Results 1 to 8 of 8
Thread: A3 BKD non start no fault codes no injector pulse
    Sep 2015
    Hi all
    I have a A3 giving me the run around. Its a non start no codes reported. and no injector signal. I have cam shaft signal and crank signal at ECU. I could do with a Known good scope pattern to compare synchronisation with. Both are hall sensors, giving a clear signal. basic checks done are good pressure from intank pump. new tandem pump fitted (not sure what pressure should be from test point when cranking) elsawin has plus 10 bar at 4000 rpm. good cranking speed 265rpm. I do lose live data when cranking and i've supplyed the starter with own battery and still same, not sure if this an issue or not. I have VVDI2 which will turn of the Imobiliser in the ECU and Ive swapped out the ECU to a different car which runs nicely with it fitted so my problem is on the car and not ECU.
    Group 51 has the data below. I cant find out what good values for start synchronisation and injector shut off status should be just says 'see label file' and what these mean or if these could help me.
    Address 01: Engine (03G 906 016 G)
    11:28:47 Group 051: Engine Speed Recognition
    0 /min Engine Speed
    0 /min Camshaft Speed
    2.0 Start Synchronisation
    00010010 Shut-Off Status Injection Sequence
    Monday,28,November,2016,11:00:10:27945
    VCDS Version: 16.8.3.1
    VIN: WAUZZZ8P84A180019   License Plate: HT04RBF
    Mileage: 256940km-159655mi   Repair Order: audi a3 non start
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
    VIN: WAUZZZ8P84A180019   Mileage: 256940km-159655miles
    Address 01: Engine        Labels: 03G-906-016-BKD.lbl
       Part No SW: 03G 906 016 G    HW: 028 101 136 4
       Component: R4 2,0L EDC G000SG  5705
       Revision: 12345678    Serial number: XXXXXXXXXXXXXX
       Coding: 0000072
       Shop #: WSC 06435 000 00000
       VCID: 2759A30E96803D7ADD-8072
    Readiness: 0 0 1 1 1
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0023174
       VCID: 3A7F6A7A7532B092B2-806E
       Part No SW: 8P0 820 043 D    HW: 8P0 820 043 D
       Component: KlimavollautomatH12 0150
       Revision: 054975      Serial number: 8P0820043D
       VCID: 2D555126B47C172A27-8078
    6 Faults Found:
    00483 - Control Module for Auxiliary Air Heater
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 79
                        Mileage: 256948 km
                        Date: 2016.11.20
                        Time: 01:12:15
    01273 - Fresh Air Blower (V2)
                        Reset counter: 119
                        Mileage: 256948 km
                        Date: 2016.11.20
                        Time: 00:01:43
                        Temperature: 8.0°C
                        Speed: 325.0 km/h
                        (no units): 38.0
                        (no units): 166.0
                        Fault Status: 00100011
                        Reset counter: 119
                        Mileage: 256937 km
                        Date: 2016.11.14
                        Time: 04:54:14
                        Voltage: 14.10 V
                        Temperature: 7.5°C
                        (no units): 166.0
                        (no units): 33.0
                        Temperature: 6.5°C
    00796 - Fan for Interior Temp Sensor (V42)
                        Fault Status: 00101011
                        Reset counter: 115
                        Mileage: 256843 km
                        Date: 2016.11.05
                        Time: 21:10:20
                        Voltage: 13.80 V
                        Temperature: 29.0°C
    00532 - Supply Voltage B+
                        Fault Frequency: 7
                        Reset counter: 119
                        Mileage: 256948 km
                        Date: 2016.11.20
                        Time: 00:00:25
                        Voltage: 9.00 V
                        Reset counter: 79
                        Mileage: 256948 km
                        Date: 2016.11.20
                        Time: 01:12:15
    Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 D    HW: 8P0 907 279 D*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000766819
       Coding: A5885F00A2141000000000000000000000
       VCID: 3E77666A691A9CB28E-806A
       Subsystem 1 - Part No: 8P2 955 119 C  Labels: 1TX-955-119.CLB
       Component: Wischer WWS Audi350 0180
       Coding: 16711696
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
       Component: Airbag 8.4ED    H00 0140
       Coding: 0011602
       VCID: 4381179E02F8F15AE1-8016
       Part No SW: 8P0 953 549     HW: 8P0 953 549
       Component: Lenksäulenmodul H11 0020
       Coding: 0002042
       VCID: 7BF1AF7E3A88499AE9-802E
       Component: Lenkradmodul    H03 0040
       Part No SW: 8P0 920 980 H    HW: 8P0 920 980 H
       Component: KOMBIINSTR. VDO H25 0150
       Revision: D10         Serial number: 2243DD10006863
       Coding: 0004403
       Shop #: WSC 00088 067 57207
       VCID: 3C736C627F068EA2A0-8068
                        Fault Status: 00000011
                        Reset counter: 79
                        Mileage: 256948 km
                        Date: 2016.11.20
                        Time: 00:03:19
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 D    HW: 1K0 907 951
       Component: Gateway         H08 0100
       Revision: 08          Serial number: 25001044210494
       Coding: 3D0F0F42070101
       VCID: 285BA0329B9E3202D4-807C
       Revision: D10         Serial number: AUX7Z0D3FNT08D
       Shop #: WSC 00137 211 56823
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
       Part No: 8P0 959 801 A
       Component: Tuersteuerger.  H10 0010
       Coding: 0000120
       VCID: 397D75767034BB8ABB-806C
       Part No: 1K2 909 144 F
       Component: EPS_ZFLS Kl.10      1301
       VCID: 2F694B2EBE70653A15-807A
       Part No: 8P0 959 433
       Component:    KSG          H02 0040
       Coding: 008800186D288505485AC63000
       VCID: 79FDB57630B47B8AFB-802C
       Subsystem 1 - Part No: 1K0 951 605 A
       Component: LIN BACKUP HORN H01 1201
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Component: Innenraumueberw.H03 0010
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH25 0160
       Revision: 00003       Serial number: 10000001122514
       VCID: 70EB885263CE3AC24C-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
       Part No: 8P0 959 802 A
       Coding: 0000120
    Address 56: Radio
    Address 76: Park Assist        Labels: 8P0-919-283.lbl
       Part No SW: 8P0 919 283     HW: 8P0 919 283
       Component: Parkhilfe 4-Kan H06 0030
       Coding: 0000003
       VCID: 78FBB0720BBE628284-802C
       Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
       Revision: 00700000    Serial number:
       VCID: 2C535C228F661E2230-8078
                014 - Defective
    End-------------------------(Elapsed Time: 01:56)--------------------------
    Are you losing a terminal relay or faulty ignition switch during the crank phase possibly?
    Verify consumers are hot for supply and ecu supply is present, & with good grounds......... Then crank the starter segregated to test with isolated jumper.
    Sep 2015
    I have tried a segregated starter and the result is the same. i'll double check supplies and earths I have checked these and they were good but you have made me question my self so will check again.
    Yeah brute force all the terminals to test & qualify.
    Sep 2015
    All supplys and earths are OK all able to drive a 60w head light bulb no issues. got a feeling its can crank cam sensor.
    I would love to know what the start sync is all about in group 51
    Sep 2016
    Riga, Latvia
    Remove cylinder head cover. Disconnect 1 injector, leave 3 connected and try to start engine. repeat this with another injector while You get engine starting/running on 3 injectors. The disconnected one will be the bad one.
  8. Likes Jack@European_Parts, Boki Ar, Uwe liked this post
    Sep 2015
    Quote Originally Posted by MartinsX View Post
    It's not piezo injectors this is Bosch system 0.9 ohms per injector and no short to case. Normally has fault code for injector supply when shorted piezo crystal.
  10. #8
    Not always it is a good idea to test and isolate as Martin said & it isn't hard to do.
