Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: No Communication with J500 Power Steering Control Module
    Jun 2014
    I'm repairing a 2013 S4 that had undercarriage damage and I've replaced the power steering rack that was damaged. I didn't own VCDS before replacing the rack so I don't have a before scan, but when I do a scan now I get a "01309 - Power Steering Control Module (J500) 004 - No Signal/Communication" and a "15428 - No Communications with Power Steering Control Module". (I do still have the old rack if that helps.)
    Is this what "component protection" looks like in a scan? I've rechecked all electrical connections to the rack several times and they all seem secure with no obvious physical damage.
    I'm also concerned about the alternator because of "02252 - Generator 004 - No Signal/Communication" but not sure what order I should tackle all of these codes. I'm assuming some will go away when I correct the more important problems. Any advice on which ones to look into first would be greatly appreciated.
    In addition to the steering rack, I've replaced the driver's airbag, all seatbelts, a bunch of suspension components, headlights and associated electronics. I still need to replace a radiator fan and the wiring for the front right ABS sensor, I think the airbag controller, and anything else I'm missing. Here is the auto-scan:
    Saturday,21,June,2014,15:04:23:62027
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUBGAFL9DA113356   License Plate:
    Mileage: belts-replaced   Repair Order:
    Chassis Type: FL (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
              62 6C 72 A9
    VIN: WAUBGAFL9DA113356   Mileage: 3780km/2348miles
    44-Steering Assist -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CGXC)       Labels: 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0002
       Revision: --H07---
       Coding: 0A250034052600060000
       Shop #: WSC 06208 123 12345
       ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
       ROD: EV_ECM30TFS0218K5907551E.rod
       VCID: 3875C55783A1C0DE637-806D
              U0131 00 [037] - -
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:26
    6141 - Coolant Fan Control Circuit 1
              P0480 00 [037] - Electrical Malfunction
                        Fault Frequency: 15
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:28
    6144 - Coolant Fan Control Circuit 2
              P0481 00 [037] - Electrical Malfunction
                        Fault Frequency: 15
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:28
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
       Component: 0B5 30TFSINAR H01 0004
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021.rod
       VCID: 4085ADB7DB71881EDB7-8015
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 291D1A
       VCID: 840DE1A707E9D43E3FF-80D1
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11101100
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:25:24
                        Hex Value: 0x0040
                        Hex Value: 0x0782
                        Hex Value: 0x0048
                        Hex Value: 0xB090
                        Hex Value: 0x0000
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:25:24
                        Hex Value: 0x0040
                        Hex Value: 0x0782
                        Hex Value: 0x002F
                        Hex Value: 0x3690
                        Hex Value: 0x0000
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:25:24
                        Hex Value: 0x0040
                        Hex Value: 0x0782
                        Hex Value: 0x001A
                        Hex Value: 0x0290
                        Hex Value: 0x0000
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:25:24
                        Hex Value: 0x0040
                        Hex Value: 0x0782
                        Hex Value: 0x000E
                        Hex Value: 0x5090
                        Hex Value: 0x0000
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:25:24
                        Hex Value: 0x0040
                        Hex Value: 0x0782
                        Hex Value: 0x000C
                        Hex Value: 0xE390
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
       Component: BCM2 2.0      H11 0621
       Coding: 0D814000000000000000
       VCID: 8103E8B318FBC116149-80D4
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 13:44:57
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01310720120951
       Coding: 6600228000
       VCID: 3973C053B0ABD9D69C9-806C
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:25
                        Temperature: 23.0°C
                        Temperature: 23.0°C
                        Absolute Pres.: 0.8 bar
                        Current: 0.000 A
                        Temperature: 23.0°C
       Revision: 08016001    Serial number: 00000454639701
       Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008004000030100000030000000
       VCID: 78F50557CB2100DEA37-802D
       Component: WWS 260712  H07 0080
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Component: USHL4.2  H30 0030
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:30
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:30
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Serial number: 003KJD90H8TW
       Coding: 303842354730303030304A55304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 4A918F9FED4D424E053-801F
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1200009NB5
       Serial number: 6334MSME70124B3EF
       Serial number: 6344MSME6F652835O
       Serial number: 6352QSME721F5448N
       Serial number: 6362QSME7E1A0968X
       Serial number: 63732SME111B4774Z
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME0A092D00Y
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20120801000928
       Coding: 000036
       VCID: 51A398F3081B7196449-8004
       Component: E221 - MFL  H03 0003
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:25
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 982 L    HW: 8K0 920 982 L
       Component: KOMBIINSTR.   H35 0553
       Revision: 00000000    Serial number: RBN337V7D
       Coding: 83B709008301D705020000
       Shop #: WSC 06325 123 12345
       VCID: 3D7BD443A483E5F6B01-8068
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:27
       Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0051
       Revision: 1Y050025    Serial number: 2541Y1271881D6
       Coding: 80C303FF00
       VCID: 448DA1A7C769943EFFF-8011
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:27
                        Bin. Bits:    10111
                        Voltage: 11.80 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
    02252 - Generator
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:16:26
                        Bin. Bits:    10111
                        Voltage: 11.80 V
                        Count: 6
                        Bin. Bits:    10000
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:24:02
                        Bin. Bits:    10111
                        Voltage: 11.60 V
                        Count: 6
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H13 0100
       Serial number: 002007120001007
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F67FE0B76EF076632D-807A
    0088 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:26
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
                        Fault Frequency: 7
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:26
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000034264172
       Coding: 00581B00000000000000
       VCID: 3B7FDA5BBA97EBC68E5-806E
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0304
       Coding: 011C13204E00410001
       VCID: 56A96BEF21F516AE91B-8003
       Revision: 00002001    Serial number: 0180938853
       Coding: 0106023A00FA400580B0013200000000
       Shop #: WSC 06324 000 00000
       Component: GTO BF  H01 0080
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Revision: 00005001    Serial number: 94813004952302
       VCID: 2D5BE40374E37576001-8078
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0304
       VCID: 55AB6CE33CF31DB6981-8000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000077285
       ROD: EV_ParkiBrake_AU48.rod
    459776 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                        Reset counter: 127
                        Mileage: 3788 km
                        Date: 2014.06.21
                        Time: 09:15:26
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156G00C7619481
       Coding: 020007010000000001
       VCID: 21430833383BA116B49-8074
       Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
       Component: H-BNT-NA      H43 0552
       Revision: --------    Serial number: 204GX0C7514384
       Coding: 110200000206A1EF45028B4E00000403140000000000000000
       VCID: 3669CB6F81B536AE71B-8063
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Component: DU7 High  H41 0104
       Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
       Component: E0380 Bedient  H02 0020
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0304
       Coding: 010C13204000210001
       VCID: 59B360D350EB39D6BC9-800C
       Revision: --H07---    Serial number: 525PA8-J2690SQ
       Coding: 1000006
       VCID: 3875C5574BA1C0DE637-806D
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H07 0304
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 120623201651
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       VCID: F2E1B77F255DEA8E1D3-80A7
    Thanks in advance for the help.
    Tom
  2. Likes jessemoc liked this post
  3. #2
    16.4905° S, 151.7375° W
    - Many answers can be found on the Ross-Tech wiki pages, for example:
    01309 - Power Steering Control Module (J500): No Communication
    Also using VCDS, select 19-CAN Gateway and have a look at the Measuring Value Block(MVB) Group - 152, field 2.
    - This will display the CAN-Bus status of the J500-Power Steering Control Module
    - You should see a [1], if you see a [0] or alternating [0]/[1] then there is a communication concern between the CAN-Bus and the J500
    - Typically you will see a fault code for the Component Protection Active
    02252 - Generator
    - Check wiring and connections to/from the alternator and the ECM.
    - Check the Advanced Measuring Values in the [01-Engine], location [134] = Alternator load
    I would fix the communications concerns with the J500 first, then clear all fault codes and see what comes back.
    Hope that helps,
    drpeter
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #3
    Jun 2014
    Thanks so much for the help and the wiki reference. The instructions on the wiki make me wonder if I have a blown fuse that I've missed. Does anyone know if this car has a fuse for the J500 (and where)?
    The MVBs showed no communication with the steering control module or the generator. For the Generator I tried both [19 - CAN Gateway], Group 6 and [01-Engine], location [134] with the same results. Here is the log:
    Wednesday,09,July,2014,19:36:49:62027,VCDS Version: Release 12.12.2,Data version: 20140212
    8R0 907 468 H,,GW-BEM 4CAN-M H11 0051,
    ,Group A:,'003,,,,Group B:,'006,,,,Group C:,'152
    ,,Electrical Coding,Ring Break,Hex Value,Hex Value,,Generator,Battery Sensor, , ,, , , ,
    ,TIME,,Diagnostic Wire,,,TIME,Communic. Status,Communic. Status,,,TIME,,,,
    Marker,STAMP,,,,,STAMP,,,,,STAMP,,,,
    ,0.06,0x00FF,       1,0x0400,0x03FF,0.19,Generator 0,BDM 1, , ,0.30,Steering 0, , ,
    ,0.41,0x00FF,       1,0x0400,0x03FF,0.52,Generator 0,BDM 1, , ,0.63,Steering 0, , ,
    ,0.76,0x00FF,       1,0x0400,0x03FF,0.87,Generator 0,BDM 1, , ,0.98,Steering 0, , ,
    ,1.10,0x00FF,       1,0x0400,0x03FF,1.22,Generator 0,BDM 1, , ,1.35,Steering 0, , ,
    ,1.46,0x00FF,       1,0x0400,0x03FF,1.57,Generator 0,BDM 1, , ,1.68,Steering 0, , ,
    ,1.79,0x00FF,       1,0x0400,0x03FF,1.92,Generator 0,BDM 1, , ,2.04,Steering 0, , ,
    ,2.14,0x00FF,       1,0x0400,0x03FF,2.25,Generator 0,BDM 1, , ,2.36,Steering 0, , ,
    ,2.49,0x00FF,       1,0x0400,0x03FF,2.60,Generator 0,BDM 1, , ,2.72,Steering 0, , ,
    ,2.83,0x00FF,       1,0x0400,0x03FF,2.94,Generator 0,BDM 1, , ,3.07,Steering 0, , ,
    ,3.19,0x00FF,       1,0x0400,0x03FF,3.30,Generator 0,BDM 1, , ,3.42,Steering 0, , ,
    ,3.53,0x00FF,       1,0x0400,0x03FF,3.66,Generator 0,BDM 1, , ,3.79,Steering 0, , ,
    ,3.89,0x00FF,       1,0x0400,0x03FF,4.00,Generator 0,BDM 1, , ,4.11,Steering 0, , ,
    ,4.24,0x00FF,       1,0x0400,0x03FF,4.35,Generator 0,BDM 1, , ,4.46,Steering 0, , ,
    ,4.57,0x00FF,       1,0x0400,0x03FF,4.68,Generator 0,BDM 1, , ,4.81,Steering 0, , ,
    ,4.92,0x00FF,       1,0x0400,0x03FF,5.03,Generator 0,BDM 1, , ,5.14,Steering 0, , ,
    ,5.25,0x00FF,       1,0x0400,0x03FF,5.38,Generator 0,BDM 1, , ,5.49,Steering 0, , ,
    ,5.60,0x00FF,       1,0x0400,0x03FF,5.71,Generator 0,BDM 1, , ,5.83,Steering 0, , ,
    ,5.96,0x00FF,       1,0x0400,0x03FF,6.07,Generator 0,BDM 1, , ,6.17,Steering 0, , ,
    ,6.29,0x00FF,       1,0x0400,0x03FF,6.41,Generator 0,BDM 1, , ,6.54,Steering 0, , ,
    Group 03 had something listed as 'Ring Break', which sounded bad, but of course I don't know what it actually means.
  6. #4
    - You are welcome
    - J500 receives constant battery power from [S206 - Fuse 3 (110-amp) (terminal 30)] (In engine compartment, center plenum chamber)
    From battery to [S206 - Fuse 3 (terminal 30)] to J500 via a 16mm black wire
    - J500 also receives power (ignition, 15-power) from the SB15 - Fuse 15 (on fuse panel B) (In Electronics Box (in plenum chamber, driver's side))
    Black/purple 0.5mm wire to J500
    - Results above were expected,
    - 'Ring Break' is pertaining to the MOST-Databus
    drpeter
  7. Likes thowell liked this post
  8. #5
    Jul 2014
    I'm having a similar problem with my car (2010 VW Jetta Sportwagen) on the J500 module. It was also involved in an accident, but just front end damage (this car apparently rear-ended someone else) The impact wasn't very bad as the front structural bumper was hardly damaged, but it was enough to set off the two front airbags, and all four seat belts. I don't believe anything in the steering was damaged. We have another matching Jetta (except it's a manual transmission), so I swapped two of the components related to the steering (I believe they are the J500 located underneath the ignition switch on the steering column, and the G85 located right behind the steering wheel), but it didn't make any difference, so it doesn't seem like it's an issue with those components themselves. I'll try what DrPeter recommended in post #2 to see what's happening there.
    Note: I'm not sure that the circuit board under the ignition switch on the steering column is the J500 module. I wasn't able find out what it looks like, so I'm not sure that one is the correct module. If anyone knows what it looks like, or where it's located, it would be quite helpful!
  9. #6
    Jul 2014
    So I checked mine (group 125, on my car), and fields 1 (steering angle sensor G85) and 3 (steering aid J500) both read 0. Is there some way to reprogram something? I was thinking that maybe it lost a setting since it was sitting for a while without the battery. It seemed to lose the setting for the sunroof and the sunscreen in this car, so they only worked manually, saying that there was "No or Incorrect Basic setting/Adaptation" (though now the screen somehow "fixed" itself and is now working properly)
  10. #7
    Jul 2014
    I was looking at the car again this evening, and I found a broken wire right after a connector on the front of the car! It was three wires that came up from the the electric steering assist down on the bottom of the car. It wasn't very noticeable, which is why we didn't see it prior. I'll try to solder it back together, and see if that fixes it.
  12. #8
    Do you have a picture..........?
  13. #9
    Jul 2014
    The broken wire is pointing right at the camera so it's a little difficult to see, but you can see that there's only two wires coming out of the connector.
    Note: the connector is located right behind the driver's side head lamp; it comes up from the bottom of the car with the two big power wires for the power steering assist
  14. #10
    Jul 2014
    That fixed it! It also seemed to fix the problem with the steering angle sensor (G85) that I was having. Also, I don't know if it was related or not, but once that was fixed, the sunroof started working normally again as well!
  15. Likes Jack@European_Parts liked this post
