Tuesday,12,November,2019,15:28:46:22340
VCDS Version: 19.6.2.0
Workshop Code: 000 11618 000000
VIN: 3VWB67AJ7JM233733   License Plate:
Mileage: 25570km-15888mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 03 04 05 08 09 15 17 19 25 2B 3C 44 5F 75
VIN: 3VWB67AJ7JM233733   Mileage: 25570km-15888miles
Address 01: Engine (J623-CZTA)       Labels: None
   Part No SW: 04E 906 023 BJ    HW: 04E 907 309 AP
   Component: R4 1.4l TFS   H22 5008
   Revision: X5H22---
   Coding: 01110012232400001000
   Shop #: WSC 00066 790 00088
   ASAM Dataset: EV_ECM14TFS01104E906023BJ 005006
   ROD: EV_ECM14TFS01104E906023BJ.rod
   VCID: E9D3FF45082E260790-80BC
   CAN Converter 01:
4509 - Internal Control Module
          P1640 00 [032] - EEPROM Error
11504 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [096] - Implausible Signal
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B400C492500FD851202E7921C00402110F01A
   Shop #: WSC 00066 790 00293
   VCID: F5EBA3355C96F2E704-80A0
                    Reset counter: 236
                    Mileage: 25577 km
                    Date: 2019.11.12
                    Time: 00:00:22
                    Count: 2
                    Count: 28672
                    Count: 16390
                    Count: 43776
                    Count: 1
                    Count: 252
                    Reset counter: 236
                    Mileage: 25577 km
                    Date: 2019.11.12
                    Time: 00:00:12
                    Count: 2
                    Count: 28672
                    Count: 297
                    Count: 43520
                    Count: 1
                    Count: 251
   Part No SW: 5K0 959 434 J    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1403
   Revision: 00092000    Serial number: 0447537496
   Coding: 032C0C
   VCID: BC7D7611373C63AF3B-80E8
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 DA    HW: 5C0 820 047 DA
   Component: J301  Klimaanlage   0211
   Revision: 2001401S    Serial number: 00000004228989
   VCID: E2C1E8693D18755F51-80B6
03984 - Left front heated seat
                    Fault Status: 00111011
                    Fault Frequency: 8
                    Reset counter: 163
                    Mileage: 10032 km
                    Date: 2019.02.12
                    Time: 12:48:49
03934 - Control Circuit for Seat Heating; Front Left
                    Fault Status: 00110111
                    Reset counter: 14
                    Mileage: 25078 km
                    Date: 2019.11.01
                    Time: 11:45:58
                    Fault Status: 00101101
                    Reset counter: 21
                    Mileage: 25577 km
                    Date: 2019.11.12
                    Time: 00:00:13
   Part No SW: 7E0 937 190 C    HW: 7E0 937 190 C
   Component: BCM PQ25 Max3 H82 0752
   Revision: B8082001    Serial number: 58207220170092
   Coding: 7B994B9A08AB0B0008392080240884C54BC6722E600351F0B0A050032844
   Shop #: WSC 11618 000 00000
   VCID: AC5D4651CF5CF32FAB-80F8
   Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1467
   Serial number: 14102743170731234905
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  022 1467
   Serial number: 14102742170720110615
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST001PCVRO00000
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Serial number: 1371607132300741AD1B
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745170816215636
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744170607020419
   Coding: 800000
                    Reset counter: 20
                    Mileage: 25577 km
                    Date: 2019.11.12
                    Time: 01:09:23
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0ELUN1
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW32.rod
   VCID: E3CFED6DEA027C575A-80B6
   Serial number: IBH000000000007RB84H
   Coding: 303146
   Subsystem 2 - Part No SW: -----------    HW: 480 002 906 17
   Serial number: 35700000000290294525
   Subsystem 3 - Part No SW: -----------    HW: 480 002 906 17
   Serial number: 35800000000F8C39452V
   Subsystem 4 - Part No SW: -----------    HW: 480 020 203 17
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001C3249E3C28496
   Subsystem 5 - Part No SW: -----------    HW: 480 020 306 17
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001C124E9844A5EC
   Subsystem 6 - Part No SW: -----------    HW: 480 021 906 17
   Component: FrontSensor_D  000 0189
   Serial number: 35500019B2517A1695D7
   Subsystem 7 - Part No SW: -----------    HW: 480 021 906 17
   Component: FrontSensor_P  000 0189
   Serial number: 35600019B2517A15329.
   Part No SW: 5C6 920 976 D    HW: 5C6 920 976 D
   Component: KOMBI         H02 1107
   Coding: 2218010000
   Shop #: WSC 00066 000 00318
   VCID: B36F5D2D1A62ACD7EA-80E6
   Part No SW: 7E0 909 901     HW: 7E0 937 190 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B8082001
   Coding: 102201
   VCID: E8D5FA411B241F0F8F-80BC
                    Mileage: 17977 km
                    Date: 2019.07.10
                    Time: 17:48:37
   Component: IMMO          H02 1107
   Coding: 000007
   VCID: EAD180490D282D1F99-80BE
   Revision: 00000000    Serial number: 17000188967006
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B1635725E07E9EC798-80E4
   Component: HRE_Master    H11 0071
   Serial number: 0381241969
   Coding: 01011101
   Shop #: WSC 31654 003 1048576
   ROD: EV_HREntryHella_VW32.rod
   Component: HRE_Slave  H12 0071
   Serial number: 0444131878
   Coding: 010111
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 304    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: B9736F05F00E568720-80EC
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.2 V
                        PD
                    Temperature: 11.0C
                    Count: 2
                    Steering Angle: 0.00
                        SteerAng n.Init
   Part No SW: 5C0 035 200 D    HW: 5C0 035 200 D
   Component: MU-S-S-US     H42 0447
   Serial number: VWZAZ2T1460965
   Coding: 02630100AA00000051220001001808009F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 962984B969D059FFED-80C2
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140566
   Coding: 02630102C21632107F1606C00000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 942DFEB17F2C4BEF93-80C0
End-------------------------(Elapsed Time: 03:15)--------------------------
