Results 21 to 30 of 32
Thread: VCDS Update 17.1
  1. #21
    Jul 2015
    sorry i canīt keep up.
    VW Passat 3C (b6) 2006 TDI with BMP engine
    Skoda ocatvia III 2014 TDI
  2. #22
    Quote Originally Posted by martijn v o View Post
    Depending on how you use the product, keeping up with every minor new version may not be necessary. We generally don't pick on people who we know are legitimate users if they're a bit behind unless we believe that updating might solve some problem they're having.
  3. #23
    Dec 2016
    Hi.
    Is there any changelog please?
  4. #24
    United States
    Nothing official yet but it will eventually end up here: http://www.ross-tech.com/vcds/revisions.php
  5. #25
    Jun 2016
    Hello Ross Tech,
    After updating from 15.7.4 to the latest version with frimware upgrade 16. 17. i cannot find this rule anymore on the instrument cluster.
    (1)-Illumination_algorithm-Scale_switching_algorithm,parking_light
    Please see the video I have made this morning.
    https://youtu.be/2E70v9zmI-I
    I want to change this valeus to not present, but with vcds latest version its not working maybe the newer version will come with this option??
    (2)-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_ bus_parkinglight
  6. #26
    Quote Originally Posted by barstanders View Post
    Hello Ross Tech,
    Please post scan data from your instrument cluster. The data from the Advanced ID function should suffice.
  7. #27
    Jun 2016
    Hello Uwe,
    Tuesday,24,January,2017,17:05:45:42750
    VCDS Version: Release 17.1.2 (x64)
    Address 17: Instruments
    Control Module Part Number: 5G0 920 871
    Component and/or Version: KOMBI 353 2200
    Software Coding: 07FD0A002390000800087A00040000
    Work Shop Code: WSC 12345
    VCID: 67F2E1F49ECB2A7942-8032
    Advanced Identification/FAZIT
    Identification: VDD-024
    Date: 13.02.13
    Manufacturer number: 5502
    Test stand number: 1211
    Flash Status
    Programming Attempts(application): 2/2/2
    Programming Attempts(data): 0/0/0
    Successful Attempts(data): 0/0/0
    Flash Date: 13.03.20
    Flash Tool Code(data): 00000 000 00000
    Misc.
    Hardware number: 5G0 920 871
    Workshop System Name: J285
    Equipment/PR Code: 0000000000000000
    Dataset Number: -----------
    Dataset Version: ----
    ASAM Dataset: EV_DashBoardVDDMQBAB
    ASAM Dataset Revision: 008031
    Car Info
    Chassis Number: WVWZZZAUZDP010048
    VCDS Info:
    Labels: 5G0-920-XXX-17.clb
  8. Likes Dana liked this post
  9. #28
    OK, that's going to take more digging that I expected. Unfortunately, I have other commitments for my time today. Please bump this in about 36 hours if I don't get back to you.
  10. #29
    Jun 2016
    Hello Uwe,
    You already know some more
  11. #30
    Interesting.
    "ENG125906-Illumination_algorithm" in your video shows the options that the data I have should be for "ENG125906-ENG125912 Illumination_algorithm - Pointer_illumination_algorithim".
    "Illumination_algorithm - Scale_switching_algorithm" does seem to have existed in some older data versions, specifically the ones that did not take the ASAM Dataset Revision into account, but I can't find it in the current one that does. The implication is that it is not defined in the factory data for your revision.
