Thursday,12,January,2017,07:48:29:43967
VCDS Version: 17.1.0.0 (x64) HEX-V2 CB: 0.4334.4
Data version: 20170106 DS267.0
VIN: WVWZZZ3CZHE0****** License Plate:
Mileage: 4264km-2649mi Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F 6C
6D A5 BB BC CA
VIN: WVWZZZ3CZHE0***** Mileage: 4264km-2649miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRLB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2.0l TDI H23 1990
Revision: B5H23---
Coding: 011D003203641D083000
Shop #: WSC 05311 115 00302
ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
ROD: EV_ECM20TDI01104L906026ET_002.rod
VCID: 005A8A810A89B8F72FF-8054
Part No SW: 0D9 300 042 M HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5013
Revision: 06454104 Serial number: TFK01609151507
Shop #: WSC 05311 115 00073
ROD: EV_TCMDQ250021.rod
VCID: 2310E50DBB5F43EF12D-8076
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62726000002035
Coding: 0FEC6A8F34280B734777060641CA49F0562CD0E2608292713862F0F8C20202
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
VCID: 7BA0FD6D636FDB2F7AD-802E
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0419208479
Coding: 0F2020070F
VCID: 3C223E7126E11C17337-8068
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8061479
14222592 - Databus
Reset counter: 119
Mileage: 3293 km
Date: 2016.12.29
Time: 14:00:12
Part No SW: 5G0 907 044 BP HW: 5G0 907 044 BP
Component: Climatronic H04 1601
Revision: 00001K10
Coding: 12020124202410011115500E0010182A
ROD: EV_ACClimaBHBVW37X_004_VW48.rod
VCID: 76B6EC59584D8647053-8022
Air quality sensor:
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
Reset counter: 128
Mileage: 3430 km
Date: 2017.01.01
Time: 01:22:48
Voltage terminal 30: 14.4 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.value: 2
Auxiliary heater: in stages-Specified value for control: 3
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BH HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 032 0222
Revision: -------- Serial number: 8658300916000O
ROD: EV_BCMBOSCH_017.rod
VCID: 015C8F850183B1FF201-8054
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160908 042 0607
Serial number: 160919141844
Component: RLHS 042 0105
Serial number: S6Y16M10D06H13M04S28
Coding: 00A8EE
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 30 06 2016 10000744
589592 - Databus
U1201 00 [008] - No Communications
Fault Frequency: 6
Reset counter: 124
Mileage: 2085 km
Date: 2016.12.11
Time: 12:46:37
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616266
Coding: 0271161851
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000_009.rod
VCID: 0D44A3B54DDBE59F549-8058
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 320067C359FFC428949C8045
ROD: EV_ACCBOSCHVW48X.rod
VCID: 343216510EB1D457FB7-8060
1538 - Sensor for Automatic Distance Control
Reset counter: 135
Mileage: 3869 km
Date: 2017.01.07
Time: 16:46:39
Control Module temperature: 20 °C
Voltage terminal 15: 13.0 V
Velocity_vehicle_reference: 23.48 m/s
Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
1542 - Sensor for Automatic Distance Control
Reset counter: 135
Mileage: 3869 km
Date: 2017.01.07
Time: 16:46:40
Velocity_vehicle_reference: 23.28 m/s
Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 20091641350260
ROD: EV_DRCONTITEMIC.rod
VCID: 382A226112D93037D7F-806C
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPKQNTV%
Coding: 88CCC000000000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F58097D7777C70F565-802A
Subsystem 1 - Part No SW: ----------- HW: 454 001 709 16
Serial number: 3576U000000ABC3DDD1+
Subsystem 2 - Part No SW: ----------- HW: 454 001 709 16
Serial number: 3586U00000048A884D1M
Subsystem 3 - Part No SW: ----------- HW: 454 801 409 16
Serial number: 3516R7606DD0C000000D
Subsystem 4 - Part No SW: ----------- HW: 454 801 409 16
Serial number: 3526R2D03DD0C000000D
Subsystem 5 - Part No SW: ----------- HW: 454 802 609 16
Serial number: 3556V11FABD0C000000R
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 EJ HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0225
Revision: FF034034 Serial number: 20161002500321
Coding: 0410
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA2FE716661DC17737-8028
291104 - Temperature Sensor for Heated Steering Wheel
B1455 01 [008] - Electrical Failure
Reset counter: 143
Mileage: 7 km
Date: 2016.11.10
Time: 15:55:58
Ubat 30 Voltage: 12.10 V
Internal error state: 0
LIN_Temp: 254
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 251
Slope: 134
kp: 13
OUT: 50
Temperatur Statisch: 30
Tsoll Wert 0: 39.00 °C
Tsoll Wert 1: 43.00 °C
Tsoll Wert 2: 47.00 °C
Part No SW: 3G0 920 791 B HW: 3G0 920 791 B
Component: KOMBI 404 2153
Coding: 07A409183F84000801886B011001000000000000
VCID: 280AF221C279A0B747F-807C
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 30091610521617
Coding: 030300045F087300FB00025A9C0F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
Serial number: 29160001867260056381
Coding: 2FFFFF
Serial number: 75410803001610011156
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Component: ELV-MQBB H05 0032
Serial number: 16000232837009
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BCDF453123A17FD01-8024
Component: TSG FS 020 0041
Serial number: 300916EIT32753
Coding: 003F1B20D000020000001000
VCID: 43D0458D5B1F63EF72D-8016
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8307
Shop #: WSC 00015 115 00302
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2E38692CD5222721B-806E
Component: TSG BFS 020 0041
Serial number: 140916EID33177
Coding: 003F1120DE00020000001000
VCID: 42DE408944056AE779B-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 039203004F210200
Shop #: WSC 05311 000 08193
VCID: 3FD8497D37F7070F165-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 042 HW: 3G0 035 042
Component: MU-H-LN-EU H51 0814
Serial number: A749J0GB003186
Coding: 02840201FF00000051110001000808101F0100E4012000009E
VCID: 58EA82E1B299D03737F-800C
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL04BPP
Subsystem 2 - Part No SW: V03 959 800 QQ HW: -----------
Component: ECE 2017 --- 0157
Component: Gracenote2--- --- 1013
Address 6C: Back-up Cam. (J772) Labels: 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 0184020162002017000040
ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
VCID: 77A8E15D5F47FF4F1E5-8022
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 5Q0 959 107 C HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0260
Revision: -------- Serial number: 30936315800000
Coding: 0228
ASAM Dataset: EV_DeckLidCONTIAU736 001013
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 05101611K10580
Coding: 000408020000040100262344C050A10010000E300040
ROD: EV_MFKBoschMQBB.rod
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 031016EJ205557
Coding: 000E11200100020000001000
VCID: 45D45B95552B5DDF5C9-8010
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 031016EJ14280B
Address CA: Sunroof (J245) Labels: None
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 008040748202
ROD: EV_SunRoofCONTIAU736_005.rod
VCID: 3D2433753DFB151F049-8068
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
