW: -----------    HW: 480 000 907 16
       Serial number: 358000000000B861DC1P
       Subsystem 4 - Part No SW: -----------    HW: 480 402 806 16
       Serial number: 3510002AF20FC4C122AA
       Subsystem 5 - Part No SW: -----------    HW: 480 402 806 16
       Serial number: 3520002BD20FC742F0AH
       Subsystem 6 - Part No SW: -----------    HW: 480 400 907 16
       Serial number: 3550002A120FC743F3EF
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 907 16
       Serial number: 3560002A120FC745209/
       Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160714400559
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: F3A9DC695A9749D958-80A6
       Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
       Component: KOMBI         244 8311
       Coding: 0BA4101DED90CF0502886A031000000000000000
       VCID: A60FF53DD9C56C710F-80F2
       Revision: --------    Serial number: 25051610521102
       Coding: 0901000830085900FB00221A1E0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07030
       ROD: EV_GatewConti_013.rod
       VCID: FCBBF75577C906A109-80A8
       Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
       Serial number: 29160001122040086225
       Coding: 35FFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: WECHSELRICHTE  H53 0041
       Serial number: 0082197
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Serial number: HA1-00004.06.16
       Coding: 0001
       VCID: CAD7618D6D9D6811CB-809E
       Revision: 00000000    Serial number: 16000134029002
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_SK25.rod
       VCID: B42B1F751F190EE181-80E0
       Serial number: 160816060509V7
       Coding: 003A13200000020000000000
       VCID: C3C94CA94AB7B95908-8096
       Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
       Serial number: 00000000000004031856
       Coding: 011000
       Component: EPS_MQB_ZFLS  129 1072
       Coding: 9302
       ROD: EV_SteerAssisMQB_013.rod
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA0238FZ
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: ED9DCA113CB39F298E-80B8
       Serial number: 210416060501M5
       VCID: C2C749AD55ADB05103-8096
       Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
       Serial number: 00000000000004023823
       Coding: 091000
       Coding: 062A00010B000400
       VCID: C0C343A55BA1A24115-8094
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0751
       Coding: 027302020000000051220002001808009F0108F401200105C6
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: B227196DE50D00D193-80E6
       Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
       Component: ABT_Std-2_Nav  H53 1031
       Serial number: VWZ8Z9SJX00AN0
       Subsystem 2 - Part No SW: 3G0 919 866 AC    HW: -----------
       Component: NAR 2016/17  --- 0445
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0568
       Coding: 02730202C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 06071611P21442
       Coding: 000307020002020100221344C040490084000E100020
       ROD: EV_MFKBoschMQBB.rod
    End----------(Elapsed Time: 02:12, VBatt start/end: 14.4V/14.4V)-----------
    Gateway Installation List:  5Q0 907 530 AM
    PR Data:
    Vehicle Identification No.	3VWH17AU6HM508859
    Model	golf variant 1,8
    GOV
    Date of production	13.09.2016
    Year	2017
    Sales type	BX5CN7
    Engine Code	CXBB
    Transmission Code	QMH
    Axle drive	6A
    Equipment	 YW
    Roof color	0Q
    Exterior color / Paint Code	0Q / C9A
    "Charism"	2H5	Driving Profile Selection and
    conventional shock absorber
    "Multimedia", video/DVD/notebook connection	9WT	MirrorLink
    Activated carbon canister	1E7	Activated carbon canister ORVR, for
    intensified evaporation system,
    siphoning device for fueling
    Additional child seat anchors	3B7	Child seat anchorage as per Canadian
    requirements a. ISOFIX child seat system
    Additional tires (winter tires)	2WA	Without additional tires
    Additional warning lights	9TC	Additional reflectors (door area)
    Air bag	4UM	Driver and front passenger airbag (NAR)
    with front passenger airbag deactivation
    (2-stage)
    Alternative drive module	0K0	Without alternative drive system
    Antennas	8L6	"diversity" window antenna
    Anti-theft protection system	7AI	Electronic engine immobilizer with panic
    alarm
    Audio-response system/voice control	QH1	Voice control
    Auxiliary heating	9M0	Without auxiliary heater/fuel-fired
    parking heater
    Backrest release	3H0	Without backrest release for front seats
    Base engine	TI5	4-cylinder SI engine 1.8 l
    unit 06K.K
    Batteries	J1L	Battery 280 A (60 Ah)
    Battery/alternator capacity	NY0	Standard battery/alternator capacity
    Body measures	5C1	Body measures for increased safety
    requirements
    Body style	K8D	Wagon/Avant
    Brake pad wear indicator	9U0	Without brake pad wear indicator
    Brake type, front	1ZD	Disk brakes in front (Geomet D)
    Brake type, rear	1KS	Disk brakes in rear (Geomet D)
    Braking systems	1AT	Electronic stability control (ESC)
    Breakaway interior mirror	4L6	Breakaway interior rearview mirror,
    auto-dimming
    Bumper	2JE	Partially painted bumpers
    Camera systems/accident sensors	KA1	With rear view camera system (type 1)
    Camera/distance sensor	QK1	With multifunction camera
    Carrier frequency for radio remote control	5D2	Carrier frequency 315 MHz
    CD ROM/DVD/SD card	77E	SD card (NAR)
    Center armrest	6E3	Center armrest in front
    Center console	3D6	Center console
    Center rear seat belts	3C8	3-point seat belt, center rear with US
    label
    Chrome work package	QJ3	Chrome package
    (type 2)
    Climatic zones	0Y4	Cold and tropical climatic zones (US)
    Compass/traffic sign display	QR8	Without dynamic road sign display
    Component part sets with country-specific design requirements	B0D	Component parts set, complying with
    vehicle type for USA (without
    California), various parts
    Components with special surface appearance	6FJ	Black exterior mirror housings
    Cruise control	8T3	Adaptive cruise control
    Delivery equipment	2A8	Delivery equipment for shipment
    Differential lock	1Y3	Electronic differential lock XDS
    dynamic traction control
    Door and lid locking system	4F6	Central locking system "Keyless Entry"
    without SAFELOCK (NAR)
    Door and side trim panels	3LJ	Door and side trim panel in foam film,
    insert in leatherette
    Doors	0A2	4 doors
    Drawers under front seats	QN0	Without drawers under front seats
    Drive layout	1X1	Four wheel drive
    Driving on the left/on the right	AV2	Driving on the right (NAR)
    ECO function for driving profiles and drive select	EF0	Without ECO function
    Electric interface for external use	UI4	Electric interface for external use,
    AUX-IN jack, USB (iPod-capable)
    Electronic engine sound measures	GM1	Standard electronic engine sound
    Emission standard	0GT	Emission standard SULEV
    Engine cooling system	8Z6	Hot country
    Engine specifications	D6J	4-cylinder SI engine 1.8 l/125 kW (16V)
    turbo FSI, homogeneous, base engine is
    TH2/TJ2/TF6/TQ6/TF5/TK5/TI5
    Equipment levels	A8T	Executive equipment
    Exhaust tailpipe	0P1	Rear side exhaust tailpipe
    Extended safety system	7W0	Without extended safety system
    Exterior mirror setting	6XN	Exterior mirrors: power-adjustable,
    separately heated
    Fire extinguisher	6A0	Without fire extinguisher
    First aid kit / warning triangle	1T0	Without first aid kit and warning
    triangle
    Floor mats	0TD	Floor mats in front and rear
    Folding table	1U8	Without folding table on front seat
    backrest
    Fresh air intake for passenger compartment (with particulate filter)	2V5	Fresh air intake system with combination
    filter
    Front Assist	6K3	Forward collision warning incl.
    autonomous emergency braking,
    for adaptive cruise control "low"
    Front fog light/additional headlight	8WH	Front fog lamp and cornering lamp
    Front seats	Q4H	Sports comfort seats in front
    Front stabilizer	0AF	Front stabilizer
    Front underbody guard	1SB	Additional front underbody guard
    Fuel quantity for initial filling	1Z0	Initial standard fuel filling
    Fuel systems	1A5	Fuel system for SI engine
    Gearshift knob/handle	6Q2	Leather gearshift knob/handle
    General operating permit, alterations	C00	Operating permit, initial registration
    Generators	9G2	Alternator 100-150 A
    Hand brake lever handle	6PC	Hand brake lever handle in leather
    Headlight	8IM	Gas-discharge headlamps with
    cornering light
    Headlight activation	9C9	Separate daytime running lights and
    automatic headlamp activation NAR with
    Coming Home and Leaving Home feature
    Headlight washer system	8X0	Without headlamp washer system
    Headlight-range adjustment	8Q5	Headlight range adjustment, automatic/
    dynamic, with cornering light (AFS 1)
    Headrests	5ZF	Front head restraints
    Heat accumulator system/additional heater	7E0	Without heat accumulator/auxiliary
    heater
    Heated washer nozzles	9T1	Heated washer nozzles in front
    Heating and air conditioning system	9AK	Climatronic with impact pressure
    control, CFC-free
    Hill hold control	UG1	Hill start assist
    Horns	8Y1	Two-tone horn
    Identification plates	1EB	Without identification plate
    Insert for the filling up of unleaded fuel/fuel type	2G7	Filler neck module 1 with insert
    Inserts	5MQ	Decorative inserts
    Installation differentiation for vehicle components	0ES	Installation differentiation for
    transmission DQ250
    -- vehicle components --
    Instrument inserts	U5C	Instrument cluster, mph speedometer
    Interior light in foot area	6T1	Interior light in footwell
    Left exterior mirror	5SH	Left exterior mirror: flat (US)
    License plate carrier	31N	Front and rear license plate carrier
    (NAR)
    License plate lighting	KL1	LED license plate lighting
    Light assistance system	8G1	High-beam control
    Light package (lighting)	QQ3	Interior ambient lighting and surround
    lighting
    Lockable wheel bolts	1PF	Standard wheel bolts
    Luggage compartment cover	3U2	Sliding trunk cover
    Luggage net/pocket on backrest(s)	4U5	Luggage pockets on backrest
    Lumbar support	7P7	Power-adjustable lumbar support for left
    front seat
    Manufacturing sequence differentiation	0FA	Standard manufacturing sequence
    Mass damper for steering wheels	1Q2	Mass damper for steering wheel, 36 Hz
    Molding roof liner	6NA	Unsplit molded headliner
    Moldings	4ZN	Bright moldings
    Multi-function display/trip computer	9S5	Multi-function display/on-board computer
    "Medium"
    Nameplate set	0NW	Nameplate set "TSI"
    Navigation device	7UF	Navigation system - Standard
    Online services	EL2	Online service, with OCU, without head
    unit coding, without engine immobilizer
    interconnection
    Operating voltage	9Z2	12-V operating voltage and 115-V
    inverter
    Outer rear seat belts	3ZD	3-point seat belts, outer rear with
    US label
    Owner's manuals	0VM	Information kit in American English
    Paint coating	FB0	Standard paint coating
    Paint preservative/transit coating	5K7	Transport protection film (minimum
    protection) with additional transport
    protection measures
    Park distance control	7X5	Park assist
    Parking brake	UH0	Parking brake
    Partition	3CA	Without partition
    Pedal cluster	VF1	Pedal cluster
    Pedestrian protection	VL0	Standard pedestrian protection measures
    Platform module floor pan, rear	4P3	Rear floor panel module, type 4
    Preparation for two-way radio installation	9D0	Without preparation for two-way radio
    installation
    Radiator grille	6KG	Radiator grille
    Radios	I8E	Standard radio (Gen2)
    Reading light	8S6	2 reading lights in front
    Rear axle	0N4	4-link rear suspension
    Rear cargo area	3GD	Plane rear cargo area
    Rear fog light	8TA	Without rear fog lamp
    Rear headrests	3Q9	Three rear head restraints
    Rear seat catch	UK3	Mechanical rear seat release
    Rear seats	3NU	Rear seat bench unsplit, backrest split
    folding with center armrest
    Rear spoiler	5J0	Without rear spoiler
    Rear stabilizer	0BF	Rear stabilizer
    Rear window wiper and washer system	8M1	Rear window wiper and washer system
    with intermittent control
    Refrigerant	KK1	Refrigerant R134a
    Refrigerator	1W2	Glove compartment cooling system
    Regional code for radio	ER3	Regional code " NAR " for radio
    Rest Assist	EM0	Without driver alert system
    Restraint systems, front	4QQ	3-point seat belts with tensioner in
    front and height adjustment, US label
    Right exterior mirror	5RR	Right exterior mirror: convex (US)
    Roof insert/convertible top	3FU	Big roof system
    Roof rails/roof load rack	3S1	Bright roof rails
    Scuff plates	7M5	Without protective film for scuff plate
    Seat adjustment	3L9	Power-adjustable left seat, right seat
    with power-adjustable backrest
    Seat belt check	9P7	Visual and acoustic seat belt reminder,
    electric contact in buckle
    Seat covering	N4S	Seat trim covers in leatherette
    Seat heater	4A3	Seat heater for front seats
    separately controlled
    Service indicator	QI7	Service indicator 10 000 miles or 1 year
    (fix)
    Service interval prolongation	QG1	Service interval prolongation
    Shock absorption, chassis, front	G25	Shock absorption in front
    Shock absorption, chassis, rear	UC5	Rear shock absorption
    Side air bag	4X3	Side airbag in front, with curtain
    airbag
    Side and rear windows	4KC	Side and rear windows in heat-insulating
    glass
    Side assist/lane departure warning	7Y4	Lane keeping system
    Smoking/non-smoking package	9JF	Non-smoker's package (NAR)
    Socket	7B3	12-volt socket(s)
    Spare wheel/breakdown set	1G9	Space-saving spare wheel for temporary
    use, radial tire
    (5-hole)
    Speaker installation	8RU	Sound system with subwoofer "branded"
    Special editions	E0A	No special edition
    Special labels/plates	0SC	Labels/plates in English
    Start/stop system/regenerative braking	7L3	Without start-stop system without
    Steering	1N3	Speed-related variable steering assist
    (Servotronic)
    Steering system arrangement	L0L	Left-hand drive
    Steering wheels	1XX	Leather-wrapped multifunction sports
    steering wheel w/ tiptronic
    Subsequent guarantee	EA0	Without follow-on warranty
    Sun visors	5XX	Sun visors with mirror, illuminated
    (NAR)
    Taillight assemblies	8SJ	Tail lamp assembly, standard design
    (for NAR)
    Telephone/telematics	9ZX	Mobile phone interface
    Tire pressure warning light	7K6	Indirect tire pressure monitoring system
    Tire suppliers	V0A	Tires without specification of tire
    brand
    Tires	I85	All-season tires 225/45 R18 95H xl
    (NAR)
    Tool kit and jack	1S1	Tool kit and jack
    Trailer hitch	1D0	Without trailer hitch
    Transmission specifications	G0R	6-speed automatic transmission for
    four-wheel drive vehicle
    Tray	7N0	Without overhead storage compartment
    Tray areas package	QE0	Without storage compartment package/box
    TV reception/digital radio reception	QU8	Satellite radio reception USA
    Type approval countries/countries with special requirements	BU2	Legal requirements for USA 2
    States with CARB requirement
    Vehicle class differentiation units/platform components	7II	Vehicle class differentiation -5GM-
    Vehicle inlet	ES0	Without vehicle inlet
    Vehicle tracking system	7G0	Without preparation for VTS
    (vehicle tracking system)
    Versions	FM0	Basic equipment variant
    Washer fluid level indicator	8W1	Washer fluid level indicator
    Weight category front axle	L48	Suspension range 48
    installation control only, no
    requirement forecast
    Weight category rear axle	0YM	Weight range 12
    Wheel covers	1NL	Trims for alloy wheels
    Wheelbases	0B1	Wheelbase
    Wheels	U90	Alloy wheels 7.5J x 18
    Window regulator	4R4	Power windows with comfort operation and
    circuit breaker
    Windshield glass type	4GF	Windshield in heat-insulating glass
    Windshield wiper intermittent control	8N6	Windshield wiper intermittent control
    with light/rain sensor
     	P10	Alltrack SEL package
     	P42	Driver assistance Alltrack SEL
     	W02	Alltrack SE package
    Press release info: https://newspress-vwusamedia.s3.amaz...ck+Release.pdf
  2. Likes Uwe, Andy liked this post
  3. #2
    United States
    01-Engine
    These are blank due to ASAM data.
    blockmap-01-8V0-906-264-L.CSV
    ;SW:8V0-906-264-L   HW:06K-907-425-B ---  Engine
    ;Component:1.8l R4 TFSI  H13 0002	 Coding:311D00322466002F1000
    ;EV_ECM18TFS0208V0906264L	1003
    ;Wednesday	11	January	2017	19:57:05:08929
    ;VCDS Version: Release 17.1.1 (x64)  Data version: 20170106 DS267.0
    ;VCID: C5CD52B14483876926-8090
    Group	Description	Actual
    Elapsed Time: 00:00
    adpmap-01-8V0-906-264-L.CSV
    Elapsed Time: 00:00
    Edit, we fixed the missing files a while ago but I forgot to update this thread. Using our latest Data Version 20170413 (which rolled out with Beta 17.2.6):
    ;EV_ECM18TFS0208V0906264L	1003	EV_ECM18TFS0208V0906264L.rod
    ;Wednesday	3	May	2017	19:03:27:59530
    ;VCDS Version: Beta 17.4.2 (x64)  Data version: 20170413 DS270.4
    ;VCID: C5C2108C4449EC6FFC-8090
    IDE00011	Vehicle Identification Number (VIN)	3VWH17AU6HM50885
    IDE00018	Voltage terminal 15	12.578	 V
    IDE00019	Voltage terminal 30	12.91	 V
    IDE00021	Engine speed	0	 /min
    IDE00025	Coolant temperature	13	 °C
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00076	Status of initial fuel filling	was not yet started
    IDE00078	Time since engine start	0	 s
    IDE00083	Throttle valve position (absolute)	16.1	 %
    IDE00084	Absolute load value	0	 %
    IDE00085	Normed load value	0	 %
    IDE00086	Accelerator position	15	 %
    IDE00090	selected gear	Shifting process active
    IDE00097	OBD - requirements for which this vehicle is designed	OBD and OBD II
    IDE00102	Control Module temperature	34	 °C
    IDE00148	Median injection timing	0	 ms
    IDE00149	Ignition angle of current cylinder: actual value	0	 °
    IDE00150	Pressure in brake booster	1.15	 bar
    IDE00151	Oil fill level	85	 mm
    IDE00155	Timing angle retardation cylinder 1	0	 °
    IDE00156	Timing angle retardation cylinder 2	0	 °
    IDE00157	Timing angle retardation cylinder 3	0	 °
    IDE00158	Timing angle retardation cylinder 4	0	 °
    IDE00167	Exhaust temperature 1 bank 1	13.5	 °C
    IDE00172	A/C compressor torque	0	 Nm
    IDE00173	Cruise Control System: specified speed	0	 km/h
    IDE00174	Camshaft adjustment: exhaust: bank 1: specified value	0	 °
    IDE00175	Camshaft adjustment: exhaust: bank 1: actual value	0	 °
    IDE00178	Camshaft adjustment intake bank 1: specified value	0	 °
    IDE00179	Camshaft adjustment intake bank 1: actual value	0	 °
    IDE00182	Camshaft adaptation intake bank 1: phase position	-0.3	 °
    IDE00184	Camshaft adaptation exhaust bank 1: phase position	47.6	 °
    IDE00186	Fuel low pressure: actual value	11.003	 bar
    IDE00187	Coolant temperature at engine start	12.7	 °C
    IDE00188	Fuel high pressure: actual value	6.3	 bar
    IDE00189	Activation of fuel pump electronics	10	 %
    IDE00190	Charge air pressure specified value	0.97	 bar
    IDE00191	Charge air pressure: actual value	0.984	 bar
    IDE00192	Coolant temperature at radiator outlet: actual value	15.5	 °C
    IDE00193	Coolant temperature at engine outlet: specified value	13.5	 °C
    IDE00194	Coolant temperature at radiator output: specified value	-48	 °C
    IDE00195	Coolant temperature difference between engine and radiator	0	 °C
    IDE00196	Engine oil temperature	12	 °C
    IDE00199	Mean engine air mass	0	 kg/h
    IDE00200	Median vehicle speed	0	 km/h
    IDE00201	High fuel pressure: specified value	130.1	 bar
    IDE00202	Low fuel pressure: specified value	5	 bar
    IDE00252	Brake system vacuum pump	Pump off
    IDE00304	Fuel level	54	 l
    IDE00322	Status of basic setting	not active
    IDE00323	Security Access: Number of invalid keys	0
    IDE00348	Intake air temperature	18	 °C
    IDE00349	Throttle valve position: normed	5	 %
    IDE00350	Air mass: specified value	0	 kg/h
    IDE00355	Cruise Control System (CCS): status	main switch off
    IDE00357	Fuel temperature	12.7	 °C
    IDE00358	Limitation: torque	290	 Nm
    IDE00371	Fuel consumption	0	 l/h
    IDE00375	Generator: load signal	0.03	 %
    IDE00380	Coolant fan 1: activation	10.16	 %
    IDE00381	Coolant fan 2: activation	0	 %
    IDE00392	Accelerator pedal: sensor voltage 1	0.752	 V
    IDE00393	Accelerator pedal: sensor voltage 2	0.366	 V
    IDE00396	Charge Pressure Actuator: acknowledgment	2.402	 V
    IDE00400	Intake manifold Runner Control (IMRC): activation	100	 %
    IDE00401	Intake manifold Runner Control (IMRC): acknowledgment	100	 %
    IDE00404	Throttle valve: activation	0	 %
    IDE00405	Crankshaft speed (RPM)	0	 /min
    IDE00406	Camshaft speed (RPM)	0	 /min
    IDE00407	Rail pressure regulation: status	Control operation
    IDE00408	Engine mount 1	not active
    IDE00409	Engine mount 2	not active
    IDE00412	Starter control: terminal 50	not active
    IDE00413	Starter control: Interlock- or P/N-signal	0
    IDE00414	Starter control: relay 1	0
    IDE00415	Starter control: relay 2	0
    IDE00416	Starter control: terminal 50 acknowledgment	1
    IDE00417	Starter control: shut-off conditions 1	00 00
    IDE00445	Unlearning counter according OBD	255
    IDE00450-ENG124478	Operating Instructions-Test_Program_Requested Action	0
    IDE00451	Currently running routine	Unknown
    IDE00472	Mean injection quantity	45	 mg/stroke
    IDE00474	Ambient air pressure	98	 kPa abs
    IDE00476	Fuel Metering Valve	0	 %
    IDE00477	Torque request: sum of auxiliary aggregate	0	 Nm
    IDE00478	Engine-drag torque	32.2	 Nm
    IDE00482	Limitation: torque of clutch protection	1024	 Nm
    IDE00495	Calculated oil temperature	12	 °C
    IDE00496	Activation of oil pressure switch valve	High pressure
    IDE00497-MAS00627	Status of oil pressure switches-Oil pressure switch for high pressure	Open
    IDE00497-MAS00628	Status of oil pressure switches-Oil pressure switch for low pressure	Open
    IDE00556	Outside air temperature	14	 °C
    IDE00559-MAS04135	Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Oxygen sensor value	0	 lambda
    IDE00559-MAS04136	Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Current	0	 mA
    IDE00560-MAS04121	Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage	1.275	 V
    IDE00560-MAS04122	Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation	99.2	 %
    IDE00582	Equivalence ratio target value	1	 Lambda
    IDE00583	Throttle valve specified value	5	 %
    IDE00584	Distance driven since erasing DTC memory	2302	 km
    IDE00585	Dist. driven with exh. Malfunction Indicator Lamp activated	0	 km
    IDE00588	Fuel tank fill level	100	 %
    IDE00589	Fuel pressure	530	 kPa rel
    IDE00592-MAS04113	Oxygen sensor control status-Oxygen sensor control 1 status	Not available
    IDE00592-MAS04114	Oxygen sensor control status-Oxygen sensor control 2 status	Not available
    IDE00593	Ignition timing adjustment cylinder 1	0	 Degrees
    IDE00594	Absolute intake pressure	97	 kPa abs
    IDE00595-MAS01839	Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 1	installed
    IDE00595-MAS01840	Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 2	installed
    IDE00595-MAS04115	Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 3	not installed
    IDE00595-MAS04116	Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 4	not installed
    IDE00595-MAS04117	Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 1	not installed
    IDE00595-MAS04118	Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 2	not installed
    IDE00595-MAS04119	Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 3	not installed
    IDE00595-MAS04120	Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 4	not installed
    IDE00597	Long term adaptation of mixture formation bank 1	1.6	 %
    IDE00601-MAS00317	Monitoring status since erasing DTC memory-Malfunction Indicator Lamp	OFF
    IDE00601-MAS00328	Monitoring status since erasing DTC memory-Monitoring of ignition misfires	activated
    IDE00601-MAS00329	Monitoring status since erasing DTC memory-Monitoring of fuel system	activated
    IDE00601-MAS00330	Monitoring status since erasing DTC memory-Monitoring of entire system	activated
    IDE00601-MAS00331	Monitoring status since erasing DTC memory-Ignition misfire test	Unknown
    IDE00601-MAS00332	Monitoring status since erasing DTC memory-Fuel system test	Unknown
    IDE00601-MAS00333	Monitoring status since erasing DTC memory-Entire system test	completed successfully
    IDE00601-MAS00503	Monitoring status since erasing DTC memory-Number of emission-relevant DTC memory entries	0
    IDE00601-MAS04092	Monitoring status since erasing DTC memory-Monitoring of compression ignition	Not supported
    IDE00601-ENG20482	Monitoring status since erasing DTC memory-Completion status of all supported non-continuous monitors since DTCs cleared	0
    IDE00602-MAS04092	Monitoring status in current driving cycle-Monitoring of compression ignition	Not supported
    IDE00602-ENG20399	Monitoring status in current driving cycle-Completion status of all supported non-continuous monitors this monitoring cycle	No
    IDE00602-ENG20507	Monitoring status in current driving cycle-Comprehensive component monitoring completed	completed successfully
    IDE00602-ENG20447	Monitoring status in current driving cycle-Comprehensive component monitoring enabled	activated
    IDE00602-ENG20496	Monitoring status in current driving cycle-Fuel system monitoring completed	not completed successfully
    IDE00602-ENG20425	Monitoring status in current driving cycle-Fuel system monitoring enabled	activated
    IDE00602-ENG20449	Monitoring status in current driving cycle-Misfire monitoring completed	completed successfully
    IDE00602-ENG20506	Monitoring status in current driving cycle-Misfire monitoring enabled	activated
    IDE00603	Number of driving cycles since erasing DTC memory	131
    IDE00604	Short term adaptation of mixture formation bank 1	0	 %
    IDE00608	Type of fuel	Gasoline
    IDE00612	Target position of EVAP canister valve	0	 %
    IDE00727	Test steps still to be performed	0
    IDE00787	Cause for cancellation	0
    IDE00949-ENG98517	Hide cylinder-Cylinder 1	active
    IDE00949-ENG98491	Hide cylinder-Cylinder 10	not active
    IDE00949-ENG98492	Hide cylinder-Cylinder 11	not active
    IDE00949-ENG98493	Hide cylinder-Cylinder 12	not active
    IDE00949-ENG98518	Hide cylinder-Cylinder 13	not active
    IDE00949-ENG98519	Hide cylinder-Cylinder 14	not active
    IDE00949-ENG98520	Hide cylinder-Cylinder 15	not active
    IDE00949-ENG98494	Hide cylinder-Cylinder 16	not active
    IDE00949-ENG98521	Hide cylinder-Cylinder 2	active
    IDE00949-ENG98522	Hide cylinder-Cylinder 3	active
    IDE00949-ENG98523	Hide cylinder-Cylinder 4	active
    IDE00949-ENG98495	Hide cylinder-Cylinder 5	not active
    IDE00949-ENG98524	Hide cylinder-Cylinder 6	not active
    IDE00949-ENG98496	Hide cylinder-Cylinder 7	not active
    IDE00949-ENG98497	Hide cylinder-Cylinder 8	not active
    IDE00949-ENG98498	Hide cylinder-Cylinder 9	not active
    IDE00968	Compressor speed	0	 /min
    IDE01076-MAS00109	Time since ignition off-Hours	23	 H
    IDE01076-MAS00110	Time since ignition off-Minutes	44	 min
    IDE01076-MAS00111	Time since ignition off-Seconds	12	 s
    IDE01098	Test of knock sensors: short trip result	Test not started
    IDE01196	Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.	0
    IDE01266	Coolant shut-off valve	closed
    IDE01369	Intake manifold runner control (IMRC): offset closed	0	 V
    IDE01377	Throttle valve adapter: actual value	6.7	 °
    IDE01378	High fuel pressure: control deviation	123.7	 bar
    IDE01385	Wear index	0
    IDE01405-MAS05513	Status of starter activation-Bit 0	OK
    IDE01405-MAS05514	Status of starter activation-Bit 1	Before starter activation
    IDE01405-MAS05515	Status of starter activation-Bit 2	After starter activation
    IDE01638	Result O2 sensor aging test bank 1 or 3 before cat. conv.	Test not started
    IDE01644	Oxygen sensor voltage bank 1 after catalytic converter	0.523	 V
    IDE01649	Throttle valve position 1	0.815	 V
    IDE01650	Throttle valve position 2	16	 %
    IDE01665	Result of test of camshaft adjustment intake bank 1	Test not started
    IDE01667	Result of test of camshaft adjustment outlet bank 1	Test not started
    IDE01670	Short trip status for oil pressure control	Test not started
    IDE01671	Starter control: clutch switch	not pressed
    IDE01672	Starter control: automatic start	not possible
    IDE01673-MAS05513	Starter control: readiness bits-Bit 0	Mech. test of starter not complete
    IDE01673-MAS05514	Starter control: readiness bits-Bit 1	Test of starter relay switching contacts not complete
    IDE01673-MAS05515	Starter control: readiness bits-Bit 2	Test of starter relay activation not complete
    IDE01673-MAS05516	Starter control: readiness bits-Bit 3	Test of terminal 50R return measuring line not completed
    IDE01673-MAS05517	Starter control: readiness bits-Bit 4	Test of starter request double injection not complete
    IDE01673-MAS05518	Starter control: readiness bits-Bit 5	Test of PN signal not complete
    IDE01673-MAS05519	Starter control: readiness bits-Bit 6	Test of interlock switch not complete
    IDE01673-MAS05520	Starter control: readiness bits-Bit 7	Test of clutch pedal switch not complete
    IDE01677	Result of O2 sensor test ready bank 1 after cat. conv.	Test not started
    IDE01683-MAS05304	Valve stroke switch of AVS from small to large-Cylinder 1	switched
    IDE01684-MAS05304	Valve stroke switch of AVS from large to small-Cylinder 1	switched
    IDE01685	Result of test of valve stroke switch AVS	Test not started
    IDE01773	Misfire sum counter	0
    IDE01774	Status misfire recognition	not active
    IDE01775	Misfires per 1000 revolutions of cylinder 1	0
    IDE01776	Misfires per 1000 revolutions of cylinder 2	0
    IDE01777	Misfires per 1000 revolutions of cylinder 3	0
    IDE01778	Misfires per 1000 revolutions of cylinder 4	0
    IDE01870	Oxygen sensor after catalytic converter: operating status	Bank 1: sensor 1 not OK
    IDE01873	Test of catalytic converter: measured value	0.023
    IDE01874	Test of catalytic converter: result	Test not started
    IDE01876	Adaptation of loss torque	-3.6	 Nm
    IDE01878	Adaptation of throttle valve	Cancel: prerequisites have not been met
    IDE01880	Accelerator position 2	15	 %
    IDE01881	Adaptation of kick-down shifting point	4.126	 V
    IDE01884	Camshaft adjustment intake bank 1: activation	11.18	 %
    IDE01886	Number of high pressure incursions	0
    IDE01894	Charge press. ctrl.: adapt. higher than max. threshold	0.39	 %
    IDE01895	Charge pressure control: less than min. threshold adaptation	0.78	 %
    IDE01901	Lost torque adaptation: idle	-4	 Nm
    IDE01905	Average of ignition timing angle delay adjustment	0	 °
    IDE01906	Dynamic average of ignition timing angle delay adjustment	0	 °
    IDE01912	Oxygen sensor bank 1 sensor 1: specified value	1
    IDE01913	Number of oxygen sensor dynamic tests: bank 1 sensor 1	0
    IDE01922	Vehicle distance driven	2792	 km
    IDE01923	Control module distance driven	2793	 km
    IDE01924	Load shift flaps: actual value	closed
    IDE01925	Load shift flaps: specified value	closed
    IDE01926	Adaptation of load shift flaps	Cancel: prerequisites have not been met
    IDE01928	Close cam shaft angle at quantity control valve	0	 °
    IDE01929	Open cam shaft angle at quantity control valve	0	 °
    IDE01931	High pressure pump injection volume control deviation	83	 mg/stroke
    IDE01932	High pressure pump injection volume	0	 mg/stroke
    IDE01975	Numb.of misfir.: cylinder 1	2
    IDE01976	Numb.of misfir.: cylinder 2	0
    IDE01977	Numb.of misfir.: cylinder 3	7
    IDE01978	Numb.of misfir.: cylinder 4	6
    IDE01986	Contact for tank leak test	Open
    IDE02116	Exhaust gas temperature before catalytic converter	13.5	 °C
    IDE02119	Long term adaptation of oxygen sensor control: bank 1	-2.3	 %
    IDE02229	Exh.gas temp.sen 1	-40	 °C
    IDE02756	Number of manual engine starts	328
    IDE02757	Number of automatic engine starts	0
    IDE03008-MAS04415	Stop process prevented-Ambient air pressure	not active
    IDE03008-MAS04416	Stop process prevented-Sporadic function restriction	not active
    IDE03008-MAS04417	Stop process prevented-Poor start detection	not active
    IDE03008-MAS04590	Stop process prevented-Mixture adaptation	not active
    IDE03008-MAS06602	Stop process prevented-Engine temperature	active
    IDE03008-MAS06605	Stop process prevented-Regeneration operation	not active
    IDE03008-MAS06606	Stop process prevented-Brake under pressure too low	not active
    IDE03010-IDE00924	Number of prevented stop processes-Steering angle	0
    IDE03010-MAS01627	Number of prevented stop processes-Steering	0
    IDE03010-MAS02040	Number of prevented stop processes-Play protection	0
    IDE03010-MAS04415	Number of prevented stop processes-Ambient air pressure	0
    IDE03010-MAS04416	Number of prevented stop processes-Sporadic function restriction	8
    IDE03010-MAS04417	Number of prevented stop processes-Poor start detection	0
    IDE03010-MAS04589	Number of prevented stop processes-Diagnosis of exhaust system	0
    IDE03010-MAS04590	Number of prevented stop processes-Mixture adaptation	0
    IDE03010-MAS04591	Number of prevented stop processes-Diagnosis of air system	0
    IDE03010-MAS04592	Number of prevented stop processes-Hybrid battery power insufficient	0
    IDE03010-MAS04593	Number of prevented stop processes-Auxiliary consumers power too high	0
    IDE03010-MAS04595	Number of prevented stop processes-Deceleration takeover active	0
    IDE03010-MAS04805	Number of prevented stop processes-Clutch protection K0	0
    IDE03010-MAS04870	Number of prevented stop processes-Test of thermostat not complete	0
    IDE03010-MAS05758	Number of prevented stop processes-Driving situation	0
    IDE03010-MAS06602	Number of prevented stop processes-Engine temperature	349
    IDE03010-MAS06605	Number of prevented stop processes-Regeneration operation	0
    IDE03010-MAS06606	Number of prevented stop processes-Brake under pressure too low	0
    IDE03010-MAS09416	Number of prevented stop processes-Adaptation active	0
    IDE03010-MAS11563	Number of prevented stop processes-Engine hood open	0
    IDE03010-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
    IDE03010-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
    IDE03010-MAS12864	Number of prevented stop processes-Tighter traffic flow detected	0
    IDE03010-MAS13643	Number of prevented stop processes-E machine output too low	0
    IDE03010-MAS13644	Number of prevented stop processes-Motor protection active	0
    IDE03010-MAS13645	Number of prevented stop processes-Fuel salinization protection active	0
    IDE03010-MAS13661	Number of prevented stop processes-Exhaust emission control diagnosis	0
    IDE03011-MAS01627	Number of requested start processes-Steering	0
    IDE03011-MAS04369	Number of requested start processes-Engine temperature too high	0
    IDE03011-MAS04370	Number of requested start processes-Engine temperature too low	0
    IDE03011-MAS04416	Number of requested start processes-Sporadic function restriction	0
    IDE03011-MAS04592	Number of requested start processes-Hybrid battery power insufficient	0
    IDE03011-MAS04593	Number of requested start processes-Auxiliary consumers power too high	0
    IDE03011-MAS04595	Number of requested start processes-Deceleration takeover active	0
    IDE03011-MAS06606	Number of requested start processes-Brake under pressure too low	0
    IDE03011-MAS06607	Number of requested start processes-SCR System requires restart	0
    IDE03011-MAS09730	Number of requested start processes-Cat. heater	0
    IDE03011-MAS11563	Number of requested start processes-Engine hood open	0
    IDE03011-MAS11834	Number of requested start processes-Rolling vehicle	0
    IDE03011-MAS13644	Number of requested start processes-Motor protection active	0
    IDE03011-MAS13645	Number of requested start processes-Fuel salinization protection active	0
    IDE03108	Result of test of oxygen sensors bank 1	Test not started
    IDE03235	Neutral position sensor: current transmission angle	20	 °
    IDE03236	Neutral position sensor: adapted transmission angle	-179.96	 °
    IDE03246	Neutral position sensor: upper adaptation value	0	 V
    IDE03247	Neutral position sensor: lower adaptation value	0	 V
    IDE03262	Adapt of angle sensor 1 f throttle valve	0.502	 V
    IDE03263	Adapt of angle sensor 2 f throttle valve	4.491	 V
    IDE03264	Adaptation of angle sensor 1 throttle valve: emerg. air gap	0.815	 V
    IDE03265	Adaptation of angle sensor 2 throttle valve: emerg. air gap	4.17	 V
    IDE03267	Intake air temperature: unconditioned voltage	2.48	 V
    IDE03276	Charge air pressure sensor: unconditioned voltage	1.592	 V
    IDE03277	Intake manifold Runner Control (IMRC): unconditioned voltage	3.901	 V
    IDE03328	Transmission neutral position sensor voltage	0	 V
    IDE03361	Driver request torque	44.2	 Nm
    IDE03362	Requested transmission torque	1024	 Nm
    IDE03375	Adaptation status for transmission neutral position sensor	0
    IDE03377	Coolant temp at radiator output: unconditioned voltage	3.723	 V
    IDE03582	Temperature sensor for engine temperature management	13.5	 °C
    IDE03585	System status for the start/stop function master	System malfunction
    IDE03587-IDE02697	Stop overrides for active participants-Multifunction unit control module	not active
    IDE03587-MAS00124	Stop overrides for active participants-A/C	not active
    IDE03587-MAS00127	Stop overrides for active participants-brakes	not active
    IDE03587-MAS00506	Stop overrides for active participants-Adaptive Cruise Control	not active
    IDE03587-MAS01090	Stop overrides for active participants-Transmission	not active
    IDE03587-MAS01106	Stop overrides for active participants-Level control system	not active
    IDE03587-MAS01490	Stop overrides for active participants-Energy management	not active
    IDE03587-MAS01627	Stop overrides for active participants-Steering	not active
    IDE03587-MAS02237	Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.	not active
    IDE03587-MAS02569	Stop overrides for active participants-All-wheel electronics	not active
    IDE03587-MAS03757	Stop overrides for active participants-Quattro Sport	not active
    IDE03587-MAS05129	Stop overrides for active participants-Engine	active
    IDE03587-MAS06709	Stop overrides for active participants-Keyless operation	not active
    IDE03587-MAS08785	Stop overrides for active participants-Parking aid	not active
    IDE03588-IDE02697	System malfunctions for active participants start/stop-Multifunction unit control module	not active
    IDE03588-MAS00124	System malfunctions for active participants start/stop-A/C	not active
    IDE03588-MAS00127	System malfunctions for active participants start/stop-brakes	not active
    IDE03588-MAS00506	System malfunctions for active participants start/stop-Adaptive Cruise Control	not active
    IDE03588-MAS01090	System malfunctions for active participants start/stop-Transmission	not active
    IDE03588-MAS01106	System malfunctions for active participants start/stop-Level control system	not active
    IDE03588-MAS01490	System malfunctions for active participants start/stop-Energy management	not active
    IDE03588-MAS01627	System malfunctions for active participants start/stop-Steering	not active
    IDE03588-MAS02237	System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.	not active
    IDE03588-MAS02569	System malfunctions for active participants start/stop-All-wheel electronics	not active
    IDE03588-MAS03757	System malfunctions for active participants start/stop-Quattro Sport	not active
    IDE03588-MAS05129	System malfunctions for active participants start/stop-Engine	not active
    IDE03588-MAS06709	System malfunctions for active participants start/stop-Keyless operation	not active
    IDE03588-MAS08785	System malfunctions for active participants start/stop-Parking aid	not active
    IDE03589-MAS01161	Error status for start-stop related sensors-Communication error	not active
    IDE03589-MAS11563	Error status for start-stop related sensors-Engine hood open	active
    IDE03589-MAS11868	Error status for start-stop related sensors-Driver door status	not active
    IDE03589-MAS12097	Error status for start-stop related sensors-driver door open	active
    IDE03589-MAS12098	Error status for start-stop related sensors-Start/Stop deactivated with button	active
    IDE03589-MAS12099	Error status for start-stop related sensors-Clutch signal error	not active
    IDE03589-MAS12100	Error status for start-stop related sensors-Brake or speed signal error	not active
    IDE03589-MAS12101	Error status for start-stop related sensors-Steering signal error	not active
    IDE03692-MAS05513	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0	Test of camshaft adjustment bank 2 outlet not complete
    IDE03692-MAS05514	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1	Test of camshaft adjustment bank 1 outlet not complete
    IDE03692-MAS05515	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2	Test of camshaft adjustment bank 2 intake not complete
    IDE03692-MAS05516	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3	Test of camshaft adjustment bank 1 intake complete
    IDE03692-MAS05517	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4	Test of knock sensor 4 not complete
    IDE03692-MAS05518	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5	Test of knock sensor 3 not complete
    IDE03692-MAS05519	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6	Test of knock sensor 2 not complete
    IDE03692-MAS05520	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7	Test of knock sensor 1 complete
    IDE03693-MAS05513	Monitoring status of additional Onboard Diagnosis-Bit 0	Test of brake light switch not complete
    IDE03693-MAS05514	Monitoring status of additional Onboard Diagnosis-Bit 1	Test of clutch switch not complete
    IDE03693-MAS05515	Monitoring status of additional Onboard Diagnosis-Bit 2	Test of idle control complete
    IDE03693-MAS05516	Monitoring status of additional Onboard Diagnosis-Bit 3	Test of coolant temperature sensor not complete
    IDE03693-MAS05517	Monitoring status of additional Onboard Diagnosis-Bit 4	Test of throttle valve potentiometer not complete
    IDE03693-MAS05518	Monitoring status of additional Onboard Diagnosis-Bit 5	Test of thermostat complete
    IDE03693-MAS05519	Monitoring status of additional Onboard Diagnosis-Bit 6	Test of charge pressure control complete
    IDE03693-MAS05520	Monitoring status of additional Onboard Diagnosis-Bit 7	Test of CCS switch not complete
    IDE03693-MAS05521	Monitoring status of additional Onboard Diagnosis-Bit 8	Test of oxygen adaptation bank 1 complete
    IDE03711	Mass flow through throttle valve	0	 kg/h
    IDE03767	Engine status	Stop
    IDE03795	Camshaft adjustment: exhaust: bank 1: activation	11.18	 %
    IDE03806	Oxygen sensor bank 1 sensor 1: status	0
    IDE03807	Oxygen sensor bank 1 sensor 2: status	0
    IDE03816	Exhaust flap bank 1	Open
    IDE03818	Heated oxygen sensor bank 1: sensor 2: resistance	65535	 Ohm
    IDE03819	Heated oxygen sensor bank 1: sensor 2: activation	0	 %
    IDE03820	Heated oxygen sensor bank 1: sensor 1: resistance	16383	 Ohm
    IDE03821	Heated oxygen sensor bank 1: sensor 1: activation	0	 %
    IDE03832	Oxygen sensor bank 1 sensor 2: response time	0	 ms
    IDE03834	Oxygen sensor bank 1 sensor 2: response time filtered	0	 ms
    IDE03836	Result of O2 sensor aging test bank 1 after cat. conv.	Test not started
    IDE03892	Fuel high pressure sensor: unconditioned voltage	0.576	 V
    IDE03918	Engine reverse rotation recognition	not recognized
    IDE03919	Oxygen regulation operability and status	OFF
    IDE03920	Oxygen adaptation status	Initializing
    IDE03921	Mixture adaptation factor at partial load	-1.89	 %
    IDE03922	Mixture adaptation factor at idle speed	0	 %
    IDE03923	Adaptive long-term value of mix. condition after cat. conv	0
    IDE03924	Relay for reserve coolant pump: status	not activated
    IDE03928	Counter for fuel entry in oil	0
    IDE03930	Charge pressure actuator: operating status	Operating mode
    IDE03931	Charge pressure actuator: actual position	30.29	 %
    IDE03932	Charge pressure actuator: specified position	0	 %
    IDE03933	Charge pressure actuator: specified value	0	 %
    IDE03934	Charge pressure actuator: adaptation for lower stop	3.574	 V
    IDE03935	Charge pressure actuator: adaptation for upper stop	0.57	 V
    IDE03953	Oxygen control: adaptation value at partial load: bank 1	-1.89	 %
    IDE03957	Throttle valve angle: specified value	6.7	 °
    IDE03963	Low fuel pressure adaptation value for EFP	1200	 mbar
    IDE03966	Transmission neutral position sensor PWM signal	0	 %
    IDE03998	Clutch Position Sensor	99.61	 %
    IDE04002-MAS03315	Charge press. ctrl.-Charge air pressure 1: specified value	Not available
    IDE04002-MAS03315	Charge press. ctrl.-Charge air pressure 1: specified value	97	 kPa
    IDE04002-MAS03316	Charge press. ctrl.-Charge air pressure 1: actual value	98.5	 kPa
    IDE04002-MAS03316	Charge press. ctrl.-Charge air pressure 1: actual value	installed
    IDE04002-MAS03317	Charge press. ctrl.-Charge air pressure 1: status	Not available
    IDE04002-MAS03317	Charge press. ctrl.-Charge air pressure 1: status	--no display--
    IDE04002-MAS03318	Charge press. ctrl.-Charge air pressure 2: specified value	Not available
    IDE04002-MAS03318	Charge press. ctrl.-Charge air pressure 2: specified value	0	 kPa
    IDE04002-MAS03319	Charge press. ctrl.-Charge air pressure 2: actual value	0	 kPa
    IDE04002-MAS03319	Charge press. ctrl.-Charge air pressure 2: actual value	not installed
    IDE04002-MAS03320	Charge press. ctrl.-Charge air pressure 2: status	Not available
    IDE04002-MAS03320	Charge press. ctrl.-Charge air pressure 2: status	--no display--
    IDE04405	Mixture deviation in adapted partial load range 1	0	 %
    IDE04409	Intake manifold pressure: corrected	0.97	 bar
    IDE04410	Intake manifold pressure: target value	0	 bar
    IDE04412	Pressure before throttle valve: corrected	0.97	 bar
    IDE04415	Oxygen ctrl factor with precontrol correction	0	 %
    IDE04420	Activation of secondary air system	Atmosphere/off
    IDE04629	AVS operating condition	No enabling
    IDE04630	AVS valve stroke position: current	Standard
    IDE04632-MAS05304	AVS error status of last switch-over standard stroke direction-Cylinder 1	OK
    IDE04633-MAS05304	AVS error status of last switch-over AVS stroke direction-Cylinder 1	OK
    IDE04634	AVS switch-over meter for reg activation of curr. drive cycle	0
    IDE04635	AVS switch-over meter: total	12
    IDE04636	AVS overflow meter for all switch-overs	0
    IDE04637	Engine temperature management actuator	99.75	 %
    IDE04638	Transmission coolant valve	Open
    IDE04677	O2 sensor 1 bank 1: O2 sensor actual value	1
    IDE04680	O2 sensor 1: bank 1: voltage raw value O2 signal	1.997	 V
    IDE04713	Active brake system status	Not operated
    IDE04814	Transmission oil cooler valve	Open
    IDE04937	Sensor for engine block temperature: raw value	-48	 °C
    IDE05140	Intake manifold pressure raw value	0.981	 bar
    IDE05259	Gear position sensor: raw value	0	 %
    IDE05260	Gear position sensor: current value	Neutral
    IDE05261	Gear position sensor: last valid value	Neutral
    IDE05262	Gear position sensor: gear position valid	invalid
    IDE05310	Charge air pressure control valve position: target value	0	 %
    IDE05311	Charge air pressure control valve position: actual value	30.29	 %
    IDE05312	Charge air pressure control valve uncond voltage sensor	2.4023	 V
    IDE05313	Charge air pressure control valve activation pulse duty factor	0	 %
    IDE05314-ENG112584	Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]	0
    IDE05315	Charge air pressure control valve voltage: position closed	3.5742	 V
    IDE05316	Charge air pressure control valve voltage: position open	0.5701	 V
    IDE05317-ENG112583	Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0]	0
    IDE05508	Adaptation val cyl 1 with slow diagnosis	0
    IDE05509	Adaptation val cyl 3 with slow diagnosis	0
    IDE05510	Adaptation val cyl 4 with slow diagnosis	0
    IDE05511	Adaptation val cyl 2 with slow diagnosis	0
    IDE05512	Adaptation val cyl 1 with fast diagnosis	0
    IDE05513	Adaptation val cyl 3 with fast diagnosis	0
    IDE05514	Adaptation val cyl 4 with fast diagnosis	0
    IDE05515	Adaptation val cyl 2 with fast diagnosis	0
    IDE05593	Secondary air injection sensor 1	0.982	 bar
    IDE05622-ENG125277	Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL	0
    IDE06006	Idle speed specified value	1350	 /min
    IDE06192	Knock sensor: cylinder 2: voltage	2.5	 V
    IDE06193	Knock sensor: cylinder 3: voltage	2.5	 V
    IDE06194	Knock sensor: cylinder 4: voltage	2.5	 V
    IDE06195	Knock sensor: cylinder 1: voltage	2.5	 V
    IDE06296-ENG104200	Activation of oxygen control after main cat-Lambda probe 2: bank 1: status	0
    IDE06307-MAS00106	Stop prevention history data-Year	2000
    IDE06307-MAS00107	Stop prevention history data-Month	1
    IDE06307-MAS00108	Stop prevention history data-Day	2
    IDE06307-MAS00109	Stop prevention history data-Hours	4
    IDE06307-MAS00110	Stop prevention history data-Minutes	0
    IDE06307-MAS00111	Stop prevention history data-Seconds	59
    IDE06308-MAS00106	Start request history data-Year	2063
    IDE06308-MAS00107	Start request history data-Month	3
    IDE06308-MAS00108	Start request history data-Day	31
    IDE06308-MAS00109	Start request history data-Hours	15
    IDE06308-MAS00110	Start request history data-Minutes	3
    IDE06308-MAS00111	Start request history data-Seconds	63
    IDE06386	Oil level: static measurement	0	 mm
    IDE06387	Oil level: last valid dynamic value	29	 mm
    IDE06388	Oil level: condition for static measurement fulfilled	Condition not met
    IDE06389	Oil level: maximum value	33	 mm
    IDE06390	Oil level: minimum value	28	 mm
    IDE06391	Oil temperature sensor 2	13	 °C
    IDE06392	Oil temperature sensor 2: raw value	13	 V
    IDE06393	Oil level: dynamic average value	0	 mm
    IDE06394	Sensor 1 for secondary air pressure: unconditioned voltage	2.427	 V
    IDE06395	Fuel low pressure sensor: unconditioned voltage	4.995	 V
    IDE06396	Coolant temperature at engine outlet: unconditioned voltage	3.801	 V
    IDE06397	Temperature sensor for engine temp. management: target value	107.3	 °C
    IDE06398	Temperature sensor for engine temp. management: uncond. voltage	3.802	 V
    IDE06399	Manifold absolute pressure sensor: unconditioned voltage	1.685	 V
    IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
    IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
    IDE06432	Oxygen sensor 1 bank 1 signal status	not active
    IDE06444	Oxygen sensor before cat bank 1 (LSB) voltage	1.997	 V
    IDE06567	Start-stop function deactivation frequency counter	0
    IDE06568	Stop prevention by driver frequency counter	0
    IDE06569	Vehicle stopped frequency counter	0
    IDE06573	Long-term adaptation of intake manifold injection	0	 %
    IDE06574	Long-term adaptation of intake manifold injection in idle	0	 mg/stroke
    IDE06610	Vehicle standstill with stop frequency counter	0
    IDE06703-IDE12714	Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration	No
    IDE06703-MAS14977	Drivetrain coordinator: ACC fault status-ACC active: although TSK passive	No
    IDE06704-MAS14986	Drivetrain coordinator: brake fault status-Deceleration sensor not available	No
    IDE06704-MAS14993	Drivetrain coordinator: brake fault status-Brake light implausible	No
    IDE06705-MAS05192	Drivetrain coordinator: brake function status-Driver braking	No
    IDE06705-MAS15003	Drivetrain coordinator: brake function status-ASP intervention	No
    IDE06706	ACC variants	ACC with braking until at standstill
    IDE06707	CCS Switch	ACC operating unit
    IDE06709	ACC variants (coding)	ACC with braking until at standstill/Stop & Go
    IDE06710	Cruise control system: permanent deactivation	No switch-off occurs
    IDE06726	Timing deviation after chain replacement: intake bank 1	-0.44	 °
    IDE06728	Timing deviation after chain replacement: exhaust bank 1	0	 °
    IDE06730	Timing deviation after other repairs: intake bank 1	0	 °
    IDE06732	Timing deviation after other repairs: exhaust bank 1	0	 °
    IDE06734	Timing deviation: current value intake bank 1	-0.56	 °
    IDE06736	Timing deviation: current value exhaust bank 1	0	 °
    IDE06738	Chain elongation: no. of valid initial values: intake bank 1	5
    IDE06740	Chain elongation: no. of valid initial values: exhaust bank 1	0
    IDE06742	Chain elongation: initial values valid: intake bank 1	active
    IDE06744	Chain elongation: initial values valid: exhaust bank 1	not active
    IDE07001	Piston-cooling jets: activation	On
    IDE07008	Tank leak: number no leak detected	57
    IDE07011	Tank leak: number communication errors to engine control	96
    IDE07014	Tank leak: number very small leaks detected	0
    IDE07019	Number of ignitions direct injection	8895172
    IDE07020	Number of ignitions intake manifold injection	0
    IDE07023	Misfires per 1000 revolutions of cyl. 1 intake manif. injection	0
    IDE07024	Misfires per 1000 revolutions of cyl. 2 intake manif. injection	0
    IDE07025	Misfires per 1000 revolutions of cyl. 3 intake manif. injection	0
    IDE07026	Misfires per 1000 revolutions of cyl. 4 intake manif. injection	0
    IDE07027	Heat quantity that was transported via the catalytic converter	-836361	 J
    IDE07031	Oil pressure switch for piston-cooling jets: status	Open
    IDE07242	Heater support pump: spec. value	10	 %
    IDE07548	Engine temp. mangmt. actuator: specified value of angle	88.75	 °
    IDE07549	Engine temp. mangmt. actuator: actual value of angle	89.23	 °
    IDE07550	Engine temp. management actuator: raw value	1476
    IDE07551	Engine temp. management actuator: duty cycle activation	0	 %
    IDE07552	Engine temper.managem.actuator adaptation: result adaptation	Adaptation successfully finished
    IDE07553	Engine temperature management actuator: after-run stop	3960
    IDE07554	Engine temperature management actuator: stop open	142
    IDE07564	Required torque adjustment by idling regulator	0	 Nm
    IDE07571	Engine torque	-32.2	 Nm
    IDE07572	High pressure regulation: adaptation value	-4.07	 mg
    IDE07574	Long-term fuel trim bank 1 at idle	0	 mg/stroke
    IDE07575	Driver request torque	12	 Nm
    IDE07576	Lost torque adaptation driving mode	-2.8	 Nm
    IDE07577	Lost torque adaptation A/C compressor and driving mode	1.4	 Nm
    IDE07598-MAS00320	Cruise control switch actuation-Main switch	not activated
    IDE07598-MAS00325	Cruise control switch actuation-Setting	not activated
    IDE07598-MAS00326	Cruise control switch actuation-Activation	not activated
    IDE07598-MAS01632	Cruise control switch actuation-Status	OK
    IDE07598-MAS02309	Cruise control switch actuation-Accelerate	not activated
    IDE07598-MAS02310	Cruise control switch actuation-Decelerate	not activated
    IDE07598-MAS05172	Cruise control switch actuation-Cancel	not activated
    IDE07598-MAS05806	Cruise control switch actuation-Main switch hardware	not activated
    IDE07598-MAS05807	Cruise control switch actuation-Coding	plausible
    IDE07598-MAS05809	Cruise control switch actuation-Limit function	not selected
    IDE07598-MAS05812	Cruise control switch actuation-Limit button	not activated
    IDE07598-MAS05813	Cruise control switch actuation-Main switch CAN	not activated
    IDE07598-MAS05842	Cruise control switch actuation-Large increment	not activated
    IDE07598-MAS05843	Cruise control switch actuation-Control component verified	Yes
    IDE07599-MAS01505	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off	Yes
    IDE07599-MAS03849	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal	No
    IDE07599-MAS04795	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off	Yes
    IDE07599-MAS05135	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected	No
    IDE07599-MAS05136	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control	No
    IDE07599-MAS05190	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated	No
    IDE07599-MAS05192	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking	No
    IDE07599-MAS05196	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error	No
    IDE07599-MAS05814	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error	No
    IDE07599-MAS05815	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error	No
    IDE07599-MAS05816	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error	No
    IDE07599-MAS05817	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation	No
    IDE07599-MAS05818	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible	No
    IDE07599-MAS05819	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking	No
    IDE07599-MAS05820	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error	No
    IDE07599-MAS05821	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak	No
    IDE07599-MAS05822	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available	No
    IDE07599-MAS05823	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization	No
    IDE07599-MAS05824	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation	No
    IDE07599-MAS05825	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault	No
    IDE07599-MAS05826	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault	No
    IDE07599-MAS05827	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met	No
    IDE07599-MAS05828	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature	No
    IDE07599-MAS05829	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault	No
    IDE07599-MAS05830	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component	No
    IDE07599-MAS05831	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component	No
    IDE07599-MAS05832	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error	No
    IDE07599-MAS05833	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error	No
    IDE07599-MAS05834	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault	No
    IDE07599-MAS05835	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault	No
    IDE07599-MAS05836	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error	No
    IDE07599-MAS05837	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error	No
    IDE07605	Cruise control system: temporary deactivation	No switch-off
    IDE07669	Oxygen sensor 2 Bank 1 after cat operation readiness Status	not active
    IDE07901	Error counter bad fuel	0
    IDE07904-ENG118117	Brake test switch status-actuated__activated	not activated
    IDE07904-ENG114825	Brake test switch status-Ident_32	0
    IDE07905-ENG118117	Brake light switch status-actuated__activated	not activated
    IDE07905-ENG114825	Brake light switch status-Ident_32	0
    IDE07906-ENG118117	Upper clutch switch: status-actuated__activated	not activated
    IDE07906-ENG114825	Upper clutch switch: status-Ident_32	0
    IDE07945-MAS00334	Status of intermittent monitoring-Catalytic converter monitoring	completed successfully
    IDE07945-MAS00335	Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature	completed successfully
    IDE07945-MAS00336	Status of intermittent monitoring-Monitoring of tank ventilation system	completed successfully
    IDE07945-MAS00337	Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system	completed successfully
    IDE07945-MAS00338	Status of intermittent monitoring-Monitoring of A/C system refrigerant	completed successfully
    IDE07945-MAS00339	Status of intermittent monitoring-Monitoring of oxygen sensor	completed successfully
    IDE07945-MAS00340	Status of intermittent monitoring-Monitoring of oxygen sensor heater	completed successfully
    IDE07945-MAS00341	Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR)	not completed successfully
    IDE08071-ENG119931	Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1	0
    IDE08072-ENG119932	Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2	0
    IDE08073-ENG119933	Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3	0
    IDE08074-ENG119934	Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4	0
    IDE08075-ENG119935	Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5	0
    IDE08495	Activation radiator shutter result	0	 %
    IDE08805	EVAP valve diag. activation condition at minimal load	0	 counts
    IDE08806	EVAP valve diag. activation condition at maximum load	-12	 mbar
    IDE10366	Chg. press. ctrl. valve: sensor voltage max. value	3.601	 V
    IDE10380	Knock sensor average voltage bank 1	0	 V
    IDE10551-MAS05304	Pre-ignition counter for oxygen shift-Cylinder 1	0
    IDE10551-MAS05305	Pre-ignition counter for oxygen shift-Cylinder 2	3
    IDE10551-MAS05306	Pre-ignition counter for oxygen shift-Cylinder 3	0
    IDE10551-MAS05307	Pre-ignition counter for oxygen shift-Cylinder 4	0
    IDE10551-MAS05308	Pre-ignition counter for oxygen shift-Cylinder 5	0
    IDE10551-MAS05309	Pre-ignition counter for oxygen shift-Cylinder 6	0
    IDE10551-MAS05310	Pre-ignition counter for oxygen shift-Cylinder 7	0
    IDE10551-MAS05311	Pre-ignition counter for oxygen shift-Cylinder 8	0
    IDE10552-MAS05304	Pre-ignition counter for torque reduction-Cylinder 1	0
    IDE10552-MAS05305	Pre-ignition counter for torque reduction-Cylinder 2	0
    IDE10552-MAS05306	Pre-ignition counter for torque reduction-Cylinder 3	0
    IDE10552-MAS05307	Pre-ignition counter for torque reduction-Cylinder 4	0
    IDE10552-MAS05308	Pre-ignition counter for torque reduction-Cylinder 5	0
    IDE10552-MAS05309	Pre-ignition counter for torque reduction-Cylinder 6	0
    IDE10552-MAS05310	Pre-ignition counter for torque reduction-Cylinder 7	0
    IDE10552-MAS05311	Pre-ignition counter for torque reduction-Cylinder 8	0
    IDE10553-MAS05304	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1	0
    IDE10553-MAS05305	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2	0
    IDE10553-MAS05306	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3	0
    IDE10553-MAS05307	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4	0
    IDE10553-MAS05308	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5	0
    IDE10553-MAS05309	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6	0
    IDE10553-MAS05310	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7	0
    IDE10553-MAS05311	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8	0
    IDE10554-MAS05304	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1	0
    IDE10554-MAS05305	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2	0
    IDE10554-MAS05306	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3	0
    IDE10554-MAS05307	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4	0
    IDE10554-MAS05308	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5	0
    IDE10554-MAS05309	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6	0
    IDE10554-MAS05310	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7	0
    IDE10554-MAS05311	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8	0
    IDE10922	Pump current of tank leakage diag.: corrected & filtered	0	 mA
    IDE10970-MAS11563	Number of prevented stop processes-Engine hood open	0
    IDE10970-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
    IDE10970-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
    IDE10989-MAS00106	Immobilizer: historic data-Year	2063
    IDE10989-MAS00107	Immobilizer: historic data-Month	3
    IDE10989-MAS00108	Immobilizer: historic data-Day	31
    IDE10989-MAS00109	Immobilizer: historic data-Hours	15
    IDE10989-MAS00110	Immobilizer: historic data-Minutes	3
    IDE10989-MAS00111	Immobilizer: historic data-Seconds	63
    IDE10994	Poor start counter at start-stop	0
    IDE11115	Start/stop driver request: counter restart by starter	0
    IDE11116	Start/stop driver request: counter internal-motor restart	0
    IDE11598	Tank deaeration valve diagnosis: unweighted input value	0	 counts
    IDE11599	Tank deaeration valve diagnosis: weighted output value	0	 counts
    IDE11600	Tank tightness: ambient temperature	-48	 °C
    IDE11919	Lock time for cooling down of secondary air pump	0	 s
    IDE12137	Tank fill level diagnostic reference value	54	 l
    IDE12138	Fuel consumption per driving cycle	44.27	 l/100km
    ENG102981	AC compressor: speed increase	0
    ENG103860	AC request: speed increase	0
    ENG103042	Accelerator pedal sender: learned end stop	4.126	 V
    ENG103719	Accelerator position	0	 %
    ENG101488	ACF: load	0
    ENG103474	Activation of oil pressure switching valve	0
    ENG103323	Additional water pump	1
    ENG101828	Air mass	0	 kg/h
    ENG104264	Alternator load	0	 W
    ENG103910	Ambient temperature	13.5	 °C
    ENG112539	AR_THR_AD_ADD_MMV	-0.0027	 cm²
    ENG98377	As	none
    ENG103165	Battery voltage	12.9	 V
    ENG07601	Bypasstool_a2l_name	ORIGINAL A2L
    ENG07600	Bypasstool_manipulation_bit	not active
    ENG101413	Calibration Identification	8V0264L 0002AXA
    ENG99697	Calibration Verification Number	01 F8 DE B2
    ENG128780	CAM_DIF_VCP[EX_1]	0	 °
    ENG128781	CAM_DIF_VCP[IN_1]	0	 °
    ENG102002	CAM_OFS_IVVT_IN[1]	0	 °
    ENG112540	CAM_PHA_ENG[GES_EX][CBK_1]	0	 °
    ENG112541	CAM_PHA_ENG[GES_IN][CBK_1]	0	 °
    ENG101169	CAM_PHA_OFS_MAF[IN][1]	0	 °
    ENG112542	CAM_SP_IND_VCP[EX_1]	0	 °
    ENG112543	CAM_SP_IND_VCP[IN_1]	0	 °
    ENG112544	CAM_VCP[EX_1]	0	 °
    ENG112545	CAM_VCP[IN_1]	0	 °
    ENG103849	Cat. ageing: bank 1: actual	0.023
    ENG101785	Cat. temperature: bank 1	13.475	 °C
    ENG102214	CPU_LOAD	42.3	 %
    ENG125189	CTR_CAM_IN_SP_PI_DET_REQ[0]	0
    ENG125190	CTR_CAM_IN_SP_PI_DET_REQ[1]	0
    ENG125191	CTR_CAM_IN_SP_PI_DET_REQ[2]	0
    ENG125192	CTR_CAM_IN_SP_PI_DET_REQ[3]	3
    ENG101127	CTR_CDN_OBD_RBM	82
    ENG114826	CTR_EDGE_CAM_EX[1]	0
    ENG114827	CTR_EDGE_CAM_IN[1]	0
    ENG100536	CTR_IGK_CYC_RBM	330
    ENG125193	CTR_LAMB_SP_PI_REQ[0]	0
    ENG125194	CTR_LAMB_SP_PI_REQ[1]	0
    ENG125195	CTR_LAMB_SP_PI_REQ[2]	0
    ENG125196	CTR_LAMB_SP_PI_REQ[3]	3
    ENG112554	CTR_MIS_DC_MMV_CYL_SAE[0]	2
    ENG112555	CTR_MIS_DC_MMV_CYL_SAE[1]	4
    ENG112556	CTR_MIS_DC_MMV_CYL_SAE[2]	3
    ENG112557	CTR_MIS_DC_MMV_CYL_SAE[3]	3
    ENG112558	CTR_MIS_TOT_NVMY_SAE	2492
    ENG125197	CTR_REQ_IV_OFF_PI_FAST[0]	0
    ENG125198	CTR_REQ_IV_OFF_PI_FAST[1]	0
    ENG125199	CTR_REQ_IV_OFF_PI_FAST[2]	0
    ENG125200	CTR_REQ_IV_OFF_PI_FAST[3]	0
    ENG125201	CTR_REQ_IV_OFF_PI_SLOW[0]	0
    ENG125202	CTR_REQ_IV_OFF_PI_SLOW[1]	0
    ENG125203	CTR_REQ_IV_OFF_PI_SLOW[2]	0
    ENG125204	CTR_REQ_IV_OFF_PI_SLOW[3]	0
    ENG128782	CTR_REQ_IV_OFF_PI_SLOW_TMP[0]	0
    ENG128783	CTR_REQ_IV_OFF_PI_SLOW_TMP[1]	0
    ENG128784	CTR_REQ_IV_OFF_PI_SLOW_TMP[2]	0
    ENG128785	CTR_REQ_IV_OFF_PI_SLOW_TMP[3]	0
    ENG100764	CTR_SUM_SRV_INTL	0
    ENG125205	CTR_TQI_POW_MAX_PI_REQ[0]	0
    ENG125206	CTR_TQI_POW_MAX_PI_REQ[1]	0
    ENG125207	CTR_TQI_POW_MAX_PI_REQ[2]	0
    ENG125208	CTR_TQI_POW_MAX_PI_REQ[3]	0
    ENG119929	CTR_VLD_CAT_GAP_AFL[1]	0
    ENG119930	CTR_VLD_CAT_GAP_AFR[1]	0
    ENG99428	CTR_VLFT_1_SWI_NOT[0]	0
    ENG103626	CTR_VLFT_1_SWI_NOT[1]	0
    ENG100809	CTR_VLFT_1_SWI_NOT[2]	0
    ENG99336	CTR_VLFT_1_SWI_NOT[3]	0
    ENG103025	CTR_VLFT_STND_SWI_NOT[0]	0
    ENG100017	CTR_VLFT_STND_SWI_NOT[1]	0
    ENG100438	CTR_VLFT_STND_SWI_NOT[2]	0
    ENG100736	CTR_VLFT_STND_SWI_NOT[3]	0
    ENG112559	CTR_VVL_LIH_ACT	0
    ENG101271	CTR_VVL_LIH_DEAC	0
    ENG100551	CTR_VVL_SWI_DC	0
    ENG99561	CTR_VVL_SWI_H	0
    ENG101173	CTR_VVL_SWI_L	12
    ENG99084	Cycle flags: (completed cycles): cat: lambda probe heater	57
    ENG100943	Cycle flags: (completed cycles): lambda probes: EGR	0
    ENG99495	Cycle flags: (completed tests): lambda adaption:	8
    ENG103597	Cycle flags:(completed cycles):lambda probes:sec.air sys.	59
    ENG101652	Cylinder shut-off: cylinder suppression	1
    ENG102657	DIAG_INST[0]	NO_ERROR
    ENG99120	DIAG_INST[1]	NO_ERROR
    ENG103260	DIAG_INST[2]	NO_ERROR
    ENG99710	DIAG_INST[3]	NO_ERROR
    ENG102667	DIAG_INST[4]	NO_ERROR
    ENG102739	DIAG_INST[5]	NO_ERROR
    ENG100162	DIAG_INST[6]	NO_ERROR
    ENG99103	DIAG_INST[7]	NO_ERROR
    ENG99261	DIAG_INST[8]	NO_ERROR
    ENG103622	DIAG_INST[9]	NO_ERROR
    ENG112560	DIST_ACT_MIL_SAE	0	 km
    ENG112561	DIST_DTC_CLR_SAE	2302	 km
    ENG103766	DIST_ENG_RUN_IN	2793567.5	 m
    ENG100531	DIST_ST	2.79E+06	 m
    ENG100131	ECU_STATE	ENG_STOP
    ENG100152-ENG104003	ECUNAME-ECU	ECM
    ENG100152	ECUNAME	#NAME?
    ENG103712	EFPPWM_MIN_AD	0	 %
    ENG104044	Engine load	0	 %
    ENG102494	Engine speed: actual	0	 /min
    ENG102783	Engine: operating status	ES
    ENG103667	ENVD_0_MON	0
    ENG100777	ENVD_0_MON_3	0
    ENG126934	ENVD_0_MON_3_VD	0
    ENG99424	ENVD_1_MON	0
    ENG100344	ENVD_1_MON_3	0
    ENG126935	ENVD_1_MON_3_VD	0
    ENG99790	ENVD_2_MON	0
    ENG100541	ENVD_2_MON_3	0
    ENG126936	ENVD_2_MON_3_VD	0
    ENG99455	ENVD_3_MON	0
    ENG101268	ENVD_3_MON_3	0
    ENG126937	ENVD_3_MON_3_VD	0
    ENG01743	ENVD_4_MON	0
    ENG01744	ENVD_5_MON	0
    ENG01745	ENVD_6_MON	0
    ENG99752	Error flags: (completed cycles): cat: lambda probe heater	0
    ENG101275	Error flags: (completed cycles): lambda probes: EGR	0
    ENG104132	Error flags: (completed cycles): lambda probes:sec.air sys.	0
    ENG101942	ESI (extended service intervals) oil warning threshold	55.9375	 mm
    ENG112562	FAC_AR_THR_AD	0	 %
    ENG104194	FAC_H_RNG_LAM_AD[1]	0	 %
    ENG104151	FAC_L_RNG_LAM_AD[1]	0	 %
    ENG100298	FAC_LAM_CP	0	 %
    ENG100108	FAC_LAM_LIM[1]	0	 %
    ENG99722	FAC_LAM_TCO_A[1]	0	 %
    ENG103521	FAC_LAM_TCO_B[1]	0	 %
    ENG103641	FAC_LAM_TCO_C[1]	0	 %
    ENG101578	FAC_LAM_TCO_D[1]	0	 %
    ENG100685	FAC_LAM_TCO_E[1]	0	 %
    ENG103307	FAC_MAF_MAX	0
    ENG99791	FAC_SLOP_IV[1]	0
    ENG102306	FAC_TPS_1_SAE	16.40625	 %
    ENG102292	FAC_TPS_1_SAE	16.40625	 %
    ENG99630	Fan control relay: fan run-on	2
    ENG101437	Fan request from air conditioner	0	 %
    ENG103644	FRF_IMMO_SNAPSHOT_BYTE1	0
    ENG102892	FRF_IMMO_SNAPSHOT_BYTE2	0
    ENG100521	FRF_IMMO_SNAPSHOT_BYTE3	0
    ENG101852	FRF_IMMO_SNAPSHOT_BYTE4	0
    ENG99312	FRF_IMMO_SNAPSHOT_BYTE5	0
    ENG103956	FRF_IMMO_SNAPSHOT_BYTE6	0
    ENG128786	FTL_SAE	100.000032	 %
    ENG104248	Fuel consumption signal	0	 µl
    ENG101667	Fuel pump: adaption value	0	 %
    ENG100969	Fuel pump: fuel pressure: I-controller	0	 %
    ENG100250	Fuel regulating valve: duty cycle	0	 %
    ENG101692	Fuel supply system: high-pressure regulator	123752	 hPa
    ENG114828	FUP_EFP_MES	11000.8	 hPa
    ENG103553	FUP_EFP_ST_H	0	 hPa
    ENG101056	FUP_EFP_ST_L	0	 hPa
    ENG99950	FUP_EFP_STOP_H	0	 hPa
    ENG100784	FUP_EFP_STOP_L	0	 hPa
    ENG102108	FUP_H	6293.8	 hPa
    ENG112563	FUP_H_SAE	530	 kPa
    ENG103368	Gearbox -CAN bus messages	126847
    ENG99170	Height correction	970.3	 hPa
    ENG103575	High-pressure system: regulator	87.47	 mg
    ENG103879	High-pressure system: regulator: mobile part	0	 mg
    ENG102603	High-pressure system: status	VCV_OPEN
    ENG101567	Idling speed stabilisation: duty cycle/AC compressor torque	0.5	 Nm
    ENG101946	Idling stabilisation: operating status	0
    ENG100345	IGA_ADJ_KNK[0]	0	 °
    ENG103593	IGA_ADJ_KNK[1]	0	 °
    ENG103360	IGA_ADJ_KNK[2]	0	 °
    ENG99404	IGA_ADJ_KNK[3]	0	 °
    ENG100425	IGA_IGC[0]	0	 °
    ENG101655	IGA_IGC[1]	0	 °
    ENG100410	IGA_IGC[2]	0	 °
    ENG100407	IGA_IGC[3]	0	 °
    ENG112564	IGA_IGC_SAE	0	 °
    ENG101741	Intake air temperature	17.25	 °C
    ENG100634	In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1	14 00 52 01 4A 00 66 00 52 00 00 00 00 00 78 00 52 00 00 00 00 00 C4 00 52 00 53 00 10 00 0F 00 0B 00 48 00 52 00 00 00 00
    ENG125209	KNKS_ERR_REL[0]	0	 V
    ENG99741	LAMB_DELTA_AD_LAM_ADJ[1]	-0.00317
    ENG99601	LAMB_DELTA_I_LAM_ADJ[1]	0
    ENG112565	LAMB_DELTA_SUM_LAM_ADJ_AD[1]	-0.00317
    ENG99674	Lambda controller: bank 1 (averaged value)	0	 %
    ENG101381	Lambda probe 1: bank 1: status	0
    ENG101039	Lambda probe 1: bank 1: status	0
    ENG102886	Lambda probe 1: bank 1: status	0
    ENG104200	Lambda probe 2: bank 1: status	0
    ENG101336	Lambda probe 2: bank 1: status	0
    ENG99661	Lambda probe ageing: bank 1: dynamic factor	0
    ENG101869	Lambda probe ageing: bank 1: probe 1: short trip result	13.475	 °C
    ENG100478	Lambda probe correction: duty cycle offset: bank 1	0
    ENG103776	Lambda probe heater: bank 1: probe 2: short trip result	1
    ENG102380	Lambda probe heater: resistance: bank 1: probe 2	65535	 Ohm
    ENG99353	Lambda probe voltage: bank 1: probe 1 (broadband probe)	1.997	 V
    ENG102763	Lambda probes actual: bank1	1
    ENG104114	Lambda probes specified: bank1	0
    ENG06592	LF_COSI_CTL_ERR_A	0
    ENG06593	LF_COSI_CTL_ERR_B	0
    ENG112566	LF_DPS_CYC_ERR_RAW_BSW[1]	0
    ENG112567	LF_DPS_CYC_ERR_RAW_BSW[2]	0
    ENG112568	LF_DPS_CYC_ERR_VLD_BSW[1]	0
    ENG112569	LF_DPS_CYC_ERR_VLD_BSW[2]	0
    ENG112570	LF_DPS_INI_ERR_RAW_BSW[1]	0
    ENG112571	LF_DPS_INI_ERR_RAW_BSW[2]	0
    ENG112572	LF_IV_ERR_RAW_BSW[0]	0
    ENG112573	LF_IV_ERR_RAW_BSW[1]	0
    ENG112574	LF_IV_ERR_RAW_BSW[2]	0
    ENG112575	LF_IV_ERR_RAW_BSW[3]	0
    ENG112576	LF_IV_ERR_VLD_BSW[0]	0
    ENG112577	LF_IV_ERR_VLD_BSW[1]	0
    ENG112578	LF_IV_ERR_VLD_BSW[2]	0
    ENG112579	LF_IV_ERR_VLD_BSW[3]	0
    ENG101645	LF_VVL_DIAG_SWI_NOT	0
    ENG127734-MAS00106	Life_cycle_data_start_requirement_development-Year	2063
    ENG127734-MAS00107	Life_cycle_data_start_requirement_development-Month	3
    ENG127734-MAS00108	Life_cycle_data_start_requirement_development-Day	31
    ENG127734-MAS00109	Life_cycle_data_start_requirement_development-Hours	15
    ENG127734-MAS00110	Life_cycle_data_start_requirement_development-Minutes	3
    ENG127734-MAS00111	Life_cycle_data_start_requirement_development-Seconds	63
    ENG127735-MAS00106	Life_cycle_data_stop_prohibition_development-Year	2063
    ENG127735-MAS00107	Life_cycle_data_stop_prohibition_development-Month	3
    ENG127735-MAS00108	Life_cycle_data_stop_prohibition_development-Day	31
    ENG127735-MAS00109	Life_cycle_data_stop_prohibition_development-Hours	15
    ENG127735-MAS00110	Life_cycle_data_stop_prohibition_development-Minutes	3
    ENG127735-MAS00111	Life_cycle_data_stop_prohibition_development-Seconds	63
    ENG127733-MAS00106	Life_cycle_data_system_failure-Year	2063
    ENG127733-MAS00107	Life_cycle_data_system_failure-Month	3
    ENG127733-MAS00108	Life_cycle_data_system_failure-Day	31
    ENG127733-MAS00109	Life_cycle_data_system_failure-Hours	15
    ENG127733-MAS00110	Life_cycle_data_system_failure-Minutes	3
    ENG127733-MAS00111	Life_cycle_data_system_failure-Seconds	63
    ENG122701	LMVDes_st_Mod_Out_VW	0
    ENG122702	LMVDes_v_Max_Man_Lim_VW	511.992	 km/h
    ENG122703	LMVLim_v_Auth_Max_Out_VW	200	 km/h
    ENG100402	LOIL_SUM_SRV_INTL	-272	 mm
    ENG99162	LV_ACC_RED_CMD	0
    ENG102235	LV_ATB_ACT_1	0
    ENG102541	LV_ATB_ACT_2	0
    ENG114829	LV_BPA_LIH_REQ[0]	0
    ENG99095	LV_CAN_HOOD_SWI	1
    ENG128787	LV_CMD_RCL_OPEN	0
    ENG128788	LV_ECRAS_FB_DIAG_POS_RESP[0]	0
    ENG103049	LV_EFPPWM_AD_STOP	1
    ENG101712	LV_ENG_RUN_IN	0
    ENG100267	LV_ENG_RUN_IN_EXT_ADJ	0
    ENG103319	LV_ERR_VLFT_1_SWI[1]	0
    ENG103549	LV_ERR_VLFT_1_SWI[2]	0
    ENG103191	LV_ERR_VLFT_1_SWI[3]	0
    ENG101989	LV_ERR_VLFT_1_SWI[4]	0
    ENG102313	LV_ERR_VLFT_STND_SWI[1]	0
    ENG103044	LV_ERR_VLFT_STND_SWI[2]	0
    ENG103443	LV_ERR_VLFT_STND_SWI[3]	0
    ENG100487	LV_ERR_VLFT_STND_SWI[4]	0
    ENG112471	LV_IGK	1
    ENG103773	LV_INH_STR_RLY	0
    ENG100044	LV_LOIL_L_WARN	0
    ENG103492	LV_LOIL_L_WARN_ACT	0
    ENG103908	LV_LOIL_L_WARN_TMP	0
    ENG103716	LV_POIL_SWI_H	0
    ENG100912	LV_POIL_SWI_L	0
    ENG112586	LV_PWR_RLY[0]	1
    ENG102417	LV_TPS_AD_ACT	0
    ENG100842	LV_TPS_AD_DIAG_ERR	0
    ENG103996	LV_TPS_AD_REQ	0
    ENG112587	LV_VCP_AD_END	0
    ENG102523	MAF	0	 mg/stroke
    ENG99288	MAF_DIF_CAM_OFS_AD_SQ_TOT	0	 kg²/h²
    ENG112588	MAP_MES_SAE	97	 kPa
    ENG103501	MASS_SA_REL[0]	0
    ENG100896	MASS_SA_REL_21_PHA	0
    ENG103045	MASS_SA_REL_22_PHA	0
    ENG103346	MFF_ADD_LAM_AD[1]	0	 mg/stroke
    ENG126493	MFF_MPL_ADD_LAM_AD[1][1]	0.25	 mg/stroke
    ENG101360	Misfire detection active	1
    ENG102335	Misfires all cylinders per 1000 rpm	0
    ENG128796	N_SP_IS_CLC	1350	 /min
    ENG103004	N_TCHA	12384	 /min
    ENG112590	N_TOOTH	0	 /min
    ENG107737-ENG112538	NC_NR_DIAG_RBM-NC Value	154
    ENG126111	NL_PRE[0]	0	 V
    ENG126112	NL_PRE[1]	0	 V
    ENG126113	NL_PRE[2]	0	 V
    ENG126114	NL_PRE[3]	0	 V
    ENG128789	NR_CYC_AD_DC_BAL_HOM[RNG_H]	0
    ENG128790	NR_CYC_AD_DC_BAL_HOM[RNG_IS]	0
    ENG128791	NR_CYC_AD_DC_BAL_HOM[RNG_L]	0
    ENG128792	NR_CYC_AD_DIAG_BAL_HOM[0]	0
    ENG128793	NR_CYC_AD_DIAG_BAL_HOM[1]	0
    ENG128794	NR_CYC_AD_DIAG_BAL_HOM[2]	0
    ENG128795	NR_CYC_AD_DIAG_BAL_HOM[3]	0
    ENG112589	NR_CYL_FIRST_VVL_SWI	0
    ENG99776	NR_CYL_VVL_H_ACK	4
    ENG119936	O2L_MAX_CAT_GAP_AFL_MV[1]	0	 g
    ENG119937	O2L_MAX_CAT_GAP_AFR_MV[1]	0	 g
    ENG99157	PRS_SA_DIF	0	 hPa
    ENG02464	PRS_UP_THR_MES	984.15	 hPa
    ENG112591	PSN_EDGE_REL_AD_CAM_EX[1][1]	0.0001	 °
    ENG112592	PSN_EDGE_REL_AD_CAM_IN[1][1]	0.8126	 °
    ENG114830	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1]	0.0001	 °
    ENG114831	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2]	0.0001	 °
    ENG114832	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1]	0.8126	 °
    ENG114833	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2]	-0.9374	 °
    ENG128797	PV	0	 %
    ENG102195	PV_AV_1	0	 %
    ENG99137	PV_AV_2	0	 %
    ENG101068	PV_AV_H	0	 %
    ENG112593	PWM_ACT_VCP[EX_1]	90.003	 %
    ENG112594	PWM_ACT_VCP[IN_1]	90.003	 %
    ENG101350	PWM_ETC	0	 %
    ENG112595	PWM_HLD_VCP[EX_1]	11.249	 %
    ENG112596	PWM_HLD_VCP[IN_1]	11.249	 %
    ENG112597	PWM_PAS_VCP[EX_1]	11.249	 %
    ENG112598	PWM_PAS_VCP[IN_1]	11.249	 %
    ENG101201	Radiator fan 1: run-on: status	600W
    ENG102359	Radiator fan 2: run-on: status	NO_ECF
    ENG119939	RATIO_O2L_LIM_CAT_GAP_AFL_MV[1]	0
    ENG119940	RATIO_O2L_LIM_CAT_GAP_AFR_MV[1]	0
    ENG102377	Ready and error flags	0
    ENG112599	RVC_AV	89.23	 °
    ENG112601	RVC_SP	88.75	 °
    ENG112600	RVCPWM	0	 %
    ENG103248	SEG_AD_MMV_ER[0]	0
    ENG101135	SEG_AD_MMV_ER[1]	-0.1597
    ENG99078	SEG_AD_MMV_ER[2]	-0.0782
    ENG103257	SEG_AD_MMV_ER[3]	-0.0591
    ENG102511	SEG_AD_MMV_ER_H[0]	0
    ENG103258	SEG_AD_MMV_ER_H[1]	-0.2923
    ENG99291	SEG_AD_MMV_ER_H[2]	-0.0741
    ENG99954	SEG_AD_MMV_ER_H[3]	-0.1855
    ENG100568	SEG_AD_MMV_ER_L[0]	0
    ENG100601	SEG_AD_MMV_ER_L[1]	-0.1597
    ENG102668	SEG_AD_MMV_ER_L[2]	-0.0782
    ENG101232	SEG_AD_MMV_ER_L[3]	-0.0591
    ENG101561	SEG_AD_MMV_ER_MID[0]	0
    ENG102964	SEG_AD_MMV_ER_MID[1]	-0.1657
    ENG100890	SEG_AD_MMV_ER_MID[2]	-0.0546
    ENG99793	SEG_AD_MMV_ER_MID[3]	-0.1113
    ENG103381	Shut-off time	3.7	 s
    ENG109006-ENG100882	Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX	20	 %
    ENG109007-ENG99938	Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX	10	 %
    ENG102971	Start adaption: temperature adaption factor 1	1
    ENG102489	Start adaption: temperature adaption factor 2	1
    ENG100723	Start adaption: temperature adaption factor 3	1
    ENG100919	Starter control: interlock switch	0
    ENG100800	Starter: start relay 1	0
    ENG99979	Starter: start relay 2	0
    ENG102033	STATE_BPA[0]	OPM
    ENG102127	STATE_COMC_NVLD	Wait
    ENG112602	STATE_CRK_STST	CRK_STST_PAS
    ENG114834	STATE_CRU_OFF_IRR_CUS	0
    ENG114835	STATE_CRU_OFF_REV_CUS	1.84E+07
    ENG112603	STATE_EOL_VVL	DEAC
    ENG112605	STATE_LS_SAE[1]	INI
    ENG104238	STATE_NVLD	READ_INI
    ENG112606	STATE_PWM_VCP[EX_1]	HLD
    ENG112607	STATE_PWM_VCP[IN_1]	HLD
    ENG101078	STATE_READY_OBD_1	7
    ENG100369	STATE_READY_OBD_3	0
    ENG100342	STATE_REQ_NVLD	NO_REQ
    ENG109090	STATE_SW_MVB	SC8S3010 CBS00I0
    ENG128798	STATE_T_ES_RD	0
    ENG128799	STATE_T_ES_VLD_RD	1
    ENG112608	STATE_VCP	passive
    ENG114836	STATE_VCV_CLOSE_SL	OFF
    ENG103723	STATE_VVL_MNG	VVL_H
    ENG112609	T_ACT_MIL_SAE	0	 min
    ENG112494	T_AST_SAE	0	 s
    ENG104148	T_COOL_LOIL	408.4	 ms
    ENG112613	T_DTC_CLR_SAE	2992	 min
    ENG102790	T_EFP_MEM_H	0	 s
    ENG102123	T_EFP_MEM_L	0	 s
    ENG109299	T_ES	1425	 min
    ENG112615	T_ES_CNT	0
    ENG112616	T_ES_DC	1417	 min
    ENG99463	T_ES_H	65535	 s
    ENG128802	T_IGK	468.69	 s
    ENG99398	T_POP_COC_INTER_1	0	 s
    ENG102747	T_PWL	0	 s
    ENG128803	T_PWL_CAN	353.6	 s
    ENG112636	T_SWI_VVL_ACR	0	 ms
    ENG101325	T_TEMP_SIG_LOIL	38.8	 ms
    ENG99126	T_VS_TOL_LOCK	0	 min
    ENG125440	TAA	14	 °C
    ENG102048	Tank breather valve: duty cycle	0	 %
    ENG101339	Tank breather valve: short trip result	0	 kg/h
    ENG100439	Tank level	0
    ENG112610	TCO_1_FIRST_ST	13	 °C
    ENG112611	TCO_1_ST	13	 °C
    ENG112612	TCO_1_SYS	13	 °C
    ENG103434	TCO_A_LAM_AD_WUP[1]	-5.25	 °C
    ENG100381	TCO_B_LAM_AD_WUP[1]	9.75	 °C
    ENG101581	TCO_C_LAM_AD_WUP[1]	24.75	 °C
    ENG100354	TCO_D_LAM_AD_WUP[1]	35.25	 °C
    ENG101973	TCO_E_LAM_AD_WUP[1]	45	 °C
    ENG128800	TCO_MDL[STUCK_L_COOL_MON]	0.445	 °C
    ENG124460	TCO_MDL[TH]	3.445	 °C
    ENG100390	TCO_MIN_INTER_LAM_AD_WUP[1]	12.75	 °C
    ENG100853	TCO_MIN_LAM_AD_WUP[1]	50.25	 °C
    ENG102279	TCS/ESP: specified torque	32.19	 Nm
    ENG99857	TCS: status	0
    ENG110436	TEG_DYN_LS_DOWN[1]	13.475	 °C
    ENG110437	TEG_DYN_LS_UP[1]	13.475	 °C
    ENG101941	TEMP_CAT_STAT_MDL[1]	19.975	 °C
    ENG112614	TEMP_CAT_UP_1_SAE	13.5	 °C
    ENG114837	TFPA	14	 °C
    ENG114838	TFU_HPP	12.75	 °C
    ENG99608	Throttle valve adjuster: adaption status	ST_CHK_END
    ENG101411	Throttle valve angle	6.703	 °
    ENG102845	Throttle valve deviation	0	 %
    ENG126115	TI_1_MES_MPI[0]	0	 ms
    ENG126116	TI_1_MES_MPI[1]	0	 ms
    ENG126117	TI_1_MES_MPI[2]	0	 ms
    ENG126118	TI_1_MES_MPI[3]	0	 ms
    ENG126119	TI_MES_4[PLS_1][0]	0	 ms
    ENG126120	TI_MES_4[PLS_1][1]	0	 ms
    ENG126121	TI_MES_4[PLS_1][2]	0	 ms
    ENG126122	TI_MES_4[PLS_1][3]	0	 ms
    ENG126123	TI_MES_4[PLS_2][0]	0	 ms
    ENG126124	TI_MES_4[PLS_2][1]	0	 ms
    ENG126125	TI_MES_4[PLS_2][2]	0	 ms
    ENG126126	TI_MES_4[PLS_2][3]	0	 ms
    ENG126127	TI_MES_4[PLS_3][0]	0	 ms
    ENG126128	TI_MES_4[PLS_3][1]	0	 ms
    ENG126129	TI_MES_4[PLS_3][2]	0	 ms
    ENG126130	TI_MES_4[PLS_3][3]	0	 ms
    ENG128801	TIA_CHA_DOWN_MV	27.691	 °C
    ENG125276	TIG_MES_SAE[IM]	18	 °C
    ENG103351	Time since engine start	0	 s
    ENG112634	TLTS_MES[TCE]	13.82	 °C
    ENG112635	TMAG_VCP	12	 °C
    ENG110444	TPS_AD_CDN_MIS	0
    ENG114839	TPS_ETC	6.703	 °
    ENG99274	TPS_SP	6.652	 °
    ENG103021	TQ_CONV	12	 Nm
    ENG128804	TQI_ADD_ACT	0.00003	 Nm
    ENG101426	TQI_GS_FAST_INC	0	 Nm
    ENG128805	TQI_N_TCHA_MAX	1023.96878	 Nm
    ENG102329	TTIP_MES_LS_UP[1]	-2047.9999	 °C
    ENG100355	V_FUP_EFP_MV	4.995	 V
    ENG100739	V_PVS_1_BAS	0.7568	 V
    ENG114840	V_PVS_KD	0	 V
    ENG99514	VBOOST	64	 V
    ENG103201	VCV_CLOSE_RNG	0	 °
    ENG102311	Vehicle speed: filtered	0	 km/h
    ENG122704	VLCAvl_st_Pt_VW	4
    ENG122705	VLCReq_st_Dem_VW	0
    ENG112639	VLS_DOWN_SAE[1]	1.275	 V
    ENG128806	VOL_FLOW_CHA_UP_RED_MV	0	 m³/s
    ENG101929	VP_TPS_1	0.8154	 V
    ENG102985	VP_TPS_2	4.165	 V
    ENG100421	VP_TPS_AD_EL_BOL_1	0.5025	 V
    ENG103444	VP_TPS_AD_EL_BOL_2	4.4914	 V
    ENG101674	VP_TPS_AD_LIH_1	0.8154	 V
    ENG99507	VP_TPS_AD_LIH_2	4.1699	 V
    Elapsed Time: 01:17
    adpmap-01-8V0-906-264-L.CSV
    ;SW:8V0-906-264-L   HW:06K-907-425-B ---  Engine
    ;Component:1.8l R4 TFSI  H13 0002	 Coding:311D00322466002F1000
    ;EV_ECM18TFS0208V0906264L	1003	EV_ECM18TFS0208V0906264L.rod
    ;Wednesday	3	May	2017	19:04:45:59530
    ;VCDS Version: Beta 17.4.2 (x64)  Data version: 20170413 DS270.4
    ;VCID: C5C2108C4449EC6FFC-8090
    IDE00001-Production mode	00 00 00 	3
    IDE00259-Idle RPM correction	0 /min	1
    IDE01945-Engine run-in oil pressure	not active 	1
    IDE02332-Deactivate production mode	00 00 00 	3
    IDE04158-Activation of start-stop function	not active 	1
    IDE04617-Protective function	Enabled 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE06726-Timing deviation after chain replacement: intake bank 1	-0.44 °	2
    IDE06728-Timing deviation after chain replacement: exhaust bank 1	0.00 °	2
    IDE06730-Timing deviation after other repairs: intake bank 1	0.00 °	2
    IDE06732-Timing deviation after other repairs: exhaust bank 1	0.00 °	2
    IDE06734-Timing deviation: current value intake bank 1	-0.56 °	2
    IDE06736-Timing deviation: current value exhaust bank 1	0.00 °	2
    IDE06738-Chain elongation: no. of valid initial values: intake bank 1	5	1
    IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1	0	1
    IDE06742-Chain elongation: initial values valid: intake bank 1	active 	1
    IDE06744-Chain elongation: initial values valid: exhaust bank 1	not active 	1
    IDE10261-MAS10172-Operating mode selec.-DI operation	not activated 	4
    IDE10261-MAS10174-Operating mode selec.-CNG operation	not activated 	4
    Elapsed Time: 00:04
    United States
    02-Auto Trans
    blockmap-02-0D9-300-012-F.CSV
    ;SW:0D9-300-012-F   HW:02E-927-770-AQ ---  Auto Trans
    ;Component:DQ250-6F MQB  H54 4901	 Coding:0014
    ;EV_TCMDQ250021	1001	EV_TCMDQ250021.rod
    ;Wednesday	11	January	2017	19:57:26:08929
    ;VCDS Version: Release 17.1.1 (x64)  Data version: 20170106 DS267.0
    ;VCID: 9975CEC198BBD389B2-80CC
    Group	Description	Actual
    IDE00018	Voltage terminal 15	13.9	 V
    IDE00019	Voltage terminal 30	14.2	 V
    IDE00021-ENG99543	Engine speed-Engine RPM	704	 /min
    IDE00022-ENG103074	Transmission input speed-Transmission Input Speed Sensor	702	 /min
    IDE00024	Transmission fluid temperature	84	 °C
    IDE00075-ENG99967	Vehicle speed-Vehicle Speed Sensor	0	 km/h
    IDE00086-ENG98363	Accelerator position-Accelerator pedal position	0	 %
    IDE00091-ENG101172	Status of starter lock-Status Engine Starter Lock	Activate
    IDE00094	Kick-down status	OFF
    IDE00095-ENG101643	Status of selector lever lock-Status Shift Lock	active
    IDE00096-ENG100569	Selector lever position-Shift Position	Position P Stop
    IDE00102-ENG102028	Control Module temperature-Control modul temperature	91	 °C
    IDE00130-ENG103124	Transmission specified idle RPM-Idle Speed Commanded Value	600	 /min
    IDE00322-ENG100540	Status of basic setting-Basic Settings Status	0
    IDE00323-ENG09093	Security Access: Number of invalid keys-Counter Value	0
    IDE00451-ENG103018	Currently running routine-Current Test Routine	0
    IDE00872-ENG102188	Current of main pressure valve-Oil Pressure Actual Current	826.5	 mA
    IDE01588-ENG101855	Driving direction-M015 SvnNAbRichtung	not known
    IDE02221	Engine torque: qualification	valid
    IDE02713	Brake Light Switch	not activated
    IDE02714	Brake test switch	not activated
    IDE02717-ENG102076	Tiptronic upshift-Tiptronic Up	OFF
    IDE02718-ENG101063	Tiptronic downshift-Tiptronic Down	OFF
    IDE02719-ENG99606	Selector lever position made plausible-Shift Position Plausible	P
    IDE02720-ENG103810	Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1	0	 /min
    IDE02721-ENG100916	Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2	0	 /min
    IDE02722-ENG101964	Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1	0	 /min
    IDE02723-ENG100382	Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2	0	 /min
    IDE02735-ENG100209	Display of driving mode in instrument panel-Display Driving Position	P
    IDE02736-ENG100252	Display of gear in instrument panel-Display Driving Gear	no gear engaged
    IDE02790-ENG104124	Specified torque clutch 1-Clutch 1 Commanded Torque	-600	 Nm
    IDE02796-ENG103463	Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value	0	 mA
    IDE02797-ENG100730	Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value	0	 mA
    IDE02800-ENG100171	Specified torque clutch 2-Clutch 2 Commanded Torque	-600	 Nm
    IDE02805-ENG99237	Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value	0	 mA
    IDE02806-ENG103118	Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value	0.1	 mA
    IDE02862-ENG103213	Production data transmission-Aggregatekennzeichnung (Getriebe)	6
    IDE02862-ENG103083	Production data transmission-Baudatum	160727
    IDE02862-ENG104019	Production data transmission-Getriebekennbuchstabe	QMH
    IDE02862-ENG99175	Production data transmission-Kassel	K
    IDE02862-ENG101707	Production data transmission-Kennung der Montagelinie	D11
    IDE02862-ENG103830	Production data transmission-Lfd.-Nr	3593
    IDE02864-ENG99505	Actual position of gear positioner A-Gearpositioner A Actual Position	-0.02	 mm
    IDE02865-ENG104121	AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1	2048
    IDE02870-ENG120871	Duty cycle of gear solenoid valve A-Gearpositioner_A_Valve_Duty_Factor	0	 %
    IDE02872-ENG102218	Actual position of gear adjuster B-Gearpositioner B Actual Position	-7.94	 mm
    IDE02873-ENG101728	AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1	1102
    IDE02878-ENG120875	Pulse duty factor of gear solenoid valve B-Gearpositioner_B_Valve_Duty_Factor	0	 %
    IDE02880-ENG103036	Actual position of gear positioner C-Gearpositioner C Actual Position	-0.4	 mm
    IDE02881-ENG99453	AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1	2053
    IDE02886-ENG120879	Pulse duty factor of gear solenoid valve C-Gearpositioner_C_Valve_Duty_Factor	0	 %
    IDE02888-ENG103826	Actual position of gear positioner D-Gearpositioner D Actual Position	-7.95	 mm
    IDE02889-ENG100525	AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1	1191
    IDE02894-ENG120883	Duty cycle of gear solenoid valve D-Gearpositioner_D_Valve_Duty_Factor	0	 %
    IDE03008-ENG122550	Stop process prevented-GE_StartStopp_Info	Stop release
    IDE03008-ENG122551	Stop process prevented-MO_StartStopp_Status	0
    IDE03008-ENG122546	Stop process prevented-Stopp-Verbot-Grund 1	not active
    IDE03008-ENG122547	Stop process prevented-Stopp-Verbot-Grund 2	not active
    IDE03008-ENG122548	Stop process prevented-Stopp-Verbot-Grund 3	not active
    IDE03008-ENG122549	Stop process prevented-Stopp-Verbot-Grund 4	not active
    IDE03008-ENG122552	Stop process prevented-Stopp-Verbot-Grund 5	not active
    IDE03008-ENG122553	Stop process prevented-Stopp-Verbot-Grund 6	not active
    IDE03008-ENG122554	Stop process prevented-Stopp-Verbot-Grund 8	not active
    IDE03171-ENG102987	Driving strategy transmission mileage-Q002 Total Driving Time	482.5	 km
    IDE03172-ENG100789	Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological	97	 %
    IDE03173-ENG103567	Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty	0	 %
    IDE03174-ENG100415	Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual	1	 %
    IDE03180-ENG103176	Number of standard trips-General Denominator	3
    IDE03181-ENG102823	Number of ignition cycles-Ignition Cycle Counter	80
    IDE03182-ENG120927	Lower adapted coupling point K1 from kiss point adaptation-lower_Adapted_Clutchpoint_K1_Of_Kisspoint_Adaption	0.265	 A
    IDE03183-ENG120930	Lower adapted coupling point K2 from kiss point adaptation-lower_Adapted_Clutchpoint_K2_Of_Kisspoint_Adaption	0.235	 A
    IDE03184-ENG120928	Upper adapted coupling point K1 from microslip adaptation-Upper_Adapted_Clutchpoint_K1_Of_Microslip_Adaption	0.785	 A
    IDE03185-ENG120929	Upper adapted coupling point K2 from microslip adaptation-Upper_Adapted_Clutchpoint_K2_Of_Microslip_Adaption	0.725	 A
    IDE03189-ENG110507	Number of prevented stop processes (statistics)-Anzahl Stoppverbote	0
    IDE03189-ENG110509	Number of prevented stop processes (statistics)-Gründe für Stoppverbot	not active
    IDE03189-ENG110508	Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots	0	 km
    IDE04612-ENG101246	Clutch temperature air / splash oil-Centrifugal oil temperature	84	 °C
    IDE04805-ENG98547	Driving profile selection-Driving program	Available
    IDE04805-ENG98560	Driving profile selection-Free run	not_available
    IDE05987-ENG110507	Engine stop prohibitions-Anzahl Stoppverbote	0
    IDE05987-ENG110509	Engine stop prohibitions-Gründe für Stoppverbot	not active
    IDE05987-ENG110508	Engine stop prohibitions-km-Stand des letzten Stoppverbots	0	 km
    IDE05988-ENG110505	Pressure of clutch 2: actual value-Clutch_2_actual_value	0	 bar
    IDE05989-ENG110503	Pressure of clutch 1: actual value-Clutch_1_actual_value	0	 bar
    IDE06425	Roller test bench mode: functional	not activated
    IDE80001-ENG100467	Analysis 1-Snapshot 1 Failure ID	65535
    IDE80002-ENG102386	Analysis 2-Snapshot 1 Mileage	0	 km
    IDE80003-ENG101467	Analysis 3-Snapshot 1 Counter	0
    IDE80005-ENG103330	Analysis 5-Snapshot 1 Shift Position Plausible	ERROR
    IDE80007-ENG101090	Analysis 7-Snapshot 1  Commanded Gear	GANG N
    IDE80008-ENG100048	Analysis 8-Snapshot 1 Preselection Gear	GANG N
    IDE80009-ENG102100	Analysis 9-Snapshot 1 Transmission Input Speed	0	 /min
    IDE80010-ENG101565	Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1	0	 /min
    IDE80011-ENG100379	Analysis 11-Snapshot 1 Transmission Speed Shaft 1	0	 /min
    IDE80012-ENG103459	Analysis 12-Snapshot 1 Transmission Speed Shaft 2	0	 /min
    IDE80021-ENG102762	Analysis 21-Snapshot 1 Clutch 1 Actual Pressure	0	 bar
    IDE80022-ENG100347	Analysis 22-Snapshot 1 Clutch 2 Actual Pressure	0	 bar
    IDE80023-ENG99119	Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value	0	 mA
    IDE80024-ENG101123	Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value	0	 mA
    IDE80025-ENG103611	Analysis 25-Snapshot 1 Accelerator Pedal Position	0	 %
    IDE80026-ENG101503	Analysis 26-Snapshot 1 Engine torque	-50	 Nm
    IDE80029-ENG103070	Analysis 29-Snapshot 1 Voltage Terminal 15	0	 V
    IDE80031-ENG102899	Analysis 31-Snapshot 1 Transmission Fluid Temperature	-60	 °C
    IDE80033-ENG103098	Analysis 33-Snapshot 2 Failure ID	65535
    IDE80034-ENG101047	Analysis 34-Snapshot 2 Mileage	0	 km
    IDE80035-ENG99915	Analysis 35-Snapshot 2 Counter	0
    IDE80037-ENG99369	Analysis 37-Snapshot 2 Shift Position Plausible	ERROR
    IDE80039-ENG101369	Analysis 39-Snapshot 2  Commanded Gear	GANG N
    IDE80040-ENG103638	Analysis 40-Snapshot 2 Preselection Gear	GANG N
    IDE80041-ENG103367	Analysis 41-Snapshot 2 Transmission Input Speed	0	 /min
    IDE80042-ENG102476	Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1	0	 /min
    IDE80043-ENG102699	Analysis 43-Snapshot 2 Transmission Speed Shaft 1	0	 /min
    IDE80044-ENG101900	Analysis 44-Snapshot 2 Transmission Speed Shaft 2	0	 /min
    IDE80053-ENG102973	Analysis 53-Snapshot 2 Clutch 1 Actual Pressure	0	 bar
    IDE80054-ENG100122	Analysis 54-Snapshot 2 Clutch 2 Actual Pressure	0	 bar
    IDE80055-ENG103189	Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value	0	 mA
    IDE80056-ENG103616	Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value	0	 mA
    IDE80057-ENG102447	Analysis 57-Snapshot 2 Accelerator Pedal Position	0	 %
    IDE80058-ENG103198	Analysis 58-Snapshot 2 Engine torque	-50	 Nm
    IDE80061-ENG101449	Analysis 61-Snapshot 2 Voltage Terminal 15	0	 V
    IDE80063-ENG104157	Analysis 63-Snapshot 2 Transmission Fluid Temperature	-60	 °C
    IDE80065-ENG122555	Analysis 65-Snapshot 1 Weg Gangsteller 1-3	0
    IDE80065-ENG122556	Analysis 65-Snapshot 1 Weg Gangsteller 2-4	0
    IDE80065-ENG122557	Analysis 65-Snapshot 1 Weg Gangsteller 5-N	0
    IDE80065-ENG122558	Analysis 65-Snapshot 1 Weg Gangsteller 6-R	0
    IDE80066-ENG122559	Analysis 66-Snapshot 2 Weg Gangsteller 1-3	0
    IDE80066-ENG122560	Analysis 66-Snapshot 2 Weg Gangsteller 2-4	0
    IDE80066-ENG122561	Analysis 66-Snapshot 2 Weg Gangsteller 5-N	0
    IDE80066-ENG122562	Analysis 66-Snapshot 2 Weg Gangsteller 6-R	0
    IDE80071-ENG127839	Analysis 71-FID event memory entry 1	FF FF
    IDE80071-ENG127848	Analysis 71-FID event memory entry 10	FF FF
    IDE80071-ENG127849	Analysis 71-FID event memory entry 11	FF FF
    IDE80071-ENG127850	Analysis 71-FID event memory entry 12	FF FF
    IDE80071-ENG127840	Analysis 71-FID event memory entry 2	FF FF
    IDE80071-ENG127841	Analysis 71-FID event memory entry 3	FF FF
    IDE80071-ENG127842	Analysis 71-FID event memory entry 4	FF FF
    IDE80071-ENG127843	Analysis 71-FID event memory entry 5	FF FF
    IDE80071-ENG127844	Analysis 71-FID event memory entry 6	FF FF
    IDE80071-ENG127845	Analysis 71-FID event memory entry 7	FF FF
    IDE80071-ENG127846	Analysis 71-FID event memory entry 8	FF FF
    IDE80071-ENG127847	Analysis 71-FID event memory entry 9	FF FF
    IDE80296-ENG127853	Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter	49
    IDE80298-ENG127880	Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter	25
    IDE80302-ENG122492	Selector lever information-Datenstand	L4
    IDE80302-ENG111628	Selector lever information-Part Number	5Q1 713025 S
    IDE80302-ENG98856	Selector lever information-Programmability	0
    IDE80302-ENG122491	Selector lever information-Programm-Stand	 V
    IDE80303-ENG127833	Overall software description-Software full name	F49M
    IDE80304-ENG120779	Mechatronics identification DQ250-Änderungsstand BorgWarner	63
    IDE80304-ENG120778	Mechatronics identification DQ250-Mechatronik-Identifikation	S28T0207
    IDE80305-ENG125922	Parameter set description-Data set name	0D9300012F_4901_HDKW
    IDE80312-ENG122524	CAN bus installation information-ACC_06	Unknown
    IDE80312-ENG122528	CAN bus installation information-BEM_05	installed
    IDE80312-ENG113024	CAN bus installation information-Charisma_01	installed
    IDE80312-ENG122522	CAN bus installation information-EPB_01	not installed
    IDE80312-ENG122525	CAN bus installation information-GRA_ACC_01	installed
    IDE80312-ENG122511	CAN bus installation information-TSK_06	installed
    ENG120958	Abbruchcode	GSA_ABBRUCH_CODE_OK
    ENG122365-ENG104207	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 0	Abschalten ENA erfolgreich
    ENG122365-ENG102209	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 1	Abschalten WDA erfolgreich
    ENG122365-ENG99197	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 2	EInschalten Endstufen erfolgreich
    ENG122365-ENG102937	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 3	Keine Unterspannung im Abschaltpfadtest
    ENG122363	Abschaltpfadtest Maximaler AD-Wert im Off-Fall	242
    ENG122364	Abschaltpfadtest Minimaler AD-Wert im On-Fall	340
    ENG120920	Abtriebsdrehzahl CAN	0	 /min
    ENG98625-ENG103724	Accelerator position: qualification-Accelerator pedal position: qualification	OK
    ENG100091	Ambient temperature	7	 °C
    ENG120963	Anzahl der Überschreitungen der zulässigen Schleuderöltemperatur	0
    ENG120964	Anzahl der Warnungen aufgrund erhöhter Schleuderöltemperatur	0
    ENG122366	Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests	453
    ENG120970	Anzahl Ereignisse auf K1	0
    ENG120972	Anzahl Ereignisse auf K2	0
    ENG98482-ENG99180	Checksum of flash-Calibration Checksumme	E3 B3 F9 06
    ENG98482-ENG100495	Checksum of flash-Cboot Checksumme	31 82 84 67
    ENG98482-ENG100117	Checksum of flash-Checksumme ECU + CAL	00 00 27 DD
    ENG98482-ENG102221	Checksum of flash-ECU Checksumme	6E 53 C6 11
    ENG110530	Clutch 1 adaption kiss point part 1 fault counter	0
    ENG110536	Clutch 2 adaption kiss point part 1 fault counter	0
    ENG99212	Common highside 1 specified condition	Common Highside soll eingeschaltet werden
    ENG99878	Common highside 2 specified condition	Common Highside soll eingeschaltet werden
    ENG103403	Converter Loss Torque	4	 Nm
    ENG100625	Coolant temperature	104	 °C
    ENG98602	Driver request torque	4	 Nm
    ENG100746	Driving strategy: sport factor	0	 %
    ENG120931	Eingelegtposition Seite A: Gangsteller 1-3	0	 %
    ENG120932	Eingelegtposition Seite A: Gangsteller 2-4	0	 %
    ENG120933	Eingelegtposition Seite A: Gangsteller 5-N	0	 %
    ENG120934	Eingelegtposition Seite A: Gangsteller 6-R	0	 %
    ENG120943	Eingelegtposition Seite B: Gangsteller 1-3	0	 %
    ENG120944	Eingelegtposition Seite B: Gangsteller 2-4	0	 %
    ENG120945	Eingelegtposition Seite B: Gangsteller 5-N	0	 %
    ENG120946	Eingelegtposition Seite B: Gangsteller 6-R	0	 %
    ENG101251	Empty	Empty
    ENG98756	Engine torque	4	 Nm
    ENG104230	Engine torque loss	-20	 Nm
    ENG123019-ENG99024	Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission	0	 km/h
    ENG120799	Gangsteller A Adaption Flags	00 1F
    ENG120808	Gangsteller B Adaption Flags	00 1F
    ENG120817	Gangsteller C Adaption Flags	00 15
    ENG120826	Gangsteller D Adaption Flags	00 1F
    ENG121005	Gangsteller Synchronposition G1 (Prozent)	55.21	 %
    ENG121006	Gangsteller Synchronposition G2 (Prozent)	45.9	 %
    ENG121007	Gangsteller Synchronposition G3 (Prozent)	46.37	 %
    ENG121008	Gangsteller Synchronposition G4 (Prozent)	54.12	 %
    ENG121009	Gangsteller Synchronposition G5 (Prozent)	53.77	 %
    ENG121010	Gangsteller Synchronposition G6 (Prozent)	54.86	 %
    ENG121011	Gangsteller Synchronposition GR (Prozent)	46.42	 %
    ENG120961	Gangsteller_Index	GS_13
    ENG120962	Gangsteller_Seite	Neutrallage
    ENG120957	Gangstellerposition zum Zeitpunkt eines Abbruchs	Neutral
    ENG120969	Gefahrene km seit letztem Ereignis auf K1	240	 km
    ENG120971	Gefahrene km seit letztem Ereignis auf K2	240	 km
    ENG99720	Height info	965	 mbar
    ENG98604	Hill factor driving strategy	0	 %
    ENG99596	Indicated engine torque without external interventions	24	 Nm
    ENG99582	Intake air temperature	0	 °C
    ENG122357-ENG122524	Kommunikationsstatus Datenbus 1 MQB-ACC_06	Unknown
    ENG122357-ENG122528	Kommunikationsstatus Datenbus 1 MQB-BEM_05	received
    ENG122357-ENG113024	Kommunikationsstatus Datenbus 1 MQB-Charisma_01	received
    ENG122357-ENG122523	Kommunikationsstatus Datenbus 1 MQB-Diagnose_01	received
    ENG122357-ENG122522	Kommunikationsstatus Datenbus 1 MQB-EPB_01	Unknown
    ENG122357-ENG122513	Kommunikationsstatus Datenbus 1 MQB-ESP_02	received
    ENG122357-ENG122514	Kommunikationsstatus Datenbus 1 MQB-ESP_05	received
    ENG122357-ENG110808	Kommunikationsstatus Datenbus 1 MQB-ESP_07	received
    ENG122357-ENG122515	Kommunikationsstatus Datenbus 1 MQB-ESP_10	Unknown
    ENG122357-ENG122516	Kommunikationsstatus Datenbus 1 MQB-ESP_19	received
    ENG122357-ENG122517	Kommunikationsstatus Datenbus 1 MQB-ESP_20	received
    ENG122357-ENG122518	Kommunikationsstatus Datenbus 1 MQB-ESP_21	received
    ENG122357-ENG122519	Kommunikationsstatus Datenbus 1 MQB-Gateway_72	received
    ENG122357-ENG122520	Kommunikationsstatus Datenbus 1 MQB-Gateway_74	received
    ENG122357-ENG122525	Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01	received
    ENG122357-ENG00240	Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01	received
    ENG122357-ENG110802	Kommunikationsstatus Datenbus 1 MQB-Kombi_01	received
    ENG122357-ENG122521	Kommunikationsstatus Datenbus 1 MQB-Kombi_02	received
    ENG122357-ENG110799	Kommunikationsstatus Datenbus 1 MQB-LWI_01	received
    ENG122357-ENG122512	Kommunikationsstatus Datenbus 1 MQB-Motor_04	received
    ENG122357-ENG122502	Kommunikationsstatus Datenbus 1 MQB-Motor_07	received
    ENG122357-ENG122503	Kommunikationsstatus Datenbus 1 MQB-Motor_11	received
    ENG122357-ENG122504	Kommunikationsstatus Datenbus 1 MQB-Motor_12	received
    ENG122357-ENG122505	Kommunikationsstatus Datenbus 1 MQB-Motor_14	received
    ENG122357-ENG122506	Kommunikationsstatus Datenbus 1 MQB-Motor_16	received
    ENG122357-ENG122507	Kommunikationsstatus Datenbus 1 MQB-Motor_17	received
    ENG122357-ENG122529	Kommunikationsstatus Datenbus 1 MQB-Motor_18	received
    ENG122357-ENG122508	Kommunikationsstatus Datenbus 1 MQB-Motor_20	received
    ENG122357-ENG122509	Kommunikationsstatus Datenbus 1 MQB-Motor_26	Unknown
    ENG122357-ENG06581	Kommunikationsstatus Datenbus 1 MQB-Motor_35	Unknown
    ENG122357-ENG122510	Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01	received
    ENG122357-ENG122526	Kommunikationsstatus Datenbus 1 MQB-OBD_01	received
    ENG122357-ENG122511	Kommunikationsstatus Datenbus 1 MQB-TSK_06	received
    ENG122357-ENG122527	Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03	received
    ENG126632	Korrekturwerte Hauptdruckadaption	0.35	 bar
    ENG121002	Korrekturwerte Hauptdruckadaption: großer Druck auf K1	0.35	 bar
    ENG121004	Korrekturwerte Hauptdruckadaption: großer Druck auf K2	0.3	 bar
    ENG121001	Korrekturwerte Hauptdruckadaption: kleiner Druck auf K1	0.35	 bar
    ENG121003	Korrekturwerte Hauptdruckadaption: kleiner Druck auf K2	0.35	 bar
    ENG99297	Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl	0
    ENG100826	Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl	0
    ENG120965	Kupplungsadaptionswerte: IKp0 fuer K1	265	 mA
    ENG120966	Kupplungsadaptionswerte: IKp0 fuer K2	235	 mA
    ENG120967	Kupplungsadaptionswerte: unterer Strompunkt Adaption K1	230	 mA
    ENG120968	Kupplungsadaptionswerte: unterer Strompunkt Adaption K2	225	 mA
    ENG110556-ENG110541	Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung	0
    ENG110556-ENG110542	Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß	0
    ENG110556-ENG110543	Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein	0
    ENG110556-ENG120771	Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen	409
    ENG110557-ENG110545	Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung	0
    ENG110557-ENG110546	Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß	0
    ENG110557-ENG110547	Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein	0
    ENG110557-ENG110544	Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen	97
    ENG120996	Maximale Spannung an UH1	9.1	 V
    ENG120998	Maximale Spannung an UH2	4.9	 V
    ENG120995	Minimale Spannung an UH1	0.2	 V
    ENG120997	Minimale Spannung an UH2	4.9	 V
    ENG111613-ENG101555	Motordrehmoment Begrenzung-Engine torque limitation	270	 Nm
    ENG120939	Neutralposition: Gangsteller 1-3	50.39	 %
    ENG120940	Neutralposition: Gangsteller 2-4	50.18	 %
    ENG120941	Neutralposition: Gangsteller 5-N	49.75	 %
    ENG120942	Neutralposition: Gangsteller 6-R	50.79	 %
    ENG120993	Oberer adaptierter Kupplungspunkt K1 aus Makroschlupfadaption	785	 mA
    ENG120994	Oberer adaptierter Kupplungspunkt K2 aus Makroschlupfadaption	725	 mA
    ENG105329-ENG101124	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)	13.2	 H
    ENG105329-ENG100216	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2)	0.3	 H
    ENG105329-ENG103067	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3)	0	 H
    ENG105329-ENG101168	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4)	0	 H
    ENG105329-ENG104150	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5)	0	 H
    ENG105329-ENG100130	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6)	0	 H
    ENG120987	Ratio FID 256	100	 %
    ENG120989	Ratio FID 257	100	 %
    ENG120988	Ratio FID 330	100	 %
    ENG120990	Ratio FID 333	100	 %
    ENG120975	Ratio FID 52	100	 %
    ENG120976	Ratio FID 53	100	 %
    ENG120977	Ratio FID 54	100	 %
    ENG120978	Ratio FID 55	100	 %
    ENG120986	Ratio FID 56	100	 %
    ENG120973	Ratio FID 57	100	 %
    ENG120974	Ratio FID 58	100	 %
    ENG120979	Ratio FID 78	100	 %
    ENG120980	Ratio FID 79	100	 %
    ENG120981	Ratio FID 80	100	 %
    ENG120982	Ratio FID 81	100	 %
    ENG120983	Ratio FID 82	100	 %
    ENG120984	Ratio FID 83	100	 %
    ENG120985	Ratio FID 84	100	 %
    ENG100188	Reached maximum temperature control module	95	 °C
    ENG123020-ENG102793	Rollwiderstand-Road Resistance	0	 %
    ENG102748	Selector lever error flags	00 00
    ENG122375-ENG122573	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag	ABS-Flag nicht gesetzt
    ENG122375-ENG122571	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag	ASR-Flag nicht gesetzt
    ENG122375-ENG122570	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag	CHS1 oder CHS2 oder beide ausgeschaltet
    ENG122375-ENG122574	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag	EDS-Flag nicht gesetzt
    ENG122375-ENG122575	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag	FDR-Flag nicht gesetzt
    ENG122375-ENG122563	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag	GV1-Flag nicht gesetzt
    ENG122375-ENG122564	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag	GV2-Flag nicht gesetzt
    ENG122375-ENG122565	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag	GV3-Flag nicht gesetzt
    ENG122375-ENG122566	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag	GV4-Flag nicht gesetzt
    ENG122375-ENG122569	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag	MPX-Flag nicht gesetzt
    ENG122375-ENG122572	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag	MSR-Flag nicht gesetzt
    ENG122375-ENG122567	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag	SV1-Flag nicht gesetzt
    ENG122375-ENG122568	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag	SV2-Flag nicht gesetzt
    ENG122375-ENG122576	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag	Tipp-Gasse-Flag nicht gesetzt
    ENG122375-ENG122578	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag	Tipp-hoch-Flag nicht gesetzt
    ENG122375-ENG122577	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag	Tipp-runter-Flag nicht gesetzt
    ENG122369	Snapshot 1 Iststrom Hauptdruckventil	0	 mA
    ENG122367	Snapshot 1 Kupplungszustand	New
    ENG122371	Snapshot 1 unterer Strompunkt Adaption K1	0	 mA
    ENG122372	Snapshot 1 unterer Strompunkt Adaption K2	0	 mA
    ENG122376-ENG122573	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag	ABS-Flag nicht gesetzt
    ENG122376-ENG122571	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag	ASR-Flag nicht gesetzt
    ENG122376-ENG122570	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag	CHS1 oder CHS2 oder beide ausgeschaltet
    ENG122376-ENG122574	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag	EDS-Flag nicht gesetzt
    ENG122376-ENG122575	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag	FDR-Flag nicht gesetzt
    ENG122376-ENG122563	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag	GV1-Flag nicht gesetzt
    ENG122376-ENG122564	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag	GV2-Flag nicht gesetzt
    ENG122376-ENG122565	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag	GV3-Flag nicht gesetzt
    ENG122376-ENG122566	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag	GV4-Flag nicht gesetzt
    ENG122376-ENG122569	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag	MPX-Flag nicht gesetzt
    ENG122376-ENG122572	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag	MSR-Flag nicht gesetzt
    ENG122376-ENG122567	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag	SV1-Flag nicht gesetzt
    ENG122376-ENG122568	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag	SV2-Flag nicht gesetzt
    ENG122376-ENG122576	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag	Tipp-Gasse-Flag nicht gesetzt
    ENG122376-ENG122578	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag	Tipp-hoch-Flag nicht gesetzt
    ENG122376-ENG122577	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag	Tipp-runter-Flag nicht gesetzt
    ENG122370	Snapshot 2 Iststrom Hauptdruckventil	0	 mA
    ENG122368	Snapshot 2 Kupplungszustand	New
    ENG122373	Snapshot 2 unterer Strompunkt Adaption K1	0	 mA
    ENG122374	Snapshot 2 unterer Strompunkt Adaption K2	0	 mA
    ENG120921	Sollgang der Fahrstrategie	 R
    ENG101057	Specified idle speed	700	 /min
    ENG100803	Speed: output	0	 /min
    ENG122358	Start Stopp Statusinformationen aktuell	not active
    ENG122358-ENG122500	Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1	0
    ENG122358-ENG122501	Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2	0
    ENG120924	Strom oberer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption	1000	 mA
    ENG120926	Strom oberer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption	1000	 mA
    ENG120923	Strom unterer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption	230	 mA
    ENG120925	Strom unterer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption	225	 mA
    ENG120935	Synchronposition Seite A: Gangsteller 1-3	46.37	 %
    ENG120936	Synchronposition Seite A: Gangsteller 2-4	45.9	 %
    ENG120937	Synchronposition Seite A: Gangsteller 5-N	49.76	 %
    ENG120938	Synchronposition Seite A: Gangsteller 6-R	46.42	 %
    ENG120947	Synchronposition Seite B: Gangsteller 1-3	55.21	 %
    ENG120948	Synchronposition Seite B: Gangsteller 2-4	54.12	 %
    ENG120949	Synchronposition Seite B: Gangsteller 5-N	53.77	 %
    ENG120950	Synchronposition Seite B: Gangsteller 6-R	54.86	 %
    ENG120999	Tastverhältnis Sicherheitsventil 1	18	 %
    ENG121000	Tastverhältnis Sicherheitsventil 2	18	 %
    ENG120991	Unterer adaptierter Kupplungspunkt K1 aus Mikroschlupfadaption	280	 mA
    ENG120992	Unterer adaptierter Kupplungspunkt K2 aus Mikroschlupfadaption	240	 mA
    ENG120960	Unterzustand Gangstelleradaption	Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
    ENG120956	Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs	Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
    ENG101346	Version info driving strategy	Temic
    ENG109005	Voltage Common Highside 1	14.3	 V
    ENG99955	Voltage Common Highside 2	14.1	 V
    ENG120922	Vorwahlgang der Fahrstrategie	2
    ENG120952	Zählerstände der Hauptdruckadaption:Abbruchzähler auf K1	0
    ENG120954	Zählerstände der Hauptdruckadaption:Abbruchzähler auf K2	0
    ENG120951	Zählerstände der Hauptdruckadaption:Erfolgszähler auf K1	17
    ENG120953	Zählerstände der Hauptdruckadaption:Erfolgszähler auf K2	9
    ENG120959	Zustand Gangstelleradaption	Synchron_GSA_AUS
    ENG120955	Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs	Synchron_GSA_AUS
    Elapsed Time: 00:23
    adpmap-02-0D9-300-012-F.CSV
    ;Wednesday	11	January	2017	19:57:49:08929
    Elapsed Time: 00:00
    United States
    03-ABS Brakes
    blockmap-03-5Q0-614-517-BK.CSV
    ;SW:5Q0-614-517-BK   HW:5Q0-614-517-AH ---  ABS Brakes
    ;Component:ESC           H62 0736	 Coding:43FA6AA134200974807F130581CC29C2562C9001C881943C16435052E02903
    ;EV_Brake1UDSContiMK100IPB	35019	EV_Brake1UDSContiMK100IPB_035_VW37.rod
    ;Wednesday	11	January	2017	19:58:41:08929
    ;VCID: FBB9F44972C7019900-80AE
    IDE00323	Security Access: Number of invalid keys	0
    IDE00609-MAS01156	Communication status of data bus 1-Communication status	Engine Control Module 1
    IDE00780	Mode	running_mode
    IDE02270-IDE00086	CAN input signal(s) status-Accelerator position	0	 %
    IDE02270-IDE02049	CAN input signal(s) status-Trailer detected	ERROR
    IDE02270-IDE02713	CAN input signal(s) status-Brake Light Switch	not activated
    IDE02270-MAS00025	CAN input signal(s) status-Driver seat belt switch	not connected
    IDE02270-MAS00218	CAN input signal(s) status-Driver door	closed
    IDE02270-MAS00314	CAN input signal(s) status-Clutch Pedal Switch	operated
    IDE02270-MAS00364	CAN input signal(s) status-Shift lever / selector lever position	Neutral
    IDE02270-MAS01281	CAN input signal(s) status-Back-up light	OFF
    IDE02270-MAS02357	CAN input signal(s) status-Vehicle identification	AU08859
    IDE02270-MAS03992	CAN input signal(s) status-Clutch pedal switch: interlock position	active
    IDE02271-IDE03311	CAN output signal(s) status-Emergency brake display	not active
    IDE02271-IDE03660	CAN output signal(s) status-Longitudinal acceleration	-0.5625	 m/s²
    IDE02486	Data logger triggering	not active
    IDE02492	Start-stop function: coding information	Start-stop function in control module not active
    IDE02986-IDE04431	indicator lights-ASR and ESP indicator lamp	OFF
    IDE02986-IDE04451	indicator lights-Tire press monitoring display indictor lamp	OFF
    IDE02986-IDE04498	indicator lights--AUTO HOLD- Indicator Lamp	Not available due to specific system
    IDE02986-IDE04771	indicator lights-Indicator lamp for electro-mechanical parking brake malfunction	Not available due to specific system
    IDE02986-MAS00253	indicator lights-ABS indicator lamp	OFF
    IDE02986-MAS00556	indicator lights-Electromechanical parking brake indicator lamp	Not available due to specific system
    IDE02986-MAS01206	indicator lights-Hill descent control indicator lamp	OFF
    IDE02986-MAS02925	indicator lights-Brake system indicator lamp	OFF
    IDE02986-MAS03234	indicator lights-ESP_off indicator lamp	OFF
    IDE03008-IDE04446	Stop process prevented-Hill descent control	not active
    IDE03008-IDE05181	Stop process prevented-Emerg.brake	not active
    IDE03008-IDE06139	Stop process prevented-AUTO HOLD slippage recognition	not active
    IDE03008-MAS04485	Stop process prevented-ESP function deactivation	not active
    IDE03008-MAS04513	Stop process prevented-Brake control module pump operation	not active
    IDE03008-MAS04515	Stop process prevented-Roll-back detected	not active
    IDE03008-MAS07931	Stop process prevented-Retaining function unavailable	not active
    IDE03008-MAS07932	Stop process prevented-Inclination limit	not active
    IDE03009-IDE04446	Start process requested-Hill descent control	not active
    IDE03009-IDE06139	Start process requested-AUTO HOLD slippage recognition	not active
    IDE03009-MAS02515	Start process requested-System malfunction	not active
    IDE03009-MAS04485	Start process requested-ESP function deactivation	not active
    IDE03009-MAS04515	Start process requested-Roll-back detected	not active
    IDE03010-IDE04446	Number of prevented stop processes-Hill descent control	2
    IDE03010-IDE05181	Number of prevented stop processes-Emerg.brake	0
    IDE03010-IDE06139	Number of prevented stop processes-AUTO HOLD slippage recognition	0
    IDE03010-MAS04485	Number of prevented stop processes-ESP function deactivation	0
    IDE03010-MAS04513	Number of prevented stop processes-Brake control module pump operation	0
    IDE03010-MAS04515	Number of prevented stop processes-Roll-back detected	0
    IDE03010-MAS07931	Number of prevented stop processes-Retaining function unavailable	0
    IDE03010-MAS07932	Number of prevented stop processes-Inclination limit	7
    IDE03011-IDE04446	Number of requested start processes-Hill descent control	0
    IDE03011-IDE06139	Number of requested start processes-AUTO HOLD slippage recognition	0
    IDE03011-MAS02515	Number of requested start processes-System malfunction	0
    IDE03011-MAS04485	Number of requested start processes-ESP function deactivation	0
    IDE03011-MAS04515	Number of requested start processes-Roll-back detected	0
    IDE03127	Prevented stop processes (ring memory)	Initial value
    IDE03127	Prevented stop processes (ring memory)	2000
    IDE03127	Prevented stop processes (ring memory)	3
    IDE03127	Prevented stop processes (ring memory)	0
    IDE03127	Prevented stop processes (ring memory)	8
    IDE03127	Prevented stop processes (ring memory)	62
    IDE03128	Requested start processes (ring memory)	Initial value
    IDE03128	Requested start processes (ring memory)	2000
    IDE03128	Requested start processes (ring memory)	3
    IDE03128	Requested start processes (ring memory)	0
    IDE03128	Requested start processes (ring memory)	8
    IDE03128	Requested start processes (ring memory)	62
    IDE03207	Hardware version for suppliers	Freescale
    IDE03212	Start-stop conditions	System malfunction
    IDE03213	Start-stop enabling	At least one release missing
    IDE03527-IDE02070	CAN signals-Wake-up cause	1
    IDE03527-IDE02445	CAN signals-Transmission type	19
    IDE03651	Bleed brake system (rework bleeding)	0	 s
    IDE03680-IDE00018	Supply voltages-Voltage terminal 15	On
    IDE03680-IDE01232	Supply voltages-Supply voltage for external components	5.005	 V
    IDE03680-IDE04444	Supply voltages-Terminal 30 voltage for pump	0.014	 V
    IDE03680-IDE04445	Supply voltages-Terminal 30 voltage for valves	14.501	 V
    IDE03680-IDE04500	Supply voltages-Terminal 30 voltage for logic	On
    IDE04422-IDE04442	Brake system sensor-Vacuum sensor	-1	 mbar
    IDE04422-IDE04450	Brake system sensor-Brake pressure sensor 1	0.2	 bar
    IDE04422-IDE04494	Brake system sensor-Brake pressure sensor 1: uncond voltage 1	Not available due to specific system
    IDE04422-IDE04495	Brake system sensor-Brake pressure sensor 1: uncond voltage 2	Not available due to specific system
    IDE04422-MAS00179	Brake system sensor-Brake Light Switch	not activated
    IDE04422-MAS02152	Brake system sensor-EPB clutch pedal travel	Not available due to specific system
    IDE04425-IDE00920	Left front ABS wheel speed sensor-Front left wheel speed	0	 km/h
    IDE04425-IDE04435	Left front ABS wheel speed sensor-Air gap	65535	 mm
    IDE04425-IDE04436	Left front ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04425-IDE04437	Left front ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04425-IDE04438	Left front ABS wheel speed sensor-Average division value	Condition not met
    IDE04425-IDE04440	Left front ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04425-IDE04441	Left front ABS wheel speed sensor-Validity of gap information	invalid
    IDE04425-MAS01466	Left front ABS wheel speed sensor-Direction of rotation	Not available due to specific system
    IDE04426-IDE00921	Right front ABS wheel speed sensor-Front right wheel speed	0	 km/h
    IDE04426-IDE04435	Right front ABS wheel speed sensor-Air gap	65535	 mm
    IDE04426-IDE04436	Right front ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04426-IDE04437	Right front ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04426-IDE04438	Right front ABS wheel speed sensor-Average division value	Condition not met
    IDE04426-IDE04440	Right front ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04426-IDE04441	Right front ABS wheel speed sensor-Validity of gap information	invalid
    IDE04426-MAS01466	Right front ABS wheel speed sensor-Direction of rotation	Not available due to specific system
    IDE04427-IDE00922	Left rear ABS wheel speed sensor-Left rear wheel speed	0	 km/h
    IDE04427-IDE04435	Left rear ABS wheel speed sensor-Air gap	65535	 mm
    IDE04427-IDE04436	Left rear ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04427-IDE04437	Left rear ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04427-IDE04438	Left rear ABS wheel speed sensor-Average division value	Condition not met
    IDE04427-IDE04440	Left rear ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04427-IDE04441	Left rear ABS wheel speed sensor-Validity of gap information	invalid
    IDE04427-MAS01466	Left rear ABS wheel speed sensor-Direction of rotation	forwards
    IDE04428-IDE00923	Right rear ABS wheel speed sensor-Right rear wheel speed	0	 km/h
    IDE04428-IDE04435	Right rear ABS wheel speed sensor-Air gap	65535	 mm
    IDE04428-IDE04436	Right rear ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04428-IDE04437	Right rear ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04428-IDE04438	Right rear ABS wheel speed sensor-Average division value	Condition not met
    IDE04428-IDE04440	Right rear ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04428-IDE04441	Right rear ABS wheel speed sensor-Validity of gap information	invalid
    IDE04428-MAS01466	Right rear ABS wheel speed sensor-Direction of rotation	forwards
    IDE04442-IDE00009	Vacuum sensor-Date of manufacture	ÿÿÿÿÿÿÿÿÿÿ
    IDE04442-IDE00010	Vacuum sensor-Serial number	FF FF FF FF FF
    IDE04442-IDE00104	Vacuum sensor-DTC	0
    IDE04442-IDE02955	Vacuum sensor-System status	Not available due to specific system
    IDE04442-IDE03205	Vacuum sensor-Manufacturer code	65535
    IDE04442	Vacuum sensor	-1	 mbar
    IDE04442-MAS12759	Vacuum sensor-Type of individual vacuum sensor	65535
    IDE04443-IDE02241	Traction control system sensor-Lateral acceleration sensor 1	0.63765	 m/s²
    IDE04443-IDE02538	Traction control system sensor-Longitudinal acceleration sensor	-0.62784	 m/s²
    IDE04443-IDE04429	Traction control system sensor-Lateral acceleration sensor 1: offset	0.2943	 m/s²
    IDE04443-IDE04430	Traction control system sensor-Longitudinal acceleration sensor: offset	-0.5625	 m/s²
    IDE04443-IDE04449	Traction control system sensor-Rotation rate sensor 1: Z-axis	0.223	 °/s
    IDE04443-IDE04460	Traction control system sensor-Steering angle sensor: offset straight line running	-177.581	 °
    IDE04443-MAS00815	Traction control system sensor-Steering angle sensor	-177.581	 °
    IDE04446-IDE01599	Hill descent control-Slope	-3	 %
    IDE04446-IDE02955	Hill descent control-System status	Available
    IDE04446-IDE03664	Hill descent control-Button for driving program	not activated
    IDE04446-MAS03095	Hill descent control-Function status	not active
    IDE04452-IDE03662	Brake system button-ASR/ESP button	not activated
    IDE04452-IDE03663	Brake system button--AUTO HOLD- Button	Not available due to specific system
    IDE04452-IDE03664	Brake system button-Button for driving program	not activated
    IDE04452-IDE04432	Brake system button-Tire Pressure Monitoring Display Button	not activated
    IDE04452-IDE04769	Brake system button-Electro-mechanical parking brake button: status	Not available due to specific system
    IDE04456-IDE02955	Brake disk drying-System status	Available
    IDE04456-IDE04775	Brake disk drying-Odometer reading of last activation	0	 km
    IDE04456-MAS01282	Brake disk drying-Wiper	not active
    IDE04456-MAS03095	Brake disk drying-Function status	not active
    IDE04461-IDE03208	Internal measured values-Software version for suppliers	MZ2RAF00038
    IDE04461-IDE03649	Internal measured values-Fill/bleed brake system	not completed successfully
    IDE04461-IDE03659	Internal measured values-Roller test bench mode	not active
    IDE04461-MAS01481	Internal measured values-Temperature in control module	52	 °C
    IDE04461-MAS04484	Internal measured values-Flashloader version	 TSCBAB00008
    IDE04499-IDE02955	Sensor for roof rack recognition-System status	Not available due to specific system
    IDE04499-MAS03095	Sensor for roof rack recognition-Function status	not recognized
    IDE04508-IDE02955	Hydraulic brake booster-System status	Not available due to specific system
    IDE04508-IDE04442	Hydraulic brake booster-Vacuum sensor	ERROR
    IDE04508-IDE04450	Hydraulic brake booster-Brake pressure sensor 1	0.2	 bar
    IDE04508-MAS03095	Hydraulic brake booster-Function status	not active
    IDE04508-MAS04002	Hydraulic brake booster-Low intake manifold pressure	ERROR
    IDE04644-IDE02955	Roll-over protection-System status	Available
    IDE04644-IDE04775	Roll-over protection-Odometer reading of last activation	0	 km
    IDE04644-MAS03095	Roll-over protection-Function status	not active
    IDE04645-IDE00003	Electromechanical parking brake-Coding	performed
    IDE04645-IDE00902	Electromechanical parking brake-Automatic distance control: status	Enabled
    IDE04645-IDE02652	Electromechanical parking brake-Start-stop status	not enabled
    IDE04645-IDE02955	Electromechanical parking brake-System status	Not available due to specific system
    IDE04645-IDE03493	Electromechanical parking brake-Driver door status	Enabled
    IDE04645-IDE04871	Electromechanical parking brake-Dynamic starting assist	not enabled
    IDE04645-IDE04941	Electromechanical parking brake-Clearance calibration	ERROR
    IDE04645-IDE04942	Electromechanical parking brake-Main examination mode	not active
    IDE04645-IDE04944	Electromechanical parking brake-Brake pedal evaluation	Enabled
    IDE04645-IDE04948	Electromechanical parking brake-Fall-back level	0
    IDE04645-IDE05711	Electromechanical parking brake-Automatic application during engine stalling	Enabled
    IDE04645-IDE06590	Electromechanical parking brake-Play protection counter: button for electromech. parking brake	0
    IDE04645-MAS02666	Electromechanical parking brake-Seat belt buckle scan	Enabled
    IDE04645-MAS03998	Electromechanical parking brake-Delay interface for electro-mechanical parking brake	6
    IDE04646-IDE02657	Electromechanical parking brake: parking brake motors-Cut-off current: left: reached	ERROR
    IDE04646-IDE02658	Electromechanical parking brake: parking brake motors-Cut-off current: right: reached	ERROR
    IDE04646-IDE04496	Electromechanical parking brake: parking brake motors-Left parking brake motor: status	ERROR
    IDE04646-IDE04497	Electromechanical parking brake: parking brake motors-Right parking brake motor: status	ERROR
    IDE04646-IDE04506	Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature	7.5	 °C
    IDE04646-IDE04507	Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature	7.5	 °C
    IDE04646-IDE04647	Electromechanical parking brake: parking brake motors-Left parking brake motor: current	ERROR
    IDE04646-IDE04648	Electromechanical parking brake: parking brake motors-Right parking brake motor: current	ERROR
    IDE04646-IDE05048	Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter	0
    IDE04646-IDE05049	Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter	0
    IDE04765-IDE02955	Counter steer support-System status	Available
    IDE04765-IDE03735	Counter steer support-Steering torque	0	 Nm
    IDE04765-IDE04775	Counter steer support-Odometer reading of last activation	460	 km
    IDE04765-MAS03095	Counter steer support-Function status	not active
    IDE04772-IDE03530	Indicator light in the button for electromech. parking brake-Monitoring status	Not available due to specific system
    IDE04772-MAS03745	Indicator light in the button for electromech. parking brake-Function light	Not available due to specific system
    IDE04774-IDE02955	Vehicle and trailer stabilization-System status	Not available due to specific system
    IDE04774-IDE04775	Vehicle and trailer stabilization-Odometer reading of last activation	0	 km
    IDE04774-MAS03095	Vehicle and trailer stabilization-Function status	not active
    IDE04871-IDE01599	Dynamic starting assist-Slope	30	 %
    IDE04871-IDE02445	Dynamic starting assist-Transmission type	automatic
    IDE04871-MAS01447	Dynamic starting assist-Act.value	normal
    IDE04871-MAS03995	Dynamic starting assist-Clutch pedal threshold: initial value	60	 %
    IDE04871-MAS03996	Dynamic starting assist-Clutch pedal threshold: learned value	0	 %
    IDE04871-MAS04734	Dynamic starting assist-Required engine torques: current slope (TARGET)	0	 Nm
    IDE04871-MAS04735	Dynamic starting assist-Current engine torques (ACTUAL)	0	 Nm
    IDE04871-MAS04736	Dynamic starting assist-Expected achievable engine torques	0	 Nm
    IDE04939-IDE02955	Tire pressure monitoring display-System status	Available
    IDE04939-IDE04248	Tire pressure monitoring display-Left front tire pressure diffusion indicator	247
    IDE04939-IDE04249	Tire pressure monitoring display-Right front tire pressure diffusion indicator	254
    IDE04939-IDE04250	Tire pressure monitoring display-Left rear tire pressure diffusion indicator	247
    IDE04939-IDE04251	Tire pressure monitoring display-Right rear tire pressure diffusion indicator	247
    IDE04939-IDE04432	Tire pressure monitoring display-Tire Pressure Monitoring Display Button	not activated
    IDE04939-IDE04946	Tire pressure monitoring display-Odometer reading at last adaptation	453	 km
    IDE04939-IDE04947	Tire pressure monitoring display-Odometer reading of last warning	343	 km
    IDE04939-MAS04538	Tire pressure monitoring display-Odometer reading two adaptations ago	18	 km
    IDE04939-MAS04539	Tire pressure monitoring display-Odometer reading three adaptations ago	0	 km
    IDE04939-MAS04540	Tire pressure monitoring display-Odometer reading four adaptations ago	0	 km
    IDE04939-MAS04541	Tire pressure monitoring display-Odometer reading of next-to-last warning	0	 km
    IDE04939-MAS04542	Tire pressure monitoring display-Odometer reading of third-to-last warning	0	 km
    IDE04939-MAS04543	Tire pressure monitoring display-Odometer reading of fourth-to-last warning	0	 km
    IDE04939-MAS04544	Tire pressure monitoring display-Left front flat tire indicator	242
    IDE04939-MAS04545	Tire pressure monitoring display-Right front flat tire indicator	255
    IDE04939-MAS04546	Tire pressure monitoring display-Left rear flat tire indicator	242
    IDE04939-MAS04547	Tire pressure monitoring display-Right rear flat tire indicator	242
    IDE05712-IDE02955	AUTO HOLD-System status	Not available due to specific system
    IDE05712-IDE03530	AUTO HOLD-Monitoring status	7
    IDE05712-IDE04498	AUTO HOLD--AUTO HOLD- Indicator Lamp	OFF
    IDE05712-IDE04561	AUTO HOLD-Switch-on and shut-off conditions	valid
    IDE05712-IDE05333	AUTO HOLD-Indicator light in AUTO HOLD button	OFF
    IDE05712-MAS00025	AUTO HOLD-Driver seat belt switch	not connected
    IDE05712-MAS03095	AUTO HOLD-Function status	not active
    IDE05712-MAS04006	AUTO HOLD-Operating mode	Last setting
    IDE05712-MAS04409	AUTO HOLD-Active hold	not active
    IDE05712-MAS04411	AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake	No
    IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
    IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
    IDE06591-ENG118150	Pump load counter-Comp_Rotatation_of_pump_motor	1939
    IDE06591-ENG118152	Pump load counter-Load_on_feeding_side_of_Pump	48166
    IDE06591-ENG118151	Pump load counter-Load_on_suction_side_of_Pump	0
    IDE06591-ENG118153	Pump load counter-Pump_motor_start_counter	148
    IDE07280-IDE04775	Multikollisionsbremse-Odometer reading of last activation	0	 km
    IDE07280-IDE06609	Multikollisionsbremse-Odometer reading of last deactivation	0	 km
    IDE07280-MAS07659	Multikollisionsbremse-Häufigkeitszähler Multikollisionsbremse aktiv	0
    IDE07280-MAS07660	Multikollisionsbremse-Häufigkeitszähler Multikollisionsbremse deaktiviert	0
    IDE07280-MAS07661	Multikollisionsbremse-Häufigkeitszähler Funktion durch Fahrer deaktiviert	0
    IDE07280-MAS07662	Multikollisionsbremse-Kilometerstand der letzten Deaktivierung durch Fahrer	0	 km
    IDE07280-MAS08118	Multikollisionsbremse-Letzter Zeitpunkt der Deaktivierung durch Fahrer	2000
    IDE07280-MAS09171	Multikollisionsbremse-Last time of activation	2000
    IDE07280-MAS09172	Multikollisionsbremse-Last time of de-activation	2000
    IDE80101	Analysis 101	A3 32 38 35 31 35 38 37 36 30 36 33 30 30 30 30 36 31 36 37 30 34 30 30 32 43 36 2F 02 1C 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE80102-ENG122580	Analysis 102-value_1_percentaged	91.4004	 %
    IDE80102-ENG122579	Analysis 102-value_1_quantity	0
    IDE80102-ENG122582	Analysis 102-value_2_percentaged	97.2594	 %
    IDE80102-ENG122581	Analysis 102-value_2_quantity	0
    IDE80102-ENG122584	Analysis 102-value_3_percentaged	94.5252	 %
    IDE80102-ENG122583	Analysis 102-value_3_quantity	18
    IDE80102-ENG122586	Analysis 102-value_4_percentaged	93.744	 %
    IDE80102-ENG122585	Analysis 102-value_4_quantity	32
    IDE80102-ENG122588	Analysis 102-value_5_percentaged	97.2594	 %
    IDE80102-ENG122587	Analysis 102-value_5_quantity	8
    IDE80102-ENG122590	Analysis 102-value_6_percentaged	96.0876	 %
    IDE80102-ENG122589	Analysis 102-value_6_quantity	11
    IDE80103-MAS00976	Analysis 103-Counter	0
    MAS00121-IDE02955	Electronic Differential Lock-System status	Available
    MAS00121-IDE04504	Electronic Differential Lock-Calculated left front brake temperature	7.5	 °C
    MAS00121-IDE04505	Electronic Differential Lock-Calculated right front brake temperature	7.5	 °C
    MAS00121-IDE04506	Electronic Differential Lock-Calculated left rear brake temperature	7.5	 °C
    MAS00121-IDE04507	Electronic Differential Lock-Calculated right rear brake temperature	7.5	 °C
    MAS00121-MAS00179	Electronic Differential Lock-Brake Light Switch	not activated
    MAS00121-MAS01853	Electronic Differential Lock-Left front	Available
    MAS00121-MAS01854	Electronic Differential Lock-Right front	Available
    MAS00121-MAS01855	Electronic Differential Lock-Left rear	Available
    MAS00121-MAS01856	Electronic Differential Lock-Right rear	Available
    MAS00121-MAS03095	Electronic Differential Lock-Function status	not active
    MAS00210-IDE80007	Parking Brake-Analysis 7	0	 km
    MAS00210-IDE80008	Parking Brake-Analysis 8	0	 km
    MAS00210-IDE80009	Parking Brake-Analysis 9	0	 km
    MAS00210-IDE80010	Parking Brake-Analysis 10	0	 km
    MAS00210-IDE80011	Parking Brake-Analysis 11	0	 km
    MAS00210-IDE80012	Parking Brake-Analysis 12	8F 0A 11 10 02 0C
    MAS00210-ENG127696	Parking Brake-Counter_1	0
    MAS00210-ENG127697	Parking Brake-Counter_2	0
    MAS00210-ENG127700	Parking Brake-Counter_3	0
    MAS00210-ENG127699	Parking Brake-Counter_4	0
    MAS00210-ENG127698	Parking Brake-Counter_5	0
    MAS00210-ENG127701	Parking Brake-Counter_6	0
    MAS00911-IDE02955	All Wheel Drive (AWD)-System status	Available
    MAS00911-IDE04502	All Wheel Drive (AWD)-Haldex clutch status	No malfunction detected
    MAS00911-IDE04943	All Wheel Drive (AWD)-Haldex clutch	Fully open
    MAS00911-MAS01464	All Wheel Drive (AWD)-Emergency running mode	not active
    MAS00911-MAS04730	All Wheel Drive (AWD)-Degree of blockage	0	 %
    MAS02138-IDE02955	Hill-start assistant-System status	Available
    MAS02138-MAS00025	Hill-start assistant-Driver seat belt switch	not connected
    MAS02138-MAS00218	Hill-start assistant-Driver door	closed
    MAS02138-MAS00988	Hill-start assistant-Reverse gear	not selected
    MAS02138-MAS03095	Hill-start assistant-Function status	not active
    MAS02426-MAS00580	Text display in instrument panel insert-Electromechanical parking brake text 1	0
    MAS02426-MAS03359	Text display in instrument panel insert-Text	0
    MAS02672-IDE02955	Start-stop-System status	Not available due to specific system
    MAS02672-IDE03214	Start-stop-Engine stop using start-stop function	not active
    MAS02672-IDE03215	Start-stop-Engine start using start-stop function	not active
    MAS02672-MAS00025	Start-stop-Driver seat belt switch	not connected
    Elapsed Time: 00:16
    adpmap-03-5Q0-614-517-BK.CSV
    ;Wednesday	11	January	2017	19:58:57:08929
    IDE00001-Production mode	not active
    IDE00252-Brake system vacuum pump	5
    IDE00820-Activating and deactivating all development messages	0
    IDE01763-Dimming	activated
    IDE02332-Deactivate production mode	Deactivating
    IDE03493-Driver door status	activated
    IDE03659-Roller test bench mode	Manual activation: possible
    IDE04456-Brake disk drying	Medium
    IDE04508-Hydraulic brake booster	8
    IDE04643-Overboost in brake system	activated
    IDE04645-Electromechanical parking brake	not activated
    IDE04774-Vehicle and trailer stabilization	not activated
    IDE04871-Dynamic starting assist	normal
    IDE04939-Tire pressure monitoring display	2
    IDE04944-Brake pedal evaluation	activated
    IDE04949-Engine drag torque control	activated
    IDE04951-Brake booster	4
    IDE04952-Braking torque boost for distance regulation	3
    IDE05055-Hydraulic brake assistant	normal
    IDE05057-Brake prefill	activated
    IDE05161-Straight ahead brake stabilization	activated
    IDE05263-AUTO HOLD functionality	not activated
    IDE05264-AUTO HOLD increase threshold: reduced tensioning force	0%
    IDE05265-AUTO HOLD increase threshold: full tensioning force	10%
    IDE05286-Expanded electronic differential lock	Standard
    IDE05337-IDE05337-Starting vibration reduction-	Strong
    IDE05337-MAS02653-Starting vibration reduction-Torque limitation	Deactivated
    IDE05711-Automatic application during engine stalling	activated
    IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake	7
    IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button	7
    IDE06139-AUTO HOLD slippage recognition	activated
    IDE06505-Electromechanical parking brake: delay level	6
    IDE07006-Tire pressure monitoring display: tire selection	1
    IDE07292-Bremsenvorbefüllung	not completed successfully
    IDE07565-ABS in lower speed range	activated
    IDE07848-Thresholds for brake performance	activated
    MAS00122-Electronic Stability Program	not activated
    MAS00970-Running manufacturer number	activated
    MAS01180-AUTO HOLD functional status	Last setting
    MAS01299-Offroad	0
    MAS02080-XCP calibration protocol	not activated
    MAS02138-Hill-start assistant	normal
    MAS02666-Seat belt buckle scan	activated
    MAS09008-MAS00988-Plausibility check-Reverse gear	activated
    MAS09008-MAS09009-Plausibility check-Neutral gear sensor	activated
    MAS09008-MAS10668-Plausibility check-Clutch movement	activated
    MAS11606-Electromechanical parking brake: emergency braking	activated
    ENG118148-Developer_Function_1	0
    ENG130301-Developer_Function_121	not activated
    ENG122844-ENG101574-dimming_characteristic_1-X1	0
    ENG122844-ENG99557-dimming_characteristic_1-X2	10
    ENG122844-ENG102140-dimming_characteristic_1-X3	50
    ENG122844-ENG102936-dimming_characteristic_1-X4	100
    ENG122844-ENG103548-dimming_characteristic_1-X5	220
    ENG122844-ENG113992-dimming_characteristic_1-X6	253
    ENG122844-ENG99777-dimming_characteristic_1-Y1	6
    ENG122844-ENG100480-dimming_characteristic_1-Y2	6
    ENG122844-ENG100773-dimming_characteristic_1-Y3	8
    ENG122844-ENG100631-dimming_characteristic_1-Y4	12
    ENG122844-ENG102174-dimming_characteristic_1-Y5	80
    ENG122844-ENG113993-dimming_characteristic_1-Y6	100
    ENG122845-ENG101574-dimming_characteristic_2-X1	0
    ENG122845-ENG99557-dimming_characteristic_2-X2	10
    ENG122845-ENG102140-dimming_characteristic_2-X3	50
    ENG122845-ENG102936-dimming_characteristic_2-X4	100
    ENG122845-ENG103548-dimming_characteristic_2-X5	220
    ENG122845-ENG113992-dimming_characteristic_2-X6	253
    ENG122845-ENG99777-dimming_characteristic_2-Y1	6
    ENG122845-ENG100480-dimming_characteristic_2-Y2	6
    ENG122845-ENG100773-dimming_characteristic_2-Y3	8
    ENG122845-ENG100631-dimming_characteristic_2-Y4	12
    ENG122845-ENG102174-dimming_characteristic_2-Y5	80
    ENG122845-ENG113993-dimming_characteristic_2-Y6	100
    Elapsed Time: 00:16
    United States
    05-Acc/Start Auth.
    blockmap-05-5Q0-959-435-B.CSV
    ;SW:5Q0-959-435-B   HW:5Q0-959-435 ---  Acc/Start Auth.
    ;Component:VWKESSYMQB    021 0710	 Coding:032C0C
    ;EV_KessyHellaMQBAB	2019	EV_KessyHellaMQBAB_002.rod
    ;Wednesday	11	January	2017	19:59:38:08929
    ;VCID: BB3934493247C19940-80EE
    IDE00019	Voltage terminal 30	14.5	 V
    IDE00020	Terminal 15 status	Terminal 15 on
    IDE00075	Vehicle speed	0	 km/h
    IDE01715	Status terminal S	On
    IDE02406	Key number of last identified ID sensor	ID sensor 1
    IDE02407	Status of vehicle locking	Vehicle unlocked
    IDE02408-MAS00218	Individual door locking: status-Driver door	closed
    IDE02408-MAS00219	Individual door locking: status-Front Passenger Door	closed
    IDE02408-MAS00220	Individual door locking: status-Left rear door	closed
    IDE02408-MAS00221	Individual door locking: status-Right rear door	closed
    IDE02409	ID sensor 1 authentication: status	No response
    IDE02410	ID sensor 2 authentication: status	No response
    IDE02411	ID sensor 3 authentication: status	No response
    IDE02412	ID sensor 4 authentication: status	No response
    IDE02413	Door handle touch sensor: last operation	Driver door
    IDE02414-MAS00080	Driver exterior door handle touch sensor-Coding information	coded
    IDE02414-MAS02176	Driver exterior door handle touch sensor-Approach to the inside	not active
    IDE02414-MAS02177	Driver exterior door handle touch sensor-Actuation to the inside	not active
    IDE02414-MAS02178	Driver exterior door handle touch sensor-Approach to the outside	not active
    IDE02414-MAS02179	Driver exterior door handle touch sensor-Actuation to the outside	not active
    IDE02414-MAS02451	Driver exterior door handle touch sensor-Pulling actuation: outside door handle	not active
    IDE02415-MAS00080	Front passenger exterior door handle touch sensor-Coding information	coded
    IDE02415-MAS02176	Front passenger exterior door handle touch sensor-Approach to the inside	not active
    IDE02415-MAS02177	Front passenger exterior door handle touch sensor-Actuation to the inside	not active
    IDE02415-MAS02178	Front passenger exterior door handle touch sensor-Approach to the outside	not active
    IDE02415-MAS02179	Front passenger exterior door handle touch sensor-Actuation to the outside	not active
    IDE02415-MAS02451	Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle	not active
    IDE02416-MAS00080	Left rear exterior door handle touch sensor-Coding information	Not coded
    IDE02416-MAS02176	Left rear exterior door handle touch sensor-Approach to the inside	not active
    IDE02416-MAS02177	Left rear exterior door handle touch sensor-Actuation to the inside	not active
    IDE02416-MAS02178	Left rear exterior door handle touch sensor-Approach to the outside	not active
    IDE02416-MAS02179	Left rear exterior door handle touch sensor-Actuation to the outside	not active
    IDE02416-MAS02451	Left rear exterior door handle touch sensor-Pulling actuation: outside door handle	not active
    IDE02417-MAS00080	Right rear exterior door handle touch sensor-Coding information	Not coded
    IDE02417-MAS02176	Right rear exterior door handle touch sensor-Approach to the inside	not active
    IDE02417-MAS02177	Right rear exterior door handle touch sensor-Actuation to the inside	not active
    IDE02417-MAS02178	Right rear exterior door handle touch sensor-Approach to the outside	not active
    IDE02417-MAS02179	Right rear exterior door handle touch sensor-Actuation to the outside	not active
    IDE02417-MAS02451	Right rear exterior door handle touch sensor-Pulling actuation: outside door handle	not active
    IDE02418	Proximity sensor driver door: number of triggers	160
    IDE02419	Proximity sensor frt.pass. door: number of triggers	106
    IDE02420	Proximity sensor left rear door: number of triggers	0
    IDE02421	Proximity sensor right rear door: number of triggers	0
    IDE02422-MAS04065	Driver door handle: version information-EEPROM	31
    IDE02423-MAS04065	ass. door handle: version information-EEPROM	31
    IDE02424-MAS04065	Left rear door handle: version information-EEPROM	0
    IDE02425-MAS04065	Right rear door handle: version information-EEPROM	0
    IDE02466	Play protection activation counter driver door	0
    IDE02467	Play protection activation counter frt.pass. door	0
    IDE02468	Play protection activation counter left rear door	0
    IDE02469	Play protection activation counter right rear door	0
    IDE02482	72-hour signaling counter driver door	0
    IDE02483	72-hour signaling counter frt.pass. door	0
    IDE02484	72-hr signaling counter left rear door	0
    IDE02485	72-hr signaling counter right rear door	0
    IDE02486	Data logger triggering	not activated
    IDE02495	Service key: number of activations	35
    IDE02496	Service key: number of timeouts	2
    IDE02497	Service key: number of incomplete messages	1
    IDE03008-MAS05971	Stop process prevented-Missing message from Engine Control Module	0
    IDE03008-MAS06116	Stop process prevented-Antenna malfunction of a go-relevant antenna	0
    IDE03008-MAS06118	Stop process prevented-ID sensor not found	0
    IDE03008-MAS06119	Stop process prevented-CAN signal: operation reader coil is set	0
    IDE03010-MAS05971	Number of prevented stop processes-Missing message from Engine Control Module	1
    IDE03010-MAS06116	Number of prevented stop processes-Antenna malfunction of a go-relevant antenna	4
    IDE03010-MAS06118	Number of prevented stop processes-ID sensor not found	2
    IDE03010-MAS06119	Number of prevented stop processes-CAN signal: operation reader coil is set	0
    IDE03127	Prevented stop processes (ring memory)	1
    IDE03127	Prevented stop processes (ring memory)	4
    IDE03127	Prevented stop processes (ring memory)	22
    IDE03212	Start-stop conditions	Stop release
    IDE03213	Start-stop enabling	System malfunction
    IDE04042-ENG123041	ID sensor history data-Scan 1: Scan_origin_en	UID Monitoring
    IDE04042-ENG123040	ID sensor history data-Scan 1: Scan_trigger_en	UID search
    IDE04042-ENG123042	ID sensor history data-Scan 1: Single_scan_en	Interior with trunk
    IDE04042-ENG123043	ID sensor history data-Scan 1: Trigger_Information_u8	A2
    IDE04042-ENG123045	ID sensor history data-Scan 2: Scan_origin_en	Passive Go
    IDE04042-ENG123044	ID sensor history data-Scan 2: Scan_trigger_en	Go authentication request
    IDE04042-ENG123046	ID sensor history data-Scan 2: Single_scan_en	Interior with trunk
    IDE04042-ENG123047	ID sensor history data-Scan 2: Trigger_Information_u8	62
    IDE04042-ENG123049	ID sensor history data-Scan 3: Scan_origin_en	Passive Go
    IDE04042-ENG123048	ID sensor history data-Scan 3: Scan_trigger_en	Go ID request
    IDE04042-ENG123050	ID sensor history data-Scan 3: Single_scan_en	Interior with trunk
    IDE04042-ENG123051	ID sensor history data-Scan 3: Trigger_Information_u8	52
    IDE05204	Manufacturing dates for driver door handle	21 60 88 32 61
    IDE05205	Manufacturing dates for frt.pass. door handle	21 60 87 15 85
    IDE05206	Manufacturing dates for left rear door handle	00 00 00 00 00
    IDE05207	Manufacturing dates for right rear door handle	00 00 00 00 00
    IDE07359	Dimming of starter button lighting	1
    ENG120048	Overtemperaturecounter for ADRIMA	0
    Elapsed Time: 00:05
    adpmap-05-5Q0-959-435-B.CSV
    ;Wednesday	11	January	2017	19:59:44:08929
    ;VCDS Version: Release 17.1.1 (x64)  Data version: 20170106 DS267.0
    ENG105462-CAN-timeout service-key message	260 ms
    ENG105634-Correction value LED dimming	1
    ENG114301-Cycletime for voltage monitoring during sleepmode	100 ms
    ENG120046-Cyclic interior scan during clamp 15 on	10 s
    ENG101877-Deactivating_Of_Start_Stop_Function	not activated
    ENG105791-Delta value LED dimming curve first point 40 percent dimming	30.00%
    ENG105792-Delta value LED dimming curve forth point 100 percent dimming	5.00%
    ENG105793-Delta value LED dimming curve second point 60 percent dimming	15.00%
    ENG105794-Delta value LED dimming curve third point 80 percent dimming	10.00%
    ENG105803-ENG120037-DeveloperCoding: Key Minder (Byte 1)-Cyclic interior scan during active warning message "Key not found"	not active
    ENG105803-ENG101923-DeveloperCoding: Key Minder (Byte 1)-Retry handling big car / expanded search	activated
    ENG105803-ENG100928-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening	not active
    ENG105803-ENG99649-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening no KESSY unlocking	activated
    ENG105803-ENG99417-DeveloperCoding: Key Minder (Byte 1)-Softtouch mounted	installed
    ENG105804-ENG99123-DeveloperCoding: Key Minder (Byte 2)-Inhibit ID-transmitter for passive go	activated
    ENG105804-ENG102581-DeveloperCoding: Key Minder (Byte 2)-Lock prevention tailgate	not active
    ENG105804-ENG101018-DeveloperCoding: Key Minder (Byte 2)-No locking with ID-transmitter last used interior	activated
    ENG105804-ENG103451-DeveloperCoding: Key Minder (Byte 2)-Re-open after passive comfort closing	activated
    ENG105804-ENG99711-DeveloperCoding: Key Minder (Byte 2)-Re-open last handling	ZV entriegeln
    ENG105804-ENG103237-DeveloperCoding: Key Minder (Byte 2)-Re-open tailgate	activated
    ENG105804-ENG104103-DeveloperCoding: Key Minder (Byte 2)-Send numbers of ID-transmitters interior (ELV-Scan)	activated
    ENG105807-ENG121989-DeveloperCoding: Passiv Entry Exit (Byte 1)-Impairment Entry / Exit key on low battery	not active
    ENG105807-ENG125240-DeveloperCoding: Passiv Entry Exit (Byte 1)-lf_crc	not active
    ENG105807-ENG99763-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: access door not open	activated
    ENG105807-ENG103722-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: all doors not open	not active
    ENG105808-ENG17833-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry at door locked/safed OR ZV safed	activated
    ENG105808-ENG123039-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit	activated
    ENG105808-ENG103289-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: control by pulling door handle during active DSL	activated
    ENG105808-ENG103620-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: retry with antennastep 1	activated
    ENG105808-ENG103529-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry: second control concept	not active
    ENG105809-ENG114300-DeveloperCoding: Passiv Go-Change Go antenna at every request	not active
    ENG105809-ENG114299-DeveloperCoding: Passiv Go-Change Go antenna during retry challenge	activated
    ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open	not active
    ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open	not active
    ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery	not active
    ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go	activated
    ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start	activated
    ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted	not active
    ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation	activated
    ENG123038-ENG17824-DeveloperCoding: Proximity Sensor-Easy Trunk	not active
    ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive	Fahrertürgriff wird nicht abgeschaltet
    ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection	activated
    ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv"	Fehlerspeichereintrag wird nicht unterdrueckt
    ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT	activated
    ENG123036-ENG17823-DeveloperCoding: Search lights-ZAT active during clamp 58xt on	activated
    ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load	not active
    ENG105810-ENG120039-DeveloperCoding: Sonstiges-Backdoor TSG	not installed
    ENG105810-ENG103075-DeveloperCoding: Sonstiges-Battery manager mounted	activated
    ENG105810-ENG102728-DeveloperCoding: Sonstiges-Diagnostic: service 86 - response on event	not active
    ENG105810-ENG98656-DeveloperCoding: Sonstiges-internal	not active
    ENG105810-ENG102591-DeveloperCoding: Sonstiges-Response extension for scan procedure	not active
    ENG105810-ENG99430-DeveloperCoding: Sonstiges-Scan Procedure: Timeoutcontrol active	activated
    ENG105810-ENG104010-DeveloperCoding: Sonstiges-Use default antenna data	not active
    ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible	not active
    ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk	installed
    ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel	left-hand drive
    ENG105825-Diagnostic: wait time after power on	3000 ms
    ENG105898-Doorknob contact sensor disconnecting time	5400 min
    ENG107050-Interior scan: deceleration after comfort closing	3200 ms
    ENG107051-Interior scan: max. engine speed for standing engine	10 km/h
    ENG107052-Interior scan: opening threshold sliding roof	1%
    ENG107053-Interior scan: opening threshold window lifter	5.00%
    ENG107054-Interior scan: Speed - threshold	20 km/h
    ENG98656-internal	0 B
    ENG107211-Key Minder: delay reunlocking tailgate	500 ms
    ENG107212-Key Minder: p_keyless_eventsearch_holding_time	10 s
    ENG107213-Key Minder: p_keyless_eventsearch_retries	2
    ENG107363-LED dimming curve first point 20 percent dimming	40.00%
    ENG107592-MCTX Pause	1 B
    ENG107593-MCTX pause for Go / Key Minder	20 ms
    ENG107594-MCTX pause for Go authentification	14 B
    ENG107595-MCTX settling phase	7 B
    ENG108165-Passive Entry Exit: control by pulling the door handle during active DSL (timeout)	2.00 s
    ENG108166-Passive Entry Exit: entry request e-sliding door active time	500 ms
    ENG108167-Passive Entry Exit: minimum activity time locking sensor	140 ms
    ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY	210 ms
    ENG108169-Passive Entry Exit: T_ACT_OP_2	5000 ms
    ENG108297-Proximity Sensor: Comfort Exit-Enlargement	200 ms
    ENG108298-Proximity Sensor: duration of proximity Signal	10 s
    ENG108299-Proximity Sensor: lower limit Impuls	2000 µs
    ENG108300-Proximity Sensor: lower limit proximity-Impuls	12200 µs
    ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle	10.0 km/h
    ENG108302-Proximity Sensor: max. Impulslength	75 ms
    ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls	20400 µs
    ENG108304-Proximity Sensor: max. intermission-length Diagnostic	14 ms
    ENG108305-Proximity Sensor: max. length of Diagnosticimpuls	71 ms
    ENG108306-Proximity Sensor: max. length of Entryimpuls	10400 µs
    ENG108307-Proximity Sensor: max. length of Exitimpuls	40400 µs
    ENG108308-Proximity sensor: max. length of signal hall sensor	100 s
    ENG108309-Proximity Sensor: max. signal-length	120 s
    ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle	20.0 km/h
    ENG108312-Proximity Sensor: min. enginespeed for a running engine	300 /min
    ENG108313-Proximity Sensor: min. length of Diagnosticimpuls	42 ms
    ENG108314-Proximity Sensor: min. length of Entryimpuls	6200 µs
    ENG108315-Proximity Sensor: min. length of Exitimpuls	24200 µs
    ENG108317-Proximity Sensor: SP_X2	10 min
    ENG108318-Proximity Sensor: SP_X3	1
    ENG108319-Proximity Sensor: SP_X4	80
    ENG108320-Proximity Sensor: SP_X5	1
    ENG108321-Proximity Sensor: SP_X6	30 min
    ENG108322-Proximity Sensor: SP_X7	1
    ENG108323-Proximity Sensor: Time Power On	1960 ms
    ENG123035-Proximity Sensor: Timervalue for ExitReverseOption	0 ms
    ENG108325-Proximity sensor: turn-off limit from battery-manager	2
    ENG108326-Proximity Sensor: upper limit intermission-length	10 ms
    ENG120045-Reduced current for transponder-ID request	0 Step
    ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol	5 Step
    ENG108576-Scan Procedure: cycle convenience coverage limiting	65 ms
    ENG108577-Scan Procedure: Number of Repeats	1
    ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause	100 ms
    ENG108579-Scan Procedure: Timeout Authentification Result	150 ms
    ENG108580-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Go)	190 ms
    ENG108581-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Kombi)	700 ms
    ENG108582-Scan Procedure: Timeout LF Repetition	100 ms
    ENG108585-ScanProcedure: Timeout Entry Response	260 ms
    ENG108586-ScanProcedure: Timeout Response	100 ms
    ENG109053-Standard dimming value ZAT	80%
    ENG100492-Stop_enabling_for_Start_/_Stop_function	According to function requirements
    ENG102207-Time Sensor Power Off Group 2	3600 min
    ENG109974-Voltage monitoring: overvoltage Delta	500 mV
    ENG109975-Voltage monitoring: overvoltage for KESSY ECU	16000 mV
    ENG109976-Voltage monitoring: overvoltage for Keyless Go	27000 mV
    ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta	0 mV
    ENG109978-Voltage monitoring: undervoltage Delta	500 mV
    ENG109979-Voltage monitoring: undervoltage for KESSY ECU	9000 mV
    ENG109980-Voltage monitoring: undervoltage for Keyless Go	6000 mV
    ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta	0 mV
    ENG120047-ZAT init value	0%
    ENG110364-ZAT nominal voltage	13.0 V
    ENG110365-ZAT post-carridge during clamp 15 off	10 min
    United States
    08-Auto HVAC
    blockmap-08-5GM-907-044-C.CSV
    Group	Description	Actual
    IDE00019	Voltage terminal 30	13.9	 V
    IDE00021	Engine speed	700	 /min
    IDE00025	Coolant temperature	99	 °C
    IDE00030	Status of actuator test	not active
    IDE00198	Refrigerant pressure	4.6	 bar
    IDE00322	Status of basic setting	was not yet started
    IDE00767	No. of unscheduled ECU resets	2
    IDE00965	Compressor shut-off requirement	A/C off or fan control switch in 0 position
    IDE00966	Compressor current: actual value	0	 A
    IDE00967	Compressor current: specified value	0	 A
    IDE00968	Compressor speed	800	 /min
    IDE00969	Compressor load	0.5	 Nm
    IDE00970	Coolant fan activation: actual value	10	 %
    IDE00971	Coolant fan activation: specified value	0	 %
    IDE00973	Outside air temperature	8.5	 °C
    IDE00974	Outside air temperature internally calculated	8	 °C
    IDE00976	Left front vent temperature	27.7	 °C
    IDE00977	Right front vent temperature	26.3	 °C
    IDE00981	Footwell vent temperature	30.7	 °C
    IDE00982	Temperature after evaporator	32.3	 °C
    IDE00983	Interior temperature	21.1	 °C
    IDE00984	Sun intensity left	0	 W/m²
    IDE00985	Sun intensity right	0	 W/m²
    IDE00987	Blower voltage: specified value	0	 V
    IDE00989	Blower status	not active
    IDE00994	Actual value for fresh air/recirculation air flow flap	94
    IDE00994	Actual value for fresh air/recirculation air flow flap	32.5	 %
    IDE00995	Specified value for fresh air/recirc air flow flap	93
    IDE00996	Fresh air stop for fresh air/recirculation air flow flap	213
    IDE00997	Recirculated air stop for fresh air/recirc air flow flap	36
    IDE00998	Left temperature flap - actual value	141
    IDE00998	Left temperature flap - actual value	55.5	 %
    IDE00999	Left temperature flap - specified value	72
    IDE01040	Left temperature flap: cold stop	28
    IDE01041	Left temperature flap: warm stop	231
    IDE01042	Right temperature flap: actual value	165
    IDE01042	Right temperature flap: actual value	67.5	 %
    IDE01043	Right temperature flap: specified value	75
    IDE01044	Right temperature flap: cold stop	26
    IDE01045	Right temperature flap: warm stop	231
    IDE01050	Front air distribution flap: actual value	236
    IDE01050	Front air distribution flap: actual value	100	 %
    IDE01051	Front air distribution flap: specified value	240
    IDE01052	Front air distribution flap: air outlet stop	235
    IDE01053	Front air distribution flap: footwell air outlet stop	22
    IDE01054	Defroster flap: actual value	17
    IDE01054	Defroster flap: actual value	0	 %
    IDE01055	Defroster flap: specified value	16
    IDE01056	Defroster flap: stop open	225
    IDE01057	Defroster flap: stop closed	21
    IDE01063	Status of recirculation air	Fresh air
    IDE01066	Convertible top status	closed
    IDE01076	Time since ignition off	38	 min
    IDE01217-MAS01447	Left heated seat stage-Act.value	0
    IDE01217-MAS01448	Left heated seat stage-Specified value	0
    IDE01218-MAS01447	Right heated seat stage-Act.value	0
    IDE01218-MAS01448	Right heated seat stage-Specified value	0
    IDE01226	Blower voltage: actual value	0	 V
    IDE01227	Blower current	0	 A
    IDE01232	Supply voltage for external components	25.5	 V
    IDE01264	Remaining time of parking heater/ventilation operation	0	 min
    IDE01287-MAS01260	Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN	19
    IDE01287-MAS01265	Counter of compressor switch-offs-Speed shut-off	6
    IDE01419	Compressor shut-off condition: last	Low pressure event
    IDE01420	Compressor shut-off requirement: penultimate	Low pressure event
    IDE01421	Compressor shut-off requirement: antepenultimate	Shut-off from Engine Control Module (ECM) via CAN
    IDE01433	Air quality status	Clean air
    IDE01442-MAS01533	Pressing a button-Defrost	not activated
    IDE01442-MAS01534	Pressing a button-Recirculating air	not activated
    IDE01442-MAS01535	Pressing a button-Rear window defogger	not activated
    IDE01442-MAS01550	Pressing a button-AC	not activated
    IDE01442-MAS01554	Pressing a button-Left heated seat	not activated
    IDE01442-MAS01556	Pressing a button-Right heated seat	not activated
    IDE01442-MAS01560	Pressing a button-OFF	not activated
    IDE01442-MAS01577	Pressing a button-Parking heater	not activated
    IDE01442-MAS02015	Pressing a button-AUTO	not activated
    IDE01442-MAS02192	Pressing a button-SYNC	not activated
    IDE01442-MAS03196	Pressing a button-Menu	not activated
    IDE01442-MAS03830	Pressing a button-Footwell air distribution	not activated
    IDE01442-MAS03831	Pressing a button-Upper body vent air distribution	not activated
    IDE01442-MAS03832	Pressing a button-Air distribution up	not activated
    IDE01442-MAS04605	Pressing a button-AC MAX	not activated
    IDE01443	Left push-and-rotary knob counter	0
    IDE01444	Right push-and-rotary knob counter	0
    IDE02270-IDE00002	CAN input signal(s) status-Transport mode	OFF
    IDE02270-IDE01211	CAN input signal(s) status-Static current measuring mode	OFF
    IDE02270-IDE01268	CAN input signal(s) status-Windshield wiper	OFF
    IDE02270-IDE01457	CAN input signal(s) status-Energy management deactivation stage	Deactivation stage 0
    IDE02270-MAS01269	CAN input signal(s) status-Wipe wash	OFF
    IDE02270-MAS01277	CAN input signal(s) status-Rear window heater actual value	OFF
    IDE02270-MAS01283	CAN input signal(s) status-Actual value of windshield heater	OFF
    IDE02271-IDE00972	CAN output signal(s) status-Idle speed increase	not active
    IDE02271-MAS00130	CAN output signal(s) status-Compressor on	OFF
    IDE03008-MAS01517	Stop process prevented-Defrost active	not active
    IDE03008-MAS01564	Stop process prevented-Windshield defogger	not active
    IDE03008-MAS02802	Stop process prevented-Interior temperature difference to setting	not active
    IDE03008-MAS02803	Stop process prevented-Interior vent difference to setting	not active
    IDE03008-MAS02804	Stop process prevented-Manual fan speed increase	not active
    IDE03008-MAS04353	Stop process prevented-Fogging hazard (humidity sensor)	not active
    IDE03008-MAS04354	Stop process prevented-Interior comfort humidity too high (humidity sensor)	not active
    IDE03008-MAS05009	Stop process prevented-A/C request: auxil. heat mode	not active
    IDE03008-MAS05047	Stop process prevented-Maximum cooling and heating set	not active
    IDE03008-MAS06551	Stop process prevented-Seat ventilation	not active
    IDE03008-MAS09538	Stop process prevented-max A/C	not active
    IDE03009-MAS01517	Start process requested-Defrost active	not active
    IDE03009-MAS01564	Start process requested-Windshield defogger	not active
    IDE03009-MAS02802	Start process requested-Interior temperature difference to setting	not active
    IDE03009-MAS02803	Start process requested-Interior vent difference to setting	not active
    IDE03009-MAS02804	Start process requested-Manual fan speed increase	not active
    IDE03009-MAS04353	Start process requested-Fogging hazard (humidity sensor)	not active
    IDE03009-MAS04354	Start process requested-Interior comfort humidity too high (humidity sensor)	not active
    IDE03009-MAS05009	Start process requested-A/C request: auxil. heat mode	not active
    IDE03009-MAS05047	Start process requested-Maximum cooling and heating set	not active
    IDE03009-MAS06551	Start process requested-Seat ventilation	not active
    IDE03009-MAS09538	Start process requested-max A/C	not active
    IDE03010-MAS01517	Number of prevented stop processes-Defrost active	0
    IDE03010-MAS01564	Number of prevented stop processes-Windshield defogger	0
    IDE03010-MAS02802	Number of prevented stop processes-Interior temperature difference to setting	0
    IDE03010-MAS02803	Number of prevented stop processes-Interior vent difference to setting	0
    IDE03010-MAS02804	Number of prevented stop processes-Manual fan speed increase	0
    IDE03010-MAS04353	Number of prevented stop processes-Fogging hazard (humidity sensor)	0
    IDE03010-MAS04354	Number of prevented stop processes-Interior comfort humidity too high (humidity sensor)	0
    IDE03010-MAS05009	Number of prevented stop processes-A/C request: auxil. heat mode	0
    IDE03010-MAS05047	Number of prevented stop processes-Maximum cooling and heating set	0
    IDE03010-MAS06551	Number of prevented stop processes-Seat ventilation	0
    IDE03010-MAS09538	Number of prevented stop processes-max A/C	0
    IDE03011-MAS01517	Number of requested start processes-Defrost active	0
    IDE03011-MAS01564	Number of requested start processes-Windshield defogger	0
    IDE03011-MAS02802	Number of requested start processes-Interior temperature difference to setting	0
    IDE03011-MAS02803	Number of requested start processes-Interior vent difference to setting	0
    IDE03011-MAS02804	Number of requested start processes-Manual fan speed increase	0
    IDE03011-MAS04353	Number of requested start processes-Fogging hazard (humidity sensor)	0
    IDE03011-MAS04354	Number of requested start processes-Interior comfort humidity too high (humidity sensor)	0
    IDE03011-MAS05009	Number of requested start processes-A/C request: auxil. heat mode	0
    IDE03011-MAS05047	Number of requested start processes-Maximum cooling and heating set	0
    IDE03011-MAS06551	Number of requested start processes-Seat ventilation	0
    IDE03011-MAS09538	Number of requested start processes-max A/C	0
    IDE03127	Prevented stop processes (ring memory)	Measured value not available
    IDE03127	Prevented stop processes (ring memory)	2063
    IDE03127	Prevented stop processes (ring memory)	31
    IDE03127	Prevented stop processes (ring memory)	15
    IDE03127	Prevented stop processes (ring memory)	63
    IDE03128	Requested start processes (ring memory)	Measured value not available
    IDE03128	Requested start processes (ring memory)	2063
    IDE03128	Requested start processes (ring memory)	31
    IDE03128	Requested start processes (ring memory)	15
    IDE03128	Requested start processes (ring memory)	63
    IDE03214	Engine stop using start-stop function	not active
    IDE03215	Engine start using start-stop function	not active
    IDE03488	Driving time remaining for basic setting of compressor run in	0	 s
    IDE04312-IDE04095	System run time-Engine running time	255	 s
    IDE04312-MAS00084	System run time-Terminal 15 on	255	 s
    IDE04797	Center push-and-rotary knob counter	0
    IDE04805-IDE02955	Driving profile selection-System status	Not available
    IDE04805-IDE06419	Driving profile selection-Driving profile switchover	no request
    IDE04805-MAS01447	Driving profile selection-Act.value	0
    IDE04805-MAS01448	Driving profile selection-Specified value	0
    IDE04805-MAS05058	Driving profile selection-Compatibility	Yes
    IDE05725	Terminal 58xs dimmer	0	 %
    IDE05726	Terminal 58xd dimmer	100
    IDE06091-IDE01440	Humidity sensor: internal-Windshield temperature	23	 °C
    IDE06091-MAS04629	Humidity sensor: internal-Sensor temperature	3624.5	 °C
    IDE06091-MAS04630	Humidity sensor: internal-Relative humidity	20563	 %
    IDE06091-MAS04647	Humidity sensor: internal-Dew point	-10.7	 °C
    IDE06201	Blower reduction	No switch-off: no reduction
    IDE06235	Potentiometer for rear vent temperature	255
    IDE07159-MAS01155	Control module switch-off: counter-Control module	0
    IDE07159-MAS05583	Control module switch-off: counter-Data bus	0
    MAS00464	Standard - ambient data 1	2000
    MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	13
    MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	490	 km
    MAS00464	Standard - ambient data 1	1
    MAS00464	Standard - ambient data 1	11
    MAS00464	Standard - ambient data 1	5
    MAS00464	Standard - ambient data 1	23
    adpmap-08-5GM-907-044-C.CSV
    ;SW:5GM-907-044-C   HW:5GM-907-044-C ---  Auto HVAC
    ;Component:Climatronic   H04 1601	 Coding:02020024200100000105000012111402
    ;EV_ACClimaBHBVW37X	6142	EV_ACClimaBHBVW37X_005_VW37.rod
    ;Wednesday	11	January	2017	20:00:56:08929
    ;VCID: C4CB4FB54FB9BE6131-8090
    IDE00001-Production mode	Deactivating
    IDE01067-Retention of driver's seat heater level	active for 10 minutes
    IDE01478-Ignore compressor switch-off by Engine Control Module	Do not ignore
    IDE01479-Gear ratio of engine - A/C compressor	0
    IDE01483-Blower voltage for voice operation	not activated
    IDE01488-Retrofitting of parking heater without CAN	not installed
    IDE01493-Air quality sensor sensitivity	Maximum
    IDE01503-Runtime for compressor run-in basic setting	120 s
    IDE01536-Post-heating of parking heater	0 min
    IDE02155-Reset all counters	not activated
    IDE02332-Deactivate production mode	0
    IDE03176-Duration of compressor run in	0 s
    IDE03251-Stop release for start-stop function	According to function requirements
    IDE04159-Deactivation of start-stop function	not active
    IDE06097-Target temperature of A/C - heater function via remote control	22.0 °C
    IDE06544-Speed switch-off threshold for compressor run-in (engine speed)	1500 /min
    IDE06545-Blower voltage for production routines	6.0 V
    IDE06546-Interior target temperature for production routines	22 °C
    IDE06547-Air distribution for production routines	No effect
    IDE06593-Recirculation air for production routines	No effect
    IDE07108-Climate modes	Matching coding
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min
    IDE07301-Remotestart-Funktion: Aktivierung Sitzheizung	Seat heater request driver side
    IDE07302-Remotestart-Funktion: Innenraumklimatisierung Status	Remote start function with last set value active
    IDE07303-Remotestart-Funktion: Aktivierungungstemperatur Scheibenheizung	4 °C
    IDE07304-Remotestart-Funktion: Aktivierung Sitzlüftung	activated
    IDE07305-Remotestart-Funktion: Aktivierungungstemperatur Sitzheizung	15 °C
    IDE07306-Remotestart-Funktion: Aktivierungungstemperatur Sitzlüftung	30 °C
    IDE07307-Remotestart-Funktion: Aktivierungungsstufe Sitzheizung	4
    IDE07308-Remotestart-Funktion: Aktivierungungsstufe Sitzlüftung	4
    IDE07398-Blower logic for manual adjustment	Matching coding
    IDE07585-Hand heater function during cold start	active
    IDE07865-Automatic Activation of front windshield heater at MAX-Defrost	not active
    IDE07948-Retention of frt.pass. seat heater level	not active
    IDE80006-Analysis 6	not activated
    IDE80007-Analysis 7	00000000 00000000
    IDE80008-Analysis 8	not active
    MAS05739-CO2 compressor on-time reduction	Matching coding
    MAS06564-Window condensation exterior reduction at high humidity	Matching coding
    MAS07251-Cut-in behavior	Matching coding
    ENG122844-ENG99557-dimming_characteristic_1-X2	6
    ENG122844-ENG102140-dimming_characteristic_1-X3	40
    ENG122844-ENG102936-dimming_characteristic_1-X4	60
    ENG122844-ENG103548-dimming_characteristic_1-X5	80
    ENG122844-ENG113992-dimming_characteristic_1-X6	100
    ENG122844-ENG99777-dimming_characteristic_1-Y1	0%
    ENG122844-ENG100480-dimming_characteristic_1-Y2	6%
    ENG122844-ENG100773-dimming_characteristic_1-Y3	40%
    ENG122844-ENG100631-dimming_characteristic_1-Y4	60%
    ENG122844-ENG102174-dimming_characteristic_1-Y5	80%
    ENG122844-ENG113993-dimming_characteristic_1-Y6	100%
    ENG122845-ENG99777-dimming_characteristic_2-Y1	2%
    ENG122845-ENG100480-dimming_characteristic_2-Y2	2%
    ENG122845-ENG100773-dimming_characteristic_2-Y3	10%
    ENG122845-ENG100631-dimming_characteristic_2-Y4	21%
    ENG122845-ENG102174-dimming_characteristic_2-Y5	85%
    ENG122845-ENG113993-dimming_characteristic_2-Y6	100%
    ENG122846-ENG101574-dimming_characteristic_3-X1	0
    ENG122846-ENG99557-dimming_characteristic_3-X2	10
    ENG122846-ENG102140-dimming_characteristic_3-X3	50
    ENG122846-ENG102936-dimming_characteristic_3-X4	100
    ENG122846-ENG103548-dimming_characteristic_3-X5	220
    ENG122846-ENG113992-dimming_characteristic_3-X6	253
    ENG122846-ENG99777-dimming_characteristic_3-Y1	3%
    ENG122846-ENG100480-dimming_characteristic_3-Y2	3%
    ENG122846-ENG100773-dimming_characteristic_3-Y3	6%
    ENG122846-ENG100631-dimming_characteristic_3-Y4	12%
    ENG122846-ENG102174-dimming_characteristic_3-Y5	100%
    ENG122846-ENG113993-dimming_characteristic_3-Y6	100%
    ENG122847-ENG101574-dimming_characteristic_4-X1	0
    ENG122847-ENG99557-dimming_characteristic_4-X2	10
    ENG122847-ENG102140-dimming_characteristic_4-X3	50
    ENG122847-ENG102936-dimming_characteristic_4-X4	100
    ENG122847-ENG103548-dimming_characteristic_4-X5	220
    ENG122847-ENG113992-dimming_characteristic_4-X6	253
    ENG122847-ENG99777-dimming_characteristic_4-Y1	2%
    ENG122847-ENG100480-dimming_characteristic_4-Y2	2%
    ENG122847-ENG100773-dimming_characteristic_4-Y3	5%
    ENG122847-ENG100631-dimming_characteristic_4-Y4	10%
    ENG122847-ENG102174-dimming_characteristic_4-Y5	85%
    ENG122847-ENG113993-dimming_characteristic_4-Y6	100%
    ENG122848-ENG101574-dimming_characteristic_5-X1	0
    ENG122848-ENG99557-dimming_characteristic_5-X2	10
    ENG122848-ENG102140-dimming_characteristic_5-X3	50
    ENG122848-ENG102936-dimming_characteristic_5-X4	100
    ENG122848-ENG103548-dimming_characteristic_5-X5	220
    ENG122848-ENG113992-dimming_characteristic_5-X6	253
    ENG122848-ENG99777-dimming_characteristic_5-Y1	2%
    ENG122848-ENG100480-dimming_characteristic_5-Y2	2%
    ENG122848-ENG100773-dimming_characteristic_5-Y3	5%
    ENG122848-ENG100631-dimming_characteristic_5-Y4	10%
    ENG122848-ENG102174-dimming_characteristic_5-Y5	85%
    ENG122848-ENG113993-dimming_characteristic_5-Y6	100%
    ENG130577-Knockout_timer_activation	not activated
    Elapsed Time: 00:15
    United States
    09-Cent. Elect.
    blockmap-09-5Q0-937-087-AA.CSV
    ;SW:5Q0-937-087-AA   HW:5Q0-937-087-AA ---  Cent. Elect.
    ;Component:BCM PQ37BOSCH 028 0162	 Coding:00511B464041A2E969E44000001407201800000000000000000000000000
    ;EV_BodyContrModul1UDSBosc	15002	EV_BCMBOSCH_016_AU37.rod
    ;Wednesday	11	January	2017	20:01:30:08929
    ;VCID: FAB7F14D7DFD38911B-80AE
    IDE00323	Security Access: Number of invalid keys	0
    IDE00374-MAS05377	Electric auxiliary heater: relay activation-Low heat output relay	not coded/not installed
    IDE00374-MAS05378	Electric auxiliary heater: relay activation-High heat output relay	not coded/not installed
    IDE00844-MAS07314	Switch for engine hood-Status engine hood contact	closed
    IDE00844-ENG122175	Switch for engine hood-Bonnet_Magnetic_Lock	not coded/not installed
    IDE01066-IDE02092	Convertible top status-Tailgate condition	not coded/not installed
    IDE01066	Convertible top status	not coded/not installed
    IDE01285	Counter of component protection malfunctions	0
    IDE01464-IDE04741	Rear window defogger-Rear window defogger button	not activated
    IDE01464-IDE04744	Rear window defogger-Rear window defogger indicator lamp	not coded/not installed
    IDE01464-MAS01580	Rear window defogger-Activation	not active
    IDE01537-IDE04742	Windshield defogger-Windshield defogger button	not coded/not installed
    IDE01537-IDE04743	Windshield defogger-Windshield defogger indicator lamp	not coded/not installed
    IDE01537-MAS01580	Windshield defogger-Activation	not coded/not installed
    IDE01943	Turn signal	Plug B
    IDE01943	Turn signal	36
    IDE01943	Turn signal	0	 %
    IDE01943	Turn signal	not active
    IDE01943	Turn signal	normal
    IDE02092-IDE02093	Tailgate condition-Status of rear lid lock	Implausible
    IDE02092-IDE02133	Tailgate condition-Activation using rear lid unlocking button	not coded/not installed
    IDE02092-MAS01872	Tailgate condition-Rear lid remote release button	not coded/not installed
    IDE02092-MAS02405	Tailgate condition-Pre-engagement contact for rotary latch	closed
    IDE02092-MAS02447	Tailgate condition-Release	Enabled
    IDE02092-MAS06265	Tailgate condition-Release button in rear lid handle	not activated
    IDE02092-MAS06430	Tailgate condition-Main notch contact of rotary latch	closed
    IDE02486	Data logger triggering	not active
    IDE02488-MAS01632	DWA Interior monitoring-Status	not coded/not installed
    IDE02488-MAS04508	DWA Interior monitoring-Alarm detected	not coded/not installed
    IDE02515	Low beam	Plug C
    IDE02515	Low beam	5
    IDE02515	Low beam	0	 %
    IDE02515	Low beam	not active
    IDE02515	Low beam	normal
    IDE02588-IDE00020	Terminal signals and start release-Terminal 15 status	active
    IDE02588-IDE00773	Terminal signals and start release-Terminal 15 status via CAN	active
    IDE02588-IDE01351	Terminal signals and start release-Terminal 75 status	On
    IDE02588-IDE01715	Terminal signals and start release-Status terminal S	active
    IDE02588-IDE01716	Terminal signals and start release-Terminal 50 status	OFF
    IDE02588-IDE06027	Terminal signals and start release-Terminal S status via CAN	active
    IDE02588-MAS12787	Terminal signals and start release-Terminal 15 ignition switch signal 1	active
    IDE02588-MAS12788	Terminal signals and start release-Terminal 15 ignition switch signal 2	active
    IDE02614-MAS02788	Reversing light switch-CAN	not active
    IDE02614-MAS05360	Reversing light switch-Discreet wire	not active
    IDE02711	Rear Window Wiper	not active
    IDE02743	High Beam	Plug B
    IDE02743	High Beam	23
    IDE02743	High Beam	0	 %
    IDE02743	High Beam	not active
    IDE02743	High Beam	normal
    IDE02857-IDE03111	Activation current-Interior light	0	 mA
    IDE02857-IDE05533	Activation current-Spray nozzle heater	120	 mA
    IDE02857-IDE06012	Activation current-Search lights	0	 mA
    IDE02857-MAS01554	Activation current-Left heated seat	0	 mA
    IDE02857-MAS01556	Activation current-Right heated seat	0	 mA
    IDE02857-MAS05942	Activation current-Windshield and rear window washer pump	0	 mA
    IDE02857-ENG128454	Activation current-Cockpittaster_1	0	 mA
    IDE02857-ENG128455	Activation current-Cockpittaster_2	0	 mA
    IDE02857-ENG128456	Activation current-Cockpittaster_3	0	 mA
    IDE02857-ENG128457	Activation current-Cockpittaster_4	0	 mA
    IDE02857-ENG128458	Activation current-DWA_Einfachhorn	0	 mV
    IDE02857-ENG126436	Activation current-signal_horn	0	 mV
    IDE02957	Ambient lighting	Not available
    IDE02957	Ambient lighting	not_defined
    IDE02957	Ambient lighting	0
    IDE02957	Ambient lighting	0	 %
    IDE02957	Ambient lighting	not coded/not installed
    IDE03111	Interior light	Plug C
    IDE03111	Interior light	12
    IDE03111	Interior light	89	 %
    IDE03111	Interior light	active
    IDE03111	Interior light	normal
    IDE03310	Brake light	Plug A
    IDE03310	Brake light	60
    IDE03310	Brake light	0	 %
    IDE03310	Brake light	not active
    IDE03310	Brake light	normal
    IDE03388-IDE01217	Left front heated seat: status-Left heated seat stage	OFF
    IDE03388-MAS02201	Left front heated seat: status-Temperature	16	 °C
    IDE03389-IDE01218	Right front heated seat: status-Right heated seat stage	OFF
    IDE03389-MAS02201	Right front heated seat: status-Temperature	16	 °C
    IDE03504	Personalized settings	1
    IDE03504	Personalized settings	All windows
    IDE03504	Personalized settings	active
    IDE03504	Personalized settings	not active
    IDE03504	Personalized settings	all
    IDE03504	Personalized settings	INDIVIDUAL
    IDE03504	Personalized settings	5	 s
    IDE03504	Personalized settings	normal
    IDE03504	Personalized settings	3
    IDE03638	static AFS light	not_defined
    IDE03638	static AFS light	0
    IDE03638	static AFS light	0	 %
    IDE03638	static AFS light	Measured value not available
    IDE03638	static AFS light	not coded/not installed
    IDE04213	Central locking button	not coded/not installed
    IDE04213-IDE07357	Central locking button-Indicator light for central locking	not coded/not installed
    IDE04254-MAS06517	Play protection for central locking-Rear spoiler counter	not active
    IDE04925	Daytime running lights	not_defined
    IDE04925	Daytime running lights	0
    IDE04925	Daytime running lights	0	 %
    IDE04925	Daytime running lights	Measured value not available
    IDE04925	Daytime running lights	not coded/not installed
    IDE05042-IDE05043	Emergency flasher button-Emergency flasher indicator lamp	On
    IDE05042-MAS02158	Emergency flasher button-Actuation condition	Not operated
    IDE05042-MAS03873	Emergency flasher button-Duty cycle	18.5	 %
    IDE05045-IDE05183	Front windshield wiper module-Malfunction left	no error
    IDE05045-IDE05184	Front windshield wiper module-Malfunction right	no error
    IDE05045-MAS01632	Front windshield wiper module-Status	not active
    IDE05045-MAS02282	Front windshield wiper module-Position	park position
    IDE05045-MAS03638	Front windshield wiper module-Wipe speed	0	 /min
    IDE05045-MAS05057	Front windshield wiper module-Number of wiper cycles	700
    IDE05045-MAS05878	Front windshield wiper module-Stage	not coded/not installed
    IDE05323	Fog light	Plug B
    IDE05323	Fog light	45
    IDE05323	Fog light	0	 %
    IDE05323	Fog light	not active
    IDE05323	Fog light	normal
    IDE05434	Rear entry light	not_defined
    IDE05434	Rear entry light	0
    IDE05434	Rear entry light	0	 %
    IDE05434	Rear entry light	Measured value not available
    IDE05434	Rear entry light	not coded/not installed
    IDE05533	Spray nozzle heater	active
    IDE05719-IDE05534	Window washer system-Headlamp washer system	not coded/not installed
    IDE05719-MAS02339	Window washer system-Windshield washer system	not active
    IDE05719-MAS02341	Window washer system-Rear window washer system	not active
    IDE05720-IDE02589	Front driver side door status-Rotary latch status	closed
    IDE05720-IDE04213	Front driver side door status-Central locking button	Not operated
    IDE05720-IDE04214	Front driver side door status-Key switch in door lock	Not operated
    IDE05720-MAS06256	Front driver side door status-Status door lock	Signal from door lock: released
    IDE05722-IDE02589	Door status: driver side rear-Rotary latch status	closed
    IDE05722-IDE04213	Door status: driver side rear-Central locking button	Not operated
    IDE05722-MAS06256	Door status: driver side rear-Status door lock	Signal from door lock: released
    IDE05727-IDE02589	Front passenger side door status-Rotary latch status	closed
    IDE05727-IDE04213	Front passenger side door status-Central locking button	Not operated
    IDE05727-IDE04214	Front passenger side door status-Key switch in door lock	Not operated
    IDE05727-MAS06256	Front passenger side door status-Status door lock	Signal from door lock: released
    IDE05729-IDE02589	Door status: frt. pass. side rear-Rotary latch status	closed
    IDE05729-IDE04213	Door status: frt. pass. side rear-Central locking button	Not operated
    IDE05729-MAS06256	Door status: frt. pass. side rear-Status door lock	Signal from door lock: released
    IDE05730	Luggage compartment light	not_defined
    IDE05730	Luggage compartment light	0
    IDE05730	Luggage compartment light	0	 %
    IDE05730	Luggage compartment light	Measured value not available
    IDE05730	Luggage compartment light	not coded/not installed
    IDE05739	Footwell light	Plug C
    IDE05739	Footwell light	72
    IDE05739	Footwell light	0	 %
    IDE05739	Footwell light	not active
    IDE05739	Footwell light	normal
    IDE05742-IDE02515	Light switch position-Low beam	not activated
    IDE05742-IDE05323	Light switch position-Fog light	not activated
    IDE05742-IDE07956	Light switch position-redundant signal line	OFF
    IDE05742-MAS00063	Light switch position-OFF	operated
    IDE05742-MAS02462	Light switch position-Automatic high beam assist	not activated
    IDE05742-MAS03835	Light switch position-Parking light	not activated
    IDE05742-MAS03836	Light switch position-Rear fog light	not coded/not installed
    IDE05822-MAS01632	DWA Vehicle inclination sensor-Status	not coded/not installed
    IDE05822-MAS04508	DWA Vehicle inclination sensor-Alarm detected	not coded/not installed
    IDE05825-MAS02594	DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch	not coded/not installed
    IDE05825-MAS04247	DWA Interior monitoring/vehicle inclination sensor button-Button	not coded/not installed
    IDE05826-MAS01632	DWA Sirens / alarm horn for anti-theft warning system-Status	not coded/not installed
    IDE05826-MAS04508	DWA Sirens / alarm horn for anti-theft warning system-Alarm detected	No
    IDE05826-MAS04509	DWA Sirens / alarm horn for anti-theft warning system-Alarm activated	No
    IDE05827	Alarm horn for anti-theft warning system	not coded/not installed
    IDE05829	Rear spoiler history data	NoEntry
    IDE05829	Rear spoiler history data	0
    IDE05829	Rear spoiler history data	5898586	 km
    IDE05830-MAS02282	Rear Spoiler-Position	not coded/not installed
    IDE05830-ENG115793	Rear Spoiler-Spoiler_Button	not coded/not installed
    IDE05830-ENG115792	Rear Spoiler-Spoiler_Cycle_Protection	not coded/not installed
    IDE05830-ENG115794	Rear Spoiler-Spoiler_Indication_Light	not coded/not installed
    IDE05830-ENG115791	Rear Spoiler-Spoiler_Position	not coded/not installed
    IDE05833	Anti-theft warning system: history data	No alarm
    IDE05833	Anti-theft warning system: history data	0	 km
    IDE05833	Anti-theft warning system: history data	2000
    IDE05834-IDE01718	Driver info-Crash signal	not active
    IDE05834-MAS00211	Driver info-Insufficient brake fluid	not active
    IDE05834-MAS00212	Driver info-Insufficient washer fluid	not active
    IDE05834-MAS00213	Driver info-Insufficient coolant	not active
    IDE05834-MAS00214	Driver info-Brake pad wear	not coded/not installed
    IDE05836-MAS03637	Rain recognition sensor-Rain quantity	0
    IDE05836-MAS03638	Rain recognition sensor-Wipe speed	0
    IDE05836-MAS04806	Rain recognition sensor-Splash	not active
    IDE05836-MAS04807	Rain recognition sensor-park position	active
    IDE05837	Activation for signal horn	not active
    IDE05838-MAS01794	Light recognition sensor-Freeway	OFF
    IDE05838-MAS02248	Light recognition sensor-Signal state	active
    IDE05838-MAS02475	Light recognition sensor-Brightness infrared	0	 lx
    IDE05838-MAS02851	Light recognition sensor-Brightness	0	 lx
    IDE05838-MAS04808	Light recognition sensor-Rain	OFF
    IDE05838-MAS04809	Light recognition sensor-Darkness	On
    IDE05838-MAS04810	Light recognition sensor-Request for light activation	On
    IDE05839	Parking light	Plug B
    IDE05839	Parking light	10
    IDE05839	Parking light	0	 %
    IDE05839	Parking light	not active
    IDE05839	Parking light	normal
    IDE05841	Central locking history data	remote_lock_unlock_switch
    IDE05841	Central locking history data	Door unlock
    IDE05841	Central locking history data	complete unlock
    IDE05841	Central locking history data	radio remote control: number 2
    IDE05842	Comfort function history data	keine Bedienstelle
    IDE05842	Comfort function history data	Open
    IDE05842	Comfort function history data	not active
    IDE06012	Search lights	Plug C
    IDE06012	Search lights	Variant A
    IDE06012	Search lights	62
    IDE06012	Search lights	0	 %
    IDE06012	Search lights	not active
    IDE06012	Search lights	normal
    IDE06091-IDE01440	Humidity sensor: internal-Windshield temperature	-38.8	 °C
    IDE06091-MAS04629	Humidity sensor: internal-Sensor temperature	13	 °C
    IDE06091-MAS04630	Humidity sensor: internal-Relative humidity	83.5	 %
    IDE06091-MAS04647	Humidity sensor: internal-Dew point	-16.3	 °C
    IDE06096-IDE03111	Interior lighting-Interior light	0	 %
    IDE06096-IDE05724	Interior lighting-Terminal 58xt dimmer	100	 %
    IDE06096-IDE05725	Interior lighting-Terminal 58xs dimmer	0	 %
    IDE06096-IDE05726	Interior lighting-Terminal 58xd dimmer	100	 %
    IDE06096-MAS01634	Interior lighting-Supply voltage	89	 %
    IDE06096-MAS04528	Interior lighting-Instrument panel and switch illumination dimmer switch	100	 %
    IDE06324-IDE04217	Tank cap lock-Fuel filler door release button	not coded/not installed
    IDE06324-MAS01580	Tank cap lock-Activation	not active
    IDE06324-MAS06251	Tank cap lock-Contact switch	not coded/not installed
    IDE06470	Ambience lighting	not_defined
    IDE06470	Ambience lighting	0
    IDE06470	Ambience lighting	0	 %
    IDE06470	Ambience lighting	Measured value not available
    IDE06470	Ambience lighting	not coded/not installed
    IDE06507-MAS13127	Button in center console-Status Taster 1	not coded/not installed
    IDE06507-MAS13128	Button in center console-Kontrollleuchte Taster 1	not coded/not installed
    IDE06507-MAS13130	Button in center console-Status Taster 2	not coded/not installed
    IDE06507-MAS13131	Button in center console-Kontrollleuchte Taster 2	not coded/not installed
    IDE06507-MAS13133	Button in center console-Status Taster 3	not activated
    IDE06507-MAS13134	Button in center console-Kontrollleuchte Taster 3	OFF
    IDE06507-MAS13136	Button in center console-Kontrollleuchte Taster 4	not coded/not installed
    IDE06507-MAS13137	Button in center console-Status Taster 4	not coded/not installed
    IDE06644-IDE06864	Vehicle positioning system-Daytime running lights	not coded/not installed
    IDE06644-MAS00145	Vehicle positioning system-Starter lock	not coded/not installed
    IDE06644-MAS01288	Vehicle positioning system-Signal horn	not coded/not installed
    IDE06644-MAS03834	Vehicle positioning system-Emergency signal flashing	not coded/not installed
    IDE06644-MAS03835	Vehicle positioning system-Parking light	not coded/not installed
    IDE06695	Energy management: last critical state	0
    IDE06695	Energy management: last critical state	2000
    IDE06864	Daytime running lights	Plug B
    IDE06864	Daytime running lights	10
    IDE06864	Daytime running lights	0	 %
    IDE06864	Daytime running lights	not active
    IDE06864	Daytime running lights	normal
    IDE07344-IDE00542	Sunroof shade-Excessive temperature protection	not active
    IDE07344-IDE03114	Sunroof shade-Comfort function	not active
    IDE07344-MAS01979	Sunroof shade-Adapting	Adapted
    IDE07344-MAS02282	Sunroof shade-Position	100	 %
    IDE07344-MAS02447	Sunroof shade-Release	active
    IDE07344-MAS03656	Sunroof shade-Reverse	not active
    IDE07344-MAS05563	Sunroof shade-Norming	normed
    IDE07345-MAS07997	Sunroof front closed position switch-Rotary switch activation	not activated
    IDE07345	Sunroof front closed position switch	not activated
    IDE07345-ENG122183	Sunroof front closed position switch-rotary_switch_position	closed
    IDE07346	Sunroof shade switches	not activated
    IDE08125-MAS01458	Left cabin heater-Operating condition	not coded/not installed
    IDE08125-MAS06651	Left cabin heater-PTC heater element: current consumption	not coded/not installed
    IDE08125-MAS06652	Left cabin heater-Blower motor: speed	not coded/not installed
    IDE08125-MAS06653	Left cabin heater-Indicator light for head area heater	not coded/not installed
    IDE08126-MAS01458	Right cabin heater-Operating condition	not coded/not installed
    IDE08126-MAS06651	Right cabin heater-PTC heater element: current consumption	not coded/not installed
    IDE08126-MAS06652	Right cabin heater-Blower motor: speed	not coded/not installed
    IDE08126-MAS06653	Right cabin heater-Indicator light for head area heater	not coded/not installed
    IDE08949-MAS07867	Operating current: light driver-Conn. pin 0	0	 mA
    IDE08949-MAS07868	Operating current: light driver-Conn. pin 1	0	 mA
    IDE08949-MAS07869	Operating current: light driver-Conn. pin 2	0	 mA
    IDE08949-MAS07870	Operating current: light driver-Conn. pin 3	0	 mA
    IDE08949-MAS07871	Operating current: light driver-Conn. pin 4	0	 mA
    IDE08949-MAS07872	Operating current: light driver-Conn. pin 5	0	 mA
    IDE08949-MAS07873	Operating current: light driver-Conn. pin 6	0	 mA
    IDE08949-MAS07874	Operating current: light driver-Conn. pin 7	0	 mA
    IDE08949-MAS07875	Operating current: light driver-Conn. pin 8	0	 mA
    IDE08949-MAS07876	Operating current: light driver-Conn. pin 9	0	 mA
    IDE08949-MAS07877	Operating current: light driver-Conn. pin 10	0	 mA
    IDE08949-MAS07878	Operating current: light driver-Conn. pin 11	0	 mA
    IDE08949-MAS07879	Operating current: light driver-Conn. pin 12	0	 mA
    IDE08949-MAS07880	Operating current: light driver-Conn. pin 13	0	 mA
    IDE08949-MAS07881	Operating current: light driver-Conn. pin 14	0	 mA
    IDE08949-MAS07882	Operating current: light driver-Conn. pin 15	0	 mA
    IDE08949-MAS07883	Operating current: light driver-Conn. pin 16	0	 mA
    IDE08949-MAS07884	Operating current: light driver-Conn. pin 17	0	 mA
    IDE08949-MAS07885	Operating current: light driver-Conn. pin 18	0	 mA
    IDE08949-MAS07886	Operating current: light driver-Conn. pin 19	0	 mA
    IDE08949-MAS07887	Operating current: light driver-Conn. pin 20	0	 mA
    IDE08949-MAS07888	Operating current: light driver-Conn. pin 21	0	 mA
    IDE08949-MAS07889	Operating current: light driver-Conn. pin 22	0	 mA
    IDE08949-MAS07890	Operating current: light driver-Conn. pin 23	0	 mA
    IDE08949-MAS07891	Operating current: light driver-Conn. pin 24	0	 mA
    IDE08949-MAS07892	Operating current: light driver-Conn. pin 25	0	 mA
    IDE08949-MAS07893	Operating current: light driver-Conn. pin 26	0	 mA
    IDE08949-MAS07894	Operating current: light driver-Conn. pin 27	0	 mA
    IDE08949-MAS07895	Operating current: light driver-Conn. pin 28	0	 mA
    IDE08949-MAS07896	Operating current: light driver-Conn. pin 29	0	 mA
    IDE08949-MAS07897	Operating current: light driver-Conn. pin 30	0	 mA
    IDE08949-MAS07898	Operating current: light driver-Conn. pin 31	0	 mA
    IDE08949-MAS07899	Operating current: light driver-Conn. pin 32	0	 mA
    IDE08949-MAS07900	Operating current: light driver-Conn. pin 33	0	 mA
    IDE08949-MAS07901	Operating current: light driver-Conn. pin 34	0	 mA
    IDE09065-MAS07963	Status: remote start-Number of permissible remote starts	2
    IDE09065-MAS07964	Status: remote start-Engine run time after remote start	600	 s
    IDE09850-MAS07146	Garage Door Opener Operating Unit-Button 1	not coded/not installed
    IDE09850-MAS07147	Garage Door Opener Operating Unit-Button 2	not coded/not installed
    IDE09850-MAS07148	Garage Door Opener Operating Unit-Button 3	not coded/not installed
    IDE11134-IDE01943	Light sequence HU test result-Turn signal	installed_not_active
    IDE11134-IDE02515	Light sequence HU test result-Low beam	installed_not_active
    IDE11134-IDE02614	Light sequence HU test result-Reversing light switch	installed_not_active
    IDE11134-IDE02743	Light sequence HU test result-High Beam	installed_not_active
    IDE11134-IDE03310	Light sequence HU test result-Brake light	installed_not_active
    IDE11134-IDE03638	Light sequence HU test result-static AFS light	installed_not_active
    IDE11134-IDE05323	Light sequence HU test result-Fog light	installed_not_active
    IDE11134-IDE05839	Light sequence HU test result-Parking light	not_installed_not_active
    IDE11134-IDE06470	Light sequence HU test result-Ambience lighting	not_installed_not_active
    IDE11134-IDE06864	Light sequence HU test result-Daytime running lights	installed_not_active
    IDE11134-MAS02354	Light sequence HU test result-Headlamp flasher	installed_not_active
    IDE11134-MAS03835	Light sequence HU test result-Parking light	installed_not_active
    IDE11134-MAS03836	Light sequence HU test result-Rear fog light	not_installed_not_active
    IDE11134-MAS11025	Light sequence HU test result-Status	0
    IDE11727-MAS13125	Funktion der Taster in der Mittelkonsole-Funktion Taster 1	Start-stop
    IDE11727-MAS13129	Funktion der Taster in der Mittelkonsole-Funktion Taster 2	Laderaumschließung
    IDE11727-MAS13132	Funktion der Taster in der Mittelkonsole-Funktion Taster 3	Driving program
    IDE11727-MAS13135	Funktion der Taster in der Mittelkonsole-Funktion Taster 4	Steering wheel heater
    IDE80251-MAS06439	Head area heater-Crash status	not coded/not installed
    IDE80251-MAS06646	Head area heater-Head area heater left: specified level	not coded/not installed
    IDE80251-MAS06647	Head area heater-Head area heater right: specified level	not coded/not installed
    IDE80251-MAS06648	Head area heater-Continuation at terminal 15 on	not coded/not installed
    IDE80251-MAS06649	Head area heater-Left front seat occupation status	not coded/not installed
    IDE80251-MAS06650	Head area heater-Right front occupation status	not coded/not installed
    MAS00043-IDE00019	Supply voltage: Terminal 30-Voltage terminal 30	14.35	 V
    MAS00043-IDE05835	Supply voltage: Terminal 30-Supply voltage for central locking	14.45	 V
    MAS00043-IDE05967	Supply voltage: Terminal 30-Voltage terminal 30 left	14.25	 V
    MAS00043-IDE05968	Supply voltage: Terminal 30-Voltage terminal 30 right	14.25	 V
    MAS00043-IDE08734	Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system	5	 V
    MAS00043-IDE08735	Supply voltage: Terminal 30-Supply voltage for seat heater	14.4	 V
    MAS00043-MAS00362	Supply voltage: Terminal 30-Battery voltage	5	 V
    MAS00043-MAS07472	Supply voltage: Terminal 30-Battery voltage BEM	14.55	 V
    MAS00043-MAS07473	Supply voltage: Terminal 30-Test voltage rear window defogger	0	 V
    MAS00043-MAS07474	Supply voltage: Terminal 30-Test voltage windshield defogger	0	 V
    MAS00179-MAS04422	Brake Light Switch-Brake light signal via CAN	OFF
    MAS00179-MAS07313	Brake Light Switch-Brake light signal via HW	OFF
    MAS00464	Standard - ambient data 1	39
    MAS00829-MAS00244	Access and start authorization-Awakening wire	not activated
    MAS00829-MAS01763	Access and start authorization-Signal Strength	-65
    MAS00829-MAS07866	Access and start authorization-Duration: last awakening wire actua.	0	 ms
    MAS01281	Back-up light	Plug C
    MAS01281	Back-up light	11
    MAS01281	Back-up light	0	 %
    MAS01281	Back-up light	not active
    MAS01281	Back-up light	normal
    MAS01431-IDE01442	Vehicle key with remote control-Pressing a button	not activated
    MAS01431-IDE01839	Vehicle key with remote control-Battery charge condition	Not available
    MAS01431-MAS00077	Vehicle key with remote control-Immobilizer	OK
    MAS01431-MAS01551	Vehicle key with remote control-Key number	255
    MAS01431-MAS05048	Vehicle key with remote control-Number of transmitters adapted	2
    MAS01431-MAS06362	Vehicle key with remote control-Code in detection area	Not available
    MAS01490-IDE02744	Energy management-Steering wheel heater	Enabled
    MAS01490-IDE04216	Energy management-Mirror heater	Enabled
    MAS01490-IDE80251	Energy management-Head area heater	not coded/not installed
    MAS01490-MAS01535	Energy management-Rear window defogger	Enabled
    MAS01490-MAS01563	Energy management-Auxiliary Air Heater	Enabling stage 3
    MAS01490-MAS01564	Energy management-Windshield defogger	Enabled
    MAS01490-MAS01632	Energy management-Status	not active
    MAS01490-MAS02390	Energy management-Shutoff	8
    MAS01490-MAS05795	Energy management-Rear seat heater	Enabled
    MAS01490-MAS05796	Energy management-Emergency shut-down	0
    MAS01490-MAS05887	Energy management-Battery cut out relay 2	not enabled
    MAS01490-MAS06551	Energy management-Seat ventilation	not coded/not installed
    MAS01490-MAS06552	Energy management-Seat heater front	Enabling stage 3
    MAS01490-MAS06553	Energy management-Display consumer switch-off	not active
    MAS01490-MAS06554	Energy management-Switch-off priority while driving	0
    MAS01490-MAS06555	Energy management-Maximum switch-off priority while driving	5
    MAS01490-MAS06556	Energy management-Switch-off with voltage drops	0
    MAS01490-MAS06557	Energy management-Switch-off priority with vehicle crash	0
    MAS01490-MAS06558	Energy management-Current negative charge balance	0	 %
    MAS01490-MAS06559	Energy management-Switch-off priority with engine off	0
    MAS01490-MAS06560	Energy management-Short distance drive	1
    MAS01597-IDE00542	Sunroof-Excessive temperature protection	not active
    MAS01597-IDE03114	Sunroof-Comfort function	not active
    MAS01597-MAS01979	Sunroof-Adapting	Adapted
    MAS01597-MAS02282	Sunroof-Position	0	 %
    MAS01597-MAS02447	Sunroof-Release	active
    MAS01597-MAS03656	Sunroof-Reverse	not active
    MAS01597-MAS05563	Sunroof-Norming	normed
    MAS01597-MAS05737	Sunroof-Position	Tilt out posi.
    MAS03835	Parking light	Plug B
    MAS03835	Parking light	10
    MAS03835	Parking light	0	 %
    MAS03835	Parking light	not active
    MAS03835	Parking light	normal
    MAS03836	Rear fog light	not_defined
    MAS03836	Rear fog light	0
    MAS03836	Rear fog light	0	 %
    MAS03836	Rear fog light	Measured value not available
    MAS03836	Rear fog light	not coded/not installed
    MAS07959	Remote start history data	no_reason_for_prohibition
    MAS07959	Remote start history data	no_reason_for_abortion
    MAS07959	Remote start history data	15
    MAS07959	Remote start history data	31
    MAS08228-MAS01632	Light sensor-Status	not coded/not installed
    MAS08228-MAS02851	Light sensor-Brightness	not coded/not installed
    MAS08228-MAS04121	Light sensor-Voltage	not coded/not installed
    MAS13141	Prüfspannung	0	 V
    ENG116910	Control unit internal measured value (supplier)	31
    ENG117285-ENG115839	Cycle_Protection_Counter-central_locking_cycle_protection_counter	0
    ENG117285-ENG115840	Cycle_Protection_Counter-general_cycle_protection_counter	1
    ENG117285-ENG124947	Cycle_Protection_Counter-last_wake_up	gueltiges Funktelegramm
    ENG116908-ENG115779	Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an	0	 H
    ENG116908-ENG115778	Ecu_Intern_Meas._Values_2-Hours_of_operation	0	 H
    ENG116908-ENG115775	Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper	0
    ENG116908-ENG115776	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper	0
    ENG116908-ENG115777	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper	0
    ENG116813-ENG115632	Entwicklermesswerte_CONTI-Kurzschlusszähler 0..99	0
    ENG117286-ENG116724	Kopfraumheizung_Entwicklung-KRH_l_Error	not coded/not installed
    ENG117286-ENG116725	Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit	not coded/not installed
    ENG117286-ENG116723	Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error	not coded/not installed
    ENG117286-ENG116727	Kopfraumheizung_Entwicklung-KRH_l_PTC_Error	not coded/not installed
    ENG117286-ENG116726	Kopfraumheizung_Entwicklung-KRH_l_ResponseError	not coded/not installed
    ENG117286-ENG116730	Kopfraumheizung_Entwicklung-KRH_r_Error	not coded/not installed
    ENG117286-ENG116731	Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit	not coded/not installed
    ENG117286-ENG116728	Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error	not coded/not installed
    ENG117286-ENG116729	Kopfraumheizung_Entwicklung-KRH_r_PTC_Error	not coded/not installed
    ENG117286-ENG116732	Kopfraumheizung_Entwicklung-KRH_r_ResponseError	not coded/not installed
    ENG116909-ENG107391	LIN activity-LIN 1	active
    ENG116909-ENG107392	LIN activity-LIN 2	not coded/not installed
    ENG116909-ENG114948	LIN activity-LIN 3	active
    ENG116909-ENG114949	LIN activity-LIN 4	not coded/not installed
    ENG116909-ENG114950	LIN activity-LIN 5	not coded/not installed
    ENG116909-ENG114951	LIN activity-LIN 6	not coded/not installed
    ENG116793	Monitor 1	00 00 00 00 00 00 00 00
    ENG116802	Monitor 10	00 00 00 00 00 00 00 00
    ENG116794	Monitor 2	00 00 00 00 00 00 00 00
    ENG116795	Monitor 3	00 00 00 00 00 00 00 00
    ENG116796	Monitor 4	00 00 00 00 00 00 00 00
    ENG116797	Monitor 5	00 00 00 00 00 00 00 00
    ENG116798	Monitor 6	00 00 00 00 00 00 00 00
    ENG116799	Monitor 7	00 00 00 00 00 00 00 00
    ENG116800	Monitor 8	00 00 00 00 00 00 00 00
    ENG116801	Monitor 9	00 00 00 00 00 00 00 00
    ENG128380	Parametermonitor_0	82 14 01 01 A0 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 00 00 00 00 00 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 0C 02 1E 64 05 B4 1E 00 00 00 00 00 0A 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116806	Parametermonitor_1	00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG130145	Parametermonitor_10	40 01 3C D0 00 0B 64 46 00 00 00 02 00 0C 45 64 40 01 3C E0 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 40 01 3E D8 40 01 3E B8 00 00 00 00 00 05 F9 AC 40 01 3C E0 00 0B 63 8A 40 01 3C 28 00 0C 42 30 40 00 A0 14 00 00 00 00 00 00 00 00 00 0C 44 74 40 01 3D D8 00 0C 48 E8 00 00 00 00 00 00 00 02 4B E1 FE 44 40 00 7A EC 40 01 3C 28 00 00 00 00 00 00 00 02 00 00 00 01 40 00 AE BC 40 00 AF 1C FF F4 80 08 00 00 00 00 00 0C 44 80 40 01 3C E0 00 00 00 01 40 01 06 40 40 01 06 60 40 00 D0 B2 00 00 00 00 00 00 00 00 40 00 D0 98 40 00 D0 B0 40 01 1C 09 40 01 3D 70 00 00 11 0A 40 01 3D 30 00 0B 61 AA 00 00 00 03 00 06 51 4C 00 00 90 00 00 05 F9 AC 00 00 00 00 88 21 21 C0 00 05 FA 88 00 00 00 00 00 00 11 0A 00 00 00 10 00 00 01 03 00 00 00 03
    ENG116807	Parametermonitor_2	0F 05 0A 00 16 00 00 14 28 05 00 14 32 5A 32 0A 1E 12 03 00 0A 01 1E 5A 0F 3C 3C 05 0A 02 0A 78 00 FA 01 1C 14 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 14 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 18 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 00 32 3C 03 32 00 32 3C 03 00 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 46 00 00 1E 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116808-ENG115827	Parametermonitor_3-parameter_monitor_3_climatic	FF 02 32 00 5A FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 5A 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 0A 28 0F 1E 06 1E 0A 0B 0A 01 64 64 03 0A 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116808-ENG115828	Parametermonitor_3-parameter_monitor_3_wiper	0A 00 00 19 19 00 03 06 19 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116809	Parametermonitor_4	04 04 14 1E 00 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 06 00 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116810	Parametermonitor_5	0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 55 00 03 09 01 0F 00 00 00 00 00 00 05 0F 96 00 00 30 03 0B 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116811	Parametermonitor_6	00 46 32 FA 3C 00 32 32 05 01 3C 00 08 05 01 00 05 00 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116911	Parametermonitor_7	00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116812	Parametermonitor_FF	00 00 05 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG126653	Personalized_Account_Key_History	0
    ENG126652-MAS03692	Personalized_key__Setting-Key 1	1
    ENG126652-MAS03693	Personalized_key__Setting-Key 2	1
    ENG126652-MAS03694	Personalized_key__Setting-Key 3	1
    ENG126652-MAS03695	Personalized_key__Setting-Key 4	1
    ENG126652-MAS03696	Personalized_key__Setting-Key 5	1
    ENG126652-MAS03697	Personalized_key__Setting-Key 6	1
    ENG126652-MAS03698	Personalized_key__Setting-Key 7	1
    ENG126654	Personalized_Signals	0
    ENG116792-ENG115817	Power up history-Funktionsanforderung	10
    ENG130589-ENG130618	Remotestart_Monitor-Double_remote_start_activations	0
    ENG130589-ENG130615	Remotestart_Monitor-Klemme_15_Zaehler	0
    ENG130589-ENG130616	Remotestart_Monitor-Remote_start_activations	0
    ENG130589-ENG130617	Remotestart_Monitor-Remote_start_directly_followed_by_driving_cycle	0
    ENG124897-ENG124955	Resetcounter_EMW-3.letzte Resetursache	8
    ENG124897-ENG124956	Resetcounter_EMW-4.letzte Resetursach	0
    ENG124897-ENG115805	Resetcounter_EMW-Anzahl Resets	7
    ENG124897-ENG114872	Resetcounter_EMW-last cause of reset	0
    ENG124897-ENG124954	Resetcounter_EMW-vorletzte Resetursache	0
    ENG116790-MAS00711	Supply voltage history-Odometer reading	18	 km
    ENG116790-ENG115814	Supply voltage history-highest voltage ever measured	14.9	 V
    ENG116790-ENG115815	Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung	14.3	 V
    ENG116790-ENG115816	Supply voltage history-voltage measurement: intern	14.3	 V
    ENG116791	Temperatures	8	 °C
    ENG116907-IDE00020	Zusaetzliche Umgebungsdaten-Terminal 15 status	On
    ENG116907-IDE01716	Zusaetzliche Umgebungsdaten-Terminal 50 status	OFF
    ENG116907-IDE02515	Zusaetzliche Umgebungsdaten-Low beam	not activated
    ENG116907-IDE07956	Zusaetzliche Umgebungsdaten-redundant signal line	infinite
    ENG116907-MAS00063	Zusaetzliche Umgebungsdaten-OFF	operated
    ENG116907-MAS01957	Zusaetzliche Umgebungsdaten-Outside air temperature	8.5	 °C
    ENG116907-MAS02462	Zusaetzliche Umgebungsdaten-Automatic high beam assist	not activated
    ENG116907-MAS02788	Zusaetzliche Umgebungsdaten-CAN	On
    ENG116907-MAS03835	Zusaetzliche Umgebungsdaten-Parking light	not activated
    ENG116907-MAS04121	Zusaetzliche Umgebungsdaten-Voltage	14.3	 V
    ENG116907-MAS06466	Zusaetzliche Umgebungsdaten-Parking light left	not activated
    ENG116907-MAS06467	Zusaetzliche Umgebungsdaten-Parking light right	not activated
    ENG116907-ENG124952	Zusaetzliche Umgebungsdaten-last_wakeup	gueltiges Funktelegramm
    ENG116907-ENG115838	Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN)	OFF
    ENG116907-ENG115837	Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW)	OFF
    Elapsed Time: 01:08
    adpmap-09-5Q0-937-087-AA.CSV
    ;Wednesday	11	January	2017	20:02:38:08929
    ;VCDS Version: Release 17.1.1 (x64)  Data version: 20170106 DS267.0
    IDE00001-ENG99061-Production mode-Access control	not active
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active
    IDE00001-ENG112304-Production mode-Heckwischer	not active
    IDE00001-ENG98647-Production mode-Interior lighting	not active
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active
    IDE00002-Transport mode	active
    IDE00820-Activating and deactivating all development messages	not active
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
    IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition	not active
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	0 ms
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	0 ms
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	0 ms
    IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen	not active
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	0
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
    IDE01550-Service position	170.49 °
    IDE02152-Characteristics in production mode	2000 ms
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	kurz
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
    IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active
    IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
    IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active
    IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	0 s
    IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	0.0 s
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80%
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80%
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80%
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.75 °
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.00 %/s
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.00 km/h
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.00 °C
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.00 °C
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.00 °C
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 °
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.00 km/h
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
    IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken	active
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte
    IDE04923-ENG115774-Turn signal control-Komfortblinken	active
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	3
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	MFG
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	not active
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus	active
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	not active
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	automatic
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	46400 lx
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	12 lx
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 s
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
    IDE04927-IDE01446-Window heater-Running time of heated front window	240 s
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C
    IDE04927-ENG126845-Window heater-FSH Automatik	active
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	active
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
    IDE05142-ENG116621-Access control-automatisches Entriegeln	active
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active
    IDE05142-ENG116706-Access control-Autounlock NAR	active
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
    IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern	not active
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	not active
    IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung	not active
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
    IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung	not active
    IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion	not active
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
    IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster	0.00 s
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
    IDE05142-ENG115755-Access control-Notschließfunktion	active
    IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung	not active
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden	Always
    IDE05142-ENG115758-Access control-Valet Parking	not active
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe	not active
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
    IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum	Freigabe_Softtouch
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Einzeltuerentriegelung
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
    IDE05143-MAS02985-Writing parameter-Value	130
    IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
    IDE05144-Read parameter address	FE 00 00
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10	37
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11	41
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12	38
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13	42
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18	8
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19	18
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2	48
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20	12
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21	22
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26	0
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27	0
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3	4C
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8	35
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9	3F
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	minimize
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	minimize
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	minimize
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	minimize
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	minimize
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	minimize
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	minimize
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	minimize
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10	127
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11	127
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12	100
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13	100
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16	0
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17	0
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18	100
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19	100
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23	25
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24	25
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25	127
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26	0
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27	127
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28	100
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29	100
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30	100
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31	0
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32	0
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33	0
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4	127
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5	127
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6	127
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7	127
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8	127
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9	127
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2	0
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20	0
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21	0
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23	0
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24	0
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3	0
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4	0
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5	0
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2	26
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20	25
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21	25
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3	26
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4	127
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5	127
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	1E
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	1F
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	22
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	23
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	0
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	16
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	18
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	39
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3A
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	0
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	47
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	2
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	0
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	0
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	26
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	27
    IDE05145-ENG115873-Light configuration-Lasttyp 0	12 - Blinkleuchten
    IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten
    IDE05145-ENG116062-Light configuration-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
    IDE05145-ENG116081-Light configuration-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
    IDE05145-ENG116100-Light configuration-Lasttyp 12	10 - allgemeine Scheinwerfer
    IDE05145-ENG116119-Light configuration-Lasttyp 13	10 - allgemeine Scheinwerfer
    IDE05145-ENG116138-Light configuration-Lasttyp 14	not active
    IDE05145-ENG116157-Light configuration-Lasttyp 15	not active
    IDE05145-ENG116176-Light configuration-Lasttyp 16	not active
    IDE05145-ENG116195-Light configuration-Lasttyp 17	not active
    IDE05145-ENG116214-Light configuration-Lasttyp 18	12 - Blinkleuchten
    IDE05145-ENG116233-Light configuration-Lasttyp 19	12 - Blinkleuchten
    IDE05145-ENG115910-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
    IDE05145-ENG116252-Light configuration-Lasttyp 20	13 - Bremsleuchten
    IDE05145-ENG116271-Light configuration-Lasttyp 21	13 - Bremsleuchten
    IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte
    IDE05145-ENG116309-Light configuration-Lasttyp 23	9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG116328-Light configuration-Lasttyp 24	9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG116347-Light configuration-Lasttyp 25	43 - allgemeine LED
    IDE05145-ENG116366-Light configuration-Lasttyp 26	not active
    IDE05145-ENG116385-Light configuration-Lasttyp 27	36 - LED Kleinleistung
    IDE05145-ENG116404-Light configuration-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG116423-Light configuration-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG115929-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
    IDE05145-ENG116442-Light configuration-Lasttyp 30	36 - LED Kleinleistung
    IDE05145-ENG116461-Light configuration-Lasttyp 31	not active
    IDE05145-ENG116480-Light configuration-Lasttyp 32	not active
    IDE05145-ENG116499-Light configuration-Lasttyp 33	not active
    IDE05145-ENG116518-Light configuration-Lasttyp 34	not active
    IDE05145-ENG115948-Light configuration-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG115967-Light configuration-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG115986-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
    IDE05145-ENG116005-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
    IDE05145-ENG116024-Light configuration-Lasttyp 8	36 - LED Kleinleistung
    IDE05145-ENG116043-Light configuration-Lasttyp 9	36 - LED Kleinleistung
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	Always
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	Always
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	Always
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	Always
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	Always
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	Always
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	13
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	14
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	18
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	19
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	0
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	0
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	2
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	4
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	20
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	8
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	8
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	0
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	8
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	20
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	43
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	0
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	0
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	0
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	8
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	8
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	15
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	15
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	24
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	24
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	2
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	4
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	15
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	15
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	9
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	10
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	3
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	5
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	6
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	3
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	5
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	0
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	0
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	7
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	6
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	7
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	0
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	0
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	0
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	0
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	0
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	0
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	0
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	0
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	8
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	8
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	8
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	8
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	8
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	8
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	9
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	9
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3	10
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5	10
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	34.00 °C
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	34.00 °C
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	50.00 °C
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	49.00 °C
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	50.00 °C
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	49.00 °C
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%
    IDE06425-Roller test bench mode: functional	not active
    IDE06507-MAS13125-Button in center console-Funktion Taster 1	Start-stop
    IDE06507-MAS13129-Button in center console-Funktion Taster 2	Laderaumschließung
    IDE06507-MAS13132-Button in center console-Funktion Taster 3	Driving program
    IDE06507-MAS13135-Button in center console-Funktion Taster 4	Steering wheel heater
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
    IDE07356-Position during interval mode	31.49 °
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit
    IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit
    IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit
    IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer	Faktor fuer x5 Minuten
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min
    IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit	6 s
    IDE08542-IDE02021-Access control 2-Comfort closing	active
    IDE08542-IDE02022-Access control 2-Comfort opening	not active
    IDE08542-ENG128459-Access control 2-easycloselight_aktiv	not active
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	not active
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	not active
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	not active
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by convenience operation via remote control key
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	not active
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	active
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active
    IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	not active
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	not active
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	active
    IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	Via ZV-Absicherung Light
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	active
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	active
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	not active
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	not active
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	not active
    IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung	not active
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	not active
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	2000 ms
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	not active
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	not active
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken	not active
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	0
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	0
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	0
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1	225
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2	225
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3	225
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1	225
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2	225
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3	225
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1	225
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2	225
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3	225
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active
    IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI	not active
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed
    IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%
    IDE10298-Alternating park position 1	7.49 °
    IDE10299-Alternating park position 2	29.49 °
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	64
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	64
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	14
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	64
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	64
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	64
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	64
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	3C
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%
    IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	0 ms
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0 s
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0 s
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0 s
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0 s
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0 s
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0 s
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0 s
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0 s
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	20 s
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0 s
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0 s
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	5 s
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0 s
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0 s
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0 s
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0 s
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0 s
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0 s
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0 s
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0 s
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0 s
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0 s
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0 s
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0 s
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0 s
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0 s
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0 s
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0 s
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0 s
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0 s
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0 s
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0 s
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0 s
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0 s
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0 s
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0 s
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0 s
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0 s
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0 s
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0 s
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0 s
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0 s
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0
    IDE11714-ENG02360-Ambientelicht Farbliste-Blauwert Farbe 10	E1
    IDE11714-ENG02342-Ambientelicht Farbliste-Blauwert Farbe 4	E1
    IDE11714-ENG02345-Ambientelicht Farbliste-Blauwert Farbe 5	E1
    IDE11714-ENG02348-Ambientelicht Farbliste-Blauwert Farbe 6	E1
    IDE11714-ENG02351-Ambientelicht Farbliste-Blauwert Farbe 7	E1
    IDE11714-ENG02354-Ambientelicht Farbliste-Blauwert Farbe 8	E1
    IDE11714-ENG02357-Ambientelicht Farbliste-Blauwert Farbe 9	E1
    IDE11714-ENG02359-Ambientelicht Farbliste-Gruenwert Farbe 10	E1
    IDE11714-ENG02341-Ambientelicht Farbliste-Gruenwert Farbe 4	E1
    IDE11714-ENG02344-Ambientelicht Farbliste-Gruenwert Farbe 5	E1
    IDE11714-ENG02347-Ambientelicht Farbliste-Gruenwert Farbe 6	E1
    IDE11714-ENG02350-Ambientelicht Farbliste-Gruenwert Farbe 7	E1
    IDE11714-ENG02353-Ambientelicht Farbliste-Gruenwert Farbe 8	E1
    IDE11714-ENG02356-Ambientelicht Farbliste-Gruenwert Farbe 9	E1
    IDE11714-ENG02358-Ambientelicht Farbliste-Rotwert Farbe 10	E1
    IDE11714-ENG02340-Ambientelicht Farbliste-Rotwert Farbe 4	E1
    IDE11714-ENG02343-Ambientelicht Farbliste-Rotwert Farbe 5	E1
    IDE11714-ENG02346-Ambientelicht Farbliste-Rotwert Farbe 6	E1
    IDE11714-ENG02349-Ambientelicht Farbliste-Rotwert Farbe 7	E1
    IDE11714-ENG02352-Ambientelicht Farbliste-Rotwert Farbe 8	E1
    IDE11714-ENG02355-Ambientelicht Farbliste-Rotwert Farbe 9	E1
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active
    MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement	not active
    MAS05055-lower turn position	31.49 °
    MAS05056-upper turn position	170.49 °
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active
    MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1	0 s
    MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3	0.000 ms
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active
    MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	60 lx
    MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	110 lx
    MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle	1000 lx
    MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO	30 lx
    MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten	60 lx
    MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten	110 lx
    MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	80
    MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell	100 lx
    MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung	4500 mV
    MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke	300 lx
    MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung	2000 mV
    MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke	0 lx
    MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung	2
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed
    ENG126647-ENG98399-debug_light_function-Activation	0
    ENG126647-ENG101417-debug_light_function-Adresse	0
    ENG126647-ENG126820-debug_light_function-Bitmask	0
    ENG126647-ENG126821-debug_light_function-Divisor	0
    ENG126647-ENG98827-debug_light_function-Offset	0
    ENG126647-ENG126822-debug_light_function-Polaritaet	0
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe	0
    ENG99457-ENG117394-Head area heater-blower_speed	1
    ENG99457-ENG98971-Head area heater-Temperature	-2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	127
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	minimize
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	Brake light
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	Blinken links Dunkelphase
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	minimize
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	Brake light
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	Blinken rechts Dunkelphase
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	25
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	39
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	12
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	13 - Bremsleuchten
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	25
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3A
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	22
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	13 - Bremsleuchten
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	25
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	9 - allgemeine Glühlampe 27W: auch H15
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	25
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	9 - allgemeine Glühlampe 27W: auch H15
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	0
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	0
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	not active
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	not active
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	47
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	36 - LED Kleinleistung
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	minimize
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	26
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Blinken links aktiv (beide Phasen)
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	minimize
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	26
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Blinken rechts aktiv (beide Phasen)
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Parking light right
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen)
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen)
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	26
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	35
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	36 - LED Kleinleistung
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	27
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3F
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	36 - LED Kleinleistung
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Parking light right
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	active
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	active
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	active
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	active
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	active
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	active
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
    ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar	active
    ENG98831-ENG02329-Personalisierung-Anzahl_Benutzerkonten	4
    ENG98831-ENG02330-Personalisierung-Automatische_ Schluesselzuordnung	active
    ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active
    ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv	active
    ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active
    ENG98831-ENG02331-Personalisierung-PSO_FSG_Setup2_Bit_0	active
    ENG98831-ENG02332-Personalisierung-PSO_FSG_Setup2_Bit_1	active
    ENG98831-ENG02333-Personalisierung-PSO_FSG_Setup2_Bit_2	active
    ENG98831-ENG02334-Personalisierung-PSO_FSG_Setup2_Bit_3	active
    ENG98831-ENG02335-Personalisierung-PSO_FSG_Setup2_Bit_4	active
    ENG98831-ENG02336-Personalisierung-PSO_FSG_Setup2_Bit_5	active
    ENG98831-ENG02337-Personalisierung-PSO_FSG_Setup2_Bit_6	active
    ENG98831-ENG02338-Personalisierung-PSO_FSG_Setup2_Bit_7	active
    ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active
    ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	active
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
    Elapsed Time: 01:37
  9. #8
    United States
    10-Park/Steer Assist
    blockmap-10-5Q0-919-298-K.CSV
    ;SW:5Q0-919-298-K   HW:5Q0-919-298 ---  Park/Steer Assist
    ;Component:PARKHILFE PLA H12 0054	 Coding:0031163011
    ;EV_EPHVA2CAU3700000	3021	EV_EPHVA2CAU3700000_003_VW37.rod
    ;Wednesday	11	January	2017	20:04:33:08929
    ;VCDS Version: Release 17.1.1 (x64)  Data version: 20170106 DS267.0
    ;VCID: C7D158B97E8F9579D4-8092
    Group	Description	Actual
    IDE00018	Voltage terminal 15	14.4	 V
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00322	Status of basic setting	not active
    IDE00323	Security Access: Number of invalid keys	0
    IDE00325	Diagnostic mode	VW - diagnostic mode
    IDE00767	No. of unscheduled ECU resets	1
    IDE00957-MAS01632	Resulting distance of front sensors-Status	infinite
    IDE00958-MAS01632	Resulting distance of rear sensors-Status	infinite
    IDE00973	Outside air temperature	-46	 °
    IDE00974	Outside air temperature internally calculated	-46.5	 °
    IDE01122-MAS00988	Parking aid input signal-Reverse gear	No
    IDE01122-MAS01374	Parking aid input signal-Trailer	not installed
    IDE01123-MAS01632	Distance of left rear park assist sensor-Status	infinite
    IDE01124-MAS01632	Distance of left rear center park assist sensors-Status	infinite
    IDE01125-MAS01632	Distance of right rear center park assist sensors-Status	infinite
    IDE01126-MAS01632	Distance of right rear park assist sensor-Status	infinite
    IDE01127-MAS01632	Distance sensor for left front park assist-Status	infinite
    IDE01128-MAS01632	Distance sensor for left front center park assist-Status	infinite
    IDE01129-MAS01632	Distance sensor for right front center park assist-Status	infinite
    IDE01130-MAS01632	Distance of right front park assist sensors-Status	infinite
    IDE01131-MAS01632	Oscillating time of left rear park assist sensors-Status	ERROR
    IDE01132-MAS01632	Oscillating time of left rear center park assist sensors-Status	ERROR
    IDE01133-MAS01632	Oscillating time of right rear center park assist sensors-Status	ERROR
    IDE01134-MAS01632	Oscillating time of right rear park assist sensors-Status	ERROR
    IDE01135-MAS01632	Decay time for left front park assist sensor-Status	ERROR
    IDE01136-MAS01632	Decay time for left front center park assist sensor-Status	ERROR
    IDE01137-MAS01632	Decay time for right front center park assist sensors-Status	ERROR
    IDE01138-MAS01632	Decay time for right front park assist sensors-Status	ERROR
    IDE01162-MAS01426	Factory setting for park assist volume/frequencies-Speaker volume for rear park assist	Stage 6
    IDE01162-MAS01427	Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist	Stage 4
    IDE01162-MAS01428	Factory setting for park assist volume/frequencies-Speaker volume for front park assist	Stage 4
    IDE01162-MAS01429	Factory setting for park assist volume/frequencies-Speaker frequency for front park assist	Stage 6
    IDE01163	Sound output for park assist in selector lever position P	OFF
    IDE01164	Park assist button	not activated
    IDE01165	Park assist activation tone	On
    IDE01166	Supply voltage for park assist sensor	13.2	 V
    IDE01169	Audio reduction request	Yes
    IDE01171	Convertible factory setting offset for volume level 1	not installed
    IDE01172	Factory setting for increment for convertible volume levels	not installed
    IDE01173	Audio reduction factory setting	Yes
    IDE01175-MAS01632	Distance of side left rear parking aid sensors-Status	infinite
    IDE01176-MAS01632	Distance of side right rear parking aid sensors-Status	infinite
    IDE01177-MAS01632	Oscillating time of side left rear parking aid sensors-Status	1.008	 ms
    IDE01178-MAS01632	Oscillating time of side right rear parking aid sensors-Status	1.072	 ms
    IDE01185-MAS01632	Distance sensor for left front parking aid-Status	infinite
    IDE01186-MAS01632	Distance sensor for right front parking aid-Status	infinite
    IDE01187-MAS01632	Decay time for side left front parking aid sensor-Status	1.088	 ms
    IDE01188-MAS01632	Decay time for right side front parking aid sensor-Status	1.04	 ms
    IDE01411-IDE11215	Personalization 1 for park assist-Automatic Activation	not activated
    IDE01411-IDE11217	Personalization 1 for park assist-Show parking space	not activated
    IDE01411-MAS01426	Personalization 1 for park assist-Speaker volume for rear park assist	Stage 6
    IDE01411-MAS01427	Personalization 1 for park assist-Speaker frequency for rear park assist	Stage 4
    IDE01411-MAS01428	Personalization 1 for park assist-Speaker volume for front park assist	Stage 4
    IDE01411-MAS01429	Personalization 1 for park assist-Speaker frequency for front park assist	Stage 6
    IDE01411-MAS06193	Personalization 1 for park assist-Profile 1	active
    IDE01411-MAS12843	Personalization 1 for park assist-Maneuvering brake function	not activated
    IDE01412-IDE11215	Personalization 2 for park assist-Automatic Activation	not activated
    IDE01412-IDE11217	Personalization 2 for park assist-Show parking space	not activated
    IDE01412-MAS01426	Personalization 2 for park assist-Speaker volume for rear park assist	Stage 6
    IDE01412-MAS01427	Personalization 2 for park assist-Speaker frequency for rear park assist	Stage 4
    IDE01412-MAS01428	Personalization 2 for park assist-Speaker volume for front park assist	Stage 4
    IDE01412-MAS01429	Personalization 2 for park assist-Speaker frequency for front park assist	Stage 6
    IDE01412-MAS06194	Personalization 2 for park assist-Profile 2	not active
    IDE01412-MAS12843	Personalization 2 for park assist-Maneuvering brake function	not activated
    IDE01413-IDE11215	Personalization 3 for park assist-Automatic Activation	not activated
    IDE01413-IDE11217	Personalization 3 for park assist-Show parking space	not activated
    IDE01413-MAS01426	Personalization 3 for park assist-Speaker volume for rear park assist	Stage 6
    IDE01413-MAS01427	Personalization 3 for park assist-Speaker frequency for rear park assist	Stage 4
    IDE01413-MAS01428	Personalization 3 for park assist-Speaker volume for front park assist	Stage 4
    IDE01413-MAS01429	Personalization 3 for park assist-Speaker frequency for front park assist	Stage 6
    IDE01413-MAS06195	Personalization 3 for park assist-Profile 3	not active
    IDE01413-MAS12843	Personalization 3 for park assist-Maneuvering brake function	not activated
    IDE01414-IDE11215	Personalization 4 for park assist-Automatic Activation	not activated
    IDE01414-IDE11217	Personalization 4 for park assist-Show parking space	not activated
    IDE01414-MAS01426	Personalization 4 for park assist-Speaker volume for rear park assist	Stage 6
    IDE01414-MAS01427	Personalization 4 for park assist-Speaker frequency for rear park assist	Stage 4
    IDE01414-MAS01428	Personalization 4 for park assist-Speaker volume for front park assist	Stage 4
    IDE01414-MAS01429	Personalization 4 for park assist-Speaker frequency for front park assist	Stage 6
    IDE01414-MAS06196	Personalization 4 for park assist-Profile 4	not active
    IDE01414-MAS12843	Personalization 4 for park assist-Maneuvering brake function	not activated
    IDE01588	Driving direction	forwards
    IDE01632	System condition of park assist	not active
    IDE01633	Cause of park assist switching off	Terminal 15 off
    IDE01943	Turn signal	not activated
    IDE01965	Parallel parking assistance button	not activated
    IDE01966	Cause of parallel park assist switching off	No shut-off requirement
    IDE01967	Parking side	Right
    IDE02486	Data logger triggering	not active
    IDE03683	Request power steering boost	No
    IDE03684	Vehicle stopped	Yes
    IDE03782	Switch-off speed for parking assist	15	 km/h
    IDE03783	Switch-on speed for parallel parking assist	37	 km/h
    IDE03784	Temporary function limitation due to environmental influences	No
    MAS00464	Standard - ambient data 1	2000
    MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	13
    MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	490	 km
    MAS00464	Standard - ambient data 1	1
    MAS00464	Standard - ambient data 1	11
    MAS00464	Standard - ambient data 1	5
    MAS00464	Standard - ambient data 1	13
    MAS01426	Speaker volume for rear park assist	Stage 6
    MAS01427	Speaker frequency for rear park assist	Stage 4
    MAS01428	Speaker volume for front park assist	Stage 4
    MAS01429	Speaker frequency for front park assist	Stage 6
    ENG113995	Dimming_Signal_Terminal_58xd_pdc_pla	0	 %
    ENG113996-ENG113979	Function_PLA-BS_alignement_BF	No
    ENG113996-ENG113982	Function_PLA-BS_alignement_driver	No
    ENG113996-ENG113978	Function_PLA-BS_identified_BF	No
    ENG113996-ENG113980	Function_PLA-BS_identified_BF_old	No
    ENG113996-ENG113981	Function_PLA-BS_identified_Driver	No
    ENG113996-ENG113983	Function_PLA-BS_identified_Driver_old	No
    ENG113996-ENG106720	Function_PLA-Fzgx_Max	0	 cm
    ENG113996-ENG106721	Function_PLA-Fzgy_Max	0.7	 cm
    ENG113996-ENG113974	Function_PLA-L_Rangier_Min	219.8	 cm
    ENG113996-ENG107571	Function_PLA-Manual_Steering_Moment	0	 Nm
    ENG113996-ENG108155	Function_PLA-Parking_Aid_Senders_Cutoff_Time	30	 s
    ENG113996-ENG113977	Function_PLA-PL_Depth_BF	0	 cm
    ENG113996-ENG113986	Function_PLA-PL_depth_BF_old	0	 cm
    ENG113996-ENG113988	Function_PLA-PL_Depth_Driver	0	 cm
    ENG113996-ENG113990	Function_PLA-PL_Depth_Driver_Old	0	 cm
    ENG113996-ENG113976	Function_PLA-PL_Length_BF	0	 cm
    ENG113996-ENG113985	Function_PLA-PL_Length_BF_old	0	 cm
    ENG113996-ENG113987	Function_PLA-PL_Length_Driver	0	 cm
    ENG113996-ENG113989	Function_PLA-PL_Length_Driver_Old	0	 cm
    ENG113996-ENG108329	Function_PLA-Psi0_BF	0	 °
    ENG113996-ENG108330	Function_PLA-Psi0_BF_Alt	0	 °
    ENG113996-ENG108331	Function_PLA-Psi0_Fahrer	0	 °
    ENG113996-ENG108332	Function_PLA-Psi0_Fahrer_Alt	0	 °
    ENG113996-ENG109009	Function_PLA-Speed_Limit_Power_Steering	0	 km/h
    ENG113996-ENG109117	Function_PLA-Steering_Angle_Actual_Value	-0.2	 °
    ENG113996-ENG109118	Function_PLA-Steering_Angle_Nominal_Value	-0.1	 °
    ENG113996-ENG113975	Function_PLA-T_Rangier_Min	0	 cm
    ENG113996-ENG113984	Function_PLA-Visual_Indication	No
    ENG113996-ENG110295	Function_PLA-X0_BF	0	 cm
    ENG113996-ENG110296	Function_PLA-X0_BF_Alt	0	 cm
    ENG113996-ENG110297	Function_PLA-X0_Fahrer	0	 cm
    ENG113996-ENG110298	Function_PLA-X0_Fahrer_Alt	0	 cm
    ENG113996-ENG110299	Function_PLA-Xa_BF_Alt	-0.1	 cm
    ENG113996-ENG110300	Function_PLA-Xa_Fahrer_Alt	-0.1	 cm
    ENG113996-ENG110301	Function_PLA-Y0_BF	0	 cm
    ENG113996-ENG110302	Function_PLA-Y0_BF_Alt	0	 cm
    ENG113996-ENG110303	Function_PLA-Y0_Fahrer	0	 cm
    ENG113996-ENG110304	Function_PLA-Y0_Fahrer_Alt	0	 cm
    ENG113996-ENG113973	Function_PLA-Ya_Alt	-0.1	 cm
    ENG113996-ENG110306	Function_PLA-Ya_Fahrer_Alt	-0.1	 cm
    Elapsed Time: 00:13
    adpmap-10-5Q0-919-298-K.CSV
    ;Wednesday	11	January	2017	20:04:47:08929
    IDE00001-Production mode	Deactivating
    IDE00845-Wheel circ.	1965 mm
    IDE01165-Park assist activation tone	On
    IDE01169-Audio reduction request	On
    IDE02328-Distance to curb	15 cm
    IDE02329-Allowance for vehicle fittings (width)	0 cm
    IDE02332-Deactivate production mode	0
    IDE02333-Allowance for vehicle fittings (length)	0 cm
    IDE03782-Switch-off speed for parking assist	15 km/h
    IDE03783-Switch-on speed for parallel parking assist	37 km/h
    MAS01426-Speaker volume for rear park assist	Stage 6
    MAS01427-Speaker frequency for rear park assist	Stage 4
    MAS01428-Speaker volume for front park assist	Stage 4
    MAS01429-Speaker frequency for front park assist	Stage 6
    Elapsed Time: 00:07
  10. #9
    United States
    13-Auto Dist. Reg
    Ignore due to ASAM data
    blockmap-13-5Q0-907-572-G.CSV
    ;SW:5Q0-907-572-G   HW:5Q0-907-572-G ---  Auto Dist. Reg
    ;Component:ACC BOSCH MQB H10 0571	 Coding:350000C141FFC428949C8045000016
    ;EV_ACCBOSCHVW416	1005
    ;Wednesday	11	January	2017	20:05:09:08929
    ;VCID: BB3934493247C19940-80EE
    Elapsed Time: 00:00
    adpmap-13-5Q0-907-572-G.CSV
    ;Wednesday	11	January	2017	20:05:10:08929
    Elapsed Time: 00:00
    Edit: Latest Data Version 20170413 (Beta 17.2.6):
    ;EV_ACCBOSCHVW416	1005	EV_ACCBOSCHVW416_001_VW37.rod
    ;Wednesday	3	May	2017	19:11:06:59530
    ;VCDS Version: Beta 17.4.2 (x64)  Data version: 20170413 DS270.4
    ;VCID: BB367674328DAA9F9A-80EE
    IDE00002	Transport mode	OFF
    IDE00018	Voltage terminal 15	12.8	 V
    IDE00102	Control Module temperature	31	 °C
    IDE00322	Status of basic setting	was not yet started
    IDE01285	Counter of component protection malfunctions	00 00
    IDE01788	Heated lens control signal	0	 %
    IDE01794	ACC operating lever signal	00000000 10101000
    IDE01985-MAS06854	FAZIT identification test sum-Version	81
    IDE01985-MAS06855	FAZIT identification test sum-Test sum	1D 0D 48 3F
    IDE03008-MAS12557	Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked	not active
    IDE03008-MAS12559	Stop process prevented-Driving ahead Vehicles start moving: ACC passive	not active
    IDE03008-MAS12560	Stop process prevented-Driving ahead Vehicles are starting: ACC off	not active
    IDE03010-MAS12557	Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked	0
    IDE03010-MAS12559	Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive	0
    IDE03010-MAS12560	Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off	0
    IDE03011-MAS12557	Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked	0
    IDE03011-MAS12558	Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible	0
    IDE03011-MAS12559	Number of requested start processes-Driving ahead Vehicles start moving: ACC passive	0
    IDE03011-MAS12560	Number of requested start processes-Driving ahead Vehicles are starting: ACC off	0
    IDE03203	Alignment instructions	Set mirror in posit 1 and start measurement
    IDE04329-IDE04332	Status of all SWaP functions-Release code for a SWaP function	Not available
    IDE04329-IDE05814	Status of all SWaP functions-Individualization characteristic	invalid
    IDE04329-IDE06260	Status of all SWaP functions-ID number	10 00 31 00
    IDE04329-MAS01340	Status of all SWaP functions-Functions	Available
    IDE04329-MAS01903	Status of all SWaP functions-Configuration	OK
    IDE04329-MAS02934	Status of all SWaP functions-Prerequisites met	Condition not met
    IDE04329-MAS05616	Status of all SWaP functions-Cancellation	Yes
    IDE04329-MAS05617	Status of all SWaP functions-Authentication	Condition not met
    IDE04332-ENG117770	Release code for a SWaP function-fsc	Not available
    IDE04334-MAS02643	Public key for SWaP function-Key	C9 37 8A 27 80 D8 2C 8D 73 BC DC 20 E7 9C 7C D0 9F 3A 9E EE 13 AB 53 8E 4B E5 96 5C 6B C2 9E CC 51 13 00 E5 1A 81 6F 28 6B 3D 28 B8 9B D9 80 37 13 BB 54 73 69 96 5B 5F D2 C8 3A 8E F0 69 43 40 DE 8E B4 F4 B1 6A A1 C3 06 F3 BC F8 5E 8B D2 E1 04 7E 13 4A 72 CF 2C 3B 52 8E 85 73 72 45 4A 66 7A 01 9A D2 C6 E1 DD 6E BD C7 AF 95 04 BB BA C2 E5 47 D4 58 9C 8C 57 D9 99 B2 E2 AC B3 81 23 6F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
    IDE04805-IDE02955	Driving profile selection-System status	Not available
    IDE04805-MAS01447	Driving profile selection-Act.val.	2
    IDE04805-MAS01448	Driving profile selection-Specified value	2
    IDE05814	Individualization characteristic	BB 0E 99 94 2C
    IDE06307-MAS00106	Stop prevention history data-Year	2000
    IDE06307-MAS00107	Stop prevention history data-Month	0
    IDE06307-MAS00108	Stop prevention history data-Day	0
    IDE06307-MAS00109	Stop prevention history data-Hours	0
    IDE06307-MAS00110	Stop prevention history data-Minutes	0
    IDE06307-MAS00111	Stop prevention history data-Seconds	0
    IDE06308-MAS00106	Start request history data-Year	2000
    IDE06308-MAS00107	Start request history data-Month	0
    IDE06308-MAS00108	Start request history data-Day	0
    IDE06308-MAS00109	Start request history data-Hours	0
    IDE06308-MAS00110	Start request history data-Minutes	0
    IDE06308-MAS00111	Start request history data-Seconds	0
    IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
    IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
    IDE07145-MAS06772	Component protection properties-Component protection generation	2
    IDE07145-MAS06773	Component protection properties-KS Standard software main version nummer	2
    IDE07145-MAS06774	Component protection properties-KS Standard software secondary version number	0
    IDE07145-MAS06775	Component protection properties-KS Standard software correct number	1
    IDE07145-MAS06776	Component protection properties-Komponent protection role	KS Slave
    IDE07145-MAS06781	Component protection properties-Secure Hardware Extension	Not Used
    IDE07145-MAS06782	Component protection properties-Master ECU Key	not administered by component protection
    IDE07145-MAS06785	Component protection properties-GFA key	used
    IDE07145-MAS06786	Component protection properties-SSW RND Generation	Not Used
    IDE07145-MAS06787	Component protection properties-Indiv Key Generation	used
    IDE07145-MAS06788	Component protection properties-SHE Secure Boot	Not Used
    IDE07145-MAS06789	Component protection properties-KSB Config Status 2	0
    IDE07145-MAS07187	Component protection properties-KS Data version	1
    IDE08768	Mirror deviation: horizontal	0.389	 °
    IDE08769	Mirror deviation: vertical	-0.609	 °
    IDE08770-MAS01466	Adjustment of screw top left-Direction of rotation	none
    IDE08770-MAS02559	Adjustment of screw top left-Rotations	0
    IDE08771-MAS01466	Adjustment of screw top right-Direction of rotation	none
    IDE08771-MAS02559	Adjustment of screw top right-Rotations	0
    IDE08772-MAS01466	Adjustment of screw bottom left-Direction of rotation	none
    IDE08772-MAS02559	Adjustment of screw bottom left-Rotations	0
    IDE08773-MAS01466	Adjustment of screw bottom right-Direction of rotation	none
    IDE08773-MAS02559	Adjustment of screw bottom right-Rotations	0
    IDE08936	Misalignment angle: horiz	-1.044	 °
    IDE08937	Misalignment angle: horiz: fast algorithm	-1.03	 °
    IDE09380-IDE01784	Performed adjustment-Misalignment angle	0	 °
    IDE09380-MAS00106	Performed adjustment-Year	16
    IDE09380-MAS00107	Performed adjustment-Month	10
    IDE09380-MAS00108	Performed adjustment-Day	24
    IDE09380-MAS08804	Performed adjustment-Horizontal offset angle	-1.03	 °
    IDE09380-MAS08805	Performed adjustment-Vertical offset angle	1.7	 °
    IDE09906	Vertical deadjustment	0.989	 °
    ENG107409	Longitudinal_acceleration_vehicle_reference	0	 m/s²
    ENG107860	Number_of_ANB_partial_bracings	0
    ENG107861	Number_of_ANB_target_bracings	1
    ENG107862	Number_of_ANB-CM	0
    ENG00926	Number_of_boost_function_active	0
    ENG00927	Number_of_deactivation_ASR_active	0
    ENG00928	Number_of_deactivation_ESC_active	0
    ENG00913	Number_of_Emergency_steer_assist	0
    ENG00915	Number_of_fully_developed_deceleration_1	0
    ENG00916	Number_of_fully_developed_deceleration_2	0
    ENG06681	Number_of_mainwarnings	0
    ENG03998	number_of_prewarnings	4
    ENG107928	Operating_time_ACC	66	 min
    ENG00919	Operating_time_ACC_active_driving_programm_auto	66	 min
    ENG00918	Operating_time_ACC_active_driving_programm_comfort	0	 min
    ENG00917	Operating_time_ACC_active_driving_programm_dynamic	0	 min
    ENG00920	Operating_time_ACC_active_driving_programm_efficiency	0	 min
    ENG00921	Operating_time_ACC_active_timegap_1	15	 min
    ENG00922	Operating_time_ACC_active_timegap_2	0	 min
    ENG00923	Operating_time_ACC_active_timegap_3	40	 min
    ENG00924	Operating_time_ACC_active_timegap_4	11	 min
    ENG00925	Operating_time_ACC_active_timegap_5	0	 min
    ENG00929	Operating_time_ACC_active_v-delta_0	66	 min
    ENG00932	Operating_time_ACC_active_v-delta_large	0	 min
    ENG00931	Operating_time_ACC_active_v-delta_medium	0	 min
    ENG00930	Operating_time_ACC_active_v-delta_small	0	 min
    ENG00933	Operating_time_STA_active	0	 min
    ENG00934	Operating_time_STA_off_activation_possible	0	 min
    ENG00935	Status_ACC_System	ACC_Off_MainSwitch_Off
    ENG08760	Sw_version_supplier	1037603449;PF_R28.3.0_VW.MQB_A1_GPevo14.0571_I3.3;0;Compiled by BBT2BP on Thu Apr  7 17:50:31 2016$!
    ENG109878	Velocity_vehicle_reference	0	 m/s
    Elapsed Time: 00:08
    ;Wednesday	3	May	2017	19:11:14:59530
    IDE00001-Production mode	Deactivating 	3
    IDE00820-ENG00957-Activating and deactivating all development messages-Development Message ECU specific	OFF 	1
    IDE00820-ENG102778-Activating and deactivating all development messages-development message S100	OFF 	1
    IDE00820-ENG101934-Activating and deactivating all development messages-development message S101	OFF 	1
    IDE00820-ENG103391-Activating and deactivating all development messages-development message S102	OFF 	1
    IDE00820-ENG00958-Activating and deactivating all development messages-XCP on FlexRay	OFF 	1
    IDE01795-Heated lens	On 	1
    IDE01949-Distance basic setting option	OFF 	1
    IDE02332-Deactivate production mode	0	3
    IDE03642-Presentation mode	not active 	1
    IDE04330-Transfer of release code for a SWaP function	0	1
    IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
    IDE05815-Sail function	Deactivating 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE08935-Expanded restart function	On 	1
    IDE09564-Distance change via speed adjustment	On 	1
    IDE09565-Prioritized target object display	OFF 	1
    IDE10280-Constant delay after transfer request	Yes 	1
    Elapsed Time: 00:05
  11. #10
    United States
    15-Airbags
    blockmap-15-5Q0-959-655-J.CSV
    ;SW:5Q0-959-655-J   HW:5Q0-959-655-J ---  Airbags
    ;Component:AirbagVW20    010 0830	 Coding:8CCCFC00000000005000001AC24800000065
    ;EV_AirbaVW20SMEVW37X	2144	EV_AirbaVW20SMEVW37X_VW37.rod
    ;Wednesday	11	January	2017	20:06:09:08929
    IDE00821	Safety belt switch 2nd row driver side	not installed
    IDE00822	Safety belt switch 2nd row frt.passenger side	not installed
    IDE00823	Safety belt switch 2nd row center	not installed
    IDE00824	Driver side 3rd row seat belt switch	not installed
    IDE00825	Passenger side 3rd row seat belt switch	not installed
    IDE00919	Driver side airbag igniter ohm value	3	 Ohm
    IDE00956	Occupation status: frt.passenger seat	Empty or child or child safety seat
    IDE01100	Passenger side airbag igniter ohm value	2.3	 Ohm
    IDE01101	Passenger side airbag igniter 2 ohm value	2.2	 Ohm
    IDE01102	Driver's side airbag igniter ohm value	2.6	 Ohm
    IDE01103	Passenger side side airbag igniter ohm value	2.5	 Ohm
    IDE01104	driver side rear airbag igniter ohm value	no measured value present
    IDE01105	Ft. pass.side rear airbag igniter ohm value	no measured value present
    IDE01106	Driver side head curtain airbag igniter ohm value	2.4	 Ohm
    IDE01107	Frt.pass. side head curtain airbag igniter ohm value	2.4	 Ohm
    IDE01108	Driver side knee airbag igniter ohm value	no measured value present
    IDE01109	Frt.pass. side knee airbag igniter ohm value	no measured value present
    IDE01110	Driver side belt tensioner igniter ohm value	2.4	 Ohm
    IDE01111	Frt.pass. side belt tensioner igniter ohm value	2.3	 Ohm
    IDE01112	Driver side belt tensioner igniter 2 ohm value	2.3	 Ohm
    IDE01113	Frt.pass. side belt tensioner igniter 2 ohm value	2.3	 Ohm
    IDE01114	Driver side belt force limiter igniter ohm value	2.4	 Ohm
    IDE01115	side belt force limiter igniter ohm value	2.4	 Ohm
    IDE01116	driver side rear belt tensioner igniter ohm value	no measured value present
    IDE01117	Passenger side rear belt tensioner igniter ohm value	no measured value present
    IDE01119	Battery open circuit igniter ohm value	no measured value present
    IDE01193	Driver belt tensioner ohm value	too Low
    IDE01194	Frt.pass. belt tensioner ohm value	too Low
    IDE01195	Seat occupied recognition ohm value	no measured value present
    IDE01197	Key switch contact 1 ohm value	too High
    IDE01198	Key switch contact 2 ohm value	too High
    IDE01200	Driver seat position sensor current value	6.4	 mA
    IDE01201	Frt.pass. seat position sensor current value	6.2	 mA
    IDE01205	Safety belt switch 2nd row driver side ohm value	no measured value present
    IDE01206	Safety belt switch 2nd row frt.pass. side ohm value	no measured value present
    IDE01207	Safety belt switch center 2nd row ohm value	no measured value present
    IDE01208	Seat belt switch 3rd row driver side ohm value	no measured value present
    IDE01209	Seat belt switch 3rd row frt.pass. side ohm value	no measured value present
    IDE01271	Number of rollover bar deployments	0
    IDE01555	Number of frontal crashes	0
    IDE01556	Number of side crashes driver side	0
    IDE01557	Number of side crashes frt.pass. side	0
    IDE01558	Number of rear crashes	0
    IDE01559	Number of rollover crashes	0
    IDE02246	Number of activations of pedestrian protection	0
    IDE02852	Igniter for battery interrupt: high voltage battery	not installed
    IDE02853	Igniter for batt. interrupt: high volt. batt. ohm value	no measured value present
    IDE03870	Seat occupied recognition malfunction status	0
    IDE06959-ENG99945	Seat occupant detection: diagnosis signal-Measured value	31	 %
    IDE06960-ENG99945	Seat occupant detection: msmt. signal-Measured value	0	 %
    IDE06961-ENG99945	Seat occupant detection: ref. signal-Measured value	0.5	 %
    MAS00001	Driver airbag igniter	correct
    MAS00003	Passenger airbag igniter	correct
    MAS00004	Front passenger airbag igniter 2	correct
    MAS00005	Driver thorax airbag igniter	correct
    MAS00006	Front passenger side airbag igniter	correct
    MAS00007	Driver side rear thorax airbag igniter	cannot be measured currently
    MAS00008	Passenger side rear thorax airbag igniter	cannot be measured currently
    MAS00009	Driver head curtain airbag igniter	correct
    MAS00010	Front passenger head curtain airbag igniter	correct
    MAS00011	Driver knee airbag igniter	cannot be measured currently
    MAS00012	Front passenger knee airbag igniter	cannot be measured currently
    MAS00013	Driver side seat belt tension igniter	correct
    MAS00014	Front passenger side seat belt tension igniter	correct
    MAS00015	Driver seat belt tensioner igniter 2	correct
    MAS00016	Front passenger side seat belt tensioner igniter 2	correct
    MAS00017	Driver side belt force limiter igniter	correct
    MAS00018	Front passenger side belt force limiter igniter	correct
    MAS00019	Driver side rear safety belt tension igniter	cannot be measured currently
    MAS00020	Passenger side rear safety belt tension igniter	cannot be measured currently
    MAS00022	Igniter for battery interrupt	cannot be measured currently
    MAS00025	Driver seat belt switch	not connected
    MAS00026	Front passenger side safety belt switch	not connected
    MAS00030	Seat occupied recognition	Not assigned
    MAS00031	Airbag deactivation status	OFF
    MAS00032	Key switch terminal 1	not installed
    MAS00033	Key switch terminal 2	not installed
    MAS00035	Seat position sensor: driver side	Rear
    MAS00036	Seat position sensor: front passenger side	Rear
    MAS00037	Calibration status	0
    MAS00044-ENG101458	Supply voltage: Terminal 15-Measured Value Voltage	14.4	 V
    MAS01634-ENG102113	Supply voltage-Measured values	correct
    Elapsed Time: 00:10
    adpmap-15-5Q0-959-655-J.CSV
    ;Wednesday	11	January	2017	20:06:20:08929
    IDE06314-Calibration data: pre-crash	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MAS00975-IDE01755-Airbag adaptations-Rollover protection system	not defined
    MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery	not defined
    MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter	activated
    MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter	activated
    MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter	activated
    MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter	activated
    MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter	not defined
    MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter	not defined
    MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter	activated
    MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter	activated
    MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter	not defined
    MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter	not defined
    MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter	activated
    MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter	activated
    MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter	not defined
    MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter	not defined
    MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt	not defined
    MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition	not defined
    MAS00975-MAS00079-Airbag adaptations-Key switch	Airbag deactivation key switch not parameterized
    MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood	not defined
    Elapsed Time: 00:01
