Results 1 to 6 of 6
Thread: GERMAN TEXT
    Jan 2015
    GERMAN TEXT
    Hi
    I ran vcds today regarding a fan temp issue, and 2 issues the first the info half of it was looks German which i dont read or speak the second was the coolant temp outlet G83 was displaying minus - 40.5 D/c
    The engine ecu temp G62 was reading sensible reading of 69 D/c
    I have readings of outlet temp from other vehicle using vcds and they are in English, No fault listed for the outlet temp sensor of -40.5D/c which i know i have a problem as the fan is not being triggered (brand new sensor ) can these sensor be tested based on resistance to temp. all the wiring checks out for continuity & power inc earth. i have not checked ecu wire,
    Thursday,15,December,2016,15:54:22:46146
    VCDS Version: 16.8.4.2 (x64)
    Data version: 20161129 DS267.0
    VIN: License Plate: 2010
    Address 01: Engine (03G 906 016 LF)
    15:53:59 Group 064: Engine Cooling
    85.5°C Kühlmitteltemp. Motoraustritt
    -40.5°C Kühlmitteltemp. Kühleraustritt
    10.0 % Coolant Fan 1 Duty Cycle
    15:53:59 Group 002: Idle Speed
    1533 /min Engine Speed (G28)
    12.2 % Accel. Pedal Pos. Sensor 1 (G79)
    0 00 0 Operation Status
    85.5°C Coolant Temperature (G62)
    A full Auto-Scan would be helpful...
  3. Likes Dana, Uwe liked this post
    Confirmed, someone didn't translate a few things in 03G-906-016-BDJ....
    Kühlmitteltemp = Coolant Temperature
    Motoraustritt = Engine Outlet
    Kühleraustritt = Radiator Outlet
    The -40.5 °C is an indication that the sensor is open circuit, or perhaps that the car in question simply doesn't have a temperature sensor at the radiator outlet.
    Jan 2015
    Full autoscan, The radiator fan outlet temp is Brand new, The Van is a o8 build, with 2010 ecu and instrument cluster and wiring list G83 sensor not f18 , & NO AIRCON
    Thursday,15,December,2016,14:53:01:46146
    VIN: WV1ZZZ2KZAX106915   License Plate: 2008/10
    Mileage: 223260km-138727mi   Repair Order: thursday test fan
    Chassis Type: 2K (1K0)
    Scan: 01 03 09 15 16 17 19 25 42 46 52 56
    VIN: WV1ZZZ2KZAX106915   Mileage: 223260km-138727miles
    Address 01: Engine        Labels: 03G-906-016-BDJ.clb
       Part No SW: 03G 906 016 LF    HW: 03G 906 016 DR
       Component: R4 2,0L EDC 0000SG  2977
       Revision: 12345678    Serial number: VWX7Z0J23N702G
       Coding: 0003031
       Shop #: WSC 35110 377 00155
       VCID: 72EBF6F26D1B63D2CF-8026
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 000 - Signal too Low
                        RPM: 924 /min
                        Torque: 83.0 Nm
                        Duty Cycle: 96.0 %
                        Bin. Bits: 11000100
                        Mass Air / Rev.: 650.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017106
       Shop #: WSC 35110 377 00156
       VCID: 3F8D6FC66EC9FEBAF0-806A
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 01000007988820
       Coding: 00884F030004100047000000000000000008FB075C000100000000000000
       Shop #: WSC 35110 377 08192
       VCID: 6FEDFF867E294E3A20-803A
       Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW357  012  0402
       Coding: 00065493
       Shop #: WSC 35110
                        Reset counter: 110
                        Mileage: 223269 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.75 V
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
       Component: 09 AIRBAG VW52  023 2400
       Revision: 04023000    Serial number: 0037TD0HHYVM
       Coding: 0012345
       VCID: 7DF1D5CE24452CAAA2-8028
       Part No SW: 1K0 953 549     HW: 1K0 953 549
       Component: Lenksäulenmodul 012 0030
       Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0002000    Serial number: VWX7Z0J23N702G
       Coding: 0016401
       VCID: 2C57288A8FBF752245-8078
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 120208F2001591
       Coding: 89801F020002027401
       VCID: 306F3CFAA39711C279-8064
                        Fault Frequency: 90
                        Reset counter: 150
                        Mileage: 223269 km
                        Time: 13:20:28
       Component: IMMO            VDD 1222
    Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
       Part No: 1K0 959 793
       Component: Tuersteuergeraet 02 0160
       Coding: 0000000
       VCID: 76E3CAE201737FF2E3-8022
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 008A0C087F2D84054858030000C0
       VCID: 000FAC3A53B74142C9-8054
    Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
       Part No: 1K0 959 792
       Coding: 0000000
       VCID: 75E1CDEE1C7574EAEA-8020
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 00000000    Serial number: VWZ1Z2K8066632
       Coding: 0000020001
       VCID: 65C19DAE6CD5846A5A-8030
                        Reset counter: 150
                        Mileage: 223269 km
                        Time: 20:57:23
    00532 - Supply Voltage B+
                        Reset counter: 150
                        Mileage: 223269 km
                        Time: 20:58:10
                        Reset counter: 71
                        Mileage: 72384 km
                        Time: 00:28:31
    End-------------------------(Elapsed Time: 01:15)--------------------------
    Jan 2015
    FULL AUTOSCAN
    Jan 2015
    Uwe.
    Can you see any issues that might not be correct in the autoscan,, It has label files for the engine i'm working with.
    Can a resistance test be done on the G83 although it is new? I may try another ecu not coded to this cluster immob, just to see with ignition on if the values change for the G83, The wiring has no open circuit, so sensor fault or some coding issue from the 2010 ecu.
    The Gate way all seems right,
