Results 1 to 6 of 6
Thread: VW Golf 6 AFS Coding help
    Jul 2014
    Hello from Finland! I have 2011 vw golf hatcback and it was in accident and I have to replace right front light and control boxes(used) on bottom of the light. Now AFS is not working because right side afs controller is not coded. Can someone please help with correct coding information? I try almost anything I can imagine but afs module won't accept any coding and if I code xenon range module, it won't change the afs coding.
    Does it need some security access or what?
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WVWZZZ1KZBP046586   License Plate:
    Chassis Type: 1K (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 61 62 69 72
    55-Xenon Range -- Status: Malfunction 0010
    Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 DQ    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 6302
       Coding: 00114014032401080000
       Shop #: WSC 00028 028 00024
       ASAM Dataset: EV_ECM16TDI02103L906023DQ 003007
       ROD: EV_ECM16TDI02103L906023DQ.rod
       VCID: 78F41DBBC3C4FBDEA37-802D
    Readiness: 1110 1000
       Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 113B200D09260000881004EC901F0051310000
       Shop #: WSC 00028 028 00001
       VCID: 840CF94B070C2F3E3FF-80D1
       Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000003
       ROD: EV_ClimaBasis_SE36.rod
       VCID: 6ED83BE3B180B56E79B-803B
    9481200 - Coolant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 21
                        Mileage: 81075 km
                        Date: 2041.14.29
                        Time: 00:13:12
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 40180A3A80251AC0408800845000082443050088624D8560648087200041
       VCID: 3874DDBB8B443BDE637-806D
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 27081  26  0512
       Coding: 009795
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRAC03W-
       Coding: 00003132
       Shop #: WSC 01383 790 00065
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B7EC2B7B27210C68E5-806E
       Serial number: 3572MSME76465157ZZZY
       Serial number: 3582MSME0C614256ZZZU
       Serial number: 3512QSME3E256B13ZZZ-
       Serial number: 3522QSME32516C41ZZZQ
       Part No SW: 5K0 953 507 BA    HW: 5K0 953 549 C
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JI10002I
       Coding: 5080140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 70E4259BABB4A39E6B7-8025
       Part No SW: 5K0 920 871 A    HW: 5K0 920 871 A
       Component: KOMBI         H03 0406
       Coding: 170D00
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 2C5CF1EB471C877E17F-8079
    Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H25 5603
       Revision:   H25       Serial number: 060810F2002091
       Coding: E9817F4600020204000002
       Shop #: WSC 11400 205 17010
       VCID: 2E58FBE3B900F56E39B-807B
       Component: IMMO          H03 0406
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EAD0B7F30D68D94EA53-80BF
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2151
       Coding: 0131252
       VCID: 336EEA975222D886565-8066
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 3162E09FA83EEA96249-8064
                000 - - - MIL ON
                        Fault Status: 11100000
                        Mileage: 81075 km
                        Date: 2041.14.29
                        Time: 00:07:32
                        Battery Volts: 12.0 V
                            DD
                        Temperature: 21.0C
                        Count: 2
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Coding: 0131252
       VCID: 346CE98B572CDFBE4FF-8061
    Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
       Coding: 1442844
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul r    X008
       Coding: 00000019
                000 - - - MIL ON
                        Reset counter: 21
                            Invalid
                            Invalid
                            Invalid
    02657 - Power Output Stage for Right Headlight (J668); Not Coded
                000 - - - MIL ON
                        Reset counter: 21
                            Invalid
                            Invalid
                            Invalid
                        Fault Status: 11100101
                        Reset counter: 21
                            Invalid
                            Invalid
                            Invalid
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2K8273924
       Coding: 0500040004
       VCID: 65CA44CF6C767636081-8030
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H25 5603
       Coding: 030B185A
       VCID: F1E2A09F28BE2A96E49-80A4
       Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0125
       Coding: 0131216
       Shop #: WSC 00028 028 1012545
       VCID: 356AD48F5C56C6B6781-8060
    Address 69: Trailer        Labels: RETROFIT69.lbl
       Part No SW: 5F0 05V 010 1    HW: 5F0 05V 010 1
       Component: TOWBARMODULE ECS    0010
       VCID: 28540DFB9BE4AB5EF37-807D
       Coding: 0131216
       VCID: 3668D3834150CDAE71B-8063
    Do you have a prior auto-scan to accident or access to the old modules to try and extract?
    United States
    If the original master #55 coding of 1442844 is refused and you already attempted to tweak the WSC/Importer/Equipment values as explained here I suspect the incorrect sub-system slave is responsible:
    Coding: 1442844
    Coding: 00000022
    Coding: 00000019
    The Left side slave looks normal for Golf (00000022) but I don't recognize the Right > 00000019. What kind of car did that used right side controller come out of? Do you still have the original 7L6 941 329 B controller .. or was is damaged with the lamp?
    This page may be helpful and the example scans were from a 2010 NAR Gti that I was driving at the time:
    http://wiki.ross-tech.com/wiki/index...#Special_Notes
  4. Likes Uwe, Jack@European_Parts liked this post
    Jul 2014
    I don't have old box and I don't know where the "new" box is from. #55 coding with 1442844 is accetable and done several times, but no effect to slave box.
    Jul 2014
    Now I tried another used afs module from vw tiguan but no luck, same problem. I can code 55 module but software coding in afs module doesn't change. Any ideas?
    VCDS Version: Release 12.12.2
    Monday,14,July,2014,14:42:48:06064
    Coding: 1442844
    Shop #: WSC 05313 210 01865
    Coding: 00000022
    Component: AFS-Lst.-Modul r S002
    Coding: 00000020
    000 - - - MIL ON
    Reset counter: 27
    Invalid
    Invalid
    Invalid
    000 - - - MIL ON
    Reset counter: 27
    Invalid
    Invalid
    Invalid
    Reset counter: 27
    Invalid
    Invalid
    Invalid
    Jul 2014
    I got used afs module from 2011 golf and it was same 22 coding that car's orginal left side module. Now everything works!
  8. Likes Uwe, Dana, Jack@European_Parts liked this post
