Results 1 to 5 of 5
Thread: Engine ECU soft code ?
    Verified VCDS-Lite User
    Oct 2016
    Hi All
    I'm trying to check that the engine ECU soft coding is correct but the little window with the coding options doesn't appear when I click on recode ?
    The ABS & Auto Trans codes had been blanked by the last owner so I thought it wise to check the engine one is correct.
    I've searched all over the web and can't find the info.
    The car is Audi A3 8L 2001 1.8T AUM in the UK, the code that is in the ECU now is 11530
    Thanks for your help.
    Yours Dave
    Without an Auto Scan any reply would probably be no more than a guess...
  3. Likes Uwe liked this post
    Oct 2016
    Thanks for replying.
    I don't understand why an auto scan would help as I don't have any error codes coming up ?
    I'm basically looking for the list like the one for the ABS ECU on Ross Tech site that Uwe helped me calculate the ABS code from but for the engine ECU. The american forums have the options list with codes for the A4 & A6's but I can't find them for the A3.
    Any help would be appriciated, thanks Dave.
    Tartu, Estonia
    Quote Originally Posted by drjohnson666 View Post
    Nobody is going to guess which P/N Ecu is installed in Your car.
    The world is my oyster...
  6. Likes Uwe, PetrolDave liked this post
    Oct 2016
    Sorry I'm not that clued up on this (I'm not a mechanic by trade), below is a copy of the last auto scan I did when I was trying to fix the ABS. The only changes since this one is the Auto Trans code is now 00012, the ABS code is 0019970 & the system test has completed.
    VCDS-Lite Version: Release 1.2
    Monday, 03 October 2016, 22:24:53:523
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine       Labels: 06A-906-032-AUM.LBL
       Controller: 06A 906 032 HL
       Component: 1.8L R4/5VT         0001
       Coding: 11530
       Shop #: WSC 00186
       VCID: 6F9152B43E85
       WAUZZZ8L02A002535     AUZ5Z0A6024009
    Address 02: Auto Trans       Labels: 01M-927-733.LBL
       Controller: 01M 927 733 JJ
       Component: AG4 Getriebe 01M    4827
       Coding: 00000
       VCID: 8175840C9811
    Address 03: ABS Brakes       Labels: None
       Controller: 1C0 907 379 E
       Component: ESP FRONT MK60      0104
       Coding: 0000000
       Shop #: WSC 80093
       VCID: 2C2B85B8CF13
    01486 -  System Function Test Activated
                000 -   -
    Address 08: Auto HVAC       Labels: Redir Fail!
       Controller: 8L0 820 043 K
       Component: A3  KLIMAAUTOMAT   0105
       Coding: 00041
       Shop #: WSC 06435
       VCID: 301391C8E33B
    Address 15: Airbags       Labels: 8L0-959-655-AI8.LBL
       Controller: 8L0 959 655 J
       Component: Airbag Front+Seite 5008
       Coding: 01104
       Shop #: WSC 06435
       VCID: 45FDD01C4CB9
    Address 17: Instruments       Labels: 8L0-920-xxx-17.LBL
       Controller: 8L0 920 980 P
       Component: KOMBI+WEGFAHRS. M73 D07
       Coding: 00444
       Shop #: WSC 00319
       VCID: 40F3C108539B
    Address 35: Centr. Locks       Labels: 8D0-862-257.LBL
       Controller: 8D0 862 257 E
       Component: CV-Pump, Alarm, RC  D17
       Coding: 15178
       Shop #: WSC 06435
       VCID: 2F1192B4FE05
    01371 -  Alarm triggered by Door Contact Switch; Driver's Side
                35-00 -   -
    01374 -  Alarm triggered by Terminal 15
                35-00 -   -
    01370 -  Alarm triggered by Interior Monitoring
                35-00 -   -
    01369 -  Alarm triggered by Hood Switch
                35-00 -   -
    00955 -  Key 1
                09-00 -  Adaptation Limit Surpassed
    01134 -  Alarm Horn (H12)
                49-10 -  No Communications - Intermittent
    Address 45: Inter. Monitor       Labels: 4B0-951-173.LBL
       Controller: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00001
       VCID: E0B3A188735B
    Address 56: Radio       Labels: 8D0-035-1xx-56.LBL
       Controller: 8L0 035 195 H
       Component: symphony II NP2    0005
       Coding: 00201
       Shop #: WSC 06435
       VCID: 33199EC4122D
    End   --------------------------------------------------------------------------------------------------
