Results 1 to 2 of 2
Thread: MultiFunction Steering Wheel octavia 2
    Mar 2016
    Romania
    Hello, i have a steering wheel without commands and i want to put a steering wheel with controls ,commands, you have to change the control Steering wheel module. donor car is Octavia 2.0 TDI 6-speed of 2007. You think that i need anything else to change?
    Tuesday,22,November,2016,17:08:08:14813
    VCDS Version: 16.8.3.1 (x64)
    VIN: TMBCS41ZX62232467   License Plate: PH 27 BBU
    Mileage: 434570km-270029mi   Repair Order: 1
    Chassis Type: 1Z (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 7D
    VIN: TMBCS41ZX62232467   Mileage: 434570km-270029miles
    56-Radio -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 03G-906-016-BKC.lbl
       Part No SW: 03G 906 016 DJ    HW: 028 101 188 3
       Component: R4 1,9L EDC G000SG  6250
       Revision: 12345678    Serial number: SKZ7Z0F3464767
       Coding: 0050071
       Shop #: WSC 73430 790 00000
       VCID: 6ED3BAED79AED8325E-803A
    17057 - Cylinder 3 Glow Plug Circuit (Q12)
                P0673 - 000 - Electrical Fault - Intermittent
                        Torque: 134.0 Nm
                        Voltage: 12.08 V
                        Bin. Bits: 00001100
                        Temperature: 4.5°C
                        Bin. Bits: 00110000
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Revision: 00H13001
       Coding: 0021633
       VCID: 71E9A1916890C7CA43-8024
       Part No: 1Z0 820 047 D
       Component: Climatic PQ35   010 0301
       VCID: 346768855702B2E268-8060
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000003938751
       Coding: 00020E131004140000110D000000000000097B065C
       Shop #: WSC 73430 790 12345
       VCID: 2A5B76FD85C6F412C2-807E
       Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer SK351  012  0401
       Coding: 00065525
       Shop #: WSC 73430
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
       Component: 07 AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037TR0AJVEB
       Coding: 0012343
       Shop #: WSC 10200 599 94742
       VCID: 7DF18DA124C8B3AAD7-8028
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 034 0070
       Coding: 0000042
       VCID: 76E3928D01FEE0F296-8022
       Part No: 1Z0 920 841 E
       Component: KOMBIINSTRUMENT VD1 0920
       Coding: 0004101
       Shop #: WSC 12345 012 32131
       VCID: 387F5CB54B6A568244-806C
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001062030391
       Coding: 7D0F0B40071302
    00469 - Infotainment Databus in Single Wire Operation
                        Fault Frequency: 16
                        Reset counter: 206
                        Mileage: 434198 km
                        Time: 17:56:58
                        Fault Frequency: 170
                        Reset counter: 246
                        Mileage: 434198 km
                        Time: 18:21:53
    01304 - Radio
                        Fault Frequency: 166
                        Reset counter: 246
                        Mileage: 434198 km
                        Time: 18:21:55
       Component: IMMO            VD1 0920
       Part No: 1T0 959 701 B
       Component: Tuer-SG         024 2345
       Coding: 0000244
       VCID: 3663528D417EA0F256-8062
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 000    3305
       Revision: 00H22000
       VCID: 377D5F89467459FA4D-8062
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 18D002407F2D0F0FC84BC61004CC
       VCID: 79F999B130E08F8AFB-802C
       Subsystem 5 - Part No: 1Z0 951 171 A
       Component: NeigungsSensor  008 4802
       Coding: 00000000
       Subsystem 6 - Part No: 1K0 951 605 D
       Subsystem 7 - Part No: 1Z0 951 171 A
       Component: Innenraumueberw.008 4802
       Part No: 1T0 959 702 B
       Coding: 0000244
    00121 - Outside Warning Light/Door exit Light Passenger Side
       Part No: 1T0 907 357
       Coding: 0000007
       VCID: 74E7A8851782F2E2A8-8020
       Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
       Component: Radio FO3       013 0029
       Revision: 00013000    Serial number: SKZ7Z3F0121543
       Coding: 0000200
       Shop #: WSC 10112 599 82830
       VCID: 2D517DE1B428E32A27-8078
       Revision: 00800000    Serial number:
    End-------------------------(Elapsed Time: 01:35)--------------------------
  2. Likes Boki Ar liked this post
  3. #2
    Mar 2016
    Romania
    please help me!!
