VCDS Update 17.1
sorry i can´t keep up.
Depending on how you use the product, keeping up with every minor new version may not be necessary. We generally don't pick on people who we know are legitimate users if they're a bit behind unless we believe that updating might solve some problem they're having.
hch
C?ID=293727
Hi.
Is there any changelog please?
   #25
barstanders
C?ID=277262
Hello Ross Tech,
After updating from 15.7.4 to the latest version with frimware upgrade 16. 17. i cannot find this rule anymore on the instrument cluster.
(1)-Illumination_algorithm-Scale_switching_algorithm,parking_light
Please see the video I have made this morning.
https://youtu.be/2E70v9zmI-I
I want to change this valeus to not present, but with vcds latest version its not working maybe the newer version will come with this option??
(2)-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight
   #26
Hello Ross Tech,
Please post scan data from your instrument cluster. The data from the Advanced ID function should suffice.
barstanders
C?ID=277262
Hello Uwe,
Tuesday,24,January,2017,17:05:45:42750
VCDS Version: Release 17.1.2 (x64)
Address 17: Instruments
Control Module Part Number: 5G0 920 871
Component and/or Version: KOMBI 353 2200
Software Coding: 07FD0A002390000800087A00040000
Work Shop Code: WSC 12345
VCID: 67F2E1F49ECB2A7942-8032
Advanced Identification/FAZIT
Identification: VDD-024
Date: 13.02.13
Manufacturer number: 5502
Test stand number: 1211
Flash Status
Programming Attempts(application): 2/2/2
Programming Attempts(data): 0/0/0
Successful Attempts(data): 0/0/0
Flash Date: 13.03.20
Flash Tool Code(data): 00000 000 00000
Misc.
Hardware number: 5G0 920 871
Workshop System Name: J285
Equipment/PR Code: 0000000000000000
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset: EV_DashBoardVDDMQBAB
ASAM Dataset Revision: 008031
Car Info
Chassis Number: WVWZZZAUZDP010048
VCDS Info:
Labels: 5G0-920-XXX-17.clb
   #28
OK, that's going to take more digging that I expected. Unfortunately, I have other commitments for my time today. Please bump this in about 36 hours if I don't get back to you.
barstanders
C?ID=277262
Hello Uwe,
You already know some more
   #30
Interesting.
"ENG125906-Illumination_algorithm" in your video shows the options that the data I have should be for "ENG125906-ENG125912 Illumination_algorithm - Pointer_illumination_algorithim".
"Illumination_algorithm - Scale_switching_algorithm" does seem to have existed in some older data versions, specifically the ones that did not take the ASAM Dataset Revision into account, but I can't find it in the current one that does. The implication is that it is not defined in the factory data for your revision.
Hello Uwe,
Thats strange.
http://forums.ross-tech.com/showthr...nstrument-cluster-retrofit-to-Premium-1-fault
On post 8 I post an admap with version 15.7.4 on this version you see that it was there.
So on the newer version gone.
Yes, the manner in which we select what data to use for a particular ASAM ID changed substantially at 16.8.1.
What would be interesting here is to connect it to ODIS and see if it admits to the existence of this channel in your cluster. In principle, I believe it should not.
