And after all I don't believe that this difference in temperature can spend 3 liters of fuel more than normally?!
Maybe it does.
Maybe it does.
+1it is easy to get 3 or more liters more fuel consumption.
+1
On my previous Audi summer consumption was 22-25mpg (11-13 l/100km), but lowest winter consumption was 16mpg(18 l/100km)!
Compare with measurement in address 17, Instrument Panel. If there is more than 3-5 degrees difference, replace T sensor. This car still have 2 separate thermistors in one shell of sensor. One is for ECU, another one for instrument panel. Look at measuring values with VCDS, do not pay attention what T gauge shows on panel. It is built-in feature in panel electronics that displays constantly 90 degrees when the real engine coolant temperature is approx from 75 up to 100 degrees.
If we compare fuel consumption of engine with good thermostat, correctly working ECT and summertime with probably thermostat opening too early and/or temperature sensor measuring 10-15 degrees less than real coolant temperature and wintertime, it is easy to get 3 or more liters more fuel consumption.
No, with the car in perfect working order ...... it was a 4.2 litre V8 RS4this was fuel consumption with bad temperature sensor?
But earlier in this thread it seems that your consumption has only increased by 3 litres per tankful?Ok, but this is 85 kW 1.9 tdi, with fuel consumption of 9-10 l/100 km, it's too high.
If that's correct then that's such a small increase it is very probably caused by lower winter temperatures.
I was illustrating how much an effect cold winter temperatures can have, with my RS4 it increased consumption by 60%...
I would pull Injectors and bench test the calibration plus observe the units for statics.
