Please can you help or point me to an existing thread to reset the SRI on my T5.1 Transporter (UK Spec with Extended Service Interval)
VCDS 16.8.4 only gives me the options...
Reset ESI - North America Only
Reset FIX&ESI - North America only
I've done this before but I have forgotten the procedure, or was there an option in the drop-down menu for UK Spec vehicles like mine in a previous VCDS release?
Autoscan...
Channel Map -- Module 17...
Thanks for your time,
Rod
Autoscan...
Chassis Type: 7H (6N0)
Scan: 01 03 04 09 10 15 17 19 25 56 77 0B
VIN: WV1ZZZ7HZEH023513 Mileage: 67120km-41706miles
Address 01: Engine (J623-CFCA) Labels: 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GN HW: 03L 907 309 L
Component: R4 2,0L EDC H38 8379
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194010232400080000
Shop #: WSC 03282 002 1048576
ASAM Dataset: EV_ECM20BTD01103L906019GN 003006
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7DF5060EECF109AAA2-8028
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 908764AD89A6099826A79172B96110
Shop #: WSC 02736 790 49152
VCID: 3A7FCD12B55FFE92C7-806E
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 M HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0411
Revision: BO034001 Serial number: 0573 185130194
Coding: E0A0301A0A212031002808102C2B9CD00090432F60044000320000000000
Shop #: WSC 02736 790 12345
VCID: 3E77C102A977D2B2FB-806A
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 002 3313
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 002 3313
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32961317000944
Coding: 108001
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K.rod
VCID: 3A7FCD12BD5FFE92C7-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00JLXK5
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3565DE2E944111EA2A-8060
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 460A01
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 316DEA3E60293DCA76-8064
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BO034001
Coding: 042300
VCID: 70EB2F3AA3A374C239-8024
Component: IMMO H04 0710
VCID: 6ADF3D528D7F8E1277-803E
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2N1618299
Coding: 05000400020014
Shop #: WSC 02734 790 12345
VCID: 3361E03692350FDA04-8066
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007665092450
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 397DD21EB859F58ACE-806C
9458195 - Control Module for Cellular Telephone
B1052 13 [008] - Open Circuit
Reset counter: 171
Mileage: 24621 km
Date: 2015.05.04
Time: 14:13:53
End-------------------------(Elapsed Time: 02:47)--------------------------
;SW:7E0-920-970-J HW:7E0-920-970-J --- Instruments
;Component:KOMBI H04 0710 Coding:460A01
;EV_Kombi_UDS_VDD_RM09 A04723 EV_Kombi_UDS_VDD_RM09_VN35.rod
;Friday 30 December 2016 14:59:40:00103
;VCDS Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: 316DEA3E60293DCA76-8064
IDE00301-Distance 67120 km
IDE00342-ESI: Resetting ESI Warning active
IDE00343-Language version English
IDE00344-Seat belt warning Version 4
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level Oil level evaluation
IDE00492-MAS02003-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID ESI or SID on
IDE00492-MAS02006-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID Extended Service Intervals (ESI)
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure dynamic oil pressure
IDE00492-MAS02011-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver without remote clock receiver
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality good oil quality
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG Oil level thermal sensor connected to instrument cluster
IDE00493-Display correction of fuel gauge -1.5
IDE00499-Display correction of consumptions and operating range 100%
IDE00500-Hour 14 H
IDE00501-Minute 59 min
IDE00505-Speed threshold of dynamic oil pressure warning kein Offset
IDE00510-ESI: distance driven from inspection 33700 km
IDE00511-ESI: time from inspection 512 d
IDE00512-ESI: minimum value km-driving distance/inspection 20000 km
IDE00513-ESI: maximum value km-driving distance/inspection 40000 km
IDE00514-ESI: maximum value of time between inspections 744 d
IDE00515-ESI: oil quality good oil quality
IDE00517-ESI: soot entry 50000 km
IDE00518-ESI: thermal load 23400 km
IDE00711-Trip recorder not installed
IDE00714-MAS00888-Additional coding-Tank characteristic curve 1
IDE00714-MAS01209-Additional coding-Speed source via CAN
IDE00714-MAS01210-Additional coding-Coolant temperature source via CAN
IDE00714-MAS01211-Additional coding-Locking bit locked
IDE00714-MAS04066-Additional coding-Number of fuel level sensors 1
IDE00820-Activating and deactivating all development messages not active
IDE00827-ESI: minimum value of time between inspections 744 d
IDE02327-Indicator light for start-stop operation active
IDE02489-Display depiction Not available
IDE02494-Automatic door locking Yes
IDE03177-MAS02569-Acoustics for timeout signaling-All Wheel Control Not available
IDE03177-MAS02570-Acoustics for timeout signaling-Lock Electronics Not available
IDE03346-IDE00301-Units adjusted-Distance miles
IDE03346-IDE00316-Units adjusted-Time 24h
IDE03346-MAS01230-Units adjusted-Date dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed Miles per hour
IDE03346-MAS02201-Units adjusted-Temperature °C
IDE03346-MAS03032-Units adjusted-Volume gallons (UK)
IDE03346-MAS03033-Units adjusted-Consumption Miles per gallon (UK)
IDE03346-MAS03034-Units adjusted-Pressure bar
IDE03349-FIX: Max. distance until next mileage-related inspection 32200 km
IDE03350-FIX: Maximum time until next time-dependent inspection 730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection 33700 km
IDE03352-FIX: Time since last time-dependent inspection 513 d
IDE03481-MAS01632-Emergency telephone number-Status not active
IDE03481-MAS04225-Emergency telephone number-Preselection
IDE03481-MAS04226-Emergency telephone number-Telephone number
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time 10 s
IDE03568-ENG102019-Service-key settings-p_main_switch_basis On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed 20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time 40 s
IDE03568-ENG104099-Service-key settings-p_write_distance 20 km
IDE04848-Volume to be replenished No
IDE05583-Pause recommendation Yes
IDE05930-Service notification in days 20 d
IDE05931-FIX: Reset value for next mileage-dependent inspection 30000 km
IDE05932-FIX: Reset value for next time-dependent inspections 365 d
IDE06418-Light warning buzzer: condition Open
IDE07221-Cylinder shut-off No
IDE08753-IDE00837-MFA display cylinder shut down-Instantaneous consumption No
IDE08753-MAS03930-MFA display cylinder shut down-Average consumption No
IDE08753-MAS03934-MFA display cylinder shut down-Range No
IDE08753-MAS05871-MFA display cylinder shut down-Full engine operation No
IDE09257-Power steering Version 2
ENG112420-MAS03095-additional_adaption-Function status No
ENG112420-MAS03118-additional_adaption-Logic address 0
ENG112417-indicator_celebration not active
ENG108924-Service_Key_Clear_All_Counters Yes
ENG112416-IDE01766-velocity_detection-Distance impulses 4
ENG112416-MAS01209-velocity_detection-Speed source Distance impulses
Elapsed Time: 00:35
Rod
