Results 1 to 6 of 6
Thread: VW Touran MY2005 G85 and limit stops adaption problem
Hybrid View
    Sep 2016
    Riga, Latvia
    This Touran went to me with no start condition. A lot of several faults codes were stored and mainly all engine related faults were because of damaged wiring loom in front part of engine compartment. Wires were repaired and faults are gone, engine starts and runs normally. Now one problem left - G85 and steering limit stops don't want to adapt. I have tried both procedures, described in Wiki (through address 03 and through 44), no results. Steering angle in MVB is not changing when turning steering wheel.
    I have out of ideas at the moment.
    First autoscan before any repairs:
    Friday,06,January,2017,10:52:45:32442
    VCDS Version: 16.8.4.2
    VIN: WVGZZZ1TZ5W120530   License Plate:
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
    VIN: WVGZZZ1TZ5W120530   Mileage: 333530km-207245miles
    08-Auto HVAC -- Status: Malfunction 1010
    44-Steering Assist -- Status: Malfunction 1010
    46-Central Conv. -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 03G-906-016-BKC.lbl
       Part No SW: 03G 906 016 HP    HW: 028 101 236 1
       Component: R4 1,9L EDC G000SG  7000
       Revision: 12345678    Serial number: VWZ7Z0D1240850
       Coding: 0000072
       Shop #: WSC 01324 785 00200
       VCID: 78FF82DF0BADF182F1-802C
    18080 - Coolant Fan Control 1
                P1672 - 000 - Open or Short to Ground - Intermittent
                        RPM: 798 /min
                        Torque: 44.0 Nm
                        Load: 0.0 %
                        Voltage: 14.29 V
                        Bin. Bits: 00001000
                        Temperature: 38.7°C
                        Duty Cycle: 9.6 %
    18359 - Radiator Fan 2 (V177)
                P1951 - 000 - Movement Restricted / Jammed - Intermittent
                        RPM: 1449 /min
                        Torque: 128.0 Nm
                        Load: 69.0 %
                        Voltage: 14.44 V
                        Bin. Bits: 00001000
                        Temperature: 39.6°C
                        Duty Cycle: 9.6 %
    16785 - EGR System
                P0401 - 000 - Insufficient Flow
                        RPM: 1680 /min
                        Torque: 66.0 Nm
                        Speed: 13.0 km/h
                        Load: 22.0 %
                        Duty Cycle: 14.7 %
                        Bin. Bits: 00001000
                        Mass Air / Rev.: 290.0 mg/str
                        Mass Air / Rev.: 605.0 mg/str
    16705 - Engine Speed Sensor (G28)
                P0321 - 000 - Implausible Signal - Intermittent
                        RPM: 1890 /min
                        Torque: 28.0 Nm
                        Speed: 41.0 km/h
                        Load: 12.2 %
                        Voltage: 14.52 V
                        Bin. Bits: 00001000
                        Idle Stabilization: 0.0°KW
                        RPM: 924 /min
    16725 - Camshaft Position Sensor (G40)
                P0341 - 000 - Implausible Signal
                        RPM: 1260 /min
                        Torque: 154.0 Nm
                        Load: 94.5 %
                        Voltage: 11.48 V
                        Bin. Bits: 00001100
                        (no units): 38.0
    Readiness: 1 2 0 0 0
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0021190
       VCID: 3A7B58D775212392C7-806E
       Part No: 1K0 820 047 EF
       Component: Climatic PQ35   084 0404
       VCID: 6CD7AE8F4FF54D2205-8038
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 00000001330612
       Coding: 00890F020004100000120C000000000000087B075C
       VCID: 397947DB7027288ACE-806C
       Subsystem 1 - Part No: 2K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW357  012  0402
       Coding: 00065493
    01049 - Supply Voltage Term 50
       Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
       Component: 02 AIRBAG VW62 0506 1500
       Revision: 09025000    Serial number: 0038BD0B31LS
       Coding: 0012338
       VCID: 35614BEB5C3FCCEA2A-8060
       Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
       Component: Lenksaulenmodul 021 0050
       Coding: 0000042
       Part No: 1T0 920 861 A
       Component: KOMBIINSTRUMENT VDD 0814
       Coding: 0003103
       Shop #: WSC 00867 461 89045
       VCID: 306F7AFFA35DE9C279-8064
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 P
       Component: Zuheizer        031 1312
       Revision:        A    Serial number: 09010046
       Coding: 0000011
       VCID: 326B70F7AD51DBD20F-8066
                        Reset counter: 30
                        Mileage: 508945 km
                        Time: 16:14:23
                        Reset counter: 69
                        Mileage: 463729 km
                        Time: 16:04:38
                        Reset counter: 30
                        Mileage: 508945 km
                        Time: 16:14:23
    00664 - Fuel gauge
                        Fault Frequency: 6
                        Reset counter: 0
                        Mileage: 462756 km
                        Time: 17:06:13
                        Reset counter: 30
                        Mileage: 509011 km
                        Time: 16:58:39
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 E    HW: 1K0 907 951
       Component: Gateway         H09 0110
       Revision: 09          Serial number: 2700104C190085
       Coding: 3D0F1340078002
       VCID: 2959979B8087980ABE-807C
                        Fault Status: 01101011
                        Reset counter: 58
                        Mileage: 314286 km
                        Time: 08:54:20
                        Reset counter: 69
                        Mileage: 332657 km
                        Time: 12:54:41
                        Reset counter: 69
                        Mileage: 332657 km
                        Time: 00:02:55
                        Fault Frequency: 7
                        Reset counter: 69
                        Mileage: 332657 km
                        Time: 00:02:56
                        Reset counter: 98
                        Mileage: 333529 km
                        Time: 07:08:45
       Component: IMMO            VDD 0814
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1T0 959 701
       Component: Tuersteuergeraet 09 0157
       Coding: 0000052
       VCID: 74E7B6EF17C595E2DD-8020
       Part No: 1K1 909 144 E
       Component: EPS_ZFLS Kl.0       1302
       VCID: 2D51638BB46F842A52-8078
    00573 - Steering Torque Sensor (G269)
                        Mileage: 3520 km
                        Temperature: 1.0°C
                        Voltage: 10.10 V
                        Voltage: 9.90 V
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 80E802087F2D8404084B016010
       VCID: 7BF59DD33A9BDA9A9C-802E
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1T0 959 702
       Coding: 0000052
       VCID: 75E18BEB1CBF8CEAEA-8020
       Part No: 1K0 035 186 L
       Component: Radio GR0       012 0018
       Revision: 0001201S    Serial number: VWZ2Z2D1929377
       Coding: 0020200
       VCID: 2F6D7983BE63F63A60-807A
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Autoscan after engine wiring repaired, short test drive and several attempts of G85 addaption.
    P.S. Please ignore EGR fault, it is done by customer and I'm asked not to touch it
    As well at the moment customer don't want to repair aux heater.
    Monday,09,January,2017,14:32:37:32442
       Coding: 0000072
    16785 - EGR System
                        RPM: 1827 /min
                        Torque: 60.0 Nm
                        Speed: 14.0 km/h
                        Load: 18.4 %
                        Duty Cycle: 14.7 %
                        Bin. Bits: 00001000
                        Mass Air / Rev.: 230.0 mg/str
                        Mass Air / Rev.: 615.0 mg/str
    Readiness: 1 1 0 0 0
       Coding: 0021190
       Coding: 00065493
       Coding: 0012338
       Component: Lenksäulenmodul 021 0050
       Coding: 0000042
       Coding: 0003103
       Coding: 0000011
                        Reset counter: 30
                        Mileage: 508945 km
                        Time: 16:14:23
                        Reset counter: 69
                        Mileage: 463729 km
                        Time: 16:04:38
    02085 - Incorrect Control Module Installed
                000 -  -  - Intermittent
                        Reset counter: 69
                        Mileage: 463729 km
                        Time: 16:04:38
    00664 - Fuel gauge
                        Fault Frequency: 6
                        Reset counter: 0
                        Mileage: 462756 km
                        Time: 17:06:13
                        Reset counter: 30
                        Mileage: 509011 km
                        Time: 16:58:39
                        Reset counter: 59
                        Mileage: 333532 km
                        Time: 01:36:08
       Coding: 0000052
    02546 - Steering Limit Stop
                        Mileage: 3520 km
                        Temperature: 27.0°C
                        Voltage: 14.30 V
                        Voltage: 14.00 V
                000 -  -
       Coding: 0000052
       Coding: 0020200
    End-------------------------(Elapsed Time: 01:41)--------------------------
    Please check wheel speed sensor, in [03-ABS] with VCDS Scope and/or a scope, start moving the car and driving slowly.
    Or G85 problem.
    Or maybe reset channel 00 in [44-Power steering].
  3. Likes MartinsX, Uwe, Jack@European_Parts liked this post
    Sep 2016
    Riga, Latvia
    Thnanks, NEtech!
    I know, that G85 can't be adapted if there are active faults stored in ABS/ESP, but I didn't know that implausible/corrupted signal without stored code will lead to the same. In VC-Scope it's clearly seen, that rear left wheel sensor is making some spikes. Will check sensor, wiring and rotor tomorrow.
    http://fotki.lv/lv/Martins_X/comments45307999/
  5. Likes Uwe, Jack@European_Parts liked this post
    Sep 2016
    Riga, Latvia
    New wheel bearing with rotor solved this issue
  7. Likes Uwe liked this post
  8. #5
    Oct 2014
    Sweden
    Hi
    I have a passat cc and my left cv boot started leaking and i had to remove my left drive axel and when i finished everything and i also had to remove the steering wheel and when i finished everything and tried to adapt the g85 sensor nothing happend. The angel showed 0° the whole time and when i followed you v-scope instruction the red graph differd from the other colors. Any idea what the problem could be? I have no code that say faulty.
  9. #6
    Quote Originally Posted by raziel90 View Post
    Hi
    Got a VCDS Auto-Scan?
  10. Likes Uwe liked this post
