Page 9 of 9 FirstFirst ... 789
Results 81 to 90 of 90
Thread: THE FOD FUN THREAD " GIVE BEFORE IT HURTS" !
  1. #81
    Verified VCDS User vreihen's Avatar
    Sep 2014
    The Land of OCC, NY, USA, Earth
    ...and apparently half-eaten chocolate bars.....
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #82
    LOL -- Jack is spreading the love, er, FOD...
    Next............Ok are you ready to play more FOD TDI enhancements?
    Good .....
    Let's add some weight to Harmonic Balancer, Pistons, and Flywheel.........!
    Now with the added TQ from follow through at acceleration & cruising speed........ install larger rims and tires to get a larger circumference.
  4. #83
  5. Likes vreihen liked this post
  6. #84
    No huh? ..........I guess we will have to agree to disagree on this one. /\
    Follow through is a powerful mechanism.......... my studies and testing say otherwise.
    Been doing this one since the Rupp and CR500 days and I can tell you it indeed does work to a degree depending on the goal.
  7. #85
    FOD.... FUN
    AC INOP....
    2001 AVH 2.0 Jetta radiator fans stay on after key switch terminal 15 engaged & stay on until battery dead or disconnected.
    When battery is disconnected & reconnected with key switch off, fans are now off or only stuck on consistently after key is now turned on.
    Recent history is AC CLUTCH WITH COMPRESSOR changed due to clutch and snout of compressor mechanically warn causing bearing tilt and mag coil to short to open circuit, additionally rear view mirror switch and brake light switch changed due to EPC light displayed & mirror switch was mechanically lobbed off & BATTERY recently changed as preventative maintenance.
    At time of a AC COMPRESSOR diagnosis, no fuses bad and power with ground are sufficient.
    Hypothesis why fan condition exists?
    What or how was FOD responsible?
  8. #86
    What no one has any proud moments...........?
  9. #87
    Aug 2016
    The Hague, NL
    Most of my FOD is self-introduced and I'd rather not confess too much...
  10. #88
    Well here is what I found when having to repair a regulator this week and found damaged lock unit.
    Hmmmmm I wonder if this groove someone cut had anything to do with the lock jam and window falling down?
    At least they used red tape.........
  11. Likes Uwe liked this post
  12. #89
    How come the forum doesn't have a menu like this or can it be updated or selected?
    https://forum.unity.com/threads/usin...operly.143875/
  13. #90
    Does it work?
    Nope the triple FOD signs went bye bye
