Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: How to code out/remove air bag control module
  1. #21
    United States
    Quote Originally Posted by 200tgreg View Post
    Can you please advise what this changes to as there is no pop up with info on?
    I wouldn't doubt NEtech had to dig, either in the factory repair manual ... or deep into a bag of tricks. Either way, he contributes regularly to the actual VCDS label files on an internal level and helps customers in forum frequently so I trust his suggestions and value his opinion. I would try his suggestion and if it doesn't help you can revert back.
  2. Likes Uwe liked this post
  3. #22
    Dec 2016
    Oh, no I didn't mean it to sound like I was doubting NEtech. I've made the change already but was just trying to work out what was meant to change, was it to do with airbag or traction control light (or both)? Couldn't see any change with faults etc hence the question
  4. Likes Dana liked this post
  5. #23
    Can you answer if somebody changed coding ?
    The coding does not look correct for that VIN, with the former engine (source partslink, etc.). That was the reason I asked.
    "It changes to" same ABS with BJX engine, which I have in an Autoscan and can look up at some data, for that ABS and engine.
    If there should be an pop up help for coding's, it probably would need a bigger area as your screen.
    Maybe it could remove DTC's in ABS.
    Maybe not helping, but no harm testing, try:
    • coding [19] with same coding.
    • In [01] save channel 00 in [Adaptation-10]
    • coding [01] with same coding.
    • Ignition of 10 minutes.
  6. Likes Uwe, 200tgreg, Dana liked this post
  7. #24
    Dec 2016
    I don't know to be honest. Quite possibly, as the ABS was changed.
    Thank you for the suggestion, have tried it but still getting the below;
    Wednesday,11,January,2017,22:44:31:10549
    VCDS Version: 17.1.0.0 (x64)
    Data version: 20170106 DS267.0
    VIN: TMBND46Y354216309   License Plate:
    Chassis Type: 6Y (6L - Seat Ibiza/Cordoba (2002 > 2009))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
    VIN: TMBND46Y354216309   Mileage: 149170km-92689miles
    Address 01: Engine        Labels: None
       Part No: 06A 906 032 QN
       Component: 1.8I R4/5VT         0020
       Coding: 11500
       Shop #: WSC 33278
       VCID: 7AFBC81D66F66C9181-5140
       VSSZZZ6LZ6R093968     SEZ7Z0E3245771
    18043 - Powertrain Data Bus
                P1635 - 35-00 - Missing Message from A/C Controller
    18017 - Crash Shut-Down Activated
                P1609 - 35-00 -
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ASR80.lbl
       Part No SW: 6Q0 907 379 AG    HW: 6Q0 907 379 AG
       Component: MABS 8.0 front  H04 0002
       Coding: 0002241
       Shop #: WSC 06403 785 00200
       VCID: 020BB0FD5E262451D9-5124
                        Reset counter: 194
                        Mileage: 149176 km
    18055 - Check Coding of ECUs on Powertrain Data Bus
                P1647 - 000 -
                        Reset counter: 194
                        Mileage: 149176 km
    Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 D
       Component: 0000 BN-SG.         1S34
       Coding: 16520
       Shop #: WSC 06402
       VCID: 3C770E052C4292A1D3-5140
    00969 - Fuse for Heated Rear Window (S41)
                37-00 - Faulty
    Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
       Part No: 6Y0 920 981 B
       Component: KOMBI+WEGFAHRSP VDO V02
       Coding: 00401
       Shop #: WSC 13765
       VCID: 3E73040D3A5E80B1FD-5140
       TMBND46Y354216309     SKZ7Z0D2602261
    01128 - Immobilizer Pickup Coil (D2)
                35-00 -  -
    01176 - Key
                07-00 - Signal too Low
       Part No: 6N0 909 901
       Component: 006A GATEWAY CAN    1S34
       Coding: 00010
       Shop #: WSC 12345
       VCID: 70EFEA35308A26C13F-5140
       Part No: 6Q0 423 156 M
       Component: LenkhilfeTRW        V210
       Coding: 00121
       Shop #: WSC 13765
       VCID: 397917112370A789C8-5140
    End-------------------------(Elapsed Time: 03:40)----------------------------
  8. #25
    Dec 2016
    Hi everyone,
    Was looking through some guides today and wanted to look at the steering angle (G85) sensor specification however when I go to [03] ABS then group 05 in measuring blocks I get the below;
    Sunday,15,January,2017,13:02:49:10549
    VCDS Version: 17.1.1.0 (x64)
       Coding: 11500
       Shop #: WSC 33278
       VCID: 7AFBC81D66F66C919B-5140
                P1609 - 35-00 -
       Coding: 0002241
       VCID: 020BB0FD5E262451C3-5140
                000 -  -  - Intermittent
                        Reset counter: 234
                        Mileage: 149176 km
                P1647 - 000 -
                        Reset counter: 194
                        Mileage: 149176 km
       Coding: 16520
       Shop #: WSC 06402
       VCID: 3C770E052C4292A1C9-5124
                37-00 - Faulty
       Coding: 00401
       Shop #: WSC 13765
       VCID: 3E73040D3A5E80B1E7-5124
                35-00 -  -
    01176 - Key
       Coding: 00010
       Shop #: WSC 12345
       VCID: 70EFEA35308A26C125-5140
       Coding: 00121
       Shop #: WSC 13765
       VCID: 397917112370A789D2-5140
    End-------------------------(Elapsed Time: 03:03)--------------------------
    Any ideas?
  9. #26
    The module you have there appears to be just an ABS with ASR, but no ESP? Is it the correct module for this car?
  10. Likes 200tgreg liked this post
  11. #27
    Dec 2016
    The module you have there appears to be just an ABS with ASR, but no ESP, so probably no steering angle sensor.
    Ah that would indeed make sense (Doh!). Thank you.
    So what else can I do at the moment? Other than work through the wiring to clear the airbag fault - what about this error: "18055 - Check Coding of ECUs on Powertrain Data Bus P1647"
    I do really appreciate all the help with this, thank you all!
  12. #28
    United States
    I do not have any additional suggestions but we received the Engine module control module maps. Thanks for sending those over!
    Internal Ref to: FS#1273
