Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Thread: OEM Bi Xenon Retrofit Golf 7 mk7 TDI
    Dec 2016
    So we have a 2015 Golf TDI base model that we would like to add the full function Bi Xenons to, including AFS and bend lighting. We installed the OEM headlights (used), all the wiring per ElsaWin diagrams, BCM (used) #5Q0937087S, as well as rear axle level sensor #5Q0512521E and headlight range control module (used) #7P6907357D. The daytime running light LED lights up correctly but only the left headlight and no high beam shutter function. Also with the upgraded BCM, non of the interior lights work any more. I am thinking that this is all coding although I Stand to be corrected. Any assistance with this would be very much appreciated. Find autoscan attached here with the upgraded modules and wiring in place. If you need the original autoscan let me know and I have that as well. (of note: I coppied the long coding from the original BCM and pasted it to the replacement BCM but still no interior lights or correct headlight function.)
    Wednesday,28,December,2016,11:25:09:54491
    VCDS Version: 16.8.2.3 (x64)
    Data version: 20160926 DS261.0
    VIN: 3VWRA7AU4FM012217   License Plate:
    Mileage: 85750km-53282mi   Repair Order: Vernon Nolt highline
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F 75
    VIN: 3VWRA7AU4FM012217   Mileage: 85750km-53282miles
    55-Headlight Range -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CRUA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 021 C    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 8412
       Revision: 85H23---
       Coding: 01190012032410080000
       Shop #: WSC 44642 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021C 001012
       ROD: EV_ECM20TDI01104L906021C.rod
       VCID: 254192032435DD6AE7-8070
    Readiness: 0 0 0 1 1
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 51534000001113
       Coding: 01FA6AA12421096E0079020181CA2580562490004081A4B200630050C002
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
       VCID: 44872F87CF4F0462D0-8010
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5G0 907 426 Q    HW: 5G0 907 426 Q
       Component: AC Manuell    H02 0907
       Revision: 00001K06
       Coding: 00020104200100000000000000000000
       ROD: EV_ACManueBHBVW37X_SK48.rod
       VCID: 39794E73B88D498AB3-806C
              B10CD 00 [008] -  -
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 20:17:54
                        Voltage terminal 30: 10.9 V
       Part No SW: 5Q0 937 087 S    HW: 5Q0 937 087 S
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86582111142168
       Coding: 03011E46424122FB49E44000000C07281800000000000000000000000000
       Shop #: WSC 00028 028 00066
       ROD: EV_BCMBOSCH_014_VW37.rod
       VCID: 4B9504BBE211CB1A11-801E
       Component: WWS    140528  043 0581
       Serial number:         140627183908
    17 Faults Found:
    533013 - Databus
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:32
    555797 - Databus
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:32
    538389 - Databus
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:32
    540693 - Databus
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:32
    6922 - Bulb for Low Beam Headlamp Right
              B1218 15 [009] - Open or Short to Plus
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:53:26
    460041 - Heated Rear Window
              B1265 14 [008] - Open or Short to Ground
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:51:47
    395273 - Control Circuit for Signal Horn
              B1344 14 [008] - Open or Short to Ground
                        Reset counter: 40
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 20:28:06
    15360768 - Component Protection
              U1101 00 [009] - Active
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:32
    934148 - No Communications with Rain/Light Sensor
              U10F6 00 [009] - -
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:33
    919810 - Dimmer Control for Instrument Panel Illumination
              B1201 21 [009] - Signal Amplitude Too Low
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:53:10
    939524 - No Communications with Humidity Sensor
              U10F5 00 [009] - -
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:36
    947204 - Control Module for Wiper Motor
              U10A3 00 [008] - No Communications
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 20:28:06
    132619 - Voltage Supply; Terminal 30; Right
              B140E 13 [008] - Open Circuit
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 20:28:06
    132363 - Voltage Supply; Terminal 30; Left
              B140D 13 [008] - Open Circuit
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:51:47
    133131 - Voltage Supply Terminal 30
              B1423 13 [008] - Open Circuit
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:51:47
    133387 - Voltage Supply; Terminal 30 for Central Locking
              B140F 13 [008] - Open Circuit
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 20:28:06
    133899 - Voltage Supply; Terminal 30 for Seat Heaters
              B1411 13 [009] - Open Circuit
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:07:34
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM00CRR1
       VCID: 51A916D3003DE1CA6B-8004
       Occupant Detection:
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  H05 0016
       Serial number: IBH0000J140000VAMU0Y
       Coding: 303338
       Subsystem 2 - Part No SW: -----------    HW: 480 002 904 14
       Serial number: 35700000000F55FCBF07
       Subsystem 3 - Part No SW: -----------    HW: 480 000 705 14
       Serial number: 358000000002F461BF0R
       Subsystem 4 - Part No SW: -----------    HW: 480 401 704 14
       Serial number: 3510002AB1529DF430B9
       Subsystem 5 - Part No SW: -----------    HW: 480 402 304 14
       Serial number: 3520002A7157E991C39D
       Subsystem 6 - Part No SW: -----------    HW: 480 400 205 14
       Serial number: 3550002BF157E995B17O
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 205 14
       Serial number: 3560002B715C4211A1D+
    9442836 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 14 [137] - Open or Short to Ground
                        Mileage: 85750 km
                        Date: 2016.12.07
                        Time: 22:34:30
       Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
       Revision: --------    Serial number: 20140826400751
       Coding: 0400
       ASAM Dataset: EV_SMLSVALEOMQB 001010
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3C775767B7BF7CA2A8-8068
       Part No SW: 5G1 920 841     HW: 5G1 920 841
       Component: KOMBI         243 4270
       Coding: 0BB41A022180CF05020868001000000000000000
       Shop #: WSC 00066 790 00221
       VCID: 65C1D20364B51D6A27-8030
    13639936 - Databus
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.07
                        Time: 05:53:22
       Part No SW: 5Q0 907 530 S    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2186
       Revision: --------    Serial number: 13061410000526
       Coding: 0101000800087300EF000008080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07025
       ROD: EV_GatewConti_011.rod
       VCID: 41892693D05D114AFB-8014
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
       Component: E221__MFL-DC1  H14 0101
       Serial number: 29140000815270014193
       Coding: 28FFFF
    131598 - Body Control Module (Central Electric)
              U0140 00 [008] - No Communications
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.26
                        Time: 19:47:31
                        Terminal 15: OFF
    131668 - Headlight Range Control Module
              U101E 00 [009] - No Communication
                        Fault Frequency: 11
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.08
                        Time: 01:15:44
                        Supply voltage: Terminal 30: 12.6 V
                        Terminal 15: On
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.08
                        Time: 01:12:40
                        Terminal 15: On
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 08061406050535
       Coding: 003003200000040000000000
       VCID: 3E735D6FA1A36EB286-806A
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000002833084
       Coding: 011000
       Coding: 0102
       ROD: EV_SteerAssisMQB_010.rod
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 090614060503R1
       VCID: 3D715A63ACA575AA9F-8068
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000002671145
       Coding: 191000
    Address 55: Headlight Range
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     013 0645
       Serial number: V7B00905142012
       Coding: 02730000FF00000021220001001800001F0100040100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 64C7CF076F8F646230-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS50076E
              B11CF 53 [009] - Deactivated
                        Reset counter: 90
                        Mileage: 80335 km
                        Date: 2016.09.16
                        Time: 15:03:57
                        Voltage terminal 30: 12.0 V
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Part No SW: 5QE 035 285     HW: 5QE 035 285
       Component: OCULowMQBUS   006 0528
       Shop #: WSC 00066 790 00020
       ROD: EV_OCULowMQB.rod
       VCID: 020BE99F95DBCA52A2-8056
    End-------------------------(Elapsed Time: 03:16)--------------------------
  2. Likes Boki Ar liked this post
  3. #2
    GMD8085: Hmm......... sounds like a fun project and I suspect that there are multiple issues that will need to be progressed before getting all of the retrofit problems resolved!
    Here are a few suggestions that you might consider - perhaps:
    Headlight Range (address 55) - has this new module been correctly introduced to the CAN Gateway list?
    BCM (address 09) The component protection error is a complicating DTC that is likely masking the true underlying problems with the project (the CP error in the CAN Gateway @ address hex19 is the mirror DTC for the BCM error). Alas there is only one way to clear CP errors - the car must be connected to VW's FAZIT database, which can only be done by a registered VW agent. After CP has been cleared, a new (hopefully, reduced-in-number) base-level set of DTC s can be established for subsequent resolution. Currently, CP is probably complicating the real problems in the auto-scan report, so CP error deletion first - I think.
    I note that Byte 6, Bit 5-6 has a value of binary 01 - this is a Xenon setting which is a good start (it confirms that the BCM has Xenon capability)
    I assume that the BCM has the Xenon value for Byte 6 from the original car - so I would have expected that the Leuchte-sets for the High/low beam lamps would also have been pre-established in the module when you retro-fitted the unit. Nevertheless, it might be prudent to check these Leuchte-sets. Here are the Leuchte-set values for the Main-beam and low-beam lamps from a 2015 S 1.8TSI /5MT -Sunroof, Bi-Xenon, PDC mk7 - NAR model which has the following BCM details (it's the closest BCM that I could find in my database to the unit in your auto-scan)
    ;SW:5Q0-937-087-R   HW:5Q0-937-087-R ---  Cent. Elect.
    ;Component:BCM PQ37BOSCH 028 0145
    ;EV_BodyContrModul1UDSBosc
    (1)-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter; Diagnosesensierung für 'LED low'
    (2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
    (3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
    (4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
    (5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
    (6)-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
    (7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
    (1)-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter; Diagnosesensierung für 'LED low'
    (2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
    (3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
    (4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
    (5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
    (6)-Leuchte11SHUTTER RB22-Dimmwert AB 11	127
    (1)-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
    (2)-Leuchte6ABL LC5-Lampendefektbitposition 6	36
    (3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
    (4)-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
    (5)-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
    (6)-Leuchte6ABL LC5-Dimmwert AB 6	127
    (7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
    (1)-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
    (2)-Leuchte7ABL RB1-Lampendefektbitposition 7	40
    (3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
    (4)-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
    (5)-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
    (6)-Leuchte7ABL RB1-Dimmwert AB 7	127
    (7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
    I'm sure others may have additional suggestions - it might also be helpful to post-up the admaps for the retrofitted modules- perhaps?
    EDIT: M87a - sorry I wasn't finished editing my reply before you posted
  4. Likes m87a liked this post
  5. #3
    Jan 2015
    Bosnia and Herzegovina
    interior light will not work, you need to visit dealer to remove component protection, other stuff will need to be addressed after this
  6. Likes DV52 liked this post
  7. #4
    Dec 2016
    Thank-you very much for the recommendations on this. I know that it will be some process to get this to all work out. We are actually in the process of getting the ability to resolve component protection in house. I expected this issue. I will check the settings that are in the BCM per your recommendations BV52.
  8. #5
    Dec 2016
    Kuddos to DV52!! These were all set to "not installed" or "inactive":
    After changing the settings to your recommendation, the shutter now works on the left light. I still get nothing out of the right hand light except for the turn signal. I will recheck the wiring. Even so, it is progress thus far! Cannot thank you enough!!!
  9. #6
    Dec 2016
    I do not know german so that complicates this more but this car does not have a rain sensor. I am guessing the car that this BCM came from did. Do you know what line i need to change to "remove" the rain senor? Also since recoding it, now I get these headlight related faults (edited out the component protection DTC):
    Thursday,29,December,2016,10:09:43:54491
    VCDS Version: Release 16.8.4 (x64) Running on Windows 8.1 x64
                    Address 09: Cent. Elect.       Labels: NONE
    Control Module Part Number: 5Q0 937 087 S    HW: 5Q0 937 087 S
      Component and/or Version: BCM PQ37BOSCH 028 0145
               Software Coding: 000008424041804169E44000000403001000000000000000000000000000
                Work Shop Code: WSC 00028 028 00066
                  ASAM Dataset: EV_BodyContrModul1UDSBosc 014004 (VW37)
                           ROD: EV_BCMBOSCH_014.rod
                          VCID: 4B9504BBE211CB1A6C-801E
    6666 - Bulb for Low Beam Headlamp Left
              B1217 15 [008] - Open or Short to Plus
                        Reset counter: 226
                        Mileage: 85750 km
                        Date: 2016.12.27
                        Time: 18:15:47
                        Reset counter: 186
                        Mileage: 85750 km
                        Date: 2016.12.27
                        Time: 18:14:37
    Could this have to do with using the "long coding" from the original low line BCM?
  10. #7
    Dec 2016
    I did add Headlight Range-55 to the installation list in the can gateway but still no communication with it. I also verified the wiring to it and that seems to be correct.
  11. #8
    Dec 2016
    Here is the info from the Can Gateway:
    Thursday,29,December,2016,11:20:46:54491
    Control Module Part Number: 5Q0 907 530 S
      Component and/or Version: GW MQB Mid    211 2186
               Software Coding: 0101000800087300EF000008080F00000001050000000000000000000000
                Work Shop Code: WSC 00066
                          VCID: 41892693D05D114A86-8014
    Advanced Identification/FAZIT
         Identification: 8PO-CGQ
         Revision: --------
         Date: 13.06.14
         Manufacturer number: 1000
         Test stand number: 0526
    Flash Status
         Programming Attempts(application): 0/0
         Programming Attempts(data): 1
         Successful Attempts(data): 1
         Flash Date: 00.00.00
         Flash Tool Code(data): 07025 790 00066
    Misc.
         Hardware number: 5Q0 907 530 L
         Workshop System Name: J533
         Equipment/PR Code: FFFFFFFFFFFFFFFF
         Dataset Number: 5G0067v____
         Dataset Version: 1821
         ASAM Dataset Revision: 011017
    Car Info
         Chassis Number: 3VWRA7AU4FM012217
    VCDS Info:
  12. #9
    Quote Originally Posted by GDM8085 View Post
    Check the bulb type specified in the Leuchte adaptation channels for the low beam headlights, I suspect it's expecting a 55W bulb but there is now a Xenon igniter instead...
  13. #10
    Dec 2016
    Do you happen to which "Leuchte adaptation channel" i need to change? There are probably over 50 listed in this module. Some seem to apply and some seem not to apply.
