Looking for some help with my recent Xenon retrofit onto my JSW. Everything is working great except for the LED DRL's on the headlights. I've tried numerous byte 18 setups and the only functionality I can get out of the LED DRL's is using:
HEX 04 (L/H side lights up but turns off when engine is started)
HEX 20 (Both light up but turn off when engine starts)
HEX 21 (Both light up but turn off when engine is started)
I also installed OEM fog lights wired to the CECM which work great along with a euro switch. AFS is installed as well and functions fine as you can see in my scan below. I used the wiring diagram posted HERE as well as many other posts on the web. My initial guess is that this is a wiring issue but I wanted to eliminate coding before I mess with my harness. Continuity is good according to the diagram, but I've read that certain wires for the DRL going to the 14 pin plugs may not be the same if the car diddnt have rear fogs? Any help is appreciated.
Friday,23,December,2016,17:27:46:38490
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
VIN: 3VWPL7AJ5CM619441 License Plate:
Mileage: 159430km-99065mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 62 72
77
VIN: 3VWPL7AJ5CM619441 Mileage: 159430km-99065miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 HG HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 8178
Revision: 12H14--- Serial number:
Coding: 0050078
VCID: 77D3063B065B1EFAF8-8022
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2705
Revision: 05351113 Serial number: 00001106200150
VCID: 171326BB261BFEFA18-8042
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C49230003880F06E8921A0042B70000
Shop #: WSC 00066 123 12345
VCID: 7BDB1A0BFA733A9A9C-802E
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000001002
Shop #: WSC 00066 000 00118
VCID: 00216DE79B955942C9-8054
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 G HW: 5K0 937 087 G
Component: BCM PQ35 H+ 111 1129
Revision: BL111001
Coding: 2F380E1A802F3EC400480081700089EC48254F48535D0560E48060240040
Shop #: WSC 18752 008 00032
VCID: 3957C003B0CFC88ACE-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 16081 26 0512
Coding: 009795
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA08FL2
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FA3AE1BA6EBE6BAF0-806A
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--000618GZ00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME5C6F6161ZZZ2
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME62022261ZZZF
Serial number: 3511HSME3A002E28ZZZK
Serial number: 3521HSME6C242E28ZZZW
Component: F.Sens.Fahr --- ----
Serial number: 35527SME0240532BZZZ3
Component: F.Sens.Beif --- ----
Serial number: 35627SME6A086E2BZZZY
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KG4000FS
Coding: 188A140000
Shop #: WSC 00066 000 00187
ROD: EV_SMLSNGKUDS_VW32.rod
VCID: 76CD0B3FC95167F2E3-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0447871
Coding: 820000
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H03 0607
Coding: 270F01
VCID: 3041FD276BB509C279-8064
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 29071101270292
Coding: 352002
VCID: 354FCC339CD72CEA2A-8060
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RDSRE06
VCID: 7EDD131F29612FB2BB-802A
Component: IMMO H03 0607
VCID: 6AF52F4F8DE9B31277-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660294098
VCID: 29771043406F780ABE-807C
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0002634910
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 5B9B7A8B52B3DA9AFC-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1509
Serial number: 00000005767035
Coding: 000490
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3449F13757AD35E21D-8060
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0002637143
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 5C99799757BDDDA2F5-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1509
Serial number: 00000005793409
Coding: 000490
Component: AFS-Steuergeraet 0148
Coding: 1446940
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3193030
Coding: 01000400040007
VCID: 63EB426B62C3E25AB4-8036
Reset counter: 242
Mileage: 159434 km
Date: 2016.12.23
Time: 16:23:08
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660296806
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 354FCC3394D72CEA2A-8060
End-------------------------(Elapsed Time: 02:12)--------------------------
