Results 1 to 4 of 4
Thread: really lost with voice command on 2010 a5 cabriolet
    Mar 2014
    default module test says voice module not available?
    i just got my vag com cable & want to change my voice settings so I can use voice commands in my 2010 cab. the module for voice is said to be not available. does anyone know what thats all about
    I also do not have the telephone module available. '
    are these only accessed through the can?
    I am new to this whole tech system audi uses. I am a professional Automotive tech for 25 years but have been out of practice since 2008
    new career.
    a little background on my car:
    01/15
    Default voice button not operative
    when I got this car last month, I believe it was working but I did not know to use the mmi system but was fiddling with it & may have hit something I shouldn't have.
    when I push the voice command button, nothing happens but on the drivers information system display (between the tach & speedo) it reads "button n used"
    anyone have any ideas, I tried resetting the MMI system & no change
    01/28
    spoke to the previous owner & he confirmed the voice button used to work when he had the car, i am know convinced I did something in playing with the settings to make this now not work. does anyone know what I could have done to make this button not work, other than plugging in a vag com cable & changing default settings?
    any help is appreciated!!
    here is the autoscan test results
    VIN: WAULFAFH0AN013041   Mileage: 51360km/31913miles
    Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AA    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H15 0003
       Revision: E1H15---
       Coding: 011C010A190F0160
       Shop #: WSC 00000 785 00200
       ASAM Dataset: EV_ECM20TFS8K2907115AA A01004
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 6ED9EB9AB1CC8D6E79B-803B
    Readiness: 1110 0101
    Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
       Part No SW: 8K0 927 158 J    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H05 0008
       Revision: --H05---
       Coding: 001012
       ASAM Dataset: EV_TCMAL651 A01006
       ROD: EV_TCMAL651.rod
       VCID: 3D7B1CD6AC2A26F6B01-8068
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 150D18
       Shop #: WSC 08224 016 263172
       VCID: 7AF1D7CAF584D1CED53-802F
       Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
       Component: BCM2 1.1      H02 0326
       Coding: 090300
       Shop #: WSC 02399 823 56573
       VCID: 77F7CEFEC696CCA6AAD-8022
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
    Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
       Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
       Component: MEM-BFS       H10 0074
       Revision: AA000000    Serial number: 00001001353492
       Coding: 08017025002400001000
       Shop #: WSC 02391 823 56573
       VCID: 438F6A2EC2CE5006C65-8016
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01061020091077
       Coding: 64132000
       VCID: 8005252213580B1E1B7-80D5
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000474750
       Coding: 26001091063CAF010000080300003D3D0F1C528800010161000000
       VCID: 3C7D11D2BF302FFE87F-8069
       Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 290909  H06 0021
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 02562A
       Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
       Component: E1 - LDS  H08 0090
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 H    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0050
       Revision: 11001001    Serial number: 39940928100831
       Coding: 200101
       VCID: 3E791BDAA92C3DEEA9B-806B
    Address 15: Airbags (J234)       Labels: 8F0-959-655.clb
       Part No SW: 8F0 959 655 A    HW: 8F0 959 655 A
       Component: AirbagVW-AU10 H10 0430
       Serial number: 003A5D0605WV
       Coding: 303737353631303030304A55304C38463053
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_AirbaAU10SMEAU485 001004
       ROD: EV_AirbaAU10SMEAU485.rod
       VCID: 366903FA891CF5AE71B-8063
       Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
       Component: BF-Gewichtss.  H01 0050
       Serial number: 5810000R0900004599
       Serial number: 6334MSME4B623770D
       Serial number: 6344MSME4B6332249
       Serial number: 6352QSME063D04025
       Serial number: 6362QSME2C3B3B30N
       Serial number: 63732SME273B3B02
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME443C3C1C8
       Revision: --------    Serial number: 90319IJ50007T
       Coding: 000016
       VCID: 3D7B1CD6A42A26F6B01-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 981 J    HW: 8T0 920 981 J
       Component: KOMBIINSTR.   H34 0255
       Revision: 00000000    Serial number: CI074NX99
       Coding: 8B1619000300D705020000
       Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0105
       Revision: EB800053    Serial number: 5300E09928820D
       Coding: 00C303
       VCID: 52A15F6A0DB4C98E7D3-8007
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0170
    Address 26: Auto Roof (J256)       Labels: 8F0-959-255.clb
       Part No SW: 8F0 959 255     HW: 8F0 959 255
       Component: VSG-AUDI-B8   H09 0170
       Coding: 030000
       ASAM Dataset: EV_ElectRoofContr 001007
       ROD: EV_ElectRoofContr.rod
       VCID: F1E370E620F21296E49-80A4
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Component: MEM-FS        H10 0074
       Revision: AA000000    Serial number: 00001010019378
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009436212
       Coding: 011C43724008332C03
       VCID: 458B7436CCFA6E36E81-8010
       Revision: 00002001    Serial number: 0121941364
       Coding: 010602BA007A442000B0030000000000
       Subsystem 1 - Part No SW: 8F0 959 719     HW: 8F0 959 719
       Component: GTO BF  H06 0050
       Part No SW: 8F0 035 223 C    HW: 8F0 035 223 C
       Component: DSP Prem      H08 0170
       Revision: 00008001    Serial number: 34862000452402
       VCID: 2045C5A233986B1EBB7-8075
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 120
                        Voltage: 11.60 V
                        Temperature: 30.0°C
                        Temperature: 37.0°C
                        Bin. Bits: 00000100
                        Bin. Bits: 00001000
                        Bin. Bits: 00000000
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009449626
       Coding: 011C43324008332C03
       VCID: 448D6932C7C0573EFFF-8011
       Revision: 00000003    Serial number: 10000000331362
       VCID: 346D39F29760E7BE4FF-8061
    Address 55: Xenon Range        Labels: 8K0-907-357.clb
       Part No: 8K5 907 357
       VCID: F7F74EFE86964CA62AD-80A2
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335IR097531304
       Coding: 020000010000000101
       VCID: 1D3BFC5604EA46F6901-8048
    00003 - Control Module
                        Fault Status: 00101110
                        Mileage: 50471 km
                        Date: 2014.02.22
                        Time: 11:43:55
                        Bin. Bits: 00000000 00001000
                        Fault Frequency: 13
                        Reset counter: 120
                        Mileage: 51365 km
                        Date: 2014.03.04
                        Time: 13:14:16
                        Bin. Bits: 00000001 11111100
       Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
       Component: H-BN-NA       H41 0042
       Revision: --------    Serial number: 490J$097519532
       Coding: 010200030006A1EF01000B0E004001010100
       VCID: 366903FA811CF5AE71B-8063
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
                        Fault Frequency: 12
                        Reset counter: 120
                        Mileage: 51365 km
                        Date: 2014.03.04
                        Time: 13:14:16
                        Bin. Bits: 10111110 10000010
                        Bin. Bits: 00000000 00001110
                        Bin. Bits: 00000000 00000000
    02452 - Multimedia Display Unit Rear Left (Y22)
                        Reset counter: 80
                        Mileage: 51365 km
                        Date: 2014.03.04
                        Time: 12:38:03
                        Voltage: 12.00 V
                        Fault Frequency: 7
                        Reset counter: 120
                        Mileage: 51365 km
                        Date: 2014.03.04
                        Time: 13:14:16
                        Bin. Bits: 00100001 00010000
                        Bin. Bits: 00000000 00001010
       Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102005812
       Coding: 010C03324008372C03
       Part No SW: 8F0 907 441     HW: 4L0 907 441 B
       Revision: --H03---    Serial number: 525PA8-J99B04F
       Coding: 1000009
       VCID: E7D71EBED636DC26BAD-80B2
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102005037
    Last edited by Uwe; 03-04-2014 at 02:05 PM. Reason: Wrapped CODE tags around AutoScan
    I'm not that familiar with the 3rd-generation MMI system myself. Audi took a lot of the stuff that used to be in separate modules and stuffed it all into 5F: Information Electronics (J794). Whether that includes voice command, I'm not sure. Someone who knows this better than me will have to chime in here.
    Lansdale, PA
    I looked at the coding, it appears SDS (speed Dialog system) is disabled. Follow the instructions here:
    http://audiforum.us/threads/a5-cabri...18/#post-74745
    Mar 2014
    Thank you for the guidance, all it took was putting me on the right route to a correct link
    i appreciate you guys a lot!!!
  5. Likes Uwe liked this post
