Results 11 to 20 of 30
Thread: Hex V2 does not register +
    Can you give us screen-shots please, both of [Options] -> [Test] with it plugged into a car, and the About screen?
    And please confirm that you don't get any error messages when starting VCDS itself.
  2. #12
    Jan 2017
    Belgium
    No error at starting VCDS...
    Removed pic as my personal details were shown and registration issue solved.
  3. #13
    Jan 2017
    Belgium
    Should I try to re-install VCDS and see what that gives?
  4. #14
    I think we understand the problem now.
    Interface is registered to you, but VCDS isn't seeing the license correctly....
    Please try the previous version. You can grab it here.
  5. #15
    Jan 2017
    Belgium
    Tried with 16.8.4
    Same issue persists
    Test says Ready
    About says Unregistered/Unauthorized
    Not able to autoscan: 'Function not supported by Gateway'
  6. #16
    Check your e-mail please (the one you used to register your interface).
  7. #17
    Jan 2017
    Belgium
    Installed the file, license was updated, now says Valid/Activated (16.8.4)
    Still not able to do an AutoScan though: 'Function not supported by Gateway'
  8. #18
    Quote Originally Posted by hex.v2.belgium View Post
    What model year B8?
    Can you try to access 19-CAN Gateway directly please, and grab us the Advanced ID info?
  9. #19
    Jan 2017
    Belgium
    Modelyear 2017
    Will try the scan now...
    EDIT: 'No Response from Controller!'
  10. Likes Dana liked this post
  11. #20
    United States
    Would you mind posting the VIN and do you have another VW/Audi family vehicle handy that uses CAN for diagnostics that you can test on? We can work with you to correct the VIN limits if you need to add a car you wouldn't normally scan after we figure out what the issue is.
    I would also try to scan it while running at idle to rule out a voltage issue.
