Monday,02,January,2017,14:42:08:45078
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
VIN: WAUZZZ4H6DN009986 License Plate:
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 19 20 28 34 36
3B 42 44 46 47 48 52 53 56 57 5B 5F 62 6C 6D 6F 72 7F 81 84
85 88 8A 8B 8D 8E 8F 90
VIN: WAUZZZ4H6DN009986 Mileage: 156732km-97388miles
44-Steering Assist -- Status: Cannot be reached 0100
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: OK 0000
84-Night Vision -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CEJA) Labels: None
Part No SW: 07P 906 023 K HW: 07P 906 023
Component: W12-6.3-U2 H16 4070
Revision: M8H16---
Coding: 002A0012256600000000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM63FSI11107P906023K 004003
ROD: EV_ECM63FSI11107P906023K.rod
VCID: 365AA02A89F76BF223-8062
16672 - Please Check DTC Memory of ECU Number 2
P1923 00 [040] - -
Mileage: 152180 km
Date: 2016.11.07
Time: 06:19:16
Engine speed: 1206.00 /min
Normed load value: 45.1 %
Coolant temperature: 33 캜
Intake air temperature: 26 캜
Voltage terminal 30: 12.657 V
8113 - Performance Malfunction in Cooling System
P2181 00 [100] - -
Mileage: 155925 km
Date: 2016.12.24
Time: 06:45:11
Engine speed: 1512.50 /min
Normed load value: 52.9 %
Vehicle speed: 74 km/h
Coolant temperature: 63 캜
Intake air temperature: 2 캜
Voltage terminal 30: 13.937 V
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4H1 927 158 BS HW: 0BK 927 156 AG
Component: 0BK 63 FSIUSA H16 1001
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMALX51011 002020
ROD: EV_TCMALX51011_002.rod
VCID: 02320CFA95BF0752DF-8056
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: A2E5E20045A74700E300
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 345E9A229F8B79E21D-8060
Part No SW: 4H0 907 064 DF HW: 4H0 907 064 CF
Component: BCM2 2.0 H32 0510
Coding: 05872F46000000000000
Shop #: WSC 27032 000 1048576
VCID: 70D65632A31305C239-8024
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 H HW: 4H0 959 760 H
Component: MEM-BFS H09 0163
Revision: AA000000 Serial number: 00000027862159
Coding: C018B60084002201040001010101112909313229283232
Shop #: WSC 02313 785 00200
VCID: 3846AE128BE39D8231-806C
Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0120
Coding: 4C0162FE9C
ROD: EV_AirCondiFront_AU64.rod
VCID: 257877662451106A9A-8070
0378 - Coolant Circulation Pump
B10D0 04 [009] - Internal System Fault
Fault Frequency: 161
Reset counter: 116
Mileage: 147605 km
Date: 2016.08.31
Time: 21:12:14
Voltage terminal 30-Data: 13.6 V
Outside air temperature-Data: 32.50 캜
Interior temperature-Data: 20.20 캜
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001388405
Coding: 0907E0950F749FF38B810004A0001800009CC3080A000101800108546D01
VCID: 6FD4554EBE2D1A3A20-803A
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120419 H35 0080
Serial number: 120626040937
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 20058197
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Serial number: 25 06 2012 00000847
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000025071200010528
Coding: 100000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000020071200010366
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103816000001673862
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 9488CD36000000000001
03110 - Active Steering Control Module (J792)
Reset counter: 152
Mileage: 147605 km
Date: 2016.08.31
Time: 21:12:00
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 E HW: 4H0 035 108
Component: DVDCAlpine H42 0190
Revision: AA001001
Coding: 020000
VCID: 22726C7A3D7FE752FF-8076
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061220501159
Coding: 282902
ASAM Dataset: EV_EPHVA18AU57X0000 003008
VCID: 77C46D2ECE7D52FAF8-8022
Address 11: Engine II (J624) Labels: None
Revision: M8H16---
ASAM Dataset: EV_ECM63FSI21107P906023K 004003
ROD: EV_ECM63FSI07P906023K.rod
14459 - EVAP System
P0456 00 [096] - Very Small Leak Detected
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H17 0400
Coding: 7404020201
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A62845A4D4F3F12B7-807E
10240 - Sensor for Automatic Distance Control
Reset counter: 141
Mileage: 155739 km
Date: 2016.12.21
Time: 20:02:46
Control Module temperature: 19 캜
Voltage terminal 15: 14.383 V
Velocity_vehicle_reference: 17.49 m/s
Longitudinal_acceleration_vehicle_reference: 0.06 m/s?
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG009LB6%
Coding: 30314246323430303031554A304C34483053
Serial number: 3575HRB405P1G7FA9OAT
Serial number: 3585HRB404P1G0QM31AG
Serial number: 3515JRB40611DKAS219.
Serial number: 3525JRB40611DKAS21E0
Serial number: 3554VRB405T19PPQCGN3
Serial number: 3564VRB405R19PPQ7P1R
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LGR0001D
Coding: 0000FC
VCID: 3744AD2E86FD92FA38-8062
Subsystem 1 - Part No SW: 4H0 951 528 J HW: 4H0 951 528 J
Component: E221 - MFL H09 0009
Serial number: 13 06 2012 D1048508
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 830 L HW: 4H0 920 830 L
Component: TBenRDWACCNV- H71 0515
Revision: 35081077 Serial number: 658090712592013
Coding: 138708005740000E120200
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 2E6A884A71A753326B-807A
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0224
Serial number: 1120626000704
Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000679178
Coding: 00C1035C00
Shop #: WSC 15171 875 99782
ASAM Dataset: EV_GatewPkoUDS 001016
ROD: EV_GatewPKOUDS_VW51.rod
VCID: 72D25C3AA51F37D2CF-8026
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970869361
4906 - Power Steering Control Module
U101D 00 [009] - No Communication
Reset counter: 116
Mileage: 156732 km
Date: 2017.01.02
Time: 14:17:14
Voltage terminal 30: 14.4 V
Voltage terminal 15: 14.2 V
Control Module temperature: 35 캜
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 F HW: 8K0 857 511 A
Component: FLA H04 0020
Revision: AA001002
Coding: 04018B6B74745D545420363E00
VCID: 345E9A22978B79E21D-8060
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4H0 919 158 E HW: 4H0 919 158 E
Component: Klima Fond H16 0120
Coding: 3600000000
ROD: EV_AirCondiHeck_AU64.rod
VCID: 32529C3A659F77D20F-8066
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008002
ROD: EV_AirSuspe_VW51.rod
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000034377983
Coding: C018BF8085853201070001010101112131313333203333
VCID: 3558A7269CF160EA2A-8060
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA77005M80
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2_VW51.rod
VCID: 3744AD2E8EFD92FA38-8062
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000129580487
Coding: 011F1E005E0062C202083007
Shop #: WSC 02312 785 00200
VCID: 48A6DED2FB03ED0241-801C
Address 44: Steering Assist
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0179813081
Coding: 011E0E2000B9359FB330C7800E0301070000000000000000000000000000
Shop #: WSC 27032 123 104857
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 225400087678
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 N HW: 4H0 947 135 N
Component: Dachelektroni H11 0080
Serial number: A2012000000000602540
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 225400086874
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 225400087679
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 225400086879
Coding: 020200
Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84288005
03634 - Switch for Window Shade Illumination; Front
Fault Status: 00101100
Reset counter: 156
Mileage: 150135 km
Date: 2016.10.10
Time: 18:46:27
Part No SW: 4H0 035 465 B HW: 4H0 035 465 B
Component: BO G3 D4 H09 0170
Revision: 08S00000 Serial number: 0018465
VCID: 257877662C51106A9A-8070
Subsystem 1 - Part No SW: 4H0 035 466 HW: 4H0 035 466
Component: BO D4 SLAVE H51 0180
Serial number: 02606120020679
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 A HW: 4H0 959 860 A
Component: MEM-FS-Fond H06 0155
Revision: AA000000 Serial number: 00000031924528
Coding: C01892808500300D0B00392038193A2039203B3B202020
VCID: 32529C3A6D9F77D20F-8066
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000129410054
VCID: 3C4EB202BFDBB1A2D5-8068
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000423710
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B6C815E42B5261A4C-807E
721152 - Brake pad replacement mode active
C1011 00 [000] - -
Part No SW: 4H0 035 056 E HW: 4H0 035 056
Component: Radio U STD H60 0093
Revision: AB001007 Serial number: 231GZ0C7516393
Coding: 080003010003000001
VCID: 247E6A62276BE9628D-8070
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4H0 919 129 D HW: 4H0 919 129
Component: DMB-DTV H05 0520
Revision: R0050000 Serial number: 05300201285901
Coding: 1A0104
VCID: 2F54954E7EAD5A3A60-807A
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0155
Revision: AA000000 Serial number: 00000031924575
Coding: C01896808500300D0F00392038193A2039203B3B3B2020
03785 - Remote Control for Rest-Seat
Reset counter: 134
Mileage: 155449 km
Date: 2016.12.17
Time: 09:23:04
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 748 C HW: 4H0 035 748
Component: H-BN-KO H18 0553
Revision: -------- Serial number: K5FAN12VAGJP7
Coding: 040500000001F9EF65D4830600000003FD0001020000000000
VCID: 2A62845A454F3F12B7-807E
Subsystem 1 - Part No: 8R0 060 884 CD
Component: KOR-23.10.13. 7711
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300QZ56
Subsystem 3 - Part No SW: 4H1 919 600 J HW: 4H1 919 600 A
Component: E380 BDT D4 H09 0065
Serial number: 00000000087737
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Reset counter: 152
Mileage: 147605 km
Date: 2016.08.31
Time: 21:07:28
Text: DU903A,Right,M,0,0,6
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000129355676
Coding: 010F1E00420062C202083007
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0111
Revision: 11001001 Serial number: 82330JF0051724
Coding: 020B000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
ROD: EV_CamerSysteTopViewAUDI_005.rod
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 184200907
Coding: 0210044000
ROD: EV_DeckLidContrUnit.rod
VCID: 3D48BF06ACC1B8AAE2-8068
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000081488
Coding: 400000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63FC297E6AE5AE5AB4-8036
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000129355675
Address 7F: Inform. Electr. II (J829) Labels: None
Part No SW: 4H0 035 762 K HW: 4H0 035 762 K
Component: H-B-AS H44 0558
Revision: -------- Serial number: 187G/0C7501367
Coding: 04000000000100400140000400001300E20000000000000000
VCID: 2E6A884A79A753326B-807A
Subsystem 1 - Part No SW: 4H0 919 607 HW: 4H0 919 607
Component: DU10 RSE H41 0021
Serial number: AUZ8ZDC1200UEK
Subsystem 2 - Part No SW: 4H4 919 607 HW: 4H4 919 607
Serial number: AUZ8ZDC27007TK-
Subsystem 3 - Part No SW: 4H0 919 709 C HW: 4H0 919 709 C
Component: E499 BDT 2 H07 0019
Serial number: 90238LG20002E
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5014 Serial number: SN120612 0054
ROD: EV_GSM2x3Mono.rod
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0042
Serial number: 0K84AE40077988
Coding: 1200
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001218400012
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Revision: -------- Serial number: 262130025421000
Coding: E8040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 267A706A59571B7293-8072
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00006952036102
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F54954E76AD5A3A60-807A
Address 8A: Multicont. Seat Rear,DS (J875) Labels: None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00006527279601
Coding: 304F00
ASAM Dataset: EV_IVBDriveSideRear 001003
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Coding: 7404020201
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 28667E5253430D02A1-807C
Address 8D: Multicont. Seat Rear,PS (J874) Labels: None
Serial number: 00006954235102
Coding: 304F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052907127
Coding: 02A08A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 27647D6E5E5D027AA8-8072
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 00660600031F0376000308014248D2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3150933660994CCA76-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 06:49)--------------------------
Tuesday,04,February,2020,16:19:41:10438
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8K3DA176982 License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 1B 42 44 46 47 52 53 56 5F 62
72
VIN: WAUZZZ8K3DA176982 Mileage: 95980km-59639miles
1B-Active Steering -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (------CDNC) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0008
Revision: ECH09---
Coding: 0A250013242601022000
Shop #: WSC 44145 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115 001010
ROD: EV_ECM20TFS0118K5907115.rod
VCID: 6FBBD437471F801F20D-803A
4531 - Fan 1 Control Circuit
P0691 00 [047] - Short to GND
Mileage: 95983 km
Date: 2019.09.05
Time: 03:21:42
Coolant temperature: 36 °C
Intake air temperature: 27 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 11.520 V
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K2 927 156 G HW: 0B5 927 156 J
Component: 0B5 20TFSIRdW H01 0003
Revision: --H01---
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001010
ROD: EV_TCMDL501021.rod
VCID: 3A2D35634CDD15B7C73-806E
Part No SW: 8K0 907 379 CJ HW: 8K0 907 379 CJ
Component: ESP8 quattro H09 0100
Coding: 091504
Shop #: WSC 06325 123 12345
VCID: 035388877B17947FD45-8056
Reset counter: 46
Mileage: 95983 km
Date: 2019.09.05
Time: 03:24:40
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0010
Hex Value: 0x1099
Hex Value: 0x0000
Reset counter: 46
Mileage: 95983 km
Date: 2019.09.05
Time: 03:24:40
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x000A
Hex Value: 0xE399
Hex Value: 0x0000
Part No SW: 8K0 907 064 GR HW: 8K0 907 064 FR
Component: BCM2 2.0 H11 0621
Coding: 05B14040000000000000
VCID: 065591934825A157F3B-8052
Subsystem 1 - Part No SW: 8K0 959 754 A HW: 8K0 959 754 A
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0814000116473011
Part No SW: 8K2 820 043 S HW: 8K2 820 043 S
Revision: D0000000 Serial number: 01291120121911
Coding: 642462C000
VCID: 392F2A6F495B1EAFCE9-806C
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 45
Mileage: 95982 km
Date: 2019.08.22
Time: 20:31:42
Temperature: 20.0°C
Temperature: 31.0°C
Absolute Pres.: 0.8 bar
Current: 0.000 A
Temperature: 17.0°C
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00000518919001
Coding: 260000108034AFC00081400000001D0D0F1D430807010201000008004401030100000024000000
VCID: 77ABEC573FCFC8DFF8D-8022
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 261112 H06 0080
Serial number: SWF12110260147
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20775648
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002211121526
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: DAB98E56000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD970N9D
Coding: 30544435363030303030554A3052384B3053
VCID: 48C95FAB02317727417-801C
Serial number: 6334MSME734372368
Serial number: 6344MSME740265356
Serial number: 6352QSME33283866G
Serial number: 6362QSME252710588
Serial number: 63732SME1B264F40%
Serial number: 63832SME15263F6C7
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [136] - Open or Short to Plus
Mileage: 95982 km
Date: 2019.08.22
Time: 20:31:52
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20121129000786
Coding: 000036
VCID: 4FFB74B7E7DFA01F00D-801A
Component: E221 - MFL H03 0004
Part No SW: 8K0 920 931 P HW: 8K0 920 931 P
Component: KOMBIINSTR. H35 0556
Revision: 00000000 Serial number: UVL224UCD
Coding: B3A6090002010008010000
VCID: 3B23306743672CBFDC5-806E
Reset counter: 45
Mileage: 95982 km
Date: 2019.08.22
Time: 20:32:00
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y12B20028E
Coding: 80CF07FF00
VCID: 4ACD65A31CBD8537573-801E
Serial number: 0670688601
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 12325001445021200410
Reset counter: 45
Mileage: 95983 km
Date: 2019.08.25
Time: 04:59:52
Bin. Bits: 11111
Voltage: 13.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Fault Frequency: 12
Reset counter: 46
Mileage: 95983 km
Date: 2019.08.25
Time: 05:06:15
Bin. Bits: 10000
Voltage: 11.80 V
Count: 11
Reset counter: 46
Mileage: 95983 km
Date: 2019.09.05
Time: 04:26:59
Bin. Bits: 10111
Voltage: 11.50 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 1B: Active Steering
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C12204101410001
VCID: 56F581D3D805D1D7C3B-8002
Revision: 00002001 Serial number: 0187831675
Coding: 01000E2200B90005803001368000000F
Subsystem 1 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Reset counter: 85
Mileage: 95982 km
Date: 2019.08.22
Time: 20:32:11
Reset counter: 85
Mileage: 95982 km
Date: 2019.08.22
Time: 21:08:40
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813008418302
VCID: 2D070E3F8D13B20F521-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55F786DFC503DACFCA1-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000134316
ROD: EV_ParkiBrake_AU48.rod
VCID: 38292F6B72D107A7317-806C
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Reset counter: 85
Mileage: 95982 km
Date: 2019.08.24
Time: 19:30:12
Voltage terminal 30: 11.3 V
Internal Fault ID: 188
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
Part No SW: 4G1 035 053 G HW: 4G1 035 053
Component: Radio U Basic H41 0121
Revision: AB001007 Serial number: 227K30C7666425
Coding: 040003010000000001
VCID: 2313E807DBD7747FF45-8076
Part No SW: 8R2 035 754 B HW: 8R2 035 754 C
Component: H-BN-RW H45 0639
Revision: -------- Serial number: 210KZ0C7506843
Coding: 0F0A0100000681ED01808B4E00000403FC0000020000000000
VCID: 363521537845F1D723B-8062
Subsystem 1 - Part No: 8R0 060 884 AS
Component: ROW 2013 0506
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130KU0C2594070
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001347873
Component: CD-Database 4949
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C12204001210001
VCID: 59EF8AEFA91BFEAFEE9-800C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0304
End----(Elapsed Time: 01:39, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
