Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: 2007 Audi Q7 MMI Problems
    Mar 2015
    Rhode Island
    Angry 2007 Audi Q7 MMI Problems
    I purchased my wife a Q7 for X-Mas CHEAP! I knew it had and MMI Problem but car runs fantastic... So I thought hey I have gone through a lot with my Audi A8 I'll tackle this lol.. SO with this said I tried to run a complete AutoScan and I cannot at all, It starts then it just cuts out and tells me that failure to communicate (-99)... I have made sure my power management in the computer is good and also check USB Hub to make sure that it was not enabled to power out. Anyways I had some success with the dataBus check and this is what I got below. I could really use some guidance on getting this MMI to work. I unplugged the Fiber lines from several modules in the back boot like the navigation and so on and put a Loop on it, there is not normal red light coming from any of them at all. I have been looking everywhere online with no luck. I would love to post a full AutoScan but I'm not sure what's going on with that or I would have. If I can get some people to shine some light that would be great, thanks so much....
    Thursday,22,December,2016,18:46:15:14758
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
    VCDS Version 16.8.4.2 (x64)
    Data version: 20161129 DS267.0
    Control Module Part Number: 4L0 910 468
      Component and/or Version: J533__Gateway   H06 0040
    Optical Bus Diagnostic : Standard
    Controller          	Electrical          	Optical
    19-CAN Gateway      	OK                  	OK
    07-Control Head(High/D3)	OK                  	OK
    0E-Media Player 1   	OK                  	OK
    47-Sound System     	ERROR               	ERROR
    56-Radio            	OK                  	OK
    37-Navigation       	OK                  	ERROR
    0F-Digital Radio(SAT)	OK                  	OK
    How about just the Gateway Installation List? There's a button for that on the Auto-Scan screen.
    Mar 2015
    Rhode Island
    Sorry I should have mentioned the gateway installation list does show up fine without a problem
    Quote Originally Posted by BostonSlaya View Post
    Well, please post it!
    Mar 2015
    Rhode Island
    Also when I try to clear all the DTCs at once it also will disconnect and say not supported
    Mar 2015
    Rhode Island
    Gateway Installation List:  4L0 910 468
    07-Control Head -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Cannot be reached 1100
    0F-Digital Radio -- Status: Cannot be reached 1100
    65-Tire Pressure -- Status: Cannot be reached 1100
  7. #7
    Mar 2015
    Rhode Island
    Posted sir thanks
  8. #8
    Interesting. There's one module that "Cannot be Reached' that's not on the optical bus, e.g. 65-Tire Pressure, but the rest looks more-or-less as I'd expect for a car with a broken MOST ring.
    At what point does the Auto-Scan cut out and give you failure to communicate?
    Have you got a battery charger connected to it? Or at least letting the engine run?
    Also, can you run a full scan on your A8 with the exact same VCDS setup (same computer, same interface)?
    Yes, I'm grasping at straws here, 'cause there's nothing super-obvious.
  9. #9
    Can you enter any modules individually by hex address?
    Please try and report back.........
    What is latency setting of interface or USB drivers when tested/observed?
  10. #10
    Mar 2015
    Rhode Island
    The tire pressure is because I pulled the fuse out earlier. Yes I had a battery charger connected and the car running. I'll go run a full auto scan on mine and see what happens now. I'll be back with an answer in about 5 mins. Thanks so much for your help really.
