Results 11 to 20 of 34
Thread: No Communication with J500 Power Steering Control Module
    Jun 2014
    Quote Originally Posted by DrPeter View Post
    - You are welcome
    - J500 receives constant battery power from [S206 - Fuse 3 (110-amp) (terminal 30)] (In engine compartment, center plenum chamber)
    From battery to [S206 - Fuse 3 (terminal 30)] to J500 via a 16mm black wire
    - J500 also receives power (ignition, 15-power) from the SB15 - Fuse 15 (on fuse panel B) (In Electronics Box (in plenum chamber, driver's side))
    Black/purple 0.5mm wire to J500
    drpeter
    Thanks again for the information you provided, this helped me track down my problem. In my case both of these fuses were OK, but this wasn't:
    For anyone that might find this thread later, this is a battery disconnect that the airbag controller will 'blow' if any of the airbags go off. The airbag module should throw a fault when it's blown (just like your seatbelts, etc.). Mine reported that it was not blown, but it had still managed to disconnect the battery. Replacing that fixed my communication problems with the J500, and my generator problem. Now I get a scan like this (oh, I also fixed my front right wheel speed sensor, but it wasn't related to the battery disconnect):
    Friday,18,July,2014,22:21:05:62027
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUBGAFL9DA113356   License Plate:
    Mileage: after-abs-fix   Repair Order:
    Chassis Type: FL (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
              62 6C 72 A9
    VIN: WAUBGAFL9DA113356   Mileage: 3780km/2348miles
    Address 01: Engine (J623-CGXC)       Labels: 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0002
       Revision: --H07---
       Coding: 0A250034052600060000
       Shop #: WSC 06208 123 12345
       ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
       ROD: EV_ECM30TFS0218K5907551E.rod
       VCID: 3875C55783A1C0DE637-806D
    6201 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
    7888 - Please Check DTC Memory of Steering Wheel Electronics
              P1698 00 [039] - -
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
       Component: 0B5 30TFSINAR H01 0004
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021.rod
       VCID: 4085ADB7DB71881EDB7-8015
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 291D1A
       VCID: 840DE1A707E9D43E3FF-80D1
       Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
       Component: BCM2 2.0      H11 0621
       Coding: 0D814000000000000000
       VCID: 8103E8B318FBC116149-80D4
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01310720120951
       Coding: 6600228000
       VCID: 3973C053B0ABD9D69C9-806C
                002 - Lower Limit Exceeded
       Revision: 08016001    Serial number: 00000454639701
       Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008004000030100000030000000
       VCID: 78F50557CB2100DEA37-802D
       Component: WWS 260712  H07 0080
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Component: USHL4.2  H30 0030
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
                013 - Check DTC Memory
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Serial number: 003KJD90H8TW
       Coding: 303842354730303030304A55304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 4A918F9FED4D424E053-801F
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1200009NB5
       Serial number: 6334MSME70124B3EF
       Serial number: 6344MSME6F652835O
       Serial number: 6352QSME721F5448N
       Serial number: 6362QSME7E1A0968X
       Serial number: 63732SME111B4774Z
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME0A092D00Y
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20120801000928
       Coding: 000036
       VCID: 51A398F3081B7196449-8004
       Component: E221 - MFL  H03 0003
                003 - Mechanical Failure
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 982 L    HW: 8K0 920 982 L
       Component: KOMBIINSTR.   H35 0553
       Revision: 00000000    Serial number: RBN337V7D
       Coding: 83B709008301D705020000
       Shop #: WSC 06325 123 12345
       VCID: 3D7BD443A483E5F6B01-8068
       Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0051
       Revision: 1Y050025    Serial number: 2541Y1271881D6
       Coding: 80C303FF00
       VCID: 448DA1A7C769943EFFF-8011
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H13 0100
       Serial number: 002007120001007
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F67FE0B76EF076632D-807A
    0127 - Please Check Fault Codes in Control Module for Steering Wheel Electronics
              U1028 00 [137] - -
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000034264172
       Coding: 00581B00000000000000
       VCID: 3B7FDA5BBA97EBC68E5-806E
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0304
       Coding: 011C13204E00410001
       VCID: 56A96BEF21F516AE91B-8003
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Part No SW: 8K0 909 144 E    HW: 8K0 909 144 B
       Component: RCEPS         H37 0506
       Revision: 00001000    Serial number: 0003459682
       Coding: 000000000000
       ASAM Dataset: EV_RCEPSAU48X 006012
       ROD: EV_RCEPSAU48X.rod
       VCID: 336FF27B9AC72386565-8066
    4215044 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
    4208000 - Steering Angle Sensor
              B1168 F1 [137] - Synchronization Failed
       Revision: 00002001    Serial number: 0180938853
       Coding: 0106023A00FA400580B0013200000000
       Shop #: WSC 06324 000 00000
       Component: GTO BF  H01 0080
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Revision: 00005001    Serial number: 94813004952302
       VCID: 2D5BE40374E37576001-8078
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0304
       VCID: 55AB6CE33CF31DB6981-8000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000077285
       ROD: EV_ParkiBrake_AU48.rod
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156G00C7619481
       Coding: 020007010000000001
       VCID: 21430833383BA116B49-8074
       Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
       Component: H-BNT-NA      H43 0552
       Revision: --------    Serial number: 204GX0C7514384
       Coding: 110200000206A1EF45028B4E00000403140000000000000000
       VCID: 3669CB6F81B536AE71B-8063
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Component: DU7 High  H41 0104
       Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
       Component: E0380 Bedient  H02 0020
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0304
       Coding: 010C13204000210001
       VCID: 59B360D350EB39D6BC9-800C
       Revision: --H07---    Serial number: 525PA8-J2690SQ
       Coding: 1000006
       VCID: 3875C5574BA1C0DE637-806D
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H07 0304
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 120623201651
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       VCID: F2E1B77F255DEA8E1D3-80A7
    My next problem seems to be the G85 Steering Angle Sensor. I followed the instructions here:
    http://wiki.ross-tech.com/wiki/index...el_Electronics
    but when I get to the Basic Settings part I get -679 degrees:
    https://www.dropbox.com/s/gcqbshqiwr...ic-Setting.png
    and then trying to set the Basic Setting results in "Group 001 not available":
    https://www.dropbox.com/s/shped3kr4j...asic-Error.png
    The steering angle sensor seems to work, but the closest I can get it to 0 degrees is to turn the wheel all the way left, and then I still get -190 degrees (or something close to that). The airbag has been replaced and I've had the steering wheel off when I replaced the steering rack. I have not replaced anything else in the steering column other than the airbag. Next I'm going to take the wheel back apart and see if I can rotate something to get this value closer to 0, but any other suggestions would be great. - Thanks
  2. #12
    Sounds like a spiral spring beneath the air bag is wound one way to far or G85 has been turned one way when the steering was apart unknown to you.
    Take apart and use blocks to bring back to zero line.
  3. Likes thowell liked this post
  4. #13
    Jun 2014
    Does that mean I need to disconnect the mechanical steering shaft from the steering rack (I hope not, it was a pain) and turn the entire steering wheel independent of the front wheels, or can I just turn the spiral spring beneath the air bag? It seems like it wouldn't turn on it's own before, but I may have been doing it wrong.
  5. #14
    Jun 2014
    Thanks, that did it. (Actually, unhooking the steering wasn't hard at all, I must have been remembering somethings else.) The only thing left now is learning the end stops. I followed the instructions from the link I posted above, and it acts like it is learning the end stops (it beeps at both ends), but I still get this error "5258753 - Steering End Stops Not Learned".
    Here is a full scan, any ideas on other ways to get the learning to stick?
    Saturday,19,July,2014,22:42:25:62027
    Mileage: endstops   Repair Order:
              62 6C 72 A9
    VIN: WAUBGAFL9DA113356   Mileage: 3800km/2361miles
       Revision: --H07---
       Revision: --H01---
       Coding: 000001
       Coding: 291D1A
       Coding: 6600228000
       Coding: 00FD11
       Coding: 02005D
       Coding: 000036
       Coding: 80C303FF00
       Coding: 1000006
  6. Likes Jack@European_Parts liked this post
  7. #15
    I would first code the Address 44.
    I wonder why there is no DTC for this. My guess it is:
    100000010001
    Remember to change non-zero values in wsc, importer, device no., like explained here before accept coding.
  8. Likes Dana, thowell liked this post
  9. #16
    Jun 2014
    100000010001
    Thanks for catching this. It wasn't throwing a code so I completely forgot about coding the new module. I guess technically all zeros was a valid code for that module, so maybe that's why it didn't complain? Anyway, it took the new coding, and I re-tried all of the procedures for Basic Setting and learning the end stops, but it won't learn the stops. Here is a new scan, pretty much the same as before but with the new coding:
    Monday,21,July,2014,18:03:23:62027
    VIN: WAUBGAFL9DA113356   License Plate: 7-21-14
              62 6C 72 A9
    VIN: WAUBGAFL9DA113356   Mileage: 3820km/2373miles
       Revision: --H07---
    Readiness: 0010 1101
       Revision: --H01---
       Coding: 000001
       Coding: 291D1A
       Coding: 6600228000
       Coding: 00FD11
       Coding: 02005D
       Coding: 000036
       Coding: 80C303FF00
       Coding: 100000010001
       Coding: 0106063A00FA400580B0013200000000
       Shop #: WSC 06324 123 12345
       Coding: 1000006
    I also did some logging hoping that it might help someone:
    Sunday,20,July,2014,22:59:59:62027
    VIN: WAUBGAFL9DA113356   License Plate: STEERING
                    Address 44: Steering Assist  (8K0 909 144 E)
    22:59:39
      025   End stops for steering-Status_end_stops_of_steering Not adapted
      026   End stops for steering-Status_steering_stroke_calc_EAL OK
      027   End stops for steering-Distance_centre_end_stop_steering_rack 479.97 °
      028   End stops for steering-Steering_stroke 599.99 °
      030   End stops for steering-Offset_steering_angle 0.00 °
      031   End stops for steering-Status_offset_calc OK
      032   End stops for steering-Offset_cog_angle_centre_steering_rack 0.00 °
    I also tried to follow these instructions:
    See post #48
    but my car doesn't have a [1B-Active Steering] module. Is that normal for this car? Is there some type of Basic Setting I can do for [44 - Steering Assist]?
  10. #17
    United States
    I agree with that new #44 coding of 100000010001 but you shouldn't need to complete Basic Settings in that controller in my opinion. The lack-of #1B is normal in this case.
    I would disconnect the battery and try setting G85 from scratch to eliminate the possibility that these PT controllers are simply confused. If you decide to experiment with #44 BS instead I would AVOID Resetting of all adaptations and go with Resetting of learned values for steering assistance alone.
  12. #18
    Jun 2014
    OK, I disconnected the battery for a 1/2 hour, re-connected it, and then followed each of these instructions (all with the engine running):
    [Select]
    [16 - Steering Wheel]
    Turn steering wheel at least 30 ° left or right and back straight ahead (Tolerance: ±5.0 °).
    [Security Access - 16]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 3 should say "OK".
    [Done, Go Back]
    [Meas. Blocks - 08]
    Group 033 Field 3 (Steering Angle Sensor -G85-)
    Specification: 0.0 °
    Tolerance (when straight): ±1.5 °
    [Done, Go Back]
    After the Steering Angle Sensor (G85) Calibration is completed, the 44-Steering Assist (J500) module may have DTC C10AC - Steering End Stops Not Learned stored. The steering limit end stops need to be adapted as follows:
    Start the engine and turn the steering to full right lock and hold it for 5 to 10 seconds. The vehicle should produce an audible beep
    Turn the steering to the complete left lock and the same audible beep should sound.
    Straighten the wheels and wait 5 to 10 seconds while observing the steering and traction control warnings. They should extinguish although it is advised to scan the vehicle again for DTCs prior to the test drive.
    Everything works exactly as described except for the very last sentence where it says "They should extinguish..." None of my warnings or steering MIL go away, and of course a scan still shows that the end stops are not learned (show in my last auto-scan).
    Do I need to be on a specific screen when I do the lock to lock learning step?
  13. #19
    United States
    At this point I wonder if that (used?) 44 rack needs parameterization / Parameter settings uploaded via SVM? It wasn't coded identically, meaning it was either used and from another configuration -or- brand new and it may be in a virgin state like Golf based racks that require Characteristic Curves?
    Hopefully someone else can confirm or deny my theory. We have 100% success with straight forward 16 replacement after Airbag replacement and no known issues with our procedure or those 44 controllers in general - but most of the body shops and mobile techs are not working on something with severe underside damage either.
  14. #20
    Jun 2014
    Yes, it was a brand new rack from genuineaudiparts so other than the learning that happens from driving it, the only other coding that has been done is what I did in post #16 above, plus the Basic Settings and other steps from the wiki. Thanks for the advice, sounds like this might be a dealer only problem then?
    Do independent shops typically have tools that can flash updates or upload the 'Characteristic Curves'?
