Results 11 to 20 of 25
Thread: help: VW Tiguan full Xenon,LED AFS retrofit
    Verified VCDS User Mrclopec's Avatar
    May 2015
    Nipomo, CA
    Is it giving you 31 out of range or another error?
    I retrofit not because I settled for a car that didn't have everything. I retrofit for the challenge!
  2. #12
    May 2015
    Nipomo, CA
    Also, will the module let you change the rest of the coding string without changing the model designation?
  3. #13
    Nov 2016
    SRB
    Quote Originally Posted by Mrclopec View Post
    yes, 31 error
  4. #14
    May 2015
    Nipomo, CA
    Ah. One more suggestion. Make sure when you change the coding string, that you have put in a different workshop code and importer value. Sometimes modules won't let the coding change unless you change these values
  5. #15
    Nov 2016
    SRB
    It want aloud to change workshop or importer code on long coding
  6. #16
    Nov 2016
    SRB
    Angry
    I have try all options, change workshope code, importer...etc
    try to change only one code, always same result, 31 request out of range
  7. #17
    May 2015
    Nipomo, CA
    You may have to change them under the options section of VCDS first. But don't forget to reset VCDS before you try to code other modules or that workshop code and importer value will show up in everything you code from that point forward.
  8. Likes Uwe liked this post
  9. #18
    Nov 2016
    SRB
    I change it in options but same thing, want recode!
    How to reset VCDS again?
  10. #19
    Jan 2015
    Bosnia and Herzegovina
    ; 1K0-937-084.CLB (Basis - Supports NO Fogs or Xenons)
    ; 1K0-937-085.CLB (Lowend - Supports NO Fogs or Xenons)
    ; 1K0-937-086.CLB (Medium - Supports Fogs but NO Xenons)
    ; 1K0-937-087.CLB (Highend - Supports Fogs and/or Xenons)
    i believe the same is apllied to 5K0
    5K0 937 086 M this module doesn't support adaptive lights
    5M0 907 357 F is for adaptive lights - same one is used for all vw cars, check coding for just rear sensor
    did you try to re flash afs module (it will remove coding and also all settings) then fill parameters from zdc?
  11. #20
    Nov 2016
    SRB
    Quote Originally Posted by m87a View Post
    Hi m87a,
    can you help me to re flash afs?
    So the BCM need to be changed as well?
    What about byte 18, those it worth try to change it?
