Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 90
Thread: THE FOD FUN THREAD " GIVE BEFORE IT HURTS" !
  1. #21
    No Artie not VSS.........and it isn't tuning.........
    People will shit when they finally hear this..........
  2. #22
    Come on guys think ............
    Hint ...........it has to do with friction reduction!
  3. #23
    Verified VCDS User vreihen's Avatar
    Sep 2014
    The Land of OCC, NY, USA, Earth
    Yeah, but who wants to trade off having to charge their battery daily, driving around with no AC, and/or removing the water pump and using the early Ford convection radiator system just to save a few drops of fuel and a couple spotted owls? Might as well leave the electric starter off and install a wrist-snapping hand crank.....
  4. Likes Uwe liked this post
  5. #24
    Sep 2014
    <===== Has been driving around for several weeks without a working AC system, and it isn't fun.....
  6. #25
    That is your fault Art, because as a friend you have full access to my shop to fix your truck yourself & you have a model sitting here I wanted you to have.
    There is no trade off to what I am about to release for information on this find!
  7. #26
    Sep 2014
    Oh, the humanity.....
  8. #27
    Second hint is that this part is internal and more than one exist.
    Any guesses?
  9. #28
    Sep 2014
    Having more than two crankshaft bearings is frivolous, and I suspect that there would still be enough compression to run with a piston ring removed from each cylinder. Both could reduce the parasitic losses significantly, at the expense of required extra maintenance and/or engine longevity.....
  10. #29
    No and that would not do what you speculate............
  11. #30
    Verified VCDS User Rembrant's Avatar
    Nov 2014
    Canada
    Any guesses?
    Must be something in the injection pump and/or injectors, or else you would have also included the PD engines.
    You also said VE engine equipped vehicles...which means the item(s) in question are not necessarily in the engine, or even under the hood for that matter.
    Camshaft caps?...lol, I dunno.
    I am still thinking and am anxiously awaiting the answer.
    I'm still skeptical and thinking the answer will sound like Nelson from the Simpsons saying "Ha ha"...lol.
    Late build 2006 White Jetta BRM 5spd. Mile eater.
  12. Likes Jack@European_Parts liked this post
