VCDS Version: Beta 14.7.0
Data version: 20140601
Saturday,05,July,2014,18:14:13:47610
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: WAUZZZ8V2E1026860 Mileage: 3143km-1952miles
Address 01: Engine (J623-CJXB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09---
Coding: 0A1D00322426010B2004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS021_AU37.rod
VCID: 7DF71BD3EC4894D204-8028
Readiness: 0010 0001
Part No SW: 0D9 300 011 R HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4319
Revision: 05852204 Serial number: TFK01401111181
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_AU37.rod
VCID: 24410EB72F62051A2B-8071
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 60174000000322
Coding: 31F193A254222A72017F070641C3698CC92A5480E08296F6024100080608
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7BF315CBF25C9AE23A-802E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000226713
Coding: 03100014000000011000000000001100
VCID: 326DF8EF65969BAAA9-8067
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011402901845
Coding: 07141C42C24106FD03804004B10807A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_AU37.rod
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A
Component: WWS371 140114 041 0585
Serial number: 140118003731
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Serial number: 22136879
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Serial number: 04 07 2013 00001787
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY133363AY9
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000058262158
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO26498227
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831400701128
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3879CAC783EA71FA97-806D
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR00SFF3
Coding: 98CCC000000000005C5400CA00C800000065
VCID: 000962279BBAF93A6F-8055
Subsystem 1 - Part No SW: ----------- HW: 480 000 901 14
Serial number: 357670000002ECBC8E0F
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 901 14
Serial number: 358670000000ECBC8E0E
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 901 14
Serial number: 3516502A513013E3D21Z
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 901 14
Serial number: 3526502A913013E211E$
Subsystem 5 - Part No SW: ----------- HW: 480 402 301 14
Serial number: 3556502B712FAE22D0DU
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 20011408491202
Coding: A018
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 7CF116D7F7529DDA33-8029
Part No SW: 8V0 920 870 N HW: 8V0 920 870 N
Component: KOMBI H03 2220
Coding: 27BD180A2A8000080101EA00180000
Shop #: WSC 00070 123 12345
VCID: 4685B43FF91E170A15-8013
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 24011410801297
Coding: 030100042B085A005B0002681C0B00000001000000000000000000000000
Shop #: WSC 29458 001 1048576
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_AU37.rod
VCID: 3F8BA1DBA6C446C256-806A
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Serial number: 03 12 2013 C0392117
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 9392272303
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 20121304081157
Coding: 001C8E204101040000001002
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 4089A227DB3A393A2F-8015
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB.rod
VCID: 3567C3F394F88C928C-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 20121302091098
Coding: 001C86204101040000001002
ROD: EV_DCUPasseSideEWMAXKLO.rod
Part No SW: 7P6 907 357 B HW: 7P6 907 357 B
Component: AFS-ECU H01 0040
Coding: 01AE00002B200200
ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
ROD: EV_HeadlRegulLEDAFSMQB.rod
VCID: 3E75DCDFA1CE4FCA5D-806B
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo li. H07 7530
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo re. H07 7530
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7000
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7000
Coding: E00100
Part No SW: 8V0 035 044 B HW: 8V0 035 044
Component: MU-H-TN-EU H40 0281
Serial number: A041K0C7509214
Coding: 01730109F308000021110001000A00002F00020601000100DE
Shop #: WSC 00070 000 00000
ASAM Dataset: EV_MUHig6C3HBAS 001041
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 3069F2E76B9AA9BADF-8065
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 KN HW: -----------
Component: ECE 2013 --- 0041
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY200UNA
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 G HW: 8V0 919 614 G
Component: ControlUnit_H H74 0764
Serial number: C1000028111300020311
15 Faults Found:
1586 - invalid data record
B2005 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:09
1587 - invalid data record
B2005 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:09
1588 - invalid data record
B2005 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:09
1589 - invalid data record
B2005 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:09
1595 - invalid data record
B2005 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:09
1591 - invalid data record
B2005 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:10
1598 - Data Set Implausible
B2012 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:09
1600 - Data Set Implausible
B2012 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:10
1543 - Control Module Incorrectly Coded
U1014 00 [008] - -
Reset counter: 138
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:10
B201A 00 [009] - -
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:10
2563 - Navigation System
B126C F1 [009] - Navigation Database Missing
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:44:01
2571 - Navigation System
B126C F2 [009] - Navigation Database Not Enabled
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:09
0513 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:13
0523 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:13
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Reset counter: 98
Mileage: 3143 km
Date: 2014.07.03
Time: 20:07:13
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0008
Serial number: 131212200095
End-------------------------(Elapsed Time: 04:03)--------------------------
