- Joined
- May 16, 2014
- Messages
- 5,469
- Reaction score
- 5,934
- Location
- Melbourne, Australia
- VCDS Serial number
- C?ID=194404
Thanks!!
Here are the links, hope they work...
Here is the new BCM that has the seat warm option available:
https://docs.google.com/spreadsheets/d/1dtTXwNik9KBJD0CjXl-Lp79qaEHsrWqjy6YJG_2yz_8/edit?usp=sharing
Here is the BCM that is in the car now and does not have the seat warmer option:
https://docs.google.com/spreadsheets/d/1y9PBrAXTdCtk4UA5KOMYyHr5S2t6t9K5UGISCHklep0/edit?usp=sharing
CO_Biker: Well done - files download,parsed,analyzed and uploaded! You can download the BCM compare spreadsheet HERE
Hopefully the spreadsheet is self explanatory, but this is how it works:
There are 2 x worksheets: CO_Biker_BCM_Compare (this is the "active" worksheet) and 09-5Q0-937-087-N unique channel -this worksheet contains the adaptation channels in your old BCM that have no matching channels in the new BCM. In the main, the uniqueness is simply German versus English names.
For the CO_Biker_BCM_Compare worksheet:
Column A = simple ID number that I've used as the primary key in MS Access
Column B = Complete list of ALL the adaptation channels in your new BCM
Column C = The settings for the Adaptation channels in your new BCM
Column D = The settings for the Adaption channels in your old BCM (where there are matching channel names in the new BCM). Note: I've forced an entry into this column for the 4 x channels related to seat heating that were unique because of the English name in your old BCM - these are colored Blue (see ID around 818)
Column E = "Same?" - this column identifies which adaptation channels you will need to alter in your new BCM. I've sorted the worksheet by this column to make it easier for you to identify the focus of your work. Clearly you can't make changes for those channels that are identified as "New" in this column (because there is no matching entry in your old BCM). All the entries that are listed as "No" theoretically should be altered, but I've found from past experience that the settings for the lighting configuration channels don't matter because these are "slave" channels for the matching Leuchte channels.
Here's how the BCM code-strings look:
