Let me see if I can provide any info, found you via tdiforums, MKVI section.
My car, 2010 Golf Canada
Address 09: Cent. Elect. (J519) Labels:
Part No SW: 1K0 937 086 E HW: 1K0 937 086 E
Component: PQ35 M 103 0575
Revision: 00103 AG
Coding: 6D180A3E90272AC480080081540089EC47250486524D8560E48420240000
Shop #: 01357 011
00200
VCID: 3245F82B6D001C8E5D3-8067
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 03021 21 0512
Coding: 009795
I have Kufatec adapters, de-pinned 11 cause using pin8 from halogen (10pin) as headlight shutter cause of mid-line
factory euro switch (non-auto, with rear fog)
I did not do the pin10+12 bridge, no need if you repin/adapters is correct .
Set the light scheme to , Byte18 to 04
I have the same options as you set as you mentioned. Added some screenshots of some other bytes.
Everything worked pretty much bang on, that simple. The rear-fog gave some slight issue but you don't have that. was far more time consuming then figuring out DRL.
No changes to any plug wiring (exclude rear-fog). It honestly sounds like your checking with the e-brake on? DRL will be off if engine on or off and e-brake on (i have a 6speed).
