Results 1 to 9 of 9
Thread: Golf 6 GTI Rear LED Long Coding help and hello
    Dec 2016
    South Africa
    Hi All
    My 1st post and a hello to all of you, My names angus im from cape town south africa. I do electronics on cars and auto electrical work. shout if you need help
    Im battling with a golf 6 gti i am trying to retro fit. I believe it is a 2011 model golf 6 gti. The customer wants to fit a full set of led lights in the rear. I have tried to do long coding from the internet but its still not working right. Ive erased page 18 and used 40 , 04 but no luck. Is there anyone that can point me in the right direction.
    I am fitting original lights and i have no plugs so i am joining wires
    Thanks in advance
    Jun 2014
  3. Likes carlab liked this post
    Oct 2014
    Arandjelovac, Serbia
    Hi Carlab, Welcome aboard
    You can post an Auto Scan and see this thread.
  5. Likes Uwe, carlab liked this post
  6. #4
    Dec 2016
    South Africa
    hi
    attached or see below the auto scan
    thanks for the reply
    i have fitted the lights. The park and brake lights work so does the indicators. i havent changed any coding. the inner lights do not work. The right inner light comes on with rear fog activated via the switch. The reverse does not work. My understanding is that the inner lights (on tailgate) are supposed to work like the outer and without the wiring mod the inner rear fog will not work.
    Right now customer is driving with lamp failure warning on. And the odd light that does not work. This is due to time constraints
    Please help i need to sort it as a personal challenge and as a vote of confidence to customer.
    See attached
    Friday,18,November,2016,20:02:21:20626
    VCDS Version: 16.8.2.3
    Data version: 20160926 DS261.0
    Chassis Type: 1K (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
              77
    VIN: WVWZZZ1KZCW077619   Mileage: 80080km-49759miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
       Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0050
       Revision: AAH18---    Serial number:
       Coding: 0403000C1C070160
       Shop #: WSC 66565 257 00032
       VCID: 67DB5AA4563D467A15-8032
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 46.0C
                        Temperature: 38.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 7.366 V
       Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2727
       Revision: 05351113    Serial number: 00001107081968
       VCID: 193F2C5CD0C9208A53-804C
       Revision: 00H31001
       Coding: 163B600D09298001681106E590220181310800
       VCID: 7BF316D4FAB5F29AE1-802E
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Revision: 00001003
       Coding: 0000001002
       VCID: 000961389B539142B4-8054
       Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 48180A3A8825F1C0400800C0340009E449554088736D8D20E48400240040
       VCID: 3A7DD3D0B50F0B92BA-806E
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 22071  26  0512
       Coding: 009795
       Component: RLS 280711 05  54  0403
       Coding: 0230AD
       Component: LIN BACKUP HO  H11 9005
    6 Faults Found:
    00984 - Left Tail Light (M4)
                        Fault Status: 00101010
                        Reset counter: 21
                        Mileage: 80086 km
                        Date: 2016.11.18
                        Time: 17:59:23
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 21
                        Mileage: 80086 km
                        Date: 2016.11.18
                        Time: 17:59:35
                        Voltage: 14.45 V
                            Term 50 Off
    00985 - Right Tail Light (M2)
                        Reset counter: 21
                        Mileage: 80086 km
                        Date: 2016.11.18
                        Time: 18:57:18
                        Voltage: 12.00 V
                            Term 50 Off
                        Fault Status: 01101010
                        Reset counter: 236
                        Mileage: 80086 km
                        Date: 2016.11.18
                        Time: 19:17:29
                        Voltage: 11.90 V
                            Term 50 Off
                        Reset counter: 236
                        Mileage: 80086 km
                        Date: 2016.11.18
                        Time: 19:17:31
                        Voltage: 11.90 V
                            Term 50 Off
                        Reset counter: 21
                        Mileage: 80086 km
                        Date: 2016.11.18
                        Time: 19:17:56
                        Voltage: 11.85 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0012
       Revision: --------    Serial number: 12561120002709
       Coding: 108103
       VCID: 3879C9D88B0319824C-806C
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5RA8BL8N
       Coding: 00003958
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 316FF4FC6079C8CA0B-8064
       Serial number: 3572MSME4E770542ZZZ-
       Serial number: 3582MSME03271142ZZZE
       Serial number: 3512QSME52160A65ZZZQ
       Serial number: 3522QSME5C131D5DZZZ2
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90440KGT00071
       Coding: 1892140000
       ROD: EV_SMLSNGKUDS_VW36.rod
       VCID: 76E507E0C997AFF29E-8022
       Component: E221__MFL-TAS  H08 0010
       Serial number: 0070415
       Coding: 830000
       Part No SW: 5K6 920 872     HW: 5K6 920 872
       Coding: 170F00
       VCID: 72ED3BF0A5FFB3D2B2-8026
       Revision:   H42       Serial number: 210711F2002197
       Coding: 350003
       VCID: 3567C0EC9C11E4EA57-8060
                        Reset counter: 159
                        Mileage: 44692 km
                        Date: 2014.02.24
                        Time: 10:57:20
    03272 - Control Module for Audio Interface
                        Reset counter: 159
                        Mileage: 44692 km
                        Date: 2014.02.24
                        Time: 10:57:20
       Component: IMMO          H03 0607
       VCID: 6ADD23908D2F7B120A-803E
    Address 2E: Media Player 3
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2106
       Coding: 0000692
       VCID: 377BCAE4461D16FA45-8062
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 74     3201
       Revision: 00H20000
       VCID: 3461FDE8576BFDE260-8060
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 7.9 V
                            PD
                        Temperature: 30.0C
                        Count: 2
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
       Component: Tuer-SG         009 2120
       Coding: 0000948
       VCID: 3363FEF45265FADA79-8066
       Coding: 1443164
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Coding: 00000022
    02988 - Left-Hand/Right-Hand Traffic Switchover Active
                        Reset counter: 50
                        Mileage: 12420 km
                        Date: 2012.02.07
                        Time: 17:46:17
                        Voltage: 12.21 V
                            ABS 1
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: RCD310 EU     H03 5004
       Revision: -----04S    Serial number: VWZ4Z2L1321023
       Coding: 05000400040005
       VCID: 72ED3BF0ADFFB3D2B2-8026
    7 Faults Found:
                        Reset counter: 236
                        Mileage: 44692 km
                        Date: 2014.02.24
                        Time: 12:04:57
                        Reset counter: 236
                        Mileage: 44692 km
                        Date: 2014.02.24
                        Time: 12:04:57
                        Reset counter: 254
                        Mileage: 20105 km
                        Date: 2012.05.28
                        Time: 13:29:46
                        Reset counter: 254
                        Mileage: 20105 km
                        Date: 2012.05.28
                        Time: 13:29:46
                        Reset counter: 254
                        Mileage: 20105 km
                        Date: 2012.05.28
                        Time: 13:29:46
                        Reset counter: 254
                        Mileage: 20105 km
                        Date: 2012.05.28
                        Time: 13:29:46
    03138 - Input AUX IN
                        Reset counter: 254
                        Mileage: 20105 km
                        Date: 2012.05.28
                        Time: 13:29:44
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 3567C0EC5C11E4EA57-8060
       Coding: 0000144
       VCID: 3665C7E04117EFF25E-8062
    Address 77: Telephone
    End-------------------------(Elapsed Time: 02:51)--------------------------
    Dec 2016
    South Africa
    bump
    anyone help
    Have you tried 21 in Byte 18?
  9. Likes carlab, GaryM liked this post
  10. #7
    Dec 2016
    South Africa
    Hi
    i will get car back and attempt thanks
  11. #8
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    See the video linked to in this post.
    As Uwe said, 21 seems to be the magic number
  12. #9
    Dec 2016
    South Africa
    Hi
