Sharan (7N) BF/BE Automatic sliding door Basic Settings
DrPeter
16.4905° S, 151.7375° W
This procedure below was recently requested by a Ross-Tech customer, I would like to post it up here for some feedback.
Let me know if this did work or if it did not work and where in the procedure was the issue.
Thanks....
drpeter
Prerequisites:
- The power windows must be adapted.
- Factory mode must be deactivated.
(Check Measuring Value Blocks - Factory Mode Adaptation)
- No crash message can present in [Slid. Door Rear] controller
(Check Measuring Value Blocks - Operation Mode)
- Must display = "No crash message present"
* Note: If a crash message is stored, proceed as follows:
- Reset the sliding door control module by removing the sliding door controller fuse for at least 30 seconds. (See repair manual)
- Then turn ignition on, and manually open and close the sliding door.
- Then trun ignition off and on again.
Reset Normalization
Select: [BE-Slid. Door Rear Left] or [BF-Slid. Door Rear Right]
Select: [Basic Settings-04]
From the pull-down menu choose:
[Resetting standardization] - Press [Start] - wait for "Finished Correctly", then Press [Stop]
then
[Resetting of all adaptation values] - Press [Start] - wait for "Finished Correctly", then Press [Stop]
Next:
- Open the sliding door via the switch in the middle of the console.
- If the door is open, close the door via the switch in the middle of the console and then open the sliding door via the switch in the middle of the console.
The basic setting of the sliding door should be complete.
Galee
U.K.
C?ID=207647
Thanks....
drpeter
Hi Drpeter I know old post but I needed to use the procedure today on U.K, spec Vw sharan 2012 63 Plate with O/S electric door fault. When the controller was unpluged and plugged in all functions for door is disabled and electric door switches flashing , also when you press the buttons to open the door there is no response. But after the procedure was preformed all function for sliding door working again after clearing all codes out.
Thanks for posting it
Svein Arne
Norway
C?ID=326262
Hi, my Sharan 2011 have been exposed to some cold Norwegian winter days up in the mountain, and I do have exactly the same problem as Mr Galee. There seems to be nothing wrong, except that the lights are flashing, and the doors does not operate automatically. Both doors can be manually operated.
I have just bought a HEX-V2, and must admit that I am a beginner when it comes to this type of work. Is this something I can fix myself?
If yes, I would need a “step be step” procedure for beginners.
I have hooked up the HEX-V2 to the car, OK, but is seems like the “Basic Settings” button for the doors are not active.
Help will be very much appreciated :-)
Please post an Auto-Scan so people can see exactly how the vehicle is equipped, configured, and what (if any) faults are present.
Svein Arne
Norway
C?ID=326262
Wednesday,14,February,2018,19:59:27:41746
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
Gateway Installation List: 7N0 907 530 D
BE-Slid. Door Rear Left -- Status: Malfunction 0010
BF-Slid. Door Rear Right -- Status: Malfunction 0010
^^^^ A valiant attempt. But that's only the Gateway Installation List, not the whole scan. ;)
Svein Arne
Norway
C?ID=326262
Sorry, I was a bit too quick :-)
Hope this will do:
Thursday,15,February,2018,16:53:30:41746
VIN: WVWZZZ7NZBV038084   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 2E 36 37 42 44 46
          4F 52 53 55 56 61 62 69 6C 6D 72 BE BF
VIN: WVWZZZ7NZBV038084   Mileage: 143130km-88936miles
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H24 9979
   Revision: 44H24---    Serial number:
   Coding: 001D003A043401080000
   Shop #: WSC 00790 218 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003014
   ROD: EV_ECM20TDI01103L906018HJ.rod
   VCID: 79AF10BCC95363EF2FB-802C
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
4891 - EGR Valve (N18)
          P0403 00 [032] - Malfunction
   Part No SW: 02E 300 054 Q    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2602
   Revision: 06351113    Serial number: 00001104061021
   Shop #: WSC 00020 000 90108
   VCID: 241111C812D1CE072CD-8070
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
   Component: J104   C3 450M VDF6 0009
   Revision: --H07---    Serial number: 00000004054445
   Coding: 0031514
   Shop #: WSC 00020 790 00000
   VCID: 372BD684B347B59F99F-8062
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
   Revision: 00085000    Serial number: 0145182623
   Coding: 03100C
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_KESSYPQ35G A02014
   VCID: 3431E188AEB15E87BCD-8060
          U1400 00 [008] - -
                    Reset counter: 26
                    Mileage: 143009 km
                    Date: 2018.02.06
                    Time: 16:30:26
   Part No SW: 5K0 907 044 G    HW: 5K0 907 044 G
   Component: Clima-Sharan  H11 0104
   Coding: 0000000109
   Shop #: WSC 16530 000 1048576
   VCID: 2F3BEEE447977D5FC1F-807A
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 B    HW: 7N0 907 049 B
   Component: KBT-H  004 0102
   Serial number: 20110826000000035956
   Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
   Component: BCM PQ35 H    011 0048
   Revision: BE011001
   Coding: 40590A3B89251AC0500800C0740009E443551408676D2DF2E4808720A2C1
   VCID: 3FDBBEA497778DDF51F-806A
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110325  31  0032
   Serial number:         110416045925
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y11M04D04h18m30s47S1
   Coding: 0380BB
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 242
                    Mileage: 143113 km
                    Date: 2012.07.01
                    Time: 00:00:07
                        Term 15 Off
                    Voltage: 12.40 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20401109500158
   Coding: 31830D
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C21C9A886E196C774D-8068
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag018 H07 0013
   Serial number: 003GFP7921PH
   Coding: 003138
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E25C3A090FD84D75A9-806A
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS602EB5E9139D5
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS60C3AFEF13DDF
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS60FE3BEA13DDE
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60416DE6139DV
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS60239FF7139DS
   Part No SW: 5K0 953 501 BM    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20110412301085
   Coding: 1112240000
   VCID: 76B51B80F84D0C97429-8022
   Coding: E30000
   Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
   Component: KOMBI         H20 0430
   Coding: 140F00
   VCID: 3039ED985AA962A7D85-8064
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 C
   Component: Zuheizer        051 2730
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   VCID: 3431E188A2315E87BCD-8060
00664 - Fuel gauge
                    Reset counter: 10
                    Mileage: 141845 km
                    Date: 2012.05.17
                    Time: 16:08:16
01444 - Under-Voltage Shut-Off (Automatic)
            000 -  -  - Intermittent
                    Reset counter: 25
                    Mileage: 141873 km
                    Date: 2012.05.18
                    Time: 08:45:54
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 140411F1003003
   Coding: 468002
   VCID: 313FE89C51236BAFD7B-8064
   Component: IMMO          H20 0430
   Coding: 000007
   VCID: 6A8D3FF0BCF5D877D61-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 138018 km
                    Date: 2017.09.29
                    Time: 12:28:54
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000093727002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E05F3E0409D7457CA9-807A
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669802245
   Coding: 020000
   VCID: 280905F862F92A67005-807C
                    Reset counter: 31
                    Mileage: 143137 km
                    Date: 2012.07.06
                    Time: 21:33:22
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2301
   Revision: 00H05000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 3333E294AB3F59BFA57-8066
                    Reset counter: 17
                    Mileage: 142202 km
                    Date: 2012.05.24
                    Time: 14:46:56
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 249
                    Mileage: 141468 km
                    Date: 2012.05.17
                    Time: 10:33:52
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2L3328497
   Coding: 040004210400000000021000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 60995DD84AC99227085-8034
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000114798124
   Coding: 01153E20DE00411001
   VCID: 44D1B148FE91EE070CD-8010
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.325 0802
   Revision: 1AH03729    Serial number: 00110890064501
   Coding: 0000258
   VCID: 3B23CAB48F6F91FF7D7-806E
                    Reset counter: 26
                    Voltage: 0.30 V
                    Voltage: 6.30 V
                    Voltage: 2.60 V
                        Not Occup.
                        Not Occup.
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FBB2EE487973D5F81F-803A
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000114406691
   VCID: 43D3B254FB9FE93F357-8016
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000293362
   Coding: 0024067
   VCID: 3333E294A73F59BFA57-8066
   Part No SW: 5M0 907 357 D    HW: 5M0 907 357 D
   Component: AFS-Steuergeraet    0149
   Coding: 3555545
   VCID: 3537DC8CA94B478F8B3-8060
   Subsystem 1 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0001
   Coding: 00000054
   Subsystem 2 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0001
   Coding: 00000054
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71BF289C91A32BAF97B-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370326296
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 F    HW: 7N0 959 795 B
   Component: TSG HL        H03 0403
   Revision:             Serial number: 0000114599841
   Coding: 01007C200000411001
   Shop #: WSC 02196 002 1048576
   VCID: 46D5AB40C8ADDC17129-8012
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000147036450
   Coding: 410C040001000000
   VCID: 73B32294EBBF19BF657-8026
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H09000    Serial number: 525 PA8J122137
   Coding: 0030011
   VCID: 6E8533E08C9D34578A9-803A
                    Reset counter: 26
                    Mileage: 143009 km
                    Date: 2012.06.29
                    Time: 16:30:18
                        Reverse OFF
                    Count: 3
   Part No SW: 7N0 959 107 B    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0803
   Revision: 41011001    Serial number: 094100437
   Coding: 0733334003
   ASAM Dataset: EV_HDSGVW428 201133
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3635DB80B8CD4C97829-8062
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H03 0403
   Revision:             Serial number: 0000114603887
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 11101216
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 3829D5B8B2D9BAE7905-806C
52496 - Motor for Rear Window Regulator
          B11EE 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 246
                    Mileage: 143137 km
                    Date: 2018.02.13
                    Time: 23:09:53
                    Voltage terminal 30: 14.7 V
                    Sliding_Door_Motor_Current: 0.0 A
                    Sliding_Door_Clutch_Current: 0 A
                    Sliding_Door_Locking_Pawl_Motor_Current: 0 A
                    Front button for automatic sliding door: not activated
                    Rear button for automatic sliding door: not activated
                    Installed on left side: Yes
                    Installed on right side: No
                    Pinch protection sensor: not activated
                    Latch_Ajar: operated
                    Latch_Pawl: operated
                    Sliding door indicator lamp: active
                    Sliding door indicator lamp 2: active
                    Activation: motor for automatic sliding door: not active
                    Automatic sliding door coupling motor activation: not active
                    Motor activation for enabling ratchet release: not active
                    Sliding_Door_Feedback_Motor_Opening: not active
                    Sliding_Door_Feedback_Motor_Closing: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: not active
                    Sliding_Door_Feedback_Clutch_In: not active
                    Sliding_Door_Feedback_Clutch_Out: not active
                    Sliding_Door_Feedback_Indicator_Light_Front: active
                    Sliding_Door_Feedback_Indicator_Light_Rear: active
                    AD-Value clamping_Protection_Seal: 100
                    Position of automatic sliding door: 0
                    Status_Sliding_Door: latch secondary position
                    Play protection: motor for automatic sliding door: not active
                    Play protection: motor for enabling ratchet release: not active
                    Play protection: automatic sliding door coupling motor: not active
                    Status_Locking_Pawl_Motor: closed
                    Status_Clutch_Motor: closed
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 11101186
   ROD: EV_AST.rod
                    Reset counter: 0
                    Time: 00:00:00
                    Voltage terminal 30: 12.4 V
                    Installed on left side: No
                    Installed on right side: Yes
                    Latch_Ajar: not activated
                    Sliding door indicator lamp: not active
                    Sliding door indicator lamp 2: not active
                    Sliding_Door_Feedback_Indicator_Light_Front: not active
                    Sliding_Door_Feedback_Indicator_Light_Rear: not active
                    AD-Value clamping_Protection_Seal: 99
End----------(Elapsed Time: 02:06, VBatt start/end: 14.8V/14.7V)-----------
OK, now that we can see the details of the sliding door modules, I'm scratching my head as to why the Basic Settings button would not be active. The Basic Settings mentioned in Post #1 of this thread should be available.
Svein Arne
Norway
C?ID=326262
view
This is how my screen looks (if the link is working)
How did you get to to Address 78? It doesn't exist in your Auto-Scan.
Try addresses BE and BF please.
Svein Arne
Norway
C?ID=326262
OK, I used BF and BE and found the Basic Setting Buttons to be active. I have now followed the procedure to my best knowledge, but the situation is still the same, flashing lights, and the doors does not operate.
I have performed a new scan, can you read anything out of it?
Thursday,15,February,2018,19:21:14:41746
          P1570 00 [032] - -
   Component: J104   C3 450M VDF7 0009
   Coding: 0031514
   Coding: 03100C
          U1400 00 [008] - -
                    Reset counter: 26
                    Mileage: 143009 km
                    Date: 2018.02.06
                    Time: 16:30:26
   Coding: 0000000109
   Slave 1:
   Revision: BE011001
   Coding: 004DBD
   Coding: 0380BB
                    Reset counter: 242
                    Mileage: 143113 km
                    Date: 2012.07.01
                    Time: 00:00:07
                        Term 15 Off
                    Voltage: 12.40 V
   Coding: 31830D
   Coding: 003138
   Coding: 1112240000
   Coding: E30000
   Coding: 140F00
   Coding: 0000041
00664 - Fuel gauge
                    Reset counter: 10
                    Mileage: 141845 km
                    Date: 2012.05.17
                    Time: 16:08:16
                    Reset counter: 25
                    Mileage: 141873 km
                    Date: 2012.05.18
                    Time: 08:45:54
   Coding: 468002
   Coding: 000007
9456681 - Key
                    Mileage: 138018 km
                    Date: 2017.09.29
                    Time: 12:28:54
   Coding: 020000
                    Reset counter: 31
                    Mileage: 143137 km
                    Date: 2012.07.06
                    Time: 21:33:22
   Revision: 00H05000
   Coding: 000018
                    Reset counter: 17
                    Mileage: 142202 km
                    Date: 2012.05.24
                    Time: 14:46:56
                    Reset counter: 249
                    Mileage: 141468 km
                    Date: 2012.05.17
                    Time: 10:33:52
   Coding: 0000258
                    Reset counter: 26
                    Voltage: 0.30 V
                    Voltage: 6.30 V
                    Voltage: 2.60 V
                        Not Occup.
                        Not Occup.
   Coding: 050B0500
   Coding: 0024067
   Coding: 3555545
   Coding: 00000054
   Coding: 00000054
   Coding: 030B185A
   Coding: 0030011
                    Reset counter: 26
                    Mileage: 143009 km
                    Date: 2012.06.29
                    Time: 16:30:18
                        Reverse OFF
                    Count: 3
   Coding: 0733334003
   ROD: EV_AST.rod
                    Reset counter: 246
                    Mileage: 143137 km
                    Date: 2018.02.13
                    Time: 23:09:53
   ROD: EV_AST.rod
                    Reset counter: 0
                    Time: 00:00:00
End----------(Elapsed Time: 02:05, VBatt start/end: 14.3V/14.3V)-----------
Svein Arne
Norway
C?ID=326262
Hi, I was hoping to get this fixed before the weeekend.
I have followed the procedure to reset the system, but nothing seem to be changed (ref above Scan).
Is there something else I can do to sort out the problem?
Svein Arne
Norway
C?ID=326262
Hi, I have just bought a HEX-V2.
Can anyone please explain a bit more in detail, how I perform tne "Prerequisites:" in the above procedure?
I have done the "Reset Normalization" part, but my electric door problem remains the same.
Guidance will be highly appreciated :-)
Sadly, the Sharan is not available at all on this side of the pond, nor am I aware of anyone who works closely with Ross-Tech on the other side that has one, hence the procedure was posted here looking for feedback, and it's a bit difficult for us to give you anything based on actual, hands-on experience.
Svein Arne
Norway
C?ID=326262
OK, problem fixed :-) I accidentally operated the electrical WINDOW for the back door, and suddenly also the electric sliding door "realized" that it was back in "Basic Settings" and could be operated, so for now everything is fine :-)
JonneH
C?ID=287892
Hello, I quess this thread is closest to my problem.
So, I have an alhambra 2012, with electric sliding doors, the left side one is not functioning, I do not seem to get any obvious fault out of it, could you have an idea where to look at?
According to this thread I did perform the reset and they went through, still my problem is as it has been all the time, the sliding door buttons keep on flashing, and does not function.
Also the sliding doorelectric mirror does not operate, would this be to the same reason?
Sunday,20,December,2020,21:39:50:43954
VCDS Version: 20.4.2.0
VIN: VSSZZZ7NZCV509575   License Plate: ZJL-851
Mileage: 223130km-138646mi   Repair Order:
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 4F 52 53
          55 56 61 62 69 6D 72 77 BE BF
VIN: VSSZZZ7NZCV509575   Mileage: 223130km-138646miles
42-Door Elect, Driver -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Sporadic communication error 1000
BF-Slid. Door Rear Right -- Status: OK 0000
   Part No SW: 03L 906 018 HM    HW: 03L 906 018 M
   Component: R4 2.0l TDI   H26 9979
   Revision: 44H26---    Serial number:
   Shop #: WSC 11800 205 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HM 003012
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 7CF6710DF740D5664F-8028
   Part No SW: 02E 300 054 S    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2701
   Revision: 05351113    Serial number: 00001109281650
   VCID: 26427365914CBFB649-8072
   Part No SW: 7N0 614 109 N    HW: 7N0 614 109 N
   Component: J104   C3 450M VDED 0021
   Revision: --H07---    Serial number: 00000004856840
   Coding: 0027518
   VCID: 387EAD1D4BF83946EB-806C
02214 - Tire Pressure Warning
                    Fault Frequency: 70
                    Reset counter: 11
                    Mileage: 222100 km
                    Date: 2015.03.09
                    Time: 14:04:12
                    Speed: 50.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.75 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 FN    HW: 5K0 907 044 FN
   Component: Clima-Sharan  H18 0204
   Revision: 00001003
   Coding: 0200104509
   Slave 1:
   Serial number: 20111007000000042131
6 Faults Found:
9601321 - Humidity sensor
          B1281 29 [008] - Signal Implausible
                    Reset counter: 239
                    Mileage: 221310 km
                    Date: 2020.08.04
                    Time: 16:27:36
13701488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 19
                    Mileage: 222346 km
                    Date: 2020.11.18
                    Time: 20:09:20
13701504 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 19
                    Mileage: 222346 km
                    Date: 2020.11.18
                    Time: 20:09:23
13701520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 202
                    Reset counter: 237
                    Mileage: 221632 km
                    Date: 2020.09.04
                    Time: 16:54:44
13701536 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 19
                    Mileage: 222346 km
                    Date: 2020.11.18
                    Time: 20:09:23
          B10AB F0 [009] - Too Low
                    Reset counter: 164
                    Mileage: 218995 km
                    Date: 2019.12.16
                    Time: 19:55:17
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0048
   Revision: BC011001
   Coding: 40590A3B89251AC0500800C0540089E443559388626D2D626484C72000C1
   Shop #: WSC 00020 790 12345
   VCID: 3B74B211BACE125E06-806E
   Component: WWS    110925  31  0032
   Serial number:         111007193025
   Coding: 004DBD
   Serial number: Y11M10D11h01m34s58S1
   Coding: 0280DD
                    Reset counter: 237
                    Mileage: 223139 km
                    Date: 2015.05.13
                    Time: 20:58:09
                    Voltage: 11.95 V
                    Reset counter: 237
                    Mileage: 223139 km
                    Date: 2015.05.13
                    Time: 20:38:32
                    Voltage: 12.20 V
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261128401065
   Coding: 16830A
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: 4486C9EDCF306DA677-8010
   Component: VW10Airbag01X H07 0013
   Serial number: 003GFPM6A6Z9
   Coding: 003158
   VCID: 3E72BB05A1DC077621-806A
   Serial number: 3493ETS604E06F314DD/
   Serial number: 3503ETS60E971EC14DD4
   Serial number: 3513ETS605F31F214DDW
   Serial number: 3523ETS60B227EC149D-
   Serial number: 35540TS600AA2E514DDN
   Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20111010301151
   Coding: 199A240000
   VCID: 6ADA47558DD45BD6AD-803E
   Subsystem 1 - Part No SW: 1P0 959 538 B    HW: 1P0 959 538 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0102
   Coding: E30000
   Part No SW: 7N5 920 870 E    HW: 7N5 920 870 E
   Coding: 141F01
   VCID: 3978A819B8F2204E14-806C
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031142
   Shop #: WSC 80093 222 71269
   VCID: 33649A31529EDA1EDE-8066
01414 - Combustion-Air Blower (V6)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 236
                    Mileage: 223096 km
                    Date: 2015.05.13
                    Time: 18:12:60
                        Start
                    Temperature: 34.0°C
                    Temperature: 72.0°C
                    Voltage: 11.42 V
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 011011F1001982
   Coding: 468202
   VCID: 387EAD1D8BF83946EB-806C
                    Fault Status: 00110100
                    Reset counter: 18
                    Mileage: 222346 km
                    Date: 2015.04.11
                    Time: 20:09:22
                    Reset counter: 18
                    Mileage: 222346 km
                    Date: 2015.04.11
                    Time: 20:09:24
                    Fault Frequency: 9
                    Reset counter: 208
                    Mileage: 221604 km
                    Date: 2015.01.24
                    Time: 20:15:27
                    Reset counter: 18
                    Mileage: 222346 km
                    Date: 2015.04.11
                    Time: 20:09:24
   Component: IMMO          H03 0607
   Revision: A1001003    Serial number: 7661059169
   VCID: 29587859405290CE64-807C
03138 - Input AUX IN
                    Reset counter: 237
                    Mileage: 223139 km
                    Date: 2015.05.13
                    Time: 21:37:21
   Revision:             Serial number: 0000120657180
   Coding: 01112E209000411011
   VCID: 4486C9EDC7306DA677-8010
                    Reset counter: 236
                    Mileage: 223096 km
                    Date: 2015.05.13
                    Time: 18:14:58
   Component: EZE_2         H40 1620
   Coding: 050B0500
   VCID: 6FEC5641BE36BEFEFA-803A
   Revision:             Serial number: 0000120428995
   Coding: 01112C209000411011
   VCID: 4384CAF1C23E6A9E4E-8016
                    Reset counter: 232
                    Mileage: 222687 km
                    Date: 2015.05.10
                    Time: 18:44:14
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000309901
   Coding: 0024167
   VCID: 3560A4295CEAC42EF0-8060
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0105
   Coding: 068200000B000000
   Shop #: WSC 00020 999 39850
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 3662A32589ECCF36F9-8062
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
   Component: Radio RCD510  050 0207
   Revision: 00000001    Serial number: VWZ1Z3L7681553
   Coding: 01000400040024
   VCID: 2B5482514AAE82DE96-807E
   Component: Batt.regelung H40 1620
   Coding: 030B085A
   VCID: 71E85039A802A80EEC-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900830146
   Revision: 3I001002    Serial number: 00000160305567
   VCID: 73E45A31D21E9A1E1E-8026
   Part No SW: 7N0 959 107 C    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0804
   Revision: 41011001    Serial number: 272100402
   Coding: 0733334003
   VCID: 377CAE218EE6363EE2-8062
0048 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 19
                    Mileage: 222346 km
                    Date: 2020.11.18
                    Time: 20:09:20
                    Voltage terminal 30: 11.66 V
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000120673670
   Coding: 01006C200000411001
   VCID: 4682D3E5F10C5FB669-8012
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661023702
   Coding: 0A00000000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 275C7E615E46A6BE72-8072
   Part No SW: 7N0 959 244     HW: 7N0 959 244
   Component: Schiebetuer_l 005 2213
   Serial number: 11351061
   ASAM Dataset: EV_AST A03002
   ROD: EV_AST.rod
   VCID: 76E26325C96C8F3639-8022
51716 - Function Restricted due to Interrupted Communications
          U1110 00 [137] - -
                    Reset counter: 237
                    Mileage: 223139 km
                    Date: 2020.12.20
                    Time: 21:32:49
                    Voltage terminal 30: 12.0 V
                    Latch_Pawl: not activated
   Component: Schiebetuer_r 005 2213
   Serial number: 11351065
   ROD: EV_AST.rod
End-------------------------(Elapsed Time: 04:23)--------------------------
JonneH
C?ID=287892
Hello, i have now installed new control unit and wiring to rear left door, the rear left door from Chanel 9 does not give fault codes anymore. It closes from buttons, like everything works (motor, latch, pinch protection että?
But it does not open from any button? Vcds show that it regognizes button pressing, but no action.
Do i need to adapt the door somehow to get it working?
golfi_vend
Tartu, Estonia
C?ID=195131
FYI: There ia TPI that requires door and window lifter modules to be updated.
Can be done with dealer tool.
