hi guys can someone have a look at my scan and suggest a course of action, mil light is on and the car is drivable
there is an old fault in the cent electric but I believe that relates to a new battery being fitted & not coded
Saturday,03,December,2016,14:43:42:50070
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: WVWZZZ9NZ6D082525 License Plate:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6D082525 Mileage: 147460km-91627miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 KA
Component: MARELLI 4TV 7448
Coding: 00071
Shop #: WSC 31414
VCID: 5BB5ECCAC9E6169A95-4B00
WVWZZZ9NZ6D082525 VWZ7Z0F3399383
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
17793 - Control Module Malfunction - Lambda Sensing Circuit
P1385 - 35-10 - - Intermittent
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Coding: 0002088
Shop #: WSC 31414 790 00001
VCID: 0109FEA25BCA9C4AAF-5124
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: 6ADBB90E16BC7F121E-5140
01596 - Motor for Outside/Recirculated Air Flap (V154)
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BK BN-SG. 1S34
Coding: 25742
Shop #: WSC 31414
VCID: 3C774F562CA831A2BC-5140
01598 - Drive Battery Voltage
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 1G AIRBAG VW51 0T 0008
Coding: 12615
Shop #: WSC 31414
VCID: 2C577F16DCC8A1222C-5140
No Faults Found
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 922 G
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01446
VCID: 36635D7E1284EBF24A-5124
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 31414
VCID: 70EFAB66306085C250-5140
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 00140
Shop #: WSC 31414
VCID: 6FEDA81A2D5E9A3A49-5140
00816 - Power Steering Sensor (G250)
30-00 - Open or Short to Plus
Address 45: Inter. Monitor Labels: 6Q0-951-171.lbl
Part No: 6Q0 951 171 C
Component: Innenraumueberw. 0020
VCID: 326B616EFEECF7D266-515E
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 65 Komfortgerát 0002
Coding: 00018
Shop #: WSC 31414
VCID: 3D71425237B238AA8B-4B00
Part No SW: 6Q0 035 152 A HW: 6Q0 035 152 A
Component: Radio BVX 005 0004
Revision: 00005000 Serial number: VWZ1Z5F8992740
Coding: 0040400
VCID: 285F830698308D02C8-5124
End---------------------(Elapsed Time: 03:22, udsna)-----------------------
