Dear all,
I have Q7, 2016 MY and the Adblue is counting down now and I am trying to reset it after the full tank filled but it would not let and unsuccessful. Attached is the full scan. The message on the VCDS on Resetting learning value for reducing agent metering system routine not OK.
I also checked status of reducing agent warning bit is 53, I think it should be zero to allow it to possible to reset.
Tuesday,13,December,2016,14:10:14:52357
VCDS Version: 16.8.4.2
VIN: WAUZZZ4M6GD005122 License Plate: 2AC-5667
Chassis Type 4M (4M1)
Scan: 01 02 03 06 08 09 15 16 17 19 28 36 42 44 47 52 5F 6C 6D 81
A5 AC BB BC
Address 01: Engine (J623-CRTC) Labels: None
Part No SW: 4M0 907 401 HW: 059 907 309 B
Component: 3.0TDI EDC17 H45 0004
Revision: 91H45---
Coding: 2A2A40320326050334180000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114M0907401 001008
ROD: EV_ECM30TDI0114M0907401.rod
VCID: 66C38BED99AB487253-8032
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4M0 927 158 J HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H03 1007
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002009
ROD: EV_TCMALX52011.rod
VCID: 3B750A99B2A9259ADC-806E
Part No SW: 4M0 907 379 K HW: 4M0 907 379 K
Component: ESP9 Premium H08 0514
Coding: 249830B230A20A9B969F5893007F5292E6A6D2240C0C50691A004A4967654B
ASAM Dataset: EV_ESP9BOSCHAU736 011006
ROD: EV_ESP9BOSCHAU736_AU73.rod
VCID: 3F8D7E89A6B139BAF0-806A
Part No SW: 4M0 959 760 E HW: 4M0 959 760 E
Component: MEM-BFS 008 0014
Serial number: 00000149530462
Coding: 000010000000B0410000210101010000110000313100000000000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
VCID: 3A7B0F9DBD931C92C7-806E
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 4M0 820 043 K HW: 4M0 820 043 K
Component: Klima Zone 4 H52 0060
Coding: 6618083C5544401102220180800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 2D5134C17CDDBB2A52-8078
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000423405
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0003
Serial number: 9558C9A7000000000001
1048839 - Indicator Lamp for Front Dash Vents
B1852 12 [008] - Short to Plus
Reset counter: 81
Mileage: 33 km
Date: 2015.08.11
Time: 08:37:43
Outside air temperature: 19.50 °C
Pressing a button-Button for instrument panel vents: not activated
Pressing a button-Defrost: not activated
Pressing a button-Recirculating air: not activated
Pressing a button-Rear window defogger: not activated
Pressing a button-Left pressure knob: not activated
Pressing a button-Right pressure knob: not activated
Pressing a button-Left air distribution: not activated
Pressing a button-Right air distribution: not activated
Pressing a button-AUTO left: not activated
Pressing a button-AUTO right: not activated
Pressing a button-Air quantity left: not activated
Pressing a button-Air quantity right: not activated
Pressing a button-AC: not activated
Pressing a button-Left heated seat: not activated
Pressing a button-Left seat ventilation: not activated
Pressing a button-Right heated seat: not activated
Pressing a button-Right seat ventilation: not activated
Pressing a button-OFF: not activated
Pressing a button-AUTO: not activated
Pressing a button-Air quantity: not activated
Pressing a button-Footwell air distribution: not activated
Pressing a button-Upper body vent air distribution: not activated
Pressing a button-Air distribution up: not activated
Pressing a button-Left cabin heater: not activated
Pressing a button-Right cabin heater: not activated
Pressing a button-AC max/eco: not activated
Pressing a button-Input mode: not activated
Pressing a button-A/C mode: not activated
Indicator light for instrument panel vents: On
Part No SW: 8W0 907 063 G HW: 8W0 907 063 G
Component: BCM1 MLBevo H12 0215
Coding: 07501943E16900CD010D5719582F0CF913033101900000000000000060001A810A4501A222B60A
ASAM Dataset: EV_BCM1BOSCHAU736 014003
ROD: EV_BCM1BOSCHAU736_014.rod
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C
Component: WWS536 150324 042 0792
Serial number: 150415205000
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 20298020
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 N HW: 4M0 941 531 N
Component: E1 - LDS H05 0007
Serial number: 19 05 2015 00024108
Subsystem 4 - Part No SW: 4M0 857 511 A HW: 4M0 857 511 A
Component: Y7_Innenspieg H08 0002
Serial number: GX1CE127041511520015
Coding: 030000
Interior Light Module:
Subsystem 5 - Part No SW: 4M0 947 135 AB HW: 4M0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00012556
Electrically Adjustable Steering Column:
Subsystem 6 - Part No SW: 4M0 907 705 HW: 4M0 907 705
Component: J866-EVLS-SG H03 0040
Serial number: WA120676000013215689
Coding: 020100
Subsystem 7 - Part No SW: 4M0 925 301 B HW: 4M0 925 301 B
Component: SL-Q7NF/AU736 H09 0006
Serial number: 00000000000000004790
Address 15: Airbags (J234) Labels: None
Part No SW: 4M0 959 655 HW: 4M0 959 655
Component: Airbag10.44 H50 0081
Serial number: 003L1000532Z
Coding: AACCF0D80C80000058F650F3C00C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_AU73.rod
VCID: 78FFD595C31FCE82F1-802C
Subsystem 1 - Part No SW: ----------- HW: 442 062 305 15
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y009F193B854C24A
Subsystem 2 - Part No SW: ----------- HW: 442 062 305 15
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00A1193B850821U
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 405 15
Component: SideSensor_Dr 1C7 0148
Serial number: 35177000229352E6F8DG
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 405 15
Component: SideSensor_Pr 1C7 0148
Serial number: 35277000229352E81790
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 405 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B51B9D755026E
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 405 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B51B9D756B26R
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 405 15
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B51B9D75391FL
Subsystem 8 - Part No SW: ----------- HW: 442 420 805 15
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00BB17C323343BK
Subsystem 9 - Part No SW: ----------- HW: 442 420 805 15
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00B9193B85242AP
Central Sensor XY:
Subsystem 10 - Part No SW: ----------- HW: 410 201 505 15
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800AB165692591E7
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HD HW: 4M0 907 129 HD
Component: Lenks.Modul H11 0008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 79F9D091F815D78A8E-802C
Address 17: Instruments (J285) Labels: None
Part No SW: 4M0 920 790 HW: 4M0 920 790
Component: FBenRDW H12 0240
Coding: 042401C0289000080323E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001020
ROD: EV_DashBoardAU736.rod
VCID: 6CD7F9C58747722205-8038
16777103 - Databus
Reset counter: 63
Mileage: 133 km
Date: 2015.09.19
Time: 11:15:54
Part No SW: 4M1 907 468 A HW: 4M1 907 468 A
Component: Gateway H13 0074
Revision: 3B010050 Serial number: 5043B009C15508
Coding: 0301000100000F407F00000000590032C8120007000000000000000000000000
ASAM Dataset: EV_GatewCONTIAU736 002022
ROD: EV_GatewCONTIAU736_002.rod
VCID: 35611CA1948DF3EA2A-8060
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20150508084334 RD129
Subsystem 2 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9041
Serial number: 4367706503
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4M0 919 158 C HW: 4M0 919 158 C
Component: Klima Zone 2 H52 0060
Coding: 000000000000000100820080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
Component: MEM-FS 008 0014
Serial number: 00000149528515
Coding: 00181B000000B0410000210101010000110000313100000000000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Part No SW: 4M0 959 593 D HW: 4M0 959 593 C
Component: TSG FS 005 0036
Serial number: 0000151363043
Coding: 005D9B005E00040000013080
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 3D710481ACBD2BAAE2-8068
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4M0 909 144 E HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H17 0003
Revision: -------- Serial number: 0000819016
Coding: 90110001000100
ASAM Dataset: EV_EPSVWBSAU736 006014
ROD: EV_EPSVWBSAU736_006.rod
VCID: 316928B160E5DFCA76-8064
3155969 - Databus
Fault Frequency: 7
Reset counter: 82
Mileage: 97 km
Date: 2015.08.13
Time: 11:32:05
FreezeFrame_mw_120C_Timeout-Engine speed: 0 /min
FreezeFrame_mw_120C_Timeout-System status: Reset
FreezeFrame_mw_120C_Timeout-Supply voltage: Terminal 30: 12.39 V
FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: OFF
FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: OFF
FreezeFrame_mw_120C_Timeout-Lenkritzelwinkel: Offset korrigiert: -14.59 °
FreezeFrame_mw_120C_Timeout-ARA signal red cyclic: 00
FreezeFrame_mw_120C_Timeout-PLA signal red cyclic: 00
FreezeFrame_mw_120C_Timeout-SCU state: System OK
FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
Part No SW: 4M0 035 223 HW: 4M0 035 223
Component: MIB2_amp_PD H02 0390
Serial number: 00000000003674
Coding: 0135060A008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE.rod
VCID: 60CF9DF57B8F2642A9-8034
Part No SW: 4M0 959 592 D HW: 4M0 959 592 C
Component: TSG BFS 005 0036
Serial number: 0000150331276
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 3C770985B7A722A2D5-8068
196662 - Motor for Window Regulator
B1487 01 [008] - Electrical Failure
Reset counter: 77
Mileage: 5365 km
Date: 2016.02.16
Time: 16:01:28
Part No SW: 4M0 035 036 HW: 4M0 035 036
Component: MU-P-LN-EU 041 0221
Serial number: A288E0FB001906
Coding: 013706010000000013110002000A00102F001BE501700100DE
VCID: 62CB97FD75833452BF-8036
Subsystem 1 - Part No SW: V03 959 802 CA HW: -----------
Component: ECE 2015 --- 0118
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9FJ4006SM
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 D HW: 4M0 919 615 D
Component: ControlUnit_P H14 0160
Serial number: 21051500000000000162
Component: Gracenote2 --- 1010
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [008] - Intermittent Disruption
Reset counter: 98
Mileage: 11388 km
Date: 2016.12.08
Time: 18:21:52
Voltage terminal 30: 14.1 V
Temperature of MOST transceiver-Maximum value: -50 °C
Temperature of MOST transceiver-Minimum value: 7 °C
Temperature of MOST transceiver-Current: 46 °C
6696 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [008] - No Communication
Fault Frequency: 12
Reset counter: 98
Mileage: 15 km
Date: 2015.06.10
Time: 05:04:28
Voltage terminal 30: 13.6 V
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4M0 907 428 HW: 4M0 907 428
Component: Areaview 2 H11 0282
Serial number: C854606JG000338
Coding: 02370601AE0FA10000404044
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 003013
ROD: EV_CamSysRVAV2CE2MLBEv_AU49.rod
VCID: 6FEDEEC9B651893A20-803A
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 4M0 959 107 HW: 4M0 959 107
Component: HDSG-Modul H12 0143
Revision: -------- Serial number: 30018628800000
Coding: 0070
ASAM Dataset: EV_DeckLidCONTIAU736 001010
VCID: 70EFEDB5AB6F96C239-8024
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 D HW: 4M1 713 041 D
Component: GSM-LL H07 0066
Revision: 0L0D5012 Serial number: 20150519001158
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 2643CBED592B887293-8072
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 4M0 907 217 B HW: 4M0 907 217 B
Component: BVS H11 0023
Coding: 0407030600000401022023A0C50000B400F0C020C020
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002020
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
1123875 - Internal Fault
B200F F2 [008] - Unknown Error Elaboration
Reset counter: 81
Mileage: 6712 km
Date: 2016.03.30
Time: 09:11:33
Control Module temperature: 51 °C
Voltage terminal 15: 14.20 V
1123986 - Dynamic Calibration
C1106 F1 [008] - Unknown Error Elaboration
Fault Frequency: 8
Reset counter: 97
Mileage: 362 km
Date: 2015.09.25
Time: 12:26:11
Control Module temperature: 73 °C
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 HW: 4M0 907 355
Component: SCR-Stg-G3H10 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 6ED3F3CDB15B80322B-803A
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 4M0 959 595 D HW: 4M0 959 595 C
Component: TSG HFS 005 0036
Serial number: 0000150343190
Coding: 004D99000000040000003080
ROD: EV_DCU2RearDriveMAXHCONT.rod
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 005 0036
Serial number: 0000150350378
ROD: EV_DCU2RearPasseMAXHCONT.rod
End-------------------------(Elapsed Time: 05:35)--------------------------
