- Joined
- Jul 3, 2014
- Messages
- 1
- Reaction score
- 0
- VCDS Serial number
- C?ID=220312
Hi ,
When I put the key in the ignition, no lights come on. In order to run a diagnostic test we jumped the ignition.
The following fault codes were retrieved:
Thursday,03,July,2014,16:09:44:11466
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZ3CZ6P159782 License Plate: 278962
Mileage: 123510km-76745mi Repair Order: retho giovanni
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 36 42 44 46 52 53 55 56 62
72 76
VIN: WVWZZZ3CZ6P159782 Mileage: 123510km/76745miles
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 997 033 K HW: Hardware No
Component: P3.2 FSI-EU4 G00 2368
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 00028 028 00001
VCID: 356766FC5C6DBCB6781-8060
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 008 - - Intermittent
Mileage: 123515 km
Date: 2014.03.22
Time: 17:08:03
Temperature: 30.0°C
Temperature: 41.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.954 V
049412 - No Communication with Cruise Control Module
U0104 - 008 - - Intermittent
Temperature: 31.0°C
Temperature: 37.0°C
Voltage: 14.097 V
001299 - Incorrect Immobilizer Key
P0513 - 008 -
Mileage: 123515 km
Date: 2014.03.22
Time: 22:46:56
RPM: 2400 /min
Load: 16.5 %
Temperature: 33.0°C
Temperature: 38.0°C
Voltage: 12.827 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 047 J HW: 02E 927 770 AE
Component: GSG DSG 070 1112
Revision: 00007000 Serial number: 00000512081250
VCID: 1F4BA454CE9116E682D-804A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658626214
Coding: 0046535
Shop #: WSC 84347 981 90792
VCID: 306957E8A30F999E2B7-8065
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: 62CDEDA0BD637B0EED3-8037
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000003734909
Coding: 47868F0700041A00000A00000F000000000A5D435C0000
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 84347
Subsystem 3 - Component: Fehler Lin-Slave 01
02071 - Local Databus
Reset counter: 250
Mileage: 123515 km
Date: 2014.03.22
Time: 22:55:00
Voltage: 12.60 V
02403 - Terminal 15 for Interior
Reset counter: 250
Mileage: 123515 km
Date: 2014.03.22
Time: 22:55:00
Voltage: 12.60 V
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 250
Mileage: 123515 km
Date: 2014.03.22
Time: 22:55:00
Voltage: 12.60 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0T AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P0GT1QR
Coding: 0012372
VCID: 2E554990B93B8F6E39B-807B
Subsystem 1 - Serial number: 6332MSME0E23580EH
Subsystem 2 - Serial number: 6342MSME0E7C1654L
Subsystem 3 - Serial number: 6351HTS61IK67JK2G
Subsystem 4 - Serial number: 6361HTS64IK26L724
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0101013
Shop #: WSC 12345 123 999999
VCID: 72ED9DE06D83EB8E9D3-8027
Part No SW: 3C0 920 870 P HW: 3C0 920 870 P
Revision: X0033000 Serial number: 00000000000000
Coding: 0007405
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C061100844
Coding: FFFD1D04C21003
VCID: 214FA2ACF8E52016B49-8074
Reset counter: 250
Mileage: 123515 km
Date: 2014.03.22
Time: 22:55:57
01304 - Radio
Reset counter: 250
Mileage: 123515 km
Date: 2014.03.22
Time: 22:56:01
Address 22: AWD Labels: None
VCID: 55A7C67CBC2D9CB6981-8000
No Faults Found
Part No SW: 3C0 959 433 N HW: 3C0 959 433 N
Component: IMMO 041 0383
Revision: 00041000 Serial number: VWZCZ000000000
Component: ELV 027 0380
3C0905861G ELV 027 0380
02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
006 - Short to Plus
Fault Status: 01100110
Reset counter: 250
Mileage: 123515 km
Date: 2014.03.22
Time: 22:56:00
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C5143988F27FD7E17F-8079
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2802
Coding: 0001015
VCID: 377B6CF446614EA66AD-8062
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 34615BF85717A5BE4FF-8061
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 041 0472
Coding: 00910A0801860E76380494157008DFCF703900
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0001014
VCID: 38796FC84B7F41DE637-806D
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Fault Frequency: 31
Reset counter: 250
Date: 2064.00.00
Time: 00:00:00
Voltage: 11.70 V
Count: 116
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Fault Frequency: 31
Reset counter: 250
Date: 2064.00.00
Time: 00:00:00
Voltage: 11.70 V
Count: 117
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11111100
Fault Frequency: 21
Reset counter: 250
Date: 2064.00.00
Time: 00:00:00
Voltage: 11.80 V
Count: 40
Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000006
VCID: F1EF12ECE8855096E49-80A4
Subsystem 1 - Part No: 7L6 941 329
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000035
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2432
Coding: 0000144
VCID: 336358E45219A286565-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930535504492
Coding: 0001114
VCID: 2859BF889BDFD15EF37-807D
End ---------------------------------------------------------------------
