VCDS 17.1 licencing issues on legitimate HEX_USB_CAN cable ...
JulianHicks
Kent, UK
C?ID=265735
I've had my VCDS HEX-CAN-USB cable for a while but after installing VCDS 17.1 on my WIn 7 laptop this morning and scanning my A8, I experienced two separate licencing issues which I'd never seen before.
1) I Autoscanned my D3 A8 and it halted when reading ECU 4F with a window labelled "VCDS Interface check" with the message "Failure to communicate [-2], Please use [Options]>[Test] for further details".
: I OK'd the window, went to Options / Test and it gave me my normal Windows showing all was well. "Port status OK ... Version 1.96 ... K1 OK K2 OK CAN OK"
: Went back to Autoscan again and it worked OK! Then did some other ECU logging to diagnose my door fault problem with no further problems.
2) After closing VCDS I realised I wanted to look at the Gateway List for which I used the Autoscan menu. This failed to run and showed me a message "Sorry! This function requires a liecenced interface".
: Once again went to Port test; all was well exactly as before. Also went to look at licence info - this was OK too - "Valid/activated"
: Went back to AUtoscan menu and I believe Gateway List now worked [may have done a autoscan successfully instead].
I've got logs and screen prints for this but not sure how I can easily incorporate screen print jpgs into this thread. Could always email to support ...
Regards - Julian
PS 17.1 was installed 'over the top' of my existing 16.8 version.
MartinsX
Riga, Latvia
C?ID=268515
"Sorry! This function requires a licensed interface"
I got this message time by time with previous versions, too. I think, this is because of my old, slow and overloaded laptop running Win XP. On my second laptop (more resources, almost fresh Win 7) I have never seen this message. So I don't stress for it :)
Can you give us complete specs on this computer, please?
golfi_vend
Tartu, Estonia
C?ID=195131
I heard similar results today with 17.1 and legitimate cable.
I myself haven't had this issue yet.
welshkaiboy
H11-2H
This happened this morning on my Micro CAN cable, never seen this issue before. I just closed down the software and started again with no issues.
TBAx
C?ID=287144
Experienced this bug before (on 16.8.3 and so on) with the HEX+CAN-USB cable, but never experienced it with the HEX-NET - all referencing the DRV (German) version. I don't think it's a performance a computer performance issue...
###                               Product Information                                            ###
Product: Ross-Tech VCDS DRV 16.8.4.5 / DS267.0 / 20170104
Installer Version: 3.2.6.239 compiled with NSIS v3.0
Installation Directory: C:\Program Files (x86)\VCDS-DRV
Installation Date/Time: 06.01.2017 @ 18:33:36 (UTC)
###                          Hardware/System Information                                         ###
ComputerSystem Manufacturer 1/1: ASUSTeK COMPUTER INC.
ComputerSystem Model 1/1: UX31LA
Processor Name 1/1: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
ComputerSystem TotalPhysicalMemory 1/1: 4172869632
BIOS Manufacturer 1/1: American Megatrends Inc.
BIOS SerialNumber 1/1: E4N0BC11897515G
BIOS Version 1/1: _ASUS_ - 1072009
###                         Operating System Information                                         ###
OperatingSystem 1/1: Microsoft Windows 10 Home
OperatingSystem Version 1/1: 10.0.14393
OperatingSystem Architecture 1/1: 64-Bit
OperatingSystem WindowsDirectory 1/1: C:\Windows
###                               Network Information                                            ###
NetworkAdapter Name 1/16: Microsoft Kernel Debug Network Adapter
NetworkAdapter Name 2/16: Intel(R) Dual Band Wireless-AC 7260
NetworkAdapter Name 3/16: Microsoft Wi-Fi Direct Virtual Adapter
NetworkAdapter Name 4/16: Microsoft ISATAP Adapter
NetworkAdapter Name 5/16: Teredo Tunneling Pseudo-Interface
NetworkAdapter Name 6/16: Bluetooth Device (RFCOMM Protocol TDI)
NetworkAdapter Name 7/16: Bluetooth Device (Personal Area Network)
NetworkAdapter Name 8/16: WAN Miniport (SSTP)
NetworkAdapter Name 9/16: WAN Miniport (IKEv2)
NetworkAdapter Name 10/16: WAN Miniport (L2TP)
NetworkAdapter Name 11/16: WAN Miniport (PPTP)
NetworkAdapter Name 12/16: WAN Miniport (PPPOE)
NetworkAdapter Name 13/16: WAN Miniport (IP)
NetworkAdapter Name 14/16: WAN Miniport (IPv6)
NetworkAdapter Name 15/16: WAN Miniport (Network Monitor)
NetworkAdapter Name 16/16: Microsoft ISATAP Adapter #2
NetworkAdapter MAC Address 1/16:
NetworkAdapter MAC Address 2/16: 7C:7A:91:55:64:D7
NetworkAdapter MAC Address 3/16: 7C:7A:91:55:64:D8
NetworkAdapter MAC Address 4/16:
NetworkAdapter MAC Address 5/16:
NetworkAdapter MAC Address 6/16:
NetworkAdapter MAC Address 7/16: 7C:7A:91:55:64:DB
NetworkAdapter MAC Address 8/16:
NetworkAdapter MAC Address 9/16:
NetworkAdapter MAC Address 10/16:
NetworkAdapter MAC Address 11/16:
NetworkAdapter MAC Address 12/16:
NetworkAdapter MAC Address 13/16:
NetworkAdapter MAC Address 14/16:
NetworkAdapter MAC Address 15/16:
NetworkAdapter MAC Address 16/16:
###                                         End                                                  ###
JulianHicks
Kent, UK
C?ID=265735
Certainly Uwe;
Lenovo T60 Laptop
Intel Core Duo T2400 @ 1.83GHz
2.00GB RAM
32bit Win 7 Home SP1
64GB SSD disk
Always runs on battery when I'm running VCDS; no other software used other that Avast ANtiVirus. Never seen a licence issue before in about 15months ...
Regards - Julian
MartinsX
Riga, Latvia
C?ID=268515
BTW I have Avast antivirus installed on Win XP computer, too, where I see "unlicensed" notification time by time :confused:
welshkaiboy
H11-2H
I also have Avast AV running too but have not seen this issue until this version. Maybe a common thread?
TBAx
C?ID=287144
Nope, Norton Security here; disabling it completely did not prevent this issue.
kamold
Australia
C?ID=241363
I had this twice today also.
Once on a Mk6 Golf and then on my Passat.
In both cases just closed and reopened VCDS but there does seem to be a new issue.
Have never seen an issue in any previous versions.
PC is running Win7 Enterprise 64bit with 8GB RAM and a Core i7-2640M.
Happy to provide any additional information that may assist.
AV is McAfee Enterprise 8.8
Sebastian
Magdeburg, Germany
HN0-nnnnnn
@TBAx, you've installed VCDS to C:\Program Files (x86)\VCDS-DRV which is not a suitable location. Please uninstall the software and re-install it to the default location (C:\Ross-Tech\VCDS-DRV), then check again and see if that makes a difference.
Keithuk
Stoke on Trent, England
C?ID=122432
The default location on my old Vista 32bit,Windows 7 32bit and Windows 10 when I tried it out, has always been C:\Ross-Tech\VCDS. I don't know where you get C:\Ross-Tech\VCDS-DRV as the default location Sebastian. The Beta versions go in C:\Ross-Tech\VCDS-Beta.
I installed the new 17.1 a couple of days ago and I tried it yesterday and it works ok. I have Avast Pro running all the time and that doesn't cause any problems when installing.
welshkaiboy
H11-2H
It does appear to be random/intermittent.
Al Bundy
Bucharest, Romania
C?ID=80804
I have the same problem:
cd6ecf82
Dana
Western PA, USA
C:\Ross-Tech\VCDS is the default location for English but Sebastian was replying to a customer using a DRV Release (German VCDS) which uses the C:\Ross-Tech\VCDS-DRV location.
TBAx
C?ID=287144
Dear Sebastian, as already posted in the german VCDS forum, changing the directory (via uninstall + reinstall) does not fix the problem. However there are many people with the standard installation directory that still get the problem, so I moved back to Program Files and fixed the ADS and priviliges for VCDS to work.
However previous version _did not_ have this issue beside being installed in the Program Files directory. But I guess that fact will still be ignored...
Dana
Western PA, USA
We believe this exact issue was duplicated successfully and the guys will be working on it tomorrow. We will update this thread with further information and thanks for reporting the issues!
Eric
HC800000
We're pretty sure we have it fixed now. This was introduced with translated 16.8.4 versions (enhanced info in About screen) and was due to the possibility of fetching values outside of an array's size in memory. Sorry about that; fixed builds should be up shortly.
