Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Hex V2 does not register +
  1. #21
    Quote Originally Posted by hex.v2.belgium View Post
    Modelyear 2017
    Will try the scan now...
    EDIT: 'No Response from Controller!'
    Can you test your interface on some other car please? I understand it is midnight in Belgium now, so that might not be possible today.
    In the meanwhile, please try some other addresses, like 01-Engine, or other common ones, like 03-ABS or 08-HVAC just to see if anything talks at all?
    You do have the ignition on, right? I can tell you did earlier when you made the screen shots, but just double-checking now..
  2. #22
    Jan 2017
    Belgium
    VIN: WVWZZZ3CZHE0*****
    Did a scan with the motor running, same result: 'No Response from Controller!'
    Don't have another VW/Audi directly at hand. Perhaps this weekend I could try to find someone, but not on short term...
  3. #23
    Jan 2017
    Belgium
    I did a scan also on 01-Engine, 03-ABS and 08-HVAC
    Same result: 'No Response from Controller!'
    And yes, ignition is on, even tried with the motor running...
  4. Likes Uwe liked this post
  5. #24
    Jan 2017
    Belgium
    PS. I do have such a low cost OBD2 Mini ELM327 Bluetooth adapter and that one is able to get data from my car with eg. Torque
  6. Likes Dana liked this post
  7. #25
    You have another e-mail.
    Have you tried generic OBD-II in VCDS?
  8. #26
    Jan 2017
    Belgium
    Hi Uwe,
    the feature code you provided made the Gateway accessible, and I was able to do an autoscan, but have some errors...
    (See mail you received yesterday + autoscan data in this post)
    (The speakers of my car did 'crack' a bit during the autoscan, don't know if this is normal behavior, but wanted to mention.)
    Did not try the generic OBD-II in VCDS, as I even don't know how to enable this.
    Questions:
    1. I assume it is now safe to use the adapter and do some adaptations, or do you first still want to do some further investigations?
    2. The malfunctions in my autoscan are due to the Hex V2 / VCDS not being fully compatible yet with my car or real faults?
    Regards,
    Nick
    Thursday,12,January,2017,07:48:29:43967
    VCDS Version: 17.1.0.0 (x64)  HEX-V2 CB: 0.4334.4
    Data version: 20170106 DS267.0
    VIN: WVWZZZ3CZHE0******   License Plate:
    Mileage: 4264km-2649mi   Repair Order:
    Chassis Type: 3C (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F 6C
              6D A5 BB BC CA
    VIN: WVWZZZ3CZHE0*****   Mileage: 4264km-2649miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H23 1990
       Revision: B5H23---
       Coding: 011D003203641D083000
       Shop #: WSC 05311 115 00302
       ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
       ROD: EV_ECM20TDI01104L906026ET_002.rod
       VCID: 005A8A810A89B8F72FF-8054
       Part No SW: 0D9 300 042 M    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5013
       Revision: 06454104    Serial number: TFK01609151507
       Shop #: WSC 05311 115 00073
       ROD: EV_TCMDQ250021.rod
       VCID: 2310E50DBB5F43EF12D-8076
       Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
       Component: ESC           H62 0736
       Revision: 00000000    Serial number: 62726000002035
       Coding: 0FEC6A8F34280B734777060641CA49F0562CD0E2608292713862F0F8C20202
       Shop #: WSC 00015 115 08193
       ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
       VCID: 7BA0FD6D636FDB2F7AD-802E
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0419208479
       Coding: 0F2020070F
       VCID: 3C223E7126E11C17337-8068
       Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
       Component: GEB.F.Heckoef  H17 0812
       Serial number: ;8061479
    14222592 - Databus
                        Reset counter: 119
                        Mileage: 3293 km
                        Date: 2016.12.29
                        Time: 14:00:12
       Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
       Revision: 00001K10
       Coding: 12020124202410011115500E0010182A
       ROD: EV_ACClimaBHBVW37X_004_VW48.rod
       VCID: 76B6EC59584D8647053-8022
              P1719 00 [008] - -
                        Reset counter: 128
                        Mileage: 3430 km
                        Date: 2017.01.01
                        Time: 01:22:48
                        Voltage terminal 30: 14.4 V
                        Auxiliary heater: in stages-Act.value: 2
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0222
       Revision: --------    Serial number: 8658300916000O
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017.rod
       VCID: 015C8F850183B1FF201-8054
       Component: WWS    160908  042 0607
       Serial number:         160919141844
       Component: RLHS  042 0105
       Serial number: S6Y16M10D06H13M04S28
       Coding: 00A8EE
       Light switch:
       Serial number: 30 06 2016  10000744
    589592 - Databus
              U1201 00 [008] - No Communications
                        Reset counter: 124
                        Mileage: 2085 km
                        Date: 2016.12.11
                        Time: 12:46:37
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0161
       Serial number: 000305183616266
       Coding: 0271161851
       ASAM Dataset: EV_EPHVA2CAU3700000 009017
       ROD: EV_EPHVA2CAU3700000_009.rod
       VCID: 0D44A3B54DDBE59F549-8058
    Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
       Component: ACC BOSCH MQB H04 0194
       Coding: 320067C359FFC428949C8045
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 343216510EB1D457FB7-8060
    1538 - Sensor for Automatic Distance Control
                        Reset counter: 135
                        Mileage: 3869 km
                        Date: 2017.01.07
                        Time: 16:46:39
                        Control Module temperature: 20 °C
                        Voltage terminal 15: 13.0 V
                        Velocity_vehicle_reference: 23.48 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
    1542 - Sensor for Automatic Distance Control
                        Reset counter: 135
                        Mileage: 3869 km
                        Date: 2017.01.07
                        Time: 16:46:40
                        Velocity_vehicle_reference: 23.28 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
       Serial number: 20091641350260
       ROD: EV_DRCONTITEMIC.rod
       VCID: 382A226112D93037D7F-806C
       Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003STPKQNTV%
       Coding: 88CCC000000000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F58097D7777C70F565-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 001 709 16
       Serial number: 3576U000000ABC3DDD1+
       Subsystem 2 - Part No SW: -----------    HW: 454 001 709 16
       Serial number: 3586U00000048A884D1M
       Subsystem 3 - Part No SW: -----------    HW: 454 801 409 16
       Serial number: 3516R7606DD0C000000D
       Subsystem 4 - Part No SW: -----------    HW: 454 801 409 16
       Serial number: 3526R2D03DD0C000000D
       Subsystem 5 - Part No SW: -----------    HW: 454 802 609 16
       Serial number: 3556V11FABD0C000000R
       Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0225
       Revision: FF034034    Serial number: 20161002500321
       Coding: 0410
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CA2FE716661DC17737-8028
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Reset counter: 143
                        Mileage: 7 km
                        Date: 2016.11.10
                        Time: 15:55:58
                        Ubat 30 Voltage: 12.10 V
                        Internal error state: 0
                        LIN_Temp: 254
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 251
                        Slope: 134
                        kp: 13
                        OUT: 50
                        Temperatur Statisch: 30
                        Tsoll Wert 0: 39.00 °C
                        Tsoll Wert 1: 43.00 °C
                        Tsoll Wert 2: 47.00 °C
       Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
       Component: KOMBI         404 2153
       Coding: 07A409183F84000801886B011001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 280AF221C279A0B747F-807C
       Revision: --------    Serial number: 30091610521617
       Coding: 030300045F087300FB00025A9C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013.rod
       Serial number: 29160001867260056381
       Coding: 2FFFFF
       Serial number: 75410803001610011156
       Analog clock:
       Component: Analoguhr  209 2002
       Serial number: 16000232837009
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BCDF453123A17FD01-8024
       Serial number: 300916EIT32753
       Coding: 003F1B20D000020000001000
       VCID: 43D0458D5B1F63EF72D-8016
       Coding: 8307
       Shop #: WSC 00015 115 00302
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2E38692CD5222721B-806E
       Serial number: 140916EID33177
       Coding: 003F1120DE00020000001000
       VCID: 42DE408944056AE779B-8016
       Component: AFS-ECU       H01 0120
       Coding: 039203004F210200
       Shop #: WSC 05311 000 08193
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       VCID: 3FD8497D37F7070F165-806A
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 042     HW: 3G0 035 042
       Component: MU-H-LN-EU    H51 0814
       Serial number: A749J0GB003186
       Coding: 02840201FF00000051110001000808101F0100E4012000009E
       VCID: 58EA82E1B299D03737F-800C
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL04BPP
       Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
       Component: ECE 2017  --- 0157
       Component: Gracenote2---  --- 1013
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 0184020162002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
       VCID: 77A8E15D5F47FF4F1E5-8022
    Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
       Part No SW: 5Q0 959 107 C    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0260
       Revision: --------    Serial number: 30936315800000
       Coding: 0228
       ASAM Dataset: EV_DeckLidCONTIAU736 001013
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 05101611K10580
       Coding: 000408020000040100262344C050A10010000E300040
       ROD: EV_MFKBoschMQBB.rod
    Address BB: Door Rear Drv (J388)       Labels: None
       Serial number: 031016EJ205557
       Coding: 000E11200100020000001000
       VCID: 45D45B95552B5DDF5C9-8010
    Address BC: Door Rear Pass (J389)       Labels: None
       Serial number: 031016EJ14280B
    Address CA: Sunroof (J245)       Labels: None
       Component: SAD_STG_1     013 0005
       Coding: 008040748202
       ROD: EV_SunRoofCONTIAU736_005.rod
       VCID: 3D2433753DFB151F049-8068
    End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
  9. Likes Dana liked this post
  10. #27
    There's an [OBD-II] button on the very first screen. But it doesn't matter now since you've got access to the car for real.
    Questions:
    I think so. This was a licensing issue of some sort. Should have no effect on functionality now that it's sorted. I apologize for the inconvenience.
    The fact that there are some fault codes stored in your car is corroborated by the gateway's Installation List at the top of the scan. In other words, the Gateway is aware of these faults.
    The only one that really bothers me is the Temperature Sensor for Heated Steering Wheel. Any problems with the steering wheel heat?
  11. Likes Dana, hex.v2.belgium liked this post
  12. #28
    Jan 2017
    Belgium
    Hi Uwe,
    good to hear my interface should be fully functional right now, so will start to look into some adaptations later tonight.
    (So the cracks I hear from my speakers is considered normal?)
    For the Heated Steering Wheel, do not seems to have any problems?
    How should I read this fault, it has occurred 254 times and the first/last time at 7km?
    Reset counter: 143
    Mileage: 7 km
    Date: 2016.11.10
    Time: 15:55:58
    LIN_Temp: 254
    Isense: 0
    Max.Leistung: 110
    PWM: 0
    Offset: 251
    Slope: 134
    kp: 13
    OUT: 50
  13. #29
    When exactly do they occur? If it's while VCDS is accessing the infotainment modules, I wouldn't let it bother me.
    First time at 7 km, 245 times since then. 245 may be as high as that counter goes.
    I'm a bit torn on this fault code. If it was my car, I would probably clear it and see if/when it comes back. If it keeps coming back, I would complain at next service visit to dealer that that the heated steering sometimes doesn't work (even if you don't really have any problems with it). That should get them to do a scan and find the fault code for themselves, and then address the cause. It's generally better to complain about a functional problem and let them find the fault code than it is to complain about fault codes that you found that don't cause a functional problem.
  14. Likes Dana, D-Dub liked this post
  15. #30
    Jan 2017
    Belgium
    Thanks Uwe,
    everything seems to work now, so will start a new post in 'Tweaks' for the adaptations I'm doing on the Passat B8.
    Will indeed talk to the dealer the next time I'm there for service, counter is now already at 256, so seems a recurring fault.
    Steering heater does work, so I'm not bothered for now...
    Thanks for the assistance, much appreciated.
    One happy customer here!
  16. Likes Uwe, Eric, Dana liked this post
