Hi all
Got myself a 2010 Estate with the good old 1.9 TDI
Its proper budget spec....... I dont mind but doesnt even have the trip/mpg computer. I know the Maxi dot seems hard to add to a face lift (Impossible back in 2012) but what if I want the mpg instant and odometer reading? Can I get a different stalk (with buttons on end to cycle through) and code it with VCDS?
Here is a VCDS log if it helps?
Thanks
Sheldon
Sunday,04,December,2016,11:18:55:32772
VCDS Version: 16.8.4.2 (x64)
VIN: TMBJS21Z2A2045227 License Plate: OCTAVIA
Mileage: 103420km-64262mi Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBJS21Z2A2045227 Mileage: 103420km-64262miles
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 TB HW: 03G 906 021 AN
Component: R4 1,9l EDC G000SG 2047
Revision: --H11--- Serial number:
Coding: 0000071
Shop #: WSC 73430 790 00999
VCID: 72E0A13D6D2F25D2CF-8026
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Mileage: 103154 km
Date: 2011.03.13
Time: 07:59:29
RPM: 924 /min
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AQ HW: 1K0 907 379 AQ
Component: MABS MK70M 0105
Revision: 00H32001
Coding: 0016641
VCID: 0102FEF158890E4AC6-8054
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3T0 820 047 H HW: 3T0 820 047 H
Component: Climatic 130 0203
Revision: 00005001
Coding: 0000000000
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_SK35.rod
VCID: 346C67259FBB6BE21D-8060
Part No SW: 1K0 937 086 G HW: 1K0 937 086 G
Component: BCM PQ35 M+ 103 0541
Revision: 00103 AE
Coding: 48180AB8B0050CB04010008011000164010000AE424D81605C0440000000
Shop #: WSC 27023 576 88146
VCID: 346C672597BB6BE21D-8060
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 12090 22 0601
Coding: 00D7B7
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 20
Reset counter: 200
Mileage: 103158 km
Date: 2011.03.13
Time: 14:37:28
Term 15 On
Voltage: 14.15 V
Term 50 Off
Fault Frequency: 20
Reset counter: 200
Mileage: 103158 km
Date: 2011.03.13
Time: 14:37:28
Term 15 On
Voltage: 14.15 V
Term 50 Off
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2FSZSS
Coding: 0020788
VCID: 3D7A420164F1AAAAE2-8068
Subsystem 1 - Serial number: 6332MSME4B71216BE
Subsystem 2 - Serial number: 6342MSME4B112E7DP
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000032
VCID: 030EF4F942951C5AD4-8056
Part No SW: 1Z0 920 903 D HW: 1Z0 920 903 D
Component: KOMBI H21 0110
Coding: 410300
Shop #: WSC 73430 031 00999
VCID: 36685D2D89C779F223-8062
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 5223
Revision: H16 Serial number: 4120K0991605EB
Coding: E9801F06000202002303
VCID: 66C8CD6D51E7C97253-8032
Fault Frequency: 96
Reset counter: 233
Mileage: 103150 km
01304 - Radio
Reset counter: 233
Mileage: 103150 km
Component: IMMO H21 0110
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2114
Coding: 0000564
VCID: 489423D53B33FF0241-801C
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 68 2901
Revision: 00H17000
VCID: 2F666849BE9D483A60-807A
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000564
VCID: 479620E9362DF07A48-8012
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 G HW: 1Z0 035 161 G
Component: Radio-SWING 008 0021
Revision: -----10S Serial number: SKZ4Z2J1122742
Coding: 000002000001
VCID: 3260613D6DAF65D20F-8066
End-------------------------(Elapsed Time: 01:42)--------------------------
Thanks
Sheldon
