Results 1 to 7 of 7
Thread: Wanted: Control Module Maps from AFP 2.8L Vr6
    United States
    Due to a discrepancy in MVB/BS 077.2 (Coolant versus MAF) we would like to review Auto-Scans (with the VIN please) and PLB function control module maps from the Mk4 chassis AFP 2.8L Vr6 Golf and Jetta.
    They use the 021-906-018-AFP.lbl label file and this engine was found in the NAR market from 1999.5 - 2002.5:
    Address 01: Engine Labels: 021-906-018-AFP.lbl
    Part No: 021 906 018 T
    Component: MOTRONIC ME7.1 G 6764
    Coding: 00031
    Internal ref: FS#1254
  2. Likes Uwe, Sebastian liked this post
  3. #2
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    Still in need?
    Wednesday,21,May,2014,12:13:57:05734
    VCDS Version: 14.5.1.0 (x64)
    Data version: 20140515
    Dealer/Shop Name: Utah Imports hj
    VIN: 9BWPG61J424006566   License Plate:
    Mileage: 170840km-106155mi   Repair Order:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: 9BWPG61J424006566   Mileage: 170840km-106155miles
       Coding: 00031
       Shop #: WSC 19400
       VCID: 9F0EA3E21FAB3AC334-5184
       9BWPG61J424006566     VWZ7Z0A3892027
    16712 - Knock Sensor 1 (G61)
                P0328 - 35-10 - Signal too High - Intermittent
    16717 - Knock Sensor 2 (G66)
                P0333 - 35-10 - Signal too High - Intermittent
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 D
       Component: ASR FRON
       Coding: 0021505
       Shop #: WSC 00034 785 00200
       VCID: AB1647320B13D663A8-5184
       Part No: 6Q0 909 605 F
       Component: 08 AIRBAG VW6  0202 0004
       Coding: 12344
       Shop #: WSC 00034
       VCID: BA387276A4497FEB23-5160
    00532 - Supply Voltage B+
    00591 - Seat Belt Switch; Driver (E24)
    00592 - Seat Belt Switch; Passenger (E25)
       Part No: 1J0 920 926 D
       Coding: 07232
       Shop #: WSC 20691
       VCID: AB1647325B13D663A8-5160
       Part No: 6N0 909 901
       Coding: 00006
       VCID: F0AC905EB2B5F5BBDD-5160
       Part No: 1C0 959 799 C
       Component: 1J Komfortgerát HLO 0003
       Coding: 00064
       VCID: B73E6B42975B6283DC-4B3C
       Component: 1J Tőrsteuer.FS KLO 0002
       Component: 1J Tőrsteuer.BF KLO 0002
                37-00 - Faulty
    End-------------------------(Elapsed Time: 08:05)--------------------------
    and
    Friday,04,April,2014,11:21:13:05734
    VCDS Version: 14.2.3.0 (x64)
    Data version: 20140320
    VIN: 9BWPG61J824003766   License Plate:
    Mileage: 219240km-136229mi   Repair Order:
              76
    VIN: 9BWPG61J824003766   Mileage: 219240km-136229miles
       Component: MOTRONIC ME7.1  G   0003
       Coding: 00031
       Shop #: WSC 01120
       VCID: 9F0EA3E21DAB3ACC0C-5184
       9BWPG61J824003766     VWZ7Z0A3885092
    16885 - Vehicle Speed Sensor
                P0501 - 35-00 - Implausible Signal
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 35-10 - Signal too Low - Intermittent
    17550 - Load Calculation Cross Check
                P1142 - 35-10 - Lower Limit Exceeded - Intermittent
    17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
                P1165 - 35-10 - System too Rich - Intermittent
    Readiness: 0000 1100
       Component: ASR FRON
       Coding: 0021505
       Shop #: WSC 00000 785 00200
       VCID: AB1647320913D66C90-5184
       Coding: 12344
       VCID: BA387276A6497FE41B-5160
       Coding: 07232
       Shop #: WSC 19506
       VCID: AB1647325913D66C90-5160
       Coding: 00006
       VCID: F0AC905EB0B5F5B4E5-5160
       Coding: 00064
       VCID: B73E6B42955B628CE4-4B3C
       Component: 1J Tőrsteuer.FS KLO 0003
                    Address 01: Engine  (021 906 018 T)
    11:22:04 Group 032: Lambda Control (Mixture Adaptation)
      -2.1 %  Adaptation (Idle) Bank 1 Sensor 1
      16.4 %  Adaptation (Partial) Bank 1 Sensor 1
                Bin. Bits
                Bin. Bits
    Monday,14,April,2014,13:11:47:05734
    VCDS Version: 14.4.0.3 (x64)
    Data version: 20140411
              76
       Coding: 00031
       Shop #: WSC 01120
       VCID: 9F0EA3E21DAB3AC3D9-5184
    Readiness: 0000 0101
       Component: ASR FRON
       Coding: 0021505
       VCID: AB1647320913D66345-5184
       Coding: 12344
       VCID: BA387276A6497FEBCE-5160
       Coding: 07232
       Shop #: WSC 19506
       VCID: AB1647325913D66345-5160
       Coding: 00006
       VCID: F0AC905EB0B5F5BB30-5160
       Coding: 00064
       VCID: B73E6B42955B628331-4B3C
    00912 - Window Regulator Switch; Front Left (E40)
    13:12:14 Group 032: Lambda Control (Mixture Adaptation)
      -1.7 %  Adaptation (Idle) Bank 1 Sensor 1
      18.8 %  Adaptation (Partial) Bank 1 Sensor 1
                Bin. Bits
                Bin. Bits
    It's funny the only two I have out of 5400+ scans were scanned a few weeks apart.
    I don't see these cars as much as I used to, but if I remember when I see another one, I'll get a control module map.
  4. Likes Sebastian, Dana liked this post
  5. #3
    Magdeburg, Germany
    Yes, please!
    United States
    hans j sent a map and scan set from: Part No: 021 906 018 M
    Thanks!
  7. Likes Uwe, Sebastian liked this post
  8. #5
    Magdeburg, Germany
    Thanks, we may still need a few more from other P/Ns.
  9. #6
    United States
    Excellent, hans j sent a map and scan from:
    Part No: 021 906 018 R
    Component: MOTRONIC ME7.1 G 6762
    Coding: 00031
    (Seb I have the originals in our Support>Dataversion folder)
  10. Likes Sebastian liked this post
  11. #7
    Jan 2019
    Indiana
    Still looking? I have several friends with this type of car wanting scans in the near future. My daily.
    Sunday,13,January,2019,15:25:37:45417
    VCDS Version: 18.9.0.4 (x64)  HEX-NET CB: 0.4437.4
    VIN: 9BWPG61J214061127   License Plate:
    Mileage: 264640km-164439mi   Repair Order:
    Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
              76
       Mileage: 264640km-164439miles
       Coding: 00031
       Shop #: WSC 03311
       VCID: 1D72DE129500A7A2D0-5184
    Readiness: 0010 1101
       Component: ASR FRONT MK60      0103
       Coding: 0021505
       Shop #: WSC 00001 785 00200
       VCID: 2B1600CA8BB459125E-5184
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 1.0.0
       Coding: 01000
       Shop #: WSC 00001
       VCID: 210AE2E2A9788342F4-51A8
       Component: 07 AIRBAG VW6  0202 0004
       Coding: 12343
       Shop #: WSC 00001
       VCID: 3A38358E24EEF09AD5-4B3C
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 B
       Component: Lenkradelektronik   0001
       Coding: 00008
       Shop #: WSC 00001
       VCID: 302C17A6F2923ACA6B-51CE
       Part No: 1J0 920 925 D
       Component: A4-KOMBIINSTR. VDO V01
       Coding: 07232
       Shop #: WSC 03311
       VCID: 2A1805CED44E401AA5-5160
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0Y2737527
       IMMO-IDENTNR: VWZ7Z0Y2737527
       Coding: 00006
       Shop #: WSC 00001
       VCID: 70ACD7A632127ACA2B-5160
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 62 Zentral-SG Komf. 0001
       Coding: 00256
       Shop #: WSC 00001
       VCID: 0640917E2096447AE1-4B1E
       Subsystem 1 - Part No: 1J1959801C
       Component: 62 Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 62 Tőrsteuerger. BF0002r
       Part No: 1J0 035 180 B
       Component:  Radio DE2         0005
       Coding: 01033
       Shop #: WSC 16403
       VCID: 1E70D91E9806BCBAC9-51F2
    End----------(Elapsed Time: 04:31, VBatt start/end: 13.9V/13.8V)-----------
  12. Likes jyoung8607, Uwe liked this post
